I am creating a plot but the numbers on the horizontal axis overlap.  Is there a way to change the directions of the numbers displayed under the horizontal axis (tickmark labels) from horizontal to vertical?
The picture below shows how the numbers are bunched together under the horizontal axis.  I'd like them to be displayed vertical
1. Take a group for example. First we can set up a group G by
G:=<<a,b>|<a2=1,b3=1,(a.b)2=1>>. Actually,G=S3. So how to simplify a long production,
such as "a.b.b.a.b.b.a.b"?
2. How to define a finitely presented algebra over some field, such as the enveloping algebra
or quantum group of a Lie algebra? And moreover how to do the similar computation about
simplifying a long production?
Anyone could help me in solving the following system of equations to get constants C1, C2, C3 and C4. MALPE give me this "soution may have been lost".  The MAPLE sheet is also attached.
Eq1:=simplify(C3*exp(-(1/4)*(C2*(x^2-2*0)+sqrt(C2*(x^2-2*0)^2+4*M*(x^2-2*0)*w1*(x^2-2*0)))/w1)+C4*exp((1/4)*(-C2*(x^2-2*0)+sqrt(C2*(x^2-2*0)^2+4*M*(x^2-2*0)*w1*(x^2-2*0)))/w1)-U) = 0;
C3*exp(-(1/4)*(C2*x^2+(x^4*(4*M*w1+C2))^(1/2))/w1)+C4*exp(-(1/4)*(C2*x^2-(x^4*(4*M*w1+C2))^(1/2))/w1)-U = 0
Eq2:=simplify(exp(-(1/4)*(C2+sqrt(C2^2+4*M*w1))*(x^2-2*0)/w1)*C3*x+exp((1/4)*(-C2+sqrt(C2^2+4*M*w1))*(x^2-2*0)/w1)*C4*x+C2-V-z) = 0;
exp(-(1/4)*(C2+(C2^2+4*M*w1)^(1/2))*x^2/w1)*C3*x+exp(-(1/4)*(C2-(C2^2+4*M*w1)^(1/2))*x^2/w1)*C4*x+C2-V-z = 0
Eq3:=simplify((-2*w2*w5*ln(C3*exp(-(1/2)*sqrt(w2*w4*(w2*w4+w3*w6))*C2*(x^2-2*0)/(w2*w4*w5))-C4)*sqrt(w2*w4*(w2*w4+w3*w6))+w2*w5*(-w2*w4+sqrt(w2*w4*(w2*w4+w3*w6)))*ln(exp(-(1/2)*sqrt(w2*w4*(w2*w4+w3*w6))*C2*(x^2-2*0)/(w2*w4*w5)))+C1*w3*w6*sqrt(w2*w4*(w2*w4+w3*w6)))/(sqrt(w2*w4*(w2*w4+w3*w6))*w3*w6)-1)= 0;
(-ln(exp(-(1/2)*(w2*w4*(w2*w4+w3*w6))^(1/2)*C2*x^2/(w2*w4*w5)))*w2^2*w4*w5+C1*w3*w6*(w2*w4*(w2*w4+w3*w6))^(1/2)-2*w2*w5*ln(C3*exp(-(1/2)*(w2*w4*(w2*w4+w3*w6))^(1/2)*C2*x^2/(w2*w4*w5))-C4)*(w2*w4*(w2*w4+w3*w6))^(1/2)+ln(exp(-(1/2)*(w2*w4*(w2*w4+w3*w6))^(1/2)*C2*x^2/(w2*w4*w5)))*(w2*w4*(w2*w4+w3*w6))^(1/2)*w2*w5-(w2*w4*(w2*w4+w3*w6))^(1/2)*w3*w6)/((w2*w4*(w2*w4+w3*w6))^(1/2)*w3*w6) = 0
Eq4:= simplify((-C2*x^2*w2*w4-.50*C2*x^2*w3*w6+sqrt(w2*w4*(w2*w4+w3*w6))*C2*x^2+2.*w2*w4*w5*ln(w3^4*w6^2*(C3^2*exp(-1.0*sqrt(w2*w4*(w2*w4+w3*w6))*C2*x^2/(w2*w4*w5))-2*C3*exp(-.5*sqrt(w2^2*w4^2+w2*w3*w4*w6)*C2*x^2/(w2*w4*w5))*C4+C4^2)/(w2*w4*(w2*w4+w3*w6)*C2^2))-5.544000000*w2*w4*w5-w3^2*w6)/(w3^2*w6)) = 0;
