Question: strange warning message from mint which do not show in maplemint
everytime I run mint I get hundreds of messages coming from child modules, saying
           These names were used as global names but were not declared:  A
Where A above is the name of the top level module.
This only shows from commnd line mint, and not from maplemint used in the GUI.
The set I have is
A:=module()
    export module foo_type()
       option object;
    end module;
     export B := module()  #child module
     end module;
end module;
  In the child module B above, whever I do
                 o:=Object(A:-foo_type);
mint gives the above warning.
It is clear the name A should not be declared, as the module B is child to it so it can see it.
The workaround is to add  global A inside each child module to remove this warning.
But why is this needed?
Here is a worksheet showing maplemint does not show this warning, and below example using command line mint on same exact code, which does
A:=module()
       option object;
       export name::string:="";
    end module;
       export step := proc()::A:-foo_type;
       local o::A:-foo_type;
          o:-name:="x";
          return o;
       end proc;
    end module;
end module;
_m128759219362528
maplemint(A)
Nested Module foo_type() on lines 1 to 2
  These exported variables were never used:  name::string
Download mint_isse_april_25_2025.mw
Here is A.mpl
A:=module()
       option object;
    end module;
       #global A;     why is this needed for mint??
          o:-name:="x";
          return o;
       end proc;
    end module;
end module;
And now the command
>/home/me/maple2025/bin.X86_64_LINUX/mint A.mpl
    |\^/|      Maple 2025 Diagnostic Program
._|\|   |/|_.  Copyright (c) Maplesoft, a division of Waterloo Maple Inc. 2025
 \  MINT   /   All rights reserved. Maple is a trademark of
 <____ ____>   Waterloo Maple Inc.
Nested Procedure step() on lines 10 to 15
Module A() on lines 1 to 18
  These exported variables were never used:  foo_type
You see the difference. mint complains that A is not declared.
Is this a bug in mint?
