I have to find the root of an equation corresponding to the maximum absolute value. I am using root finding package to get all the roots. But after getting all the roots i am not able to apply abs function. Maple sheet is attached.
with(DEtools):
with(ColorTools):
Digits := 30
30
x := proc (t) options operator, arrow; x0*exp(lambda*t) end proc:
phi := proc (t) options operator, arrow; phi0*exp(lambda*t) end proc:
eqm1 := collect(simplify(coeff(expand(diff(x(t), `$`(t, 2))+(2*0)*beta*(diff(x(t), t))+0*x(t)+n*psi*(-v*(phi(t)-phi(t-2*Pi/(n*omega0)))+x(t)-x(t-2*Pi/(n*omega0)))), exp(lambda*t))), {phi0, x0})
(-n*psi*v+n*psi*v*exp(-2*lambda*Pi/(n*omega0)))*phi0+(lambda^2+n*psi-n*psi*exp(-2*lambda*Pi/(n*omega0)))*x0
eqm2 := collect(simplify(coeff(expand(diff(phi(t), `$`(t, 2))+(2*0)*(diff(phi(t), t))+phi(t)+n*(-v*(phi(t)-phi(t-2*Pi/(n*omega0)))+x(t)-x(t-2*Pi/(n*omega0)))), exp(lambda*t))), {phi0, x0})
(-n*v+n*v*exp(-2*lambda*Pi/(n*omega0))+lambda^2+1)*phi0+(n-n*exp(-2*lambda*Pi/(n*omega0)))*x0
mode := simplify(evalc(Re(evalc(subs(lambda = I*Omega, solve(subs(x0 = m*phi0, eqm1), m)))))^2+evalc(Im(evalc(subs(lambda = I*Omega, solve(subs(x0 = m*phi0, eqm1), m)))))^2)
-2*n^2*psi^2*v^2*(-1+cos(2*Omega*Pi/(n*omega0)))/(Omega^4-2*Omega^2*n*psi+2*Omega^2*n*psi*cos(2*Omega*Pi/(n*omega0))+2*n^2*psi^2-2*n^2*psi^2*cos(2*Omega*Pi/(n*omega0)))
A, b := GenerateMatrix([eqm1, eqm2], [x0, phi0])
A, b := Matrix(2, 2, {(1, 1) = lambda^2+n*psi-n*psi*exp(-2*lambda*Pi/(n*omega0)), (1, 2) = -n*psi*v+n*psi*v*exp(-2*lambda*Pi/(n*omega0)), (2, 1) = n-n*exp(-2*lambda*Pi/(n*omega0)), (2, 2) = -n*v+n*v*exp(-2*lambda*Pi/(n*omega0))+lambda^2+1}), Vector(2, {(1) = 0, (2) = 0})
with(RootFinding):
eq := subs(n = 6, psi = 1000, omega0 = 1.15, v = 0.1e-1, Determinant(A))
6000.94*lambda^2-5999.94*exp(-.289855072463768115942028985507*lambda*Pi)*lambda^2+lambda^4+6000-6000*exp(-.289855072463768115942028985507*lambda*Pi)
zeros := RootFinding:-Analytic(eq, lambda, re = 0 .. 400, im = -200 .. 200)
0.899769545162895563524511282265e-56, 0.813609592584011756247655681635e-1-20.6993361029378520006643410260*I, .242743338419727199544214811606-34.4961764258358768825593120288*I, .440964962950043888796944083291-100.074138054178692973033664525*I, .107710271188082726666762251538-106.954651646879437684160623413*I, 1.12290283496379505456476079030-62.0290638297730162295171014475*I, .879463466045683309032252293625-93.2168861049771086211729407830*I, 2.54860869821265794971735119535-80.1919866273564551209847942490*I, 1.52678990439144770439544731898-86.4450560720567958301493690195*I, 2.62945288424037545703549470125-75.0161229879790946191171617450*I, 1.68779005203728587549371003511-68.8012471850312399391042105550*I, .776570081405504740452992339900-55.1681878011205261920670466495*I, 0.851171007270465178285429398270e-9+1.00000500045406723708450960132*I, 0.851171007270465178285445699470e-9-1.00000500045406723708450960133*I, 0.874874719902730972066854301075e-2-6.89997772561385443312823760560*I, 0.354201863215292148351069041542e-1-13.7998152076043523748759861636*I, .369195444156713173497807954493-41.3921704506707022569621870947*I, .540047057129385026999638567235-48.2843908783769449582520027744*I, .149078330738225743331408017894-27.5982749361891156626731068484*I, .369195444156713173497807954500+41.3921704506707022569621870948*I, .440964962950043888796944083291+100.074138054178692973033664525*I, .107710271188082726666762251538+106.954651646879437684160623413*I, 1.12290283496379505456476079030+62.0290638297730162295171014475*I, .879463466045683309032252293625+93.2168861049771086211729407830*I, 2.54860869821265794971735119535+80.1919866273564551209847942490*I, 1.52678990439144770439544731898+86.4450560720567958301493690195*I, 2.62945288424037545703549470125+75.0161229879790946191171617450*I, 1.68779005203728587549371003511+68.8012471850312399391042105550*I, .776570081405504740452992339900+55.1681878011205261920670466495*I, 0.813609592584011756247655681660e-1+20.6993361029378520006643410260*I, 0.354201863215292148351069041261e-1+13.7998152076043523748759861634*I, 0.874874719902730972066854301075e-2+6.89997772561385443312823760560*I, .540047057129385026999638567235+48.2843908783769449582520027744*I, .242743338419727199544214811602+34.4961764258358768825593120288*I, .149078330738225743331408017894+27.5982749361891156626731068484*I
