Hello I am a student in university from Indonesia
I have installed my app maple13. But to activated need purchase code. Where i can find my purchase code.
Its Important for me.
Thx
I want to produce a user defined function in Maple and use it in my program like Matlab. My function in Matlab is as below:
function R=ff(i,m)
K=1;
Q= zeros( i );
for j=1:2:i
 Q(j)=2*i-K;
 K=4+K;
end
R=Q(m);
How to produce this function in Maple and use it in my program?
Maple 18. I just got a 4K monitor and the filenames and bottom toolbar are far too small. Is there any way to resize them? Does the same problem exist on later versions?
I was posting some code on a forum tonight. I specificially added # comments to the code. I used Ctrl_c ,Crtl_v. All the # comments were removed including the 2016 grey boxes which appeared as NULL.
Is there away around this. The comments were very important to help in understanding. The pasted code did look readable though.
I also experimented with exporting the code as .txt and opening it in Word. Required loads of editing to make it look presentable, which really opend the door to introuucing errors, also all # coments were removed too.
The forum just has the normal type comments box. Nothing fancy. Actually it is a WordPress Blog. It does accept latex but that is ok for one or two lines. Could be a real mess if 30--40 lines of code go wrong and latex as far as I know can't be copy/pasted back in to Maple.
How Maple knows free and dummy index?
Hi.  I've spent the last 5 hours or so working on a worksheet on Maple, without saving but with autosaving every 15 min.
Maple worksheet crashed. When I opened it again, that all changes were losted! But I find autosave .bak  file. How may I open it?
Is there any way I can recover my work?
In maple we have type/symmfunc check for a symmetric function. I want to write cycfunc function.
Example: cycfunc(a^2*b + b^2*c + c^2a, [a,b,c]) return true.
Thanks you very much.
In Maple18.02:
Hso := Matrix(8, {(1, 4) = -x, (1, 6) = I*x, (2, 3) = x, (2, 5) = I*x, (3, 2) = x, (3, 5) = -I*z, (3, 8) = y, (4, 1) = -x, (4, 6) = I*z, (4, 7) = -y, (5, 2) = -I*x, (5, 3) = I*z, (5, 8) = -I*y, (6, 1) = -I*x, (6, 4) = -I*z, (6, 7) = -I*y, (7, 4) = -y, (7, 6) = I*y, (8, 3) = y, (8, 5) = I*y})
av, AV := LinearAlgebra[Eigenvectors](Hso)
Error, (in Polynomial:-Quadratic) type `truefalseFAIL` does not exist
This does not happen in Maple17.
Hi there,
I'm new here. My first question:
Is there a way to make Maple output display explicit multiplcations signs in 2D-math?
Example:
When you enter 5*2^x Maple will output 5*2^x. Is there a way to make Maple display the multiplications signs in output in stead just implicit multiplication signs (i.e. whitepaces)? (I would settle for Maple display all multiplication signs in output - not just the ones which are made explicit in the input.)
I searched this site. No luck. I looked into "Typesetting Rule Assistant", but I couldn't find a way to alter the output of multiplication sign (*).
Can you guys help me?
Kind Regards,
Jens
P.S.: I'm a teacher from Denmark. We use Maple before college/university for a lot of pupils. Some less competent pupils have a tendency to overlook the whitespace.
Respected member!
Please help me to find the solution of attached problem.
> subject to boundary conditions
alpha := evalf(2*Pi*(1/180)); EP := .2; lambda := .1; HA := 5; RE := 20
ODEforNum := (1+EP)*(((D@@3)(F))(r)+4*alpha^2*(D(F))(r))+2*alpha*RE*F(r)*(D(F))(r)-HA*alpha^2*(D(F))(r)-3*EP*lambda*((1/2)*(D(F))(r)^2*((D@@3)(F))(r)+(D(F))(r)*((D@@2)(F))(r)^2)/alpha^2-EP*lambda*(72*F(r)^2*(D(F))(r)+2*(D(F))(r)^3+32*F(r)*(D(F))(r)*((D@@2)(F))(r)+2*F(r)^2*((D@@3)(F))(r)) = 0
1.2*((D@@3)(F))(r)-0.243693936e-3*(D(F))(r)+1.396263402*F(r)*(D(F))(r)-24.62104762*(D(F))(r)^2*((D@@3)(F))(r)-49.24209525*(D(F))(r)*((D@@2)(F))(r)^2-1.44*F(r)^2*(D(F))(r)-0.4e-1*(D(F))(r)^3-.64*F(r)*(D(F))(r)*((D@@2)(F))(r)-0.4e-1*F(r)^2*((D@@3)(F))(r) = 0
BCSforNum := F(0) = 1, (D(F))(0) = 0, F(1) = 0
Digits := 15
15
numsol := dsolve({BCSforNum, ODEforNum}, numeric, output = listprocedure)
Download MapleN.mw
Hi guys,
I'm trying to solve this system I have but the solution doesn't display:
-I have two second degree differential equations with two functions.
