Sorry to bother moderators again but a question from @panke has just disappeared.
I browsed its old questions but found none in a recent past related to the one removed.
Can you please tell me where it has been moved ?
TIA
PS: I understand perfectly the need to avoid multiple occurrences of a same thread, but in case of the displacement of a question, couldn't a systematic message be sent?
I was developping an answer to @jennierubyjane  but the question disappeared meanwhile.
Here is the answer hopping for someone to restore the initial question (if it still matters?).
To  @jennierubyjane : comments and advices are in Maple 1D font within your original worksheet.
EDITED : Answer has been displaced here  233262-How-Do-I-Solve-Error-in-Dsolvenumericbvpconvertsys
This might be a trivial question, but I have not been able to find the answer. I am using Maple 2018.
I am working with differential operators acting on real valued functions of a real variable. On the first hand, I want to be able to do simple algebra with these operators. For example, I might want to compute the commutator of two such operators. I have been using the DEtools package, toghether with the 'mult' command to perform such calculations. See the atached file containing a simplified version of what I am doing.
Now, I also want to be able to act with my differential operators on a function, and get the resulting function.
(a) What command allows me to do that within my framework? (i.e. that of DEtools with the way I have defined and used my operators)
(b) I there a better way to proceed? (i.e. is there a better way to do both algebra with differential operators and to act with them on functions to get the resulting function)
Many thanks
Example.mw
# Below you find a small example about the function diffdiameter(conc,number), which has the unit length as long as the second argument number is not zero. Using the convert function it is possible to remove the units entirely, but this does not help, if I want to plot the functions. Is there a possibilty to plot diffdiameter(conc,number-not-zero) and diffdiameter(conc,0) in one diagramm? with(Units[Simple]); with(plots); diffdiameter := (conc, number) -> -number*diameter*exp(-conc/Unit(mol/kg)); diffdiameter := proc (conc, number) options operator, arrow; Units:-Simple:-`-`(Units:-Simple:-`*`(Units:-Simple:-`*`(numb\ er, diameter), Units:-Simple:-exp(Units:-Simple:-`-`(Units:-Si\ mple:-`*`(conc, Units:-Simple:-`/`(Unit(Units:-Simple:-`*`(mol\ , Units:-Simple:-`/`(kg))))))))) end proc diameter := 2*Unit(m); diameter := 2 Unit(m) evalf(diffdiameter(Unit(mol/kg), 6)); evalf(diffdiameter(Unit(mol/kg), 0)); -4.414553294 Unit(m) 0. convert(evalf(diffdiameter(Unit(mol/kg), 6)), unit_free); convert(evalf(diffdiameter(Unit(mol/kg), 0)), unit_free); -4.414553294 0. plot([convert(evalf(diffdiameter(conc, 0.001)), unit_free), convert(evalf(diffdiameter(conc, 6)), unit_free)], conc = 0 .. 4*Unit(mol/kg), title = "derivative Diameter with conc", labels = ["concentration / mol/kg", "deriv diameter / m"], color = ["blue", "red"], legend = ["bare diameter", "PLUS diameter"], labeldirections = ["horizontal", "vertical"], titlefont = [Helvetica, bold, 16], axesfont = [Helvetica, 14], labelfont = [Helvetica, 14], axes = boxed); plot([convert(evalf(diffdiameter(conc, 0)), unit_free), convert(evalf(diffdiameter(conc, 6)), unit_free)], conc = 0 .. 4*Unit(mol/kg)); Error, (in plot) invalid subscript selector
on DLMF page, they show this transformation on independent variable for second order ode
https://dlmf.nist.gov/1.13#Px7
About half way down the page, under Elimination of First Derivative by Change of Independent Variable section.
I tried to verify it using Maple dchange. But the problem it looks like dchange wants the old variable to be on the left side (z in this example) and the new variable (eta in this example) to be on the right side in the transformation. But on the above web page, it is the other way around.
Here are my attempts
ode:=diff(w(z),z$2)+f(z)*diff(w(z),z)+g(z)*w(z)=0;
tranformation:=eta=int(exp(-int(f(z),z)),z);
PDEtools:-dchange({tranformation},ode,known={z},unknown={eta});
PDEtools:-dchange({tranformation},ode,{eta},known={z});
PDEtools:-dchange({tranformation},ode,{eta});
All give errors
Error, (in dchange/info) missing a list with the new variables
Error, (in dchange/info) the new variables are not contained in the rhs of the direct transformation equations
The problem it does not seem possible to invert the transformation shown on the webpage, so that the old variable z show on the left side and the new variable (eta) on the right side.
Why is this restriction on dchange  Since one tells it which is the new variable and which is the old variable? May be I am not using dchange correctly in this example.
Any suggestion for a workaround to use dchange to verify the above result?