"zeros.select(int 1)"
Error, missing operation
Download question.mw
I will be really thankful for the help.
Sunit
I'm running into a very simple problem with the way that Maple integrates Heaviside functions. Naively, it should act like a step function, but it is not integrating properly. See the attached document.
int(int(Heaviside(-x^2-y^2+1), x = -1 .. 1), y = -1 .. 1)
evalf(Int(Heaviside(-x^2-y^2+1), [x = -1 .. 1, y = -1 .. 1]))
3.141592654
int(piecewise(-x^2-y^2+1 > 0, 1, 0), [x = -1 .. 1, y = -1 .. 1])
Pi
Note that the symbolic integration of the Heaviside function (defined to be 1 inside the unit circle and 0 outside) gives zero, whereas it should clearly give the area of the unit circle, which the numerical integration does. I even checked that the (suposedly equivalent) piecewise definition symbolically evaluates to the area, and it, too, gets the right answer.
Anyone have any clue as to why the symbolic integration of this Heaviside function is so wrong? My understanding is that if we do the integral as two nested 1D integrals, the returned function (as a function of y) is zero everywhere except at y=0, but that result cannot be right either.
Thoughts?
Download Heaviside-error.mw
I am trying to find the optimal routing probabilities in a Maple procedure where the Mean Value Analysis is used to compute the queueing values. The Maple code is below. It first tries to compute the visit ratios where the probability routing values are the decision variables. There is one specified constraint on the sum of the probability decision variables.
interface(warnlevel=0): interface(displayprecision = 4): with( plots ):
with(linalg):with( Optimization ); with(Student[NumericalAnalysis]):
[ImportMPS, Interactive, LPSolve, LSSolve, Maximize, Minimize,
NLPSolve, QPSolve]
f:=proc(x1,x2,x3)
global T,lambda,nq,u;
local i,j,pop,Sum;
n:=3;N:=2;M:=3;
# Gauss-Seidel iterations
A:=Matrix([[1,-x1,-x2],[0,1,-x3],[0,0,1]]);
b:= Vector([1,0,0]);
v := IterativeApproximate(LinearAlgebra:-Transpose(A), b, initialapprox = Vector([1, 3/4, 3/4]), tolerance = 10^(-3), maxiterations = 20, stoppingcriterion = relative(infinity), method = gaussseidel);
mu:=array(1..n,[2.0,1.0,1.0]);
nq:=array(1..M,[0,0,0]);# must initialize queue lengths
for i from 1 to N do
pop:=i;
for j from 1 to M do # mean waiting times
T[j]:=t[j]*(1 + nq[j]) od;
Sum := 0.0;
for j from 1 to M do # mean cycle time
Sum := Sum + v[j]*T[j] od;
for j from 1 to M do #compute the throughputs
lambda[j] := (v[j]*pop)/Sum od;
for j from 1 to M do #compute the queue lengths
nq[j]:= lambda[j]*T[j] od;
for j from 1 to M do #compute the utilizations
u[j]:= lambda[j]*t[j] od;
od;
RETURN(lambda[1]);
proc(x1, x2, x3) ... end;
sol := Optimization:-NLPSolve(f, {}, {proc (x1, x2, x3) options operator, arrow; x1+x2+x3-5/3 end proc}, 0 .. 1, 0 .. 1, 0 .. 1, initialpoint = [.75, .25, .6667], assume = nonnegative); 1;
Error, (in Optimization:-NLPSolve) non-numeric result encountered
I am not sure why I get the error message
I was trying to call a C shared library which calls a Python function. I got the following error:
Error, external linking: error loading external library
/directory/of/my/library/libbe.so: libpython2.7.so.1.0: cannot open shared object
file: No such file or directory
Since I was running this using a pbs file, I made sure that I exported LD_LIBRARY_PATH (to libpython.so) inside the specific node. Does anyone have ideas on why this happens? Thank you!
