i tried to solve a nonlinear ode with numerical method but maple can't solve it and this error occur:
my maple codes are attached below:
numeriacal_sol.mw
can any help me?
Hi everybody,
I face the following problem :
I develop a Maple simulation code with its own maplets-based interface, and I would like to draw up an "execution report" that presents many informations in a smart and synthetic way :
  1. a summary of the data the user provided through the interface (numerical values, files, ...)
  2. the results of some preliminary operations (ie. the construction of the equations to solve)
  3. some plots of the numerical solution (typically of an ode system)
This execution report should mix texts, plots, charts, ...
At least, I would like the report to be written in LaTeX.
I use to use the software R which provides some facilities to build reports of this kind  (packages knitr or Sweave for those who would know) , and I am wondering if there exists something comparable in Maple ?
Could the DocumentTools package (I know by name only) help me ?
More generally, if you were faced with such a problem, how would you deal with it?
As always any suggestion or advice will be greatly appreciated
I need to formulate the follow relationship in proper math symbols:
Differential in A (last days value minus today's) has a tendency to reach the Differential in B (today's)
I though this could be expressed with
AΔ -> BΔ
BUt I guess there are more elegant and mathematically correct ways to do this in Maple?
thank you!
Dave
Lets say you a country where the official government debt (not adjusted for who owns the debt) is 30% of GDP. The official government debt consist of 50% government bonds and the central banks owns 40% of these government bonds. Since the government finance the centralbank we have to adjust the official government debt and remove the 40% of the government bonds that the centralbank own to get the real government debt expresed as % of GDP. In my initial calculation I simply did like this:
Real government debt expressed as % of GDP = 0.3*(1-0.4) =18%
However, that such number does not take into consideration that the official government debt is only made up of 50% government bonds. I tried to play around with different types of equations but I found none that makes any logical sense and provides me with a reasonable number. I would expect the real government debt to around 23% of GDP. This might be a simple question but I must admit I am stuck and I am not making any progress.  Any help would be appreciated.
As I understand it, Maple will detect and use the available cores in a system, if the calculation is suitable for multi-core use.
As I am installing Maple on a multi-user cluster, using a scheduler to run maple scripts, I want to ensure the maple jobs only use the number of cores allocated to the job.
Is it possible to set the number of cores used ?
If I have misunderstood how Maple works (I am new to it), or if there is a section in the documentation which explains this, please point me in the right direction.  I haven't found this info so far.
I have the transition matrix used in Markov chain
A := Matrix([[alpha, beta, gamma], [delta, epsilon, zeta], [eta, theta, mu]])
I would like to write a system of equations that can be solved  to get a Markov chain  irreducible and aperiodic
All the entries of the transition matrix are in the interval [0,1)
Many tanks for any help
if I use the command below, I will get the right answer.
`assuming`([simplify((2*I)*deltas*Pi*BW*Ei(1, (2*I)*deltas*Pi*BW)-(2*I)*deltas*Pi*BW*Ei(1, -(2*I)*deltas*Pi*BW))], [real, BW > 0, deltas > 0, ts > 0, deltas <= ts, 2*BW*ts >= 1])
and the answer is :
2*BW*Pi*deltas*(Pi-2*Si(2*BW*Pi*deltas))
while I use the same command for the compliacated Ei function, it doesn't work any more, I don't know the reason.
 `assuming`([simplify(Ei(1, I*BW*Pi*deltas-(5*I)*BW*Pi*ts)-Ei(1, -I*BW*Pi*deltas+(5*I)*BW*Pi*ts), Ei)], [real, BW > 0, deltas > 0, ts > 0, deltas <= ts, 2*BW*ts >= 1])
 and it's reault is :
Ei(1,I*BW*Pi*deltas-5*I*BW*Pi*ts)-Ei(1,-I*BW*Pi*deltas+5*I*BW*Pi*ts)
I am looking for a nice algorithm to determine if a polynomial is expressible as an ALGEBRAIC combination of a list of other polynomials. I have written my own for LINEAR combinations, but cannot quite generalize this method.
Any help would be greatly appreciated.
Hello, I am trying to plot an expression for my General Relativity class, this expression is one of the expanding universe FLRW solutions to the Einstein field equations and contains an unknown functions.
sqrt(S(t))*sqrt(1+S(t))-arcsinh(sqrt(S(t))) = t
My question is how do I get maple to plot this?
i use
A -> B
B -> C
would like to find A -> C directly from A -> B and B -> C
but logic table show that AND(A->B, B->C) is not equal to A -> C
and (A->B) -> (B->C) is not equal to A -> C too
which logic operations can do this?
because do not want to use result to verify and because i do not know the result in the beginning
I could keep on using the commands
with(GraphTheory):
with(RandomGraphs):
DrawGraph(RandomTree(7))
but then this is not helpful because I do not get non-isomorphic graph each time and there are repetitions. So any other suggestions would be very helpful.
I assigned the greek alphabet pi=0.45 in Maple but it displayed an error message since it is already a known constant 3.142. Please how can I assign pi to 0.45 in Maple ?
for example
func1 := proc(system1)
for i from 1 to 100 do
solve([system1[1], system1[2]],[x,y]);
func1([diff(y,t) = data[i+t+1], diff(x,t) = data[i+t+1]])
i is depend on the for loop inside a function, but woud like to pass this system into a function with i
this will cause error
how to write better for passing a system as parameter using variable inside a function?
indets(AA(MM(AA(X1,X2),B2),MM(AA(B2,X3),X5)));
this can get a list of X1,X2,B2,X3,X5
propositionsentence := MM(AA("it", "run"), "maple"):
indets(propositionsentence);
but this can not get "it", "run", "maple"
how to do this in case this in maple 12?
Dear Maple users
I was using the animation command to create an animation consisting of a running sine curve with a ball following the curve, as shown below. I wonder if it is possible to create it with the Explore command too? Or is this command more limited? I need to be able to add more animations, like I can with the display command ...
Regards, Erik.
First 1020 1021 1022 1023 1024 1025 1026 Last Page 1022 of 2463
