Question: I can't integrate Maple code into Java using OpenMaple
Dear all,
I am running Maple 11 on my PC. I have Windows 7 (64 bit installed), use Eclipse SDK for Java development.
I have made some mathematical calculations in Maple 11, now I want to integrate them to Java using OpenMaple API.
I viewed help, maple soft and maple primes resources ...... I found test.java example in Maple 11 directory.
I can't add classpath to OpenMaple libraries in Java.
I have Java SDK 6 installed in directory: C:\Program Files\Java\jdk1.6.0_21\
I have Maple11 installed in directory: C:\Program Files(x86)\Maple11\
When I run following commands in run dialog box
C:\Program Files\Java\jdk1.6.0_21\bin\javac -classpath "C:\Program Files(x86)\Maple11\java\externalcall.jar;C:\Program Files(x86)\Maple11\java\jopenmaple.jar;." test.java
A command window just appears each time and vanishes.
Now, it is time to set path, using commands in run dialog box:
C:\Program Files\Java\jdk1.6.0_21\bin\java -classpath "C:\Program Files(x86)\Maple11\java\externalcall.jar;C:\Program Files(x86)\Maple11\java\jopenmaple.jar;." test
After all this process, it should show me this output "1/2*x^2 Done " on the screen, but it does not.
And in Eclipse SDK, I open this program test.java, Eclipse SDK does not find these libraries path to import.
Can anyone help me how to solve this problem, so that I can integrate my maple work into java.
Regards,
Vicky