(-C2*x^2*w2*w4-.5000000000*C2*x^2*w3*w6+(w2*w4*(w2*w4+w3*w6))^(1/2)*C2*x^2+2.*w2*w4*w5*ln(w3^4*w6^2*(C3^2*exp(-(w2*w4*(w2*w4+w3*w6))^(1/2)*C2*x^2/(w2*w4*w5))-2.*C3*exp(-.5*(w2*w4*(w2*w4+w3*w6))^(1/2)*C2*x^2/(w2*w4*w5))*C4+C4^2)/(w2*w4*(w2*w4+w3*w6)*C2^2))-5.544000000*w2*w4*w5-w3^2*w6)/(w3^2*w6) = 0
solve({Eq1, Eq2, Eq3,Eq4}, {C1, C2, C3,C4});
Download solution_lost.mw
I have this system
> system1D := H = alpha*gamma[2, 2]*d[2, 1]-beta*d[1, 2]*gamma[1, 2]^2-gamma*d[1, 2]*gamma[2, 1]^2+alpha*gamma[2, 2]^2*d[2, 2]-beta*d[2, 2]*gamma[2, 2]^2-gamma*d[2, 2]*gamma[2, 2]^2, E = alpha*gamma[2, 1]*d[1, 1]-beta*d[1, 2]*gamma[1, 1]-gamma*d[1, 1]*gamma[2, 1]+alpha*gamma[2, 1]^2*d[1, 2]-beta*d[2, 2]*gamma[2, 1]-gamma*d[2, 1]*gamma[2, 2], B = alpha*gamma[1, 1]*d[2, 1]-beta*d[1, 1]*gamma[1, 1]^2-gamma*d[1, 1]*gamma[1, 1]^2+alpha*gamma[1, 1]^2*d[2, 2]-beta*d[2, 1]*gamma[2, 1]^2-gamma*d[2, 1]*gamma[1, 2]^2, D = alpha*gamma[1, 2]*d[2, 1]-beta*d[1, 1]*gamma[1, 2]^2-gamma*d[1, 2]*gamma[1, 1]^2+alpha*gamma[1, 2]^2*d[2, 2]-beta*d[2, 1]*gamma[2, 2]^2-gamma*d[2, 2]*gamma[1, 2]^2, A = alpha*gamma[1, 1]*d[1, 1]-beta*d[1, 1]*gamma[1, 1]-gamma*d[1, 1]*gamma[1, 1]+alpha*gamma[1, 1]^2*d[1, 2]-beta*d[2, 1]*gamma[2, 1]-gamma*d[2, 1]*gamma[1, 2], C = alpha*gamma[1, 2]*d[1, 1]-beta*d[1, 1]*gamma[1, 2]-gamma*d[1, 2]*gamma[1, 1]+alpha*gamma[1, 2]^2*d[1, 2]-beta*d[2, 1]*gamma[2, 2]-gamma*d[2, 2]*gamma[1, 2], F = alpha*gamma[2, 1]*d[2, 1]-beta*d[1, 2]*gamma[1, 1]^2-gamma*d[1, 1]*gamma[2, 1]^2+alpha*gamma[2, 1]^2*d[2, 2]-beta*d[2, 2]*gamma[2, 1]^2-gamma*d[2, 1]*gamma[2, 2]^2, G = alpha*gamma[2, 2]*d[1, 1]-beta*d[1, 2]*gamma[1, 2]-gamma*d[1, 2]*gamma[2, 1]+alpha*gamma[2, 2]^2*d[1, 2]-beta*d[2, 2]*gamma[2, 2]-gamma*d[2, 2]*gamma[2, 2], H = alpha*delta[2, 2]*d[2, 1]-beta*d[1, 2]*delta[1, 2]^2-gamma*d[1, 2]*delta[2, 1]^2+alpha*delta[2, 2]^2*d[2, 2]-beta*d[2, 2]*delta[2, 2]^2-gamma*d[2, 2]*delta[2, 2]^2, E = alpha*delta[2, 1]*d[1, 1]-beta*d[1, 2]*delta[1, 1]-gamma*d[1, 1]*delta[2, 1]+alpha*delta[2, 1]^2*d[1, 2]-beta*d[2, 2]*delta[2, 1]-gamma*d[2, 1]*delta[2, 2], B = alpha*delta[1, 1]*d[2, 1]-beta*d[1, 1]*delta[1, 1]^2-gamma*d[1, 1]*delta[1, 1]^2+alpha*delta[1, 1]^2*d[2, 2]-beta*d[2, 1]*delta[2, 1]^2-gamma*d[2, 