Question: About the robustness of Student:-NumericalAnalysis:-MatrixDecomposition
As the following worksheet shows, Student:-NumericalAnalysis:-MatrixDecomposition cannot factorize the input matrix m and throws an error, but if we simply reorder or exchange the elements of m, no error will be raised. (The reason for setting 'method' = 'LDLt' is that LinearAlgebra:-LUDecomposition can be used for other methods.)
with(Student:-NumericalAnalysis, MatrixDecomposition)
m := Matrix([[3*(sqrt(3)+1)/8,-1/2,1/2,-(sqrt(3)+1)/8,-1/2,1/2,-(sqrt(3)+1)/8,-1/2,1/2,-(sqrt(3)+1)/8],
             [-1/2,sqrt(3)-1,-(sqrt(3)-1),-1/2,0,0,1/2,0,0,1/2],
             [1/2,-(sqrt(3)-1),sqrt(3)-1,1/2,0,0,-1/2,0,0,-1/2],
             [-(sqrt(3)+1)/8,-1/2,1/2,3*(sqrt(3)+1)/8,1/2,-1/2,-(sqrt(3)+1)/8,1/2,-1/2,-(sqrt(3)+1)/8],
             [-1/2,0,0,1/2,sqrt(3)-1,-(sqrt(3)-1),-1/2,0,0,1/2],
             [1/2,0,0,-1/2,-(sqrt(3)-1),sqrt(3)-1,1/2,0,0,-1/2],
             [-(sqrt(3)+1)/8,1/2,-1/2,-(sqrt(3)+1)/8,-1/2,1/2,3*(sqrt(3)+1)/8,1/2,-1/2,-(sqrt(3)+1)/8],
             [-1/2,0,0,1/2,0,0,1/2,sqrt(3)-1,-(sqrt(3)-1),-1/2],
             [1/2,0,0,-1/2,0,0,-1/2,-(sqrt(3)-1),sqrt(3)-1,1/2],
             [-(sqrt(3)+1)/8,1/2,-1/2,-(sqrt(3)+1)/8,1/2,-1/2,-(sqrt(3)+1)/8,-1/2,1/2,3*(sqrt(3)+1)/8]],
            'shape'='symmetric'):
MatrixDecomposition(m, 'method' = 'LDLt'): # this does not work
Error, (in Student:-NumericalAnalysis:-MatrixDecomposition) a pivot element 0 is encountered, and the entries below it are not all 0; the factorization cannot continue
MatrixDecomposition(m([1, 4, 7, 10, 2, 5, 8, 3, 6, 9] $ 2), 'method' = 'LDLt'): # yet this works
MatrixDecomposition(m([2, 3, 5, 6, 8, 9, 1, 4, 7, 10] $ 2), 'method' = 'LDLt'): # this also works
randomize(5):
k := 0:
to 1e3 do
        try
                MatrixDecomposition(m(combinat:-randperm(10) $ 2), 'method' = 'LDLt')
        catch :
                k++
        end
od:
k/1e3;
.469
Download LDL_factorization_robustness.mw
The last instance above suggests that it only works on about half of the inputs (that are equivalent to each other). Although I tried changing the value of Digits, the failure rate remained high. Is Student:-NumericalAnalysis:-MatrixDecomposition not robust enough?
