I have checked many Maple pages and I found nowhere the answer to this question.
EQ:= s^2-4*s+1=3;
I need to print the following statement:
The Equation Is: EQ
I need the equation to appear where EQ is.
Thank you guys!
I appreciate it.
I have the following problem : plotting with the squareroot function somehow stops showing the whole graph as soon as the range of the input allows values less than -10, I have attached two pictures that show the transition:
This is still fine:
But here is an example where the graph is cropped:
How can I change this to get the whole graph ? Thanks a lot for your help !!
Is there a Maple function that given a set of substitutions in form object=set of substitute objects produces a sequence of sets, each a product of substitution from the next, remove repetitions. An example:
#Substitutions
a = {b, c, d}, b = {a, b, e}, c = {a, d, f};
#Result
a = ({e, f}, {b, c, d}), b = ({f}, {c, d}, {a, b, e}), c = ({e}, {b}, {a, d, f});
Hi I'm not really sure how to phrase this but I'm doing projectile motion and I'm try to graph the solutions for v_0 by theta_0.
hi .why matrix a dont create?
bot.mw
psi := (1/4)*(1-Zeta)^2*(2+Zeta), (1/4)*(1-Zeta)^2*(Zeta+1), (1/4)*(Zeta+1)^2*(2+Zeta), (1/4)*(Zeta+1)^2*(Zeta-1)
psi[1]
for i to 4 do for j to 4 do a[i, g] = 2*psi[i]*psi[j] end do end do
a
a
`a__1,1`
`a__1,1`
Download bot.mw
I want to solve system of non linear odes numerically.
I encounter following error
Error, (in dsolve/numeric/bvp) cannot determine a suitable initial profile, please specify an approximate initial solution
how to correct it
regards
In workbook mode I use the Insert>>Paragaph>>Before Cursor to create a text block. I just want to type text into this block by way of comments on what preceded/follows. However, when I type parentheses or <> of (I expect) other stuff that Maple recognises as being parts of mathematical expressions Maple switches to italic and bold and starts generally interefering with my text. In the case of my title I get the result in the picture below. Is there any way to stop Maple doing this so I can type text?
How I can solve it ? If I want a solution dependent of a. With fsolve? But how?
-x3+ax2-lnx=0
I'm working in a project where I use the Java Open Maple library. I need to evaluate a procedure but with a very large number. In the function engine.newNumeric() the only large option is a long which is not enough for me. I use Java BigInteger class to represent my very large numbers. Any suggestions that might help is very welcomed!
I am trying to write a procedure that implements Karmarkar's algorithm for solving linear programming problems.
I am getting a parsing error and I am not sure why. Each of the command in the procedure are working the way I want them to but there is something wrong with the loop controls. The code is attached below:
with(LinearAlgebra);
print(??); # input placeholder
Karmarkar:= proc(A,c)
     n:=ColumnDimension(A);
     x:=ZeroVector(n);
     y:=Vector(n,1/(n));
     r:=1/(sqrt(n*(n-1)));
     for i from 1 to nops(NullSpace(A))do
          x:=x+NullSpace(A)[i];
     C:=1.0;
     while C>0.0001 do ;
          Diag := DiagonalMatrix(x/Norm(x, 1));
          B := `<,>`(A.Diag, Vector[row](n, 1));
          p := (IdentityMatrix(n)-Transpose(B).MatrixInverse(B.Transpose(B)).B).Transpose(c.Diag);
          p:=evalf(p/(Norm(p,2)));
          y:=y-0.9*r*p;
          x_new:=evalf((Diag . y)/((Vector[row](n,1) . (Diag . y))));
          C:=evalf((c . x_new-c . x)/(c . x));
          if C>0.0001 then
               x_new:=x;
Any ideas on how to fix this?
I'm trying to solve a system of two differential equations of the second order in Maple. I set it up as a system of four differential equations of the first order, but after calling for the solution, all I get back is what I entered in without receiving a solution of any sort. What do I need to fix?
