Question: Worksheet Exercises
This question is related to the Question Why I cannot get results of those instructions?
I am doing exercises from the Book introductory Programming Guide. On two different occassions I get two different results. Can someone explain this behavior by Maple 10. I use May 13, 2005 Build ID 190196 on a PC with Windows XP Professional. I Copy below extracts from the two worksheets.
1.6 Exercises.
1. Assign the integers 12321, 23432, and 34543 to the names a, b, and
c. Use these names to ßnd the sum and diÞerence of each pair of
numbers.
Answer:
> 1.6    Exercises (1)
a := 12321; b := 23432; c := 34543; A := a + b; B := b + c; C := c + a;
                           a := 12321
                           b := 23432
                           c := 34543
                           A := 35753
                           B := 57975
                           C := 46864
>               ND := c - a; E := c - b; F := b - a;
                          ND := 22222
                           E := 11111
                           F := 11111
2. Write two procedures. The ßrst requires two inputs and ßnds their
sum. The second requires two inputs and ßnds their product. Use
these procedures to add and multiply pairs of numbers. How could
you use these procedures to add and multiply three numbers?
Answer:
>                    s := proc(x, y)  ...  end;
>                    p := proc(u, v)  ...  end;
>                    interface(verboseproc = 2)
>                             s(7, 9)
                            s(7, 9)
>                             s(2, 3)
                            s(2, 3)
>                             p(7, 9)
                            p(7, 9)
>                             evalf(%)
                            p(7, 9)
Learning Maple Procedures.
>                          "Hellow World"
                         "Hellow World"
>                                 1739
>                            a := ----
>                                 1432
                                1739
                           a := ----
                                1432
>                               1
>                               - a
>                               2
                              1739
                              2864
>                                 /1  \
>                            evalf|- a|
>                                 \2  /
                          0.6071927374
>                      d  / 3      2         \
>                     --- \x  + 3 x  + log(x)/
>                      dx
                            2         1
                         3 x  + 6 x + -
                                      x
>                         help("versions")
>                        help("interface")
>                     f := proc(x)  ...  end;
>                               f(9)
                               3.
>                               f(7)
                          2.333333333
> 1.6    Exercises (1)
                           a := 12321
                           b := 23432
                           c := 34543
                           A := 35753
                           B := 57975
                           C := 46864
                          ND := 22222
                           E := 11111
                           F := 11111
> 1.6 Exercises (2)
>                          help("return")
>                             s(7, 9)
                              16.
>                          help("debug")
>                             trace(f)
                               f
>                             p(7, 9)
                              63.
>                  t := proc(x, y, z)  ...  end;
>                           t(7, 9, 10)
                              26.
>                  w := proc(x, y, z)  ...  end;
>                           w(7, 9, 10)
                              630.
>                        "Good, Good, Good"
                       "Good, Good, Good"
>                          help("array")
>                          help("escape")
2.6 Exercises (1).
>                  a := 5434; b := 6342; % + %%;
                           a := 5434
                           b := 6342
                             11776
>                     c := 92; d := 310; % %%;
                            c := 92
                            d := 310
                             28520
>                              a + b
>                 VectorCalculus[DotProduct](c, d)
                              64
                              155
>                                1
                              155
                              64
2.6 Exercises (2).
2. Estimate Pi to 10,000 digits.
3. Concatenate three strings "int", "(x^2,", and "x)". Parse the resulting string. Evaluate the parsed string.
5.
Determine a random integer between 40 and 100 using the com-
mand rand(40..100). Concatenate this number with the string, "The
student's grade is ". Extract the student's grade from the result-
ing string.
6. Assign the expressions x^2 and x*x to the names a and b. Find
the three operands of a and b. Compare the results with those re-
turned by using the dismantle function, that is, dismantle(a) and
dismantle(b). The dismantle function displays the internal data
structure used.
4. The Fibonacci numbers are a sequence of numbers. The ßrst two num-
bers in the sequence are zero (0) and one (1). For n greater than two,
the nth number in the sequence is the sum of the two preceding num-
bers. Assign values to indexed names representing the ßrst, second,
and general Fibonacci numbers.
> ?constants;
>                               /1   \
>                            sin|- Pi|
>                               \2   /
>                                  /1   \
>                         evalf[20]|- Pi|
>                                  \2   /
                     1.5707963267948966192
>                         evalf[10000](Pi)
> n:=4: "p" || (2*n+1);
                              "p9"
> "p" || (2*m+1);
                        "p" || (2 m + 1)
> "x" || (1..2) || (1..3);
            "x11", "x12", "x13", "x21", "x22", "x23"
> a:=2; a || 4; cat(a,4);
                             a := 2
                               a4
                               24
> a4 := 5; a || 4; cat(a,4);
                            a4 := 5
                               5
                               24
> This is at variance with what is given in the book. Why?
>     s1 := "int"; s2 := "(x^2,"; s3 := "x)"; cat(s1, s2, s3);
                          s1 := "int"
                         s2 := "(x^2,"
                           s3 := "x)"
                          "int(x^2,x)"
>                           mstring := %
                    mstring := "int(x^2,x)"
>                          help("parse")
>                          parse(mstring)
                              / 2   \
                           int\x , x/
>                             evalf(%)
                                      3
                        0.3333333333 x
> 2.6 Exercises (4): Fibonacci Numbers.
Error, missing operator or `;`
> "F:= proc(m:: nonnegint)  local  i, old, new, tem ;   #F(n) denotes the n-th
>    Fibonacci number. This procedure gives the first m Fibonacci numbers.
>    F(0) := 0; F(1):= 1; old := 0; new := 1; for i  from 2 to m do  tem :=
>    new + old; old := new; new := tem; end do; F(new); end proc; "
Error, unable to parse
Fcolon;&equals procApplyFunction(mcolon;&colon nonnegint) local icomma old
  comma newcomma tem semi  FApplyFunction(0) colon;&equals 0semi F
  ApplyFunction(1)colon;&equals 1semi Typesetting:-mambiguous(
  old colon;&equals 0 semi ApplyFunctionnew colon;&equals ,
  Typesetting:-merror("unable to parse"))1semi for i  from 2 to m do tem
  colon;&equals ApplyFunctionnew  +  ApplyFunctionold semi ApplyFunctionold
  colon;&equals ApplyFunctionnew semi ApplyFunctionnew colon;&equals temsemi
  end dosemi FApplyFunction(new)semi end procsemi
>                              F(10)
Error, (in F) too many levels of recursion
>                           help("temp")
