Hi all, i have a problem someone help me.
Define per(f(a,b,c)) = {f(a,b,c), f(b,c,a), f(c,a,b)}. I want to write a function removePer() that removes the permutations, example:
ds := {a, b, a^2, b^2, c, c + 2a, a - b, c^2, a + 2b, b + 2c}
then removePer(ds) return {a, a^2, c + 2a, a - b} because per(a) = {a, b, c}, per(a^2)  = {a^2, b^2, c^2} and per(c+2a) ={a+2b, b+2c, c+a}. Note that removePer(ds) can return {b, a^2, c + 2a, a - b} or {c, a^2, c + 2a, a - b}, ...  but just one result.
ds := {ab, bc, a - b^2, b - c^2, a^2, c - a^2},
then removePer(ds) return {ab, a - b^2, a^2}.
Thank you very much.
Spherical coordinates in electrical engineering are rho theta phi meaning distance, zenith and azimuth
making a righ-handed trihedron
In MAPLE I find a left-handed trihedron.
Can I change the order of coordinates?
Hi dears,
How can I draw the solution of the following 3d linear inequalities in Maple?
A:={-x-y+3*z >= 0, -x+2*y >= 0, 3*x-2*y-z >= 0, x > 0, y > 0, z > 0}
I am looking forward to hearing from you
Sincerely yours.
hi.how i can solve or fsolve this equations?
i can not with fsolve?
thanks alot
SOLVE.mw
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/SOLVE.mw .
Download SOLVE.mw
Let say I have a linear system of equations with 28 unknowns (Z1, Z2, ..., Z28).
I know that dimension of space of solution > 0. I want for all unknowns to be expressed only by (let say: Z20, Z21, ..., Z28).
How to specify these free variables? I'm pretty sure it is implemented in Maple.
Hello. My question is enclosed in the Maple file. Using DrawGraph I get a complicated mess.
graph.mw
So as to build a function which gives several outputs, i have made a code with this manner :
Input:=[i1, ..., in]
Output:=proc(Input);
      export o1, o2, o3
      o1=f1(Input);
      o2=f2(Input);
      o3=f3(Input);
      end module
End proc;
By doing, output1:=Output(Input):-o1; , i obtained my result. However, as my structure begins with the procedure (proc End proc), I can't export my result in package.
For this reason, I'm thinking about changing the structure of my code by starting with the creation of the module and put all the functions inside.
Output:=module():
export o1,o2,o3;
option package;
o1:=proc(Input)
f1(Input);
o2:=proc(Input)
f2(Input);
o3:=proc(Input)
f3(Input);
End module;
Can you give me your feedback on the two structures ? Do you think that the second choice Module->Functions is more appropriated ?
Thanks a lot of your help and feedback.
Hi,everyone!!
I want to plot a phaseplane of the following equation.
this is my code:
But,I can't get what i want. What*s wrong with my code? And how do I modify it?
Thanks you very much.
I am facing to run the following expression for an arbitrary values of M, k and alpha.
u := simplify(sum(sum(c[p, q]*2^((K-1)*(1/2))*(sum(sum(sum(sum(2^((K-1)*(p-i-j+q-k-l))*GAMMA(p-i-j+1)*x^(p-i-j-alpha)*(1-p)^j*(1-q)^l*g[i]*binomial(p-i, j)*binomial(p, i)*binomial(p-k, l)*binomial(q, k)/GAMMA(p-i-alpha-j+1), l = 0 .. q-k), k = 0 .. q), j = 0 .. p-i-ceil(alpha)), i = ceil(alpha) .. p))/sqrt(2*(-1)^q*factorial(q)^2*g[2*q]/factorial(2*q)), q = 1 .. Delta), p = ceil(alpha) .. Delta));
FD := simplify(convert(%, StandardFunctions)); expand(radnormal(convert(FD, elementary)))
Please correct it and run it for M=10, k=1, alpha=0.5.
Hi all, I have a problem someone can help me
F := {a^2, b^2, c^2, ab, bc, ca}
G := [a^2, b^2, c^2, ab, bc, ca]
How to convert F to G and G to F ?
I would like to set a metric in its contravariant form before its covariant form but Maple does not do this operation.
Hello :)
When points of triangle, A, B, C (R^2) are given, how to find area of triangle; equation and radius of circle which passes traingle(A,B,C) and height(AH).
or where can i find information about how to do this?
thank you so much:)
How to get tangent angle between two curves?
example for these : f(x)=((x^4+5)^(1/2))/(sinx+5) and g(x)=cosx^2   ; x>0
I am trying to simplify noncommutative expressions that use the 'dot' operator: `.`. The following is a minimal example:
a2 . (1/(a2 . (1/a1) . a2)) . a2, which evaluates to:   a2 . (1/(a2 . (1/a1) . a2)) . a2
This should simplify to 'a1', as I am expecting `.` to work like noncommutative multiplication. If there is any way to define this behavior I would appreciate some help. Alternatively, I would also be happy with reworking 'simplify' to work in this scenario. If it helps, I am working with finitely presented groups. If you see the Maple package 'GroupTheory', you'll see that the 'Group' function has this built in. If we input generators and relators it will simplify expressions of the above type, so I know it can be done!
Lastly, I would prefer displaying '1/a1' as 'a1^-1', but that is just for aesthetics.
Here is a minimal document: minimalexample.mw
I'm trying to solve a system of 9 ODE in a model of a chemical reactor. But, unfortunately, when I try to plot the curves, I get the following error message: Error, (in f) unable to store '[Float(undefined)]+8.5809018712796' when datatype=float[8]
Can anyone help me please? I read some related problems here, but couldnt find a solution yet.
Thanks for your time
Best regards
First 1065 1066 1067 1068 1069 1070 1071 Last Page 1067 of 2463