Hello people in mapleprimes,
I have a question. I hope someone give an answer to me.
rho:=sqrt((x-a)^2+(y-b)^2);
limit(x-a+y-2,rho=0);
brings an error
Error, invalid input: limit expects its 2nd argument, p, to be of type Or(name = algebraic, set(name = algebraic)), but received ((x-a)^2+(y-b)^2)^(1/2) = 0
Isn't other way than the following?
limit(x-a+y-2,{x=a,y=b});
Best wishes.
taro
I am working in Document mode, 2D input.  I have doing some complex number evalutions
Lets say I have a complex number Z= 2+3i
when I ask maple for the "abs(Z)" I get the display of "abs(2+3i)" rather than the numberic answer. This occurs with all the complex operation arg, abs, polar conversion,
polar(abs(2+3*i), argument(2+3*i))   this is from Maple.
How do I display the numeric value for these functions in my document
Thanks Bill
I've got a load of data that contains a lot of noise in the form of sinusoidal interference patterns. This is quite thick and it disturbes what I am trying to look at. I've uploaded a picture to represent what I am trying to show. I know I need a cut-off frequency I just don't know how to implement it. Thank you in advance for your help!
Gambia Man
In maple18 has:
with(Student[Basics][ExpandSteps])
but how to see step-by-step factor ??
(Sorry! I'm not very good at English.)
Dear Community,
I've made a nonlinear curve fit with the Minimize routine (see attachment). What would be an easy and elegant way to rerun the model (Model) with the fitted values of a, b, c and plot the result together with the measured points in the same chart? I'm stuck here.
Tx in advance,
best regards
Andras
BroSzem_Data.xlsx
Nonlin_Curve_Fit.mw
Hey there,
I am using the fsolve command in order to solve numerically a system of equations with N equations and N unknowns. According to my discretization the number of equations changes. If I have a small number of equations it all works out perfectly. But if I increase the number of equations I just get something like that:
Sorry, for the long post, but for a small number of unknowns Ai it works. It seems that maple doesnt try to compute? Has anyone encountered the same problems?
Any help is appreciated.
Jens
Greetings to all. The title describes it well, I am writing about testing the limits of the Maple integration engine. A recent discussion at math.stackexchange.com features a family of integrals that involve the product of a power of the natural logarithm and a rational function, more precisely,
int((log(x))^n/(x^3+1), x=0..infinity);
These integrals can be evaluated recursively as described at the MSE link using a technique that generalizes to other types of rational factors. Unfortunately Maple apparently only finds a simple closed form for a few small initial values of n. The following transcript of a Maple session illustrates the problem. Mathematica was successful here. Also observe the memory allocation in the Maple session.
    |\^/|     Maple 18 (X86 64 LINUX)
._|\|   |/|_. Copyright (c) Maplesoft, a division of Waterloo Maple Inc. 2014
 \  MAPLE  /  All rights reserved. Maple is a trademark of
 <____ ____>  Waterloo Maple Inc.
      |       Type ? for help.
