As you can see, could you know how many columns of matrix ee has?
It is not easy.
The true column number is 7.
Is there a good method to sperate differetn columns apart? for example, use comma
 I am using a very basic function in Statistics package as below and get error.
X := RandomVariable(Normal(a, b));
I was having trouble importing an excel sheet
with(ExcelTools):
a:=Import("c:/inquire.xls","test1a.tabs","A2:B50")
  Error, (in ExcelTools:-Import) There was an error reading the Excel file
The excel sheet only had one tab visible named test1a.tabs
However it loaded fine without the range and sheetname specified
      a:=Import("c:/inquire.xls")
and it loaded fine using the sheet name as a number
     b:=Import("c:/inquire.xls",1,"A2:B50")
I was wondering if anyone else experienced this or if I was doing something wrong someone could point out.
I find fsolve() to be curiously unstable. Some of the behaviour I can guess at, but other parts are not as clear.
Define a function.
P := x->fsolve(exp(-(1/100)*t^2)*cos(2*t),t=x):
plot(P,4..5,smartview=false);
I'm begginer in maple so I have many questions
I have
f1 := [x2^3-3*x1+x2, -x2-x3+u, x2-2*x3]
I want to put
x1=2*x1
x2=2*x2
x3=5*x3
and I wand it in loop
for x4,...xn
so that f1 will be a vector
I set up a worksheet with embedded components in Maple 18. I am now trying to use the worksheet with Maple 2015. The GetProperty( ) procedure in DocumentTools cannot find a number of kinds of the embedded components (perhaps all kinds).
Why would this happen, and how can I fix it?
guys, i have a tensorial expression which i want to compute it, but i have some problem tensor.mw
thanks in advance
   Hi there,
   How can we pl0t the volume or surface of revolution of cardioid r=1-cos(\theta) about  polar axis or the vertical axis in maple14.
 Any help will be appreciated.
M.R.Yegan
The member function can provide the position of x in table/list s for the first variable
e.g.
f:=[a,b,c,a,a];
member(a,f,'p');
will provide p=1
If I would like to know the position of all a, [1,4,5], is there any simple way to obtain them? I can do something like
n:=0;
for i from 1 to 5 do
 if f[i]='a' then
  n:=n+1;
  p[n]:=i;
something like that
Thank you very much
I have s := [[x[1] = 0, x[2] = 0, x[3] = 0]]
when I use s in
J1 := eval(Ja, s)
This message appear
Error, invalid input: eval expects its 2nd argument, eqns, to be of type {integer, equation, set(equation)}, but received s
 But When I wrote
J1 := eval(Ja, [x[1] = 0, x[2] = 0, x[3] = 0]), it runs well
I need the solution for first one since s created automaticly
what should I do?
I have a problem with MAPLE. I would like to solve a system of 18 inequalities with 4 variables. The variables shall be rational numbers. I should also mention that I am not sure if the system has a solution. Here is my MAPLE code:
LinearMultivariateSystem({0 < (1/20)*b11, 0 < (1/20)*b1818, 0 < (1/20)*b22, 0 < (1/20)*b33, 0 < -653385574770525739/313841848320000+(1001/20)*b33+(3003/5)*b22+4004*b11-(91/5)*b1818, 0 < -476383516463665673/69742632960000+(3003/20)*b33-(1001/10)*b1818+(27027/2)*b11+(3861/2)*b22, 0 < -372810037848242383/52306974720000+(72072/5)*b11+(3003/20)*b33-(858/5)*b1818+2002*b22, 0 < -302968656462848461/125536739328000+(1001/20)*b33-(1001/10)*b1818+5005*b11+(1365/2)*b22, 0 < -94060277895192911/627683696640000+(91/20)*b33+273*b11-(7/10)*b1818+(91/2)*b22, 0 < -3219528868317343/14944849920000+468*b11+(91/20)*b33-(91/5)*b1818+63*b22, 0 < -1167616840098623/627683696640000+(7/10)*b22+(1/20)*b33+(21/4)*b11-(7/10)*b1818, 0 < 6620337745005653/9510359040000+(91/20)*b1818-(91/5)*b33-(6552/5)*b11-(819/4)*b22, 0 < 10321214321183681/627683696640000-(21/4)*b22-(7/10)*b33-28*b11+(1/20)*b1818, 0 < 19939504442621873/627683696640000-(7/10)*b33-(39/4)*b22-(364/5)*b11+(91/20)*b1818, 0 < 21128314477665001/24141680640000-(91/5)*b33-1848*b11+(1001/20)*b1818-(1001/4)*b22, 0 < 30458564958023749/6340239360000-(1001/10)*b33+(3003/20)*b1818-9828*b11-(27027/20)*b22, 0 < 78768022311702133/17933819904000-(1001/10)*b33-8580*b11+(1001/20)*b1818-(5005/4)*b22, 0 < 418747163878248241/52306974720000-(858/5)*b33+(3003/20)*b1818-16016*b11-(9009/4)*b22}, [b11, b22, b33, b1818])
I am sorry for the writing style but I do not know how to write the command in MAPLE-style in this forum:-)
The first 4 inequalities shall ensure that all four variables b11, b22, b33, b1818 are positive. When entering the command i get the following error:
Can anybody help me please?:-)
Best regards,
Lucas
 @Carl Love @Markiyan Hirnyk
i have this Matrix: A:=Matrix([[Matrix[[a,b],[c,d]]], [Matrix[[e,f],g,h]] ])
i want this Matrix change to: A:=Matrix([[a,b,e,f],[c,d,g,h]])
help me plz
thank you
I have few packages downloaded from following link:
http://cpc.cs.qub.ac.uk/
Following are packages that I need to install on Maple:
Rif: For differential elimination.
GeM: For computing symmetries and conservation laws for nonlinear PDEs.
wkptest: For symbolic computation of Painleve test for nonlinear PDEs.
My problem is to install these packages onto Maple, but I do not know how to do this. For example, the package Rif contains file like maple.hdb, maple.ind, maple.lib, but I do not know what to do with these files. I shall be grateful to auduience of Mapleprime if somebody can help me on this.
I have a large program and when i add a line, i obtain as result [La longueur de sortie dépasse la limite de 1% noeuds]. pLease, can someone help me to continue my program.
First 1267 1268 1269 1270 1271 1272 1273 Last Page 1269 of 2464
