Question: How to simplify this radical expression
The below problem has already occured several times to me. In all such instances Maple did not realise that extracting a factor from a square root is the key for further simplification. Doing this by hand is obvious and often easy when extracted factors are positive.
Did I overlook something? Are there other ways avoid disassembling an expression with the op command?
Should simplify or other commands be improved to adress such problems?
How to transform the left-hand side by commands that it matches the right-hand side
sqrt(x__0+1)*sqrt(-2*beta^2*x__0-2*beta^2+4)*sqrt(-(x__0+1)*(beta^2-1))/((beta^2*x__0+beta^2-2)*(beta^2*x__0+beta^2-x__0-1)) = 2/(sqrt(-beta^2+1)*sqrt(-2*beta^2*x__0-2*beta^2+4))
(x__0+1)^(1/2)*(-2*beta^2*x__0-2*beta^2+4)^(1/2)*(-(x__0+1)*(beta^2-1))^(1/2)/((beta^2*x__0+beta^2-2)*(beta^2*x__0+beta^2-x__0-1)) = 2/((-beta^2+1)^(1/2)*(-2*beta^2*x__0-2*beta^2+4)^(1/2))
assumptions := 0 < x__0 and x__0 < 1, 0 < beta and beta < 1
`assuming`([simplify(lhs((x__0+1)^(1/2)*(-2*beta^2*x__0-2*beta^2+4)^(1/2)*(-(x__0+1)*(beta^2-1))^(1/2)/((beta^2*x__0+beta^2-2)*(beta^2*x__0+beta^2-x__0-1)) = 2/((-beta^2+1)^(1/2)*(-2*beta^2*x__0-2*beta^2+4)^(1/2))))], [assumptions])
-(4+(-2*x__0-2)*beta^2)^(1/2)/((-beta^2+1)^(1/2)*(-2+(x__0+1)*beta^2))
I have tried the usual simplify and combine commands to remove the square root from the numerator.
Extracting a factor for -2 from the square root would probably make further simplification possible but there is no simple command to do so.
Factor_ := -2
-2
old := simplify([op(denom(-(4+(-2*x__0-2)*beta^2)^(1/2)/((-beta^2+1)^(1/2)*(-2+(x__0+1)*beta^2))))])
[(-beta^2+1)^(1/2), -2+(x__0+1)*beta^2]
new := old; new[1] := old[1]/Factor_; new[2] := old[2]*Factor_
[-(1/2)*(-beta^2+1)^(1/2), 4-2*(x__0+1)*beta^2]
subs(1/old[1] = 1/new[1], 1/old[2] = 1/new[2], -(4+(-2*x__0-2)*beta^2)^(1/2)/((-beta^2+1)^(1/2)*(-2+(x__0+1)*beta^2)))
2*(4+(-2*x__0-2)*beta^2)^(1/2)/((-beta^2+1)^(1/2)*(4-2*(x__0+1)*beta^2))
expand(simplify(2*(4+(-2*x__0-2)*beta^2)^(1/2)/((-beta^2+1)^(1/2)*(4-2*(x__0+1)*beta^2))))
2/((-beta^2+1)^(1/2)*(-2*beta^2*x__0-2*beta^2+4)^(1/2)) = rhs((x__0+1)^(1/2)*(-2*beta^2*x__0-2*beta^2+4)^(1/2)*(-(x__0+1)*(beta^2-1))^(1/2)/((beta^2*x__0+beta^2-2)*(beta^2*x__0+beta^2-x__0-1)) = 2/((-beta^2+1)^(1/2)*(-2*beta^2*x__0-2*beta^2+4)^(1/2)))
2/((-beta^2+1)^(1/2)*(-2*beta^2*x__0-2*beta^2+4)^(1/2)) = 2/((-beta^2+1)^(1/2)*(-2*beta^2*x__0-2*beta^2+4)^(1/2))
is(2/((-beta^2+1)^(1/2)*(-2*beta^2*x__0-2*beta^2+4)^(1/2)) = 2/((-beta^2+1)^(1/2)*(-2*beta^2*x__0-2*beta^2+4)^(1/2)))
true
Second approach after "discovering" that content works also on square roots
[op(-(4+(-2*x__0-2)*beta^2)^(1/2)/((-beta^2+1)^(1/2)*(-2+(x__0+1)*beta^2)))]
[-1, 1/(-beta^2+1)^(1/2), (4+(-2*x__0-2)*beta^2)^(1/2), 1/(-2+(x__0+1)*beta^2)]
mul(`~`[`*`](`~`[content]([-1, 1/(-beta^2+1)^(1/2), (4+(-2*x__0-2)*beta^2)^(1/2), 1/(-2+(x__0+1)*beta^2)]), `~`[primpart]([-1, 1/(-beta^2+1)^(1/2), (4+(-2*x__0-2)*beta^2)^(1/2), 1/(-2+(x__0+1)*beta^2)])))
-2^(1/2)*(-beta^2*x__0-beta^2+2)^(1/2)/((-beta^2+1)^(1/2)*(beta^2*x__0+beta^2-2))
simplify(-2^(1/2)*(-beta^2*x__0-beta^2+2)^(1/2)/((-beta^2+1)^(1/2)*(beta^2*x__0+beta^2-2))) = rhs((x__0+1)^(1/2)*(-2*beta^2*x__0-2*beta^2+4)^(1/2)*(-(x__0+1)*(beta^2-1))^(1/2)/((beta^2*x__0+beta^2-2)*(beta^2*x__0+beta^2-x__0-1)) = 2/((-beta^2+1)^(1/2)*(-2*beta^2*x__0-2*beta^2+4)^(1/2)))
2^(1/2)/((2+(-x__0-1)*beta^2)^(1/2)*(-beta^2+1)^(1/2)) = 2/((-beta^2+1)^(1/2)*(-2*beta^2*x__0-2*beta^2+4)^(1/2))
is(%)
true
(14)
Context: The left-hand side in an integrand which was produced by a change of variables in a elliptic integral. Maple simplifies only halfway which makes validation of the result of the variable change difficult.
Related functional programming question: Is a onliner `...`(-(4+(-2*x__0-2)*beta^2)^(1/2)/((-beta^2+1)^(1/2)*(-2+(x__0+1)*beta^2)))from the above content-primpart construct possible?
Download Simplify_radical_02.mw
