Question: Thank you, another question about the flexible beam.
Thank you very much.
As you say, the rigid body frame components, can define the end points of the link. But what about "the flexible beam", how to define its endpoint? The "maplesim help"  say "the beam is straight and its neutral axis is aligned with the x axis of the primary frame", then its deformation is measured.  I think in a system, the flexible beam is used together with the rigid body frames, but it always point to the direction of the x axis, so I can't specify the shape of the arm. How can solve that?