1]*delta[1, 2]^2, D = alpha*delta[1, 2]*d[2, 1]-beta*d[1, 1]*delta[1, 2]^2-gamma*d[1, 2]*delta[1, 1]^2+alpha*delta[1, 2]^2*d[2, 2]-beta*d[2, 1]*delta[2, 2]^2-gamma*d[2, 2]*delta[1, 2]^2, A = alpha*delta[1, 1]*d[1, 1]-beta*d[1, 1]*delta[1, 1]-gamma*d[1, 1]*delta[1, 1]+alpha*delta[1, 1]^2*d[1, 2]-beta*d[2, 1]*delta[2, 1]-gamma*d[2, 1]*delta[1, 2], C = alpha*delta[1, 2]*d[1, 1]-beta*d[1, 1]*delta[1, 2]-gamma*d[1, 2]*delta[1, 1]+alpha*delta[1, 2]^2*d[1, 2]-beta*d[2, 1]*delta[2, 2]-gamma*d[2, 2]*delta[1, 2], F = alpha*delta[2, 1]*d[2, 1]-beta*d[1, 2]*delta[1, 1]^2-gamma*d[1, 1]*delta[2, 1]^2+alpha*delta[2, 1]^2*d[2, 2]-beta*d[2, 2]*delta[2, 1]^2-gamma*d[2, 1]*delta[2, 2]^2, G = alpha*delta[2, 2]*d[1, 1]-beta*d[1, 2]*delta[1, 2]-gamma*d[1, 2]*delta[2, 1]+alpha*delta[2, 2]^2*d[1, 2]-beta*d[2, 2]*delta[2, 2]-gamma*d[2, 2]*delta[2, 2];
> subs({A = 0, B = 0, C = 0, D = 0, E = 0, F = 0, G = 0, H = 0, delta[1, 1] = 1, delta[1, 2] = 0, delta[2, 1] = 0, delta[2, 2] = 0, gamma[1, 1] = 1, gamma[1, 2] = 0, gamma[2, 1] = 0, gamma[2, 2] = 0, delta[1, 1]^2 = 0, delta[1, 2]^2 = 0, delta[2, 1]^2 = 1, delta[2, 2]^2 = 0, gamma[1, 1]^2 = 0, gamma[1, 2]^2 = 1, gamma[2, 1]^2 = 0, gamma[2, 2]^2 = 0}, {system1D});
The problem is: there is any simple way to use command "subs" when some expression such that delta[1,1]=1, gamma[1,1]=1, gamma[1,2]^2=1 have value and others are zero.
Can someone please advice and help me on this?
witribm
Hello to you all,
I have this DE
but when I try to change the variable
I get this
>algsubs(r(t) = 1/u(t), diff(diff(r(t), t), t)-k/r(t) = -K/r(t)^2);
Why is it not done for the rest of the terms.  Is there a more easy way to do it.  Take into account that I cannot use dsolve because it is in an course in integral.
Thank in advance for your help.
Mario Lemelin
Maple 2015 Ubuntu 14.04 - 64 bits
Maple 2015 Win 10 Pro - 64 bits messagerie : mario.lemelin@cgocable.ca téléphone :  (819) 376-0987
Does anyone know an easy way to convert %d_ to D? I tried the convert command, but no effect.  Thanks.
Michael
For my lecture advanced dynamics, I got the question to make a sketch of the coordinate system and the particle’s motion, with the following position vector:
r(t) = (a cos(ωt))i + (b sin(ωt))j + (ct)k
In this function, ω is in [rad/s], a and b are in [m], t in [s] and c is [m/s].
