Question: How can we display an UNsimplified expression in a Mathcontainer Component?
I'd like to display a UNsimplified mathematical expression in a Mathcontainer component using a Button component. In Maple Help under Mathcontainer, it is writing that we can display a unsimplified expression using the value attribut. For example:
Do(%Mathcontainer0(value) = a^2*b/a);
should display the unsimplified expression in the Mathcontainer0 component. And
 Do(%Mathcontainer0(expression) = a^2*b/a);
should display the simplified expression in the Mathcontainer0 component.
Unfortunately, both displays the same, which is the simplified expression ab.
I also used the following, but it produced the same result.
SetProperty('MathContainer0', 'value', a^2*b/a);
SetProperty('MathContainer0', 'expression', a^2*b/a);
Thanks!