> restart; read `cl.maple`;
alpha := (n, k) ->
                                                           n
    -1/3 exp(1/3 I Pi + 2/3 I Pi k) (1/3 I Pi + 2/3 I Pi k)
Q := proc(n)
local res;
option remember;
    if n = 0 then return 2/9*sqrt(3)*Pi end if;
    res := -add(alpha(n + 1, k), k = 0 .. 2)/(n + 1) - add(
        binomial(n + 1, p)*(2*I*Pi)^(n - p)*Q(p),
        p = 0 .. n - 1)/(n + 1);
    simplify(res)
end proc
                               infinity
                              /               n
                             |          log(x)
              VERIF := n ->  |          ------- dx
                             |           3
                            /           x  + 1
> Q(6);
                                7  1/2
                          910 Pi  3
                              6561
> VERIF(6);
memory used=3.8MB, alloc=40.3MB, time=0.18
       7  1/2
9890 Pi  3       490    5  1/2
------------- + ----- Pi  3    Psi(1, 1/3)
   177147       19683
        490    5  1/2                10    3  1/2            2
     + ----- Pi  3    Psi(1, 2/3) + ---- Pi  3    Psi(1, 1/3)
       19683                        2187
        20   1/2   3
     + ---- 3    Pi  Psi(1, 2/3) Psi(1, 1/3)
       2187
        10    3  1/2            2    40                 4
     + ---- Pi  3    Psi(1, 2/3)  + ----- Psi(2, 2/3) Pi
       2187                         19683
        10   1/2               3
     + ---- 3    Pi Psi(1, 1/3)
       2187
       10               1/2               2
     + --- Psi(1, 2/3) 3    Pi Psi(1, 1/3)
       729
       10   1/2                           2
     + --- 3    Pi Psi(1, 1/3) Psi(1, 2/3)
       729
        10   1/2               3    40     4
     + ---- 3    Pi Psi(1, 2/3)  - ----- Pi  Psi(2, 1/3)
       2187                        19683
        20             2  1/2
     + ---- Psi(2, 2/3)  3    Pi
       6561
        40               1/2
     - ---- Psi(2, 2/3) 3    Psi(2, 1/3) Pi
       6561
        40    2
     + ---- Pi  Psi(2, 2/3) Psi(1, 1/3)
       2187
        40    2
     + ---- Pi  Psi(2, 2/3) Psi(1, 2/3)
       2187
        20   1/2            2
     + ---- 3    Psi(2, 1/3)  Pi
       6561
        40    2
     - ---- Pi  Psi(1, 1/3) Psi(2, 1/3)
       2187
        40    2
     - ---- Pi  Psi(1, 2/3) Psi(2, 1/3)
       2187
> evalf(Q(6));
                          725.5729634
> evalf(VERIF(6));
                          725.5729630
> quit
memory used=22.4MB, alloc=44.3MB, time=0.47
user@host:~/complex-logint$ math
Mathematica 10.0 for Linux x86 (64-bit)
Copyright 1988-2014 Wolfram Research, Inc.
In[1]:= Integrate[Log[z]^6/(1+z^3), {z, 0, Infinity}]
                7
          910 Pi
Out[1]= ------------
        2187 Sqrt[3]
In[2]:= N[Out[1]]
Out[2]= 725.573
In[3]:=
My question for you all is what the appropriate techniques would be to get Maple to at least simplify the rather involved output from the integration engine to obtain a match of the closed form from the recursive equation.
Best regards, Marko Riedel.
cl-maple.txt
Below z is made using different complex values on polar form, and I then need to express the resulting z on polar form with numeric values for length and angle.  However, I had no luck using evalc, evalf, or other I could find.
How can I convert z to a polar form with numeric arguments like shown below ?
Hi everybody,
I would like to define a function with random values to be used in pdsolve (numeric) as a initial condition.
Any help?
Javier
Trying to solve this IVP of the SHO  (second order linear costant-coefficient).
Everything works fine until I come to the solving even after using dsolve with initial conditions (even using the differential operator D in the initial conditions)  , the answer still contains _C1, an unknown constant.
The full worksheet is below.  The code for dsolve is:
sol3 := dsolve(subs(par1, {de1, D(x)*0 = 0, x(0) = 1}), x(t));
Hoping you can help with a solution.
Hi guys.
           if an expression complicated as the following,
sqrt(sqrt(9)*sqrt((1+(b+1)^2*c^2+((10/3)*b-2)*c)*(1+(b+1)^2*c^2+(2*b-2)*c))+3+(3*b^2+6*b+3)*c^2+(8*b-6)*c) , where b>0 c>0
is it possible to tell whether it could be positive?
I used coulditbe command, however, it returned 'FAIL'.
First 1132 1133 1134 1135 1136 1137 1138 Last Page 1134 of 2463