I have no idea what this should look like, and I was thinking about plotting this with Maple, but thus far I'm not succeeding in plotting it. Which function or method can I use to visualize this in Maple?
Thanks a lot!
I have this system
> system2hD := 0 = -d[1, 2], 0 = -d[2, 1], 0 = -delta*d[1, 2], 0 = -d[1, 1]-delta*d[1, 1], 0 = -delta*d[1, 1]-d[2, 2];
> solve({system2hD, delta <> 0, delta <> 1}, {d[1, 1], d[1, 2], d[2, 1], d[2, 2]});
      {d[1, 1] = 0, d[1, 2] = 0, d[2, 1] = 0, d[2, 2] = 0}
But, I hope to get the answers as {d[1, 1] = -delta*d[1, 1], d[1, 2] = 0, d[2, 1] = 0, d[2, 2] = -delta*d[1, 1]}. I think, I should not use the command "solve".
Can someone please advice and hepl me on this?
witribm
Hello all,
Yesterday, I upgraded to Mac OS X El Capitan.
Now, when working with Maple 2015, I feel the gui is very slow and sometimes irresponsive, when trying to scroll through my worksheets as well as through help pages (e.g., "help plot3d"). When I do the same within Maple 18, it works without any problems.
Does anybody else have the same issue?
Cheers,
Franky
Below is a calculation with 200 Volt and 100 Ω.
The output is 1 Ampere at -45 degrees.
This is useful for electrical circuit calculations, and I can get the right result on a TI-nspire.
However I can't make maple 2015 do it. It's resembling polar coordinates but I can't seem to find any info I can understand.
"((200&angle;0&deg;))/((100&angle;45&deg;)+(100&angle;45&deg;))=\
1&angle;-45&deg;"
below is the same equation but in a picture so it can be read by humans:
http://imgur.com/3i2Su0B
Hopefully theres some simple comands that can help make this easy.
For example, I have a commutation table of finite Lie algebra. I'd like to extract some information from it (mainly, I'm interested in maximal dimension of abelian Lie subalgebra).
if eval(simplify( subs(a=2,subs(b= 5,f))))) - n = 0 then
      hello := union(hello, {f})
end if:
after subs(a=2,subs(b= 5,f))) to verify , some of hello return -n
negative
why it is possible to pass the if condition statement?
if it is normal case, how to write correct if statement to ensure no -n
I want to plot a cone in 3-d for any given axis vecttor, center and eccentricity.
Hello everybody
In the following attached file, I have used "fnormal" command to omit small numbers that are less than "1e-6" but when I run the maple, I see the numbers such as 2.10^(-11). What's the problem?
Lin1.mw
I'm currently taking a Chaos and Fractal Geometry class that did not have a pre-req of computer programming or knowledge of Maple, but I am apparently the only person in the class who has not taken a class/does not have this knowledge so my professor really flew by teaching the material. My sob story aside, I was hoping you great people would be able to help me out with (what are apparently) really basic procedures and plots while I try to read up on how to actaully do it myself (if anyone has a good supplement to recommend, I'm all ears!). Anyway, here are the one's that I'm stumped on:
  • "Write a Maple proc L that takes as input two lists and returns as output a set containing the terms they have in common (not necessarily in the same position). For example, L([1, 3, x, 5],[2, x, 5, 2, 1, 8]) should return [1, x, 5]."
    I'm thinking this is going to use some form of the intersection command, but I cannot for the life of me figure out how to set up the syntax
  • "Write a Maple program that implements the Euclidean algorithm to compute the gcd(x, y) for any natural numbers x, y (except x = y = 0). Your program should not just compute the gcd, but should do so by implementing the Euclidean algorithm directly (i.e. proc(x,y) RETURN(gcd(x,y)) end; is not what I am looking for here! :) )."
    If only he would've let me do the easy one :(
  • "Write a Maple program to plot the Pythagorean spiral. The program should take a single positive integer n as an argument and plot the spiral until the side of length n is reached"
    Not even a clue on how to approach this one.
Thanks again to any and all help/recommendations you can make. I really appreciate it!
First 1258 1259 1260 1261 1262 1263 1264 Last Page 1260 of 2464
