Question: internal error when using ODESteps
Fyi, this looks like a bug in odesteps. I was not expecting it to give steps for this, but I do not think it should give internal error. Will report it also.  It should just say not supported or something like this.
SupportTools:-Version();
ode:=x^2*diff(y(x),x$2)+(x^2-5*x)*diff(y(x),x)+(5-6*x)*y(x)=0; #22942.
x^2*(diff(diff(y(x), x), x))+(x^2-5*x)*(diff(y(x), x))+(5-6*x)*y(x) = 0
sol:=dsolve(ode);
y(x) = c__1*x^5*(x+5)+c__2*x*(x^4*(x+5)*Ei(1, x)+(-x^4-4*x^3+3*x^2-4*x+6)*exp(-x))
Student:-ODEs:-ODESteps(ode)
Warning, cannot verify that the given particular solution, y(x) = 1+1/5*x, actually solves the corresponding homogeneous ODE, diff(diff(y(x),x),x)+1/x*(x-5)*diff(y(x),x)-(-5+6*x)/x^2*y(x) = 0
Error, (in Student:-ODEs:-ChangeVariables) the ODE, diff(diff(U(T),T),T) = 5*(T^2+6*T-5)/T^2/(5+T)*U(T)-diff(U(T),T)*(T^2+2*T-25)/T/(5+T), contains the undifferentiated dependent variable, U(T), but the transformation %3, does not
Download internal_error_ODESteps_sept_2_2025.mw
