Question: Maple 2025 on windows 10 keeps reshuffling much worst than Maple 2024.2
I had this problem in Maple 2024.2 but not as bad as Maple 2025. In Maple 2024.2 the UI will shuffle every few hrs. Then I have to close Maple and restart it.
With Maple 2025, it now shuffle when I try to do anything. Basically I am not able to use Maple 2025 at all.
I made sure my NVidia drivers are up to date.
I have two monitors. Both running at 2560x1080 (native). 60 HZ. Both are LG Electronics 32" wide.
Only Maple have this issue on my PC.
Here is a movie. Once I open any new menu or click on anything, the desktop goes bizzerick and Maple screen starts glitching randomly and move around with the mouse. I can;t even see the close button any more. In this case, I simply did this:
Open new Maple 2025.
Then just did FILE->Open->Browse and now it started to shuffle.
New installation of Maple 2025 today.
I never seen anything like this in all the  years I have been using windows apps except with Maple.
Here is another movie, where I start Maple 2025, and simply do insert executable section, then it starts to shuff. I have not typed anything.
I will try to also reboot my PC to see if it helps, but I've done this before, but not after updating the drivers (even though it is not needed). (waiting for a script to finish, which can take few more hrs).
I will also try to remove one monitor to see if has anything to do with it.
The above Makes Maple 2025 completely not useable.
I called Maple customer support also and left my phone number to see if they can suggest something.
New PC (2 years), latest windows 10, 128 GB RAM.
The new user interface seems to made this shuffling problem worst than with Maple 2024.2
Any idea what else to try?
Update
Rebooted PC. No effect.
Resinstaled NVidia drivers, and did clear installation, resetting to factory settings. No effect.
Removed one monitor. No effect.
Have no idea why Maple UI does this.
Windows 10 pro, 22H2
Update 2
I've downloaded Maple 2025 trial for 15 days to try on Linux.
Installed OK and UI works great with no shuffling. All on same PC. Linux running inside Virtual box.
So the shuffling only happens on windows.
I think I will go tommorrow buy a new PC and install Linux on it and just use Maple on Linux from now on. I've uninstalled Maple 2025 from windows since it is completely not useable for me.