Here's what I did:
_________________________________________________
> with(plots);
> m := 0.46e-1; d := 0.42e-1; v := 60; alpha0 := 12; g := 9.81; pa := 1.205; cd := .2; n := 100; omega := 2*Pi*(1/60);
> p := 6*m/(Pi*d^3);
> k1 := (3/4)*cd*pa/(d*p); k2 := (3/8)*omega*pa/p;
> gl1 := vx(t) = diff(x(t), t);
> gl2 := vy(t) = diff(y(t), t);
> gl3 := diff(vx(t), t) = -k1*vx(t)*(vx(t)^2+vy(t)^2)^(1/2)-k2*vy(t);
> gl4 := diff(vy(t), t) = -g-k1*vy(t)*(vx(t)^2+vy(t)^2)^(1/2)+k2*vy(t);
> init1 := x(0) = 0;
> init2 := y(0) = 0;
> init3 := vx(0) = v*cos((1/15)*Pi);
> init4 := vy(0) = v*sin((1/15)*Pi);
> sol; dsolve({gl1, gl2, gl3, gl4, init1, init2, init3, init4}, {vx(t), vy(t), x(t), y(t)}, type = numeric);
> sol(.1);
                            sol(0.1)
> odeplot(sol, t, x(t), t, y(t), t = 0 .. 1);
____________________________________________________________________________
After calling for the solution at t=0.1, I don't get anything back. I also tried plotting the solution, but then I receive an error message.
I have downloaded and trying to run the application "Traveling Salesman Problem" by Bruno Guerrieri:
http://www.maplesoft.com/applications/view.aspx?SID=6873
However, the animations do not work properly. Instead of the animations, I get series of sets of plots. Each such set consists of four plots: one with a green edge, one with a blue edge, one with blue edges, and one with points (nodes).
I guess, it happens because of a new version of maple: the application was created in 2008 for Maple 12, and I use Maple 2015.
Could anybody, please, tell me what exactly should I change in the code so that it will work properly?
Any help will be very much appreciated.
Many thanks in advance!
Hi All,
I'm trying to numerically solve a differential equation which has a numeric function in it.
For example, consider the function f.
f:=(r)-> evalf(Int( <some messy function>, <some range>)) ;  <- This can be solved numerically and returns an answer quickly. i.e
f(23) gives 102;
Now, I want to numericaly solve something like.
Eq:= diff(p(r),r,r) + diff(p(r),r) - f(p(r));
ICS:=D(p)(0.001)=0, p(0.001) = 3
dsolve({Eq,ICS},numeric).
dsolve will not attempt to solve it due to the numeric integration in f. Is there a way I can just use numeric techniques to solve this kind of problem?
Is it possible to view maple workbook content in older versions?
This is for the infamous Calc 2 Goblet Maple Project
I have tried everything changed all the numbers and got nowhere or worse results. The only thing that accurately works is the example project:
(0, 1.5) and end at (0.5, 0.2). which equals f1(x)=-2.6x+1.5
and f2:=x->0.2+0.05*sin(2*(x-0.5)) which is really 0.2+0.05sin(2x-1)
The goal is to change the example project so it becomes something of my own creation.
When I change f2:=x->0.4+0.05*sin(2*x-0.5)) it is at least attached but forms a sharp dip down first then connects at the point when it should be smooth curve. It seems you can do anything to the other curve
f3:=x->a*x^3+b*x^2+c*x+d;
x -> a x^3 + b x^2 + c x + d
connection1:=f3(5.5)=f2(5.5);
166.375 a + 30.25 b + 5.5 c + d = 0.3727989445
arc1:=f3(7)=1;
343 a + 49 b + 7 c + d = 1
arc2:=f3(7.5)=0.9;
421.875 a + 56.25 b + 7.5 c + d = 0.9
arc3:=f3(9)=1.6;
729 a + 81 b + 9 c + d = 1.6
values:=solve({eq1,eq2,eq3,eq4},{a,b,c,d});
F:=x->piecewise(x<0.5,f1(x),x>=0.5 and x<5.5,f2(x),x>=5.5,f3(x));
plot(F(x),x=0..9,y=0..4,scaling=constrained);
So how can this be fixed?
First 1170 1171 1172 1173 1174 1175 1176 Last Page 1172 of 2463
