Question: How to improve overall look of Explore command?
I have not used Explore command alot. Just starting to learn it. But I am stuck on improving the basic look of it.
There are way too much space between sliders and too much white space between the sliders and the plot itself. Also the fonts used below the sliders are too large and do not even know how to remove them or make the fonts smaller.
Looking at the help page, I do not see options to adjust these. But help pages are very hard to read to find an option.
Here is an example. I am using worksheet, with 100% default zoom.
Explore(plot((b+0.7)*sin(x/(a+1))/x+b, x=-4*Pi .. 4*Pi, view=-2 .. 6,gridlines),
        a=-2.0 .. 1.0,
        b=0.0 .. 3.0,
        width=300,placement='top');
This is the output
I'd like to be like this
Overall, even though Explore works, I find the look of it pretty bad actually due to the above issues. It does not look professional and polished.
This is a big problem, because if there are 4 or 5 sliders, now one can not even see the plot itself when changing the sliders, because one has to scroll down to see the plot now and then scroll back up to reach the top sliders to move them.  Even on Large monitor.
Is there a trick to control the spacing between sliders and the main body which is the plot window? Removing all wasted white space and making sliders font smaller for numbers below the sliders or remove them will go long way to making Explore command output look better.
