Is Symbolic Laplace and Inverse Laplace transform possible on Maple? if Yes, how do I find the inverse laplace of this function
Respected member!
Please help me to find the solution of attached problem, I am a new user so pleaes forgive any mistakes.
R := 2.0
2.0
ODEforNum := r^3*((D@@4)(F))(r)+r^2*R*((D@@3)(F))(r)*(F(r)-2/R)+R*((D(F))(r)-r*((D@@2)(F))(r))*(r*(D(F))(r)+3*(F(r)-1/R)) = 0:
numsol := dsolve({BCSforNum, ODEforNum}, numeric, output = listprocedure)
Download mplprimes.mw
I'm having trouble scaling Maple 16 to be usable on a QHD+ resolution 13" screen. I was wondering if anyone know if it's possible to scale the interface of Maple through some option or if there is another trick to fix it.
Thanks in advance!
How can i get a positive random matrix of order 6 ?? to do the cholesky decomposition
Hello.
I have a Pde solution in from of the sum.
pde := diff(u(x, t), t) = diff(u(x, t), x$2)
symbolic := pdsolve([pde, u(x, 0) = 1, u(0, t) = 0, u(1, t) = 0])
symbolic := u(x, t) = Sum(-(2*((-1)^_Z9-1))*sin(_Z9*Pi*x)*exp(-Pi^2*_Z9^2*t)/(Pi*_Z9), _Z9 = 1 .. infinity)
I tried a subs or eval command dosen't work.
pdex1.mw
pde := diff(u(x, t), t) = diff(u(x, t), `$`(x, 2)):
ics := [u(x, 0) = 1, u(0, t) = 0, u(1, t) = 0]:
pds := pdsolve(pde, ics, numeric, time = t, range = 0 .. 1, spacestep = 1/4024, timestep = 1/4024):
u(x, t) = Sum(-2*((-1)^_Z9-1)*sin(_Z9*Pi*x)*exp(-Pi^2*_Z9^2*t)/(Pi*_Z9), _Z9 = 1 .. infinity)
eval(rhs(symbolic), `~`[_Z9] = n)
subs(`~`[_Z9] = n, rhs(symbolic))
subs[eval](`~`[_Z9] = n, rhs(symbolic))
Download pdex1.mw
Hello dear! Hope you will be fine. I want to simplify the equation (4) like equation (3) in the attached file please correct it. I shall be thankful to you.
Help.mw
With my best regards and sincerely.
Muhammad Usman
School of Mathematical Sciences
Peking University, Beijing, China
I want to write a function func(n) get a^ib^jc^k from expand (a+b+c)^n
Example
When n = 1 then (a + b + c)^1 = a + b + c and func(n) return {a, b, c}.
When n = 2 then (a + b + c)^2 = a^2 + b^2 + c^2 + 2ab + 2bc + 2ca and func(n) return {a^2, b^2, c^2, ab, bc, ca}.
When n = 3 then func(n) return {a^3, b^3, c^3, a^2b, b^2c, c^2a, ab^2, bc^2, ca^2, abc}.
I have solution using 3 loops but in think it's not nice, someone can help me. Thanks you very much.
The piecewise plot below displays a sphere truncated by the plane z = 2 - y.
f := proc (x, y, z) options operator, arrow; piecewise(z <= 2-y, x^2+y^2+z^2-16, z-2+y) end proc; implicitplot3d(f, -4 .. 4, -4 .. 4, -4 .. 4, style = surface, numpoints = 50000);
The 3 transforms below when executed in display(T(sphere([0, 0, 0], 4, numpoints = 50000)), scaling = constrained) display the truncated sphere differently:
1) the truncating plane only partly conforms to the boundary of the truncated sphere
2) the truncated sphere is correct provided that the else condition coordinate is in the truncating plane and truncated sphere
3) the truncated sphere is correct but hollow
1) T := transform(proc (x, y, z) options operator, arrow; `if`(z <= 2-y, [x, y, z], [x, y, 2-y]) end proc)
2) T := transform(proc (x, y, z) options operator, arrow; `if`(z <= 2-y, [x, y, z], [0, 0, 2]) end proc)
3) T := transform(proc (x, y, z) options operator, arrow; `if`(z <= 2-y, [x, y, z], [`&+-`(sqrt(16-y^2-z^2)), y, 2-y]) end proc)
Please explain the different behavior of the three transforms.
Good evening sir.
I request your valuable support with regard to the above cited query.
With thanks & regards.
Mr.M.Anand
Associate Professor in Mathematics
how can i find e relative maximum or minimum of a function on maple ??
Hi.
I got 2 surfaces given by z=(r,theta)
I have plotted them by converting to cartesian, it gave me a good representation, but i dont get the surface entirely closed. I then used the task template vizual integration and got the solid i needed.
The problem with the rough representation cartesian conertation gives is that the integrals for volume, flux etc becomes so complex maple struggle to calculate it and since the surface is not completly closed it gives me the wrong value.
How can I plot cylindrical and spherical cordinates?
I have checked the following helping page in maple: Set Coordinate System for 3-D Plots
plot_cylindrical.mw
I have the planes:
Plane 1: x + 3y - 5z = 0
Plane 2: x + 4y - 8z = 0
Plane 3: - 2x - 7y + 13z = 0
and I want to plot them in a 3d space with plot3d.
I tried to assign each plane to its own variable like this:
P1 := x+3y:
P2 := x+4y:
P3 := -2x-7y:
plot3d([PlaneOne, PlaneTwo, PlaneThree], x = -8 .. 8, y = -20 .. 20, plotlist = true, color = [blue, red, green])
The planes plot, but they aren't showing correctly.
Here's how they should look, and here's how they look.
Please help. I don't know what I'm doing wrong
Hi everyone,
I need to assign the output of the timer block to a variable which is then will be used in a trapeziod signal to add a time offset. Please see the visual below.
Thanks for your time,
Canberk
When I call up a Help page I see mostly boxes with question marks inside. If I copy the page into Word I get a badly formatted document in Canbria font. On other pages I get a font drop down box that indicates the page is in DejaVu Sans font and if I then change that to some font on my system (MAC 10.12.1) I get a perfectly readable document. Is there some preference, startup code or setting I can change to fix this annoyance?
First 1068 1069 1070 1071 1072 1073 1074 Last Page 1070 of 2463