-I have a set of two boundary conditions per function.
eq2:=2*diff(y(x), x$2)+diff(z(x), x$2)=0;
2*(diff(diff(y(x), x), x))+diff(diff(z(x), x), x) = 0
eq3:=2*diff(z(x), x$2)+diff(y(x), x$2)=0;
2*(diff(diff(z(x), x), x))+diff(diff(y(x), x), x) = 0
SOL:=dsolve({eq2, eq3, D(y)(0)=0, D(y)(1)=1, D(z)(0)=0, D(z)(1)=1}, {y(x), z(x)});
"SOL := "
Download trial.mwtrial.mw
This is reduced from another forum.
e1 := 12*g^2+12*h^2+4*i^2+3*j^2=684;
e2 :=  12*l^2+12*m^2+4*n^2+3*o^2=684;
e3 := 12*q^2+12*r^2+4*s^2+3*t^2=172;
e4 := 12*v^2+12*w^2+4*x^2+3*y^2=108;
e5 := 12*g*l+12*h*m+4*n*i+3*j*o=-84;
e6 := 12*g*q+12*h*r+4*s*i+3*j*t=-84;
e7 := 12*g*v+12*h*w+4*x*i+3*j*y=-84;
e8 := 12*l*q+12*m*r+4*n*s+3*o*t=-84;
e9 := 12*l*v+12*m*w+4*n*x+3*o*y=-84;
e10 := 12*q*v+12*r*w+4*s*x+3*y*t=-84;
e11 := g+h+i+j=-1;
e12 := l+m+n+o=-1;
e13 := q+r+s+t=-1;
e14 := v+w+x+y=-1;
e15 := h*i+m*n+3*s*r+4*x*w=-21;
e16 := g*i+l*n+3*s*q+4*x*v=-21;
e17 := i+n+3*s+4*x=-3;
e18 := g*h+m*l+3*q*r+4*w*v=-7;
e19 := h+m+3*r+4*w=-1;
e20 := g+l+3*q+4*v=-1;
e21 := i*j+o*n+3*s*t+4*x*y=-84;
e22 := j*h+o*m+3*r*t+4*y*w=-28;
e23 := j*g+o*l+3*q*t+4*y*v=-28;
e24 := j+o+3*t+4*y=-4;
e25 := j^2+o^2+3*t^2+4*y^2=144;
e26 := i^2+n^2+3*s^2+4*x^2=129;
e27 := h^2+m^2+3*r^2+4*w^2=57;
e28 := g^2+l^2+3*q^2+4*r^2=57;
eqset := {e1, e2, e3, e4, e5, e6, e7, e8, e9, e10, e11, e12, e13, e14, e15,
          e16, e17, e18, e19, e20, e21, e22, e23, e24, e25, e26, e27, e28};
for s in eqset do print(s) end do;
Error, too many levels of recursion
If I then do
S := {1,2,3,6,3,6,8,2,3,6};
for s in S do print(s) end do;
Then,
has the correct output.
What am I doing wrong?
Tom Dean
Dear All
I have a trignometric function and I plotted it in 2D. It is visible from the graph that the function has Maxima and Minima. My question is, can I located all values
0.12981e-1+0.80285e-1*cos(.9519256799*x)+0.41370e-1*cos(1.903851360*x)+0.35690e-1*cos(2.855777040*x)+0.147e-3*cos(3.807702720*x)
plot(diff(0.12981e-1+0.80285e-1*cos(.9519256799*x)+0.41370e-1*cos(1.903851360*x)+0.35690e-1*cos(2.855777040*x)+0.147e-3*cos(3.807702720*x), x), x = -6.2 .. 6.2)
Download Max_Min_from_Graph.mw
of "x" corresponding to these Max. and Min. ?
dy/dx=sqrt(1+(a*x)+(2*y))
for the case a=1, y=1 and x=0 construct a program for the runge-kutta method of order 2 with formulae as follows where f(x,y)=dy/dx.
k_1=h*f(x_n,y_n)
k_2=h*f(x_n+h,y_n+k_1)
y_(n+1)=y_n+1/2(k_1+k_2).
After creating a program obtain value of y correct to 4 decimal places when x=1 for h=0.1 and h =0.05.
Meanwhile, thank you so much for everything.
I know I'm asking a lot but if you have time, you can help me do this?
Building a system of interactive components that, taken a function, two points 'a' and 'b' values ​​and an integer n, the calculations point between a and b in which the function assumes the minimum value by using the following procedure:
• It divides the values ​​between a and b into n equal parts (these will distance the one with the other (b-n)/2);
• calculates the function in each of these points;
• located between these values,  what is the minimum (in case of a tie, take the one closest to a)
I think i have to create a vector for each  part and  prehaps with a fcycle for, calculate the function, finelly i'll use minimize with all function.
Do you think is the correct procedure? If yes, how can I do it?
First 1040 1041 1042 1043 1044 1045 1046 Last Page 1042 of 2462