Here is my hand derivation (pdf file attached also)
Can the above be done using dchange?
Maple 2021.2 on windows 10
sol.pdf
Tetrahedron with length of sides like this picture has volume is an integer number. Is there another tetrahedron like that?
Hi! I have recently started some Maple in chaos in dynamical systems and I am thinking about counting experimental invariant denisty measure (which is in brief  "how often the point visits the given interval") for some discrete mappings (in this case it's logistic mapping 3.7*x*(1-x)).
x := array(1 .. 10^6 + 2);
x[1] := 0.2;
for i to 10^6 do
    x[i + 1] := 3.7*x[i]*(1 - x[i]);
counter := 0;
for i to 10^6 do
    if 0 <= x[i] and x[i] < 0.1 then counter := counter + 1; end if;
counter;
counter := 0;
for i to 0^6 do
    if 0.2 <= x[i] and x[i] < 0.3 then counter := counter + 1; end if;
counter;
counter := 0;
for i to 10^6 do
    if 0.9 <= x[i] and x[i] < 1 then counter := counter + 1; end if;
counter;
display(plot([[0, 0], [0.3, 0]]), plot([[0.3, 74089], [0.4, 74089]]), plot([[0.4, 57290], [0.5, 57290]]), plot([[0.5, 86726], [0.6, 86726]]), plot([[0.6, 122087], [0.7, 122087]]), plot([[0.7, 269178], [0.8, 269178]]), plot([[0.8, 185490], [0.9, 185490]]), plot([[0.9, 115405], [1, 115405]]))
I don't know how can I automate this code. I need smaller intervals because I took length 0.1 which is not good enough.
I want to get something like this (it is for logistic map such as above but in below example they plotted this graph for 4*x*(1-x) )
Figure 3 | Constructing Multi-Branches Complete Chaotic Maps That Preserve  Specified Invariant Density
thanks in advance
The "rows and series" chapter is coming to an end. But im not getting this question. Ive got a feeling they are not really specific with this book. But that could just be me.
Any way here is the question:
"In classical physics there is the kinetic energy of a body with the mass m0 and the speed v given by E1=1/2*m0*v^2. According to Einstein the kinetic energy E2=(m*c^2)-(m0*c^2)=((m0*c^2)/sqrt(1-(v/c)^2))-m0*c^2, at which m is the relativistic mass with a speed v, and m0 the mass in rest. Further c is the speed of light. Wright down E2 as a linear function of v^2 and show that E2=E1 when v is small compared to c."
Now i cant see what they did to get this answer:
A taylor series was probably used, the question before it also used a taylor series.
If someone knows what they did. What did they do to get the the answer the book gave?
Greetings,
The Function
But ODEsteps supports simliar ODEs (see attached).
Is the ODESteps command not generic enough to cover the pendulum or have I missed something?
ODESteps.mw
Hi everyone, how can i plot nonlinear phase portraithere k,w, alpha,K, k, gamma, beta are arbitrary constants and i have three equilibrium points:
I hope the resulting graphics are as follows :
How can I plot these phase portraits? Thanks in advance.
hello,
i want to animate a sequence from a nomeric solution i recived, i have a sequene for displacment and another one for time, is there a way to do that ?
Has somebody experienced something like that before?
I was searching for a bug in a sheet, and was absolute unable to find out why some results in a sheet were different from another sheet.
Found out that it actually was a pure graphics problem. With normal zoom (100%) the minus signum is not visible.
Blowing up the zoom to 125% shows the signum again.
I have an expression of the form
Expr := n0*C[0] + n1*C[1] + ... + nk*C[k] + n = 0,
where the numbers n0,...,nk and n are known to Maple (after it made some calculations), whereas C[0],...,C[k] are undetermined.
I would like to know the values of all of n0,...,nK and n. For n0,...,nk, I found them with
coeff(Expr, C[m], 1),
with m in 0,...,k. But I don't know how to get the value of the "independent term" n.
Can someone help me with this?
I have a list of lists made from a combinat and was wondering how to make a new list from it that only contains lists that the elements sum up to 0.
For example:
L1 := [[1,1,1,1], [1,2,0,0], [0,0,0,0], [1,1,-2,0]];
and I want the result to be
L2:= [[0,0,0,0], [1,1,-2,0]]
Thank you in advance! I'm new to maple so would appreciate the guidance!
I am studying something about complex numbers.
What commands are specific to find in Maple for complex numbers ?
  • complexplot()
  • conformal()
  • conformal3d()
It seems that there are a lot of standard calculus statements can be used by adding the word : complex
Iam using here a package downloaded from Maple website : complex analysis for mathematics and engineering
Got the impression that some modern plot commands for complex numbers are not yet in this book present ..and how about other commands?
an_introduction_to_complex_numbers.mws
First 355 356 357 358 359 360 361 Last Page 357 of 2429
