Greetings to all,
I want to make a "circular" list but I cannot find a way.
To be more precise, let K=[x1,x2,x3,x4], is any way to set K[0]:=K[4] and K[5]:=K[1]?
Thanx a lot,
Giorgos
http://www.maplesoft.com/applications/view.aspx?SID=5083&view=html&L=F
Error, (in hanoi) cannot determine if this expression is true or false: 0 < n
N:=n:moves:=[];
hanoi:=proc(N,source,dest,aux) global moves;
if N>0 then
hanoi(N-1,source,aux,dest):
moves:=[moves[],[N,source,dest]]:
hanoi(N-1,aux,dest,source);
end if:
sol:=hanoi(n,1,3,2);
There is million items in list,
what is the difference between seq and for loop ?
is seq faster than for loop?
it is very slow when running code below, how to speed up this part of code?
https://gist.github.com/LovelyYanki/c0b61fbb9d5954b34e03#file-gistfile1-txt
HSKeyIn := Table();
for ij from 1 to 1685159 do
s := solve([mm[ij][1,1]=1,mm[ij][1,2]=1,mm[ij][1,3]=1],[a,b,c]):
if nops(s) > 0 then
if (rhs(s[1][1]) = 1 or rhs(s[1][1]) = 0) and (rhs(s[1][2]) = 1 or rhs(s[1][2]) = 0) and (rhs(s[1][3]) = 1 or rhs(s[1][3]) = 0) then
#print(lhs(indices(T3, pairs)[ij])):
#print("***"):
h := HilbertSeries([mm[ij][1,1],mm[ij][1,2],mm[ij][1,3]], {a,b,c}, z):
#print(h):
if not assigned(HSkeyIn[h]) then
if mod(ij, 100) = 0 then
print(ij):
end if:
HSkeyIn[h] := [[mm[ij][1,1],mm[ij][1,2],mm[ij][1,3]]]:
print(ij):
end if:
HSkeyIn[h] := [op(HSkeyIn[h]), [mm[ij][1,1],mm[ij][1,2],mm[ij][1,3]]]:
end if:
end if:
end if:
mm := [[a, 1], [a, b]];
mmseq := {seq(mm[ij],ij=1..2)};
how to filter above in seq when any items in the [] has 1
criteria is below
if mm[ij][1] = 1 or mm[ij][2] = 1 or mm[ij][3] = 1 then
Dummy := 0:
mm2 := [op(mm2), mm[ij]]:
end if
In a course I am looking at, the system of units is mostly in FPS.  Wich I never use.  But they ask sometime to convert it to SI.  But with Maple, I have a problem:
For Force, it use lb that I cannot convert into N
So what unit should I use to convert FPS to SI for the force.
I know that slug*ft*s^(-2) convert to N with no problem.
Thank you for your help.
Mario Lemelin
Maple 2015 Ubuntu 14.04 - 64 bits
Maple 2015 Win 7 - 64 bits messagerie : mario.lemelin@cgocable.ca téléphone :  (819) 376-0987
Cheers!
I'm having a problem with my student work, about to have a solution of 6 equations... Can help me in this file? i dont know how to solve this... this had-me a null solve...
Thanks for the help =)
M1 := 0.15e5;
0.15e5
0.60e5
0.12e5
21000.00000
`&sigma;adm` := 175*10^6;
175000000
(1/300000)*L
210000000000
Atria := (3.5*12)/(LBC+LCD)
12.00000000
Ctria := LAB+LBC+(1/3)*(2*(LCD+LDE))
6.333333334
AiXil := Atria*Ctria
76.00000001
C := AiXil/Atria
6.333333334
SumFX := FAx;
FAx
SumFY := FAy+FCy+FEy-F5-QTria;
FAy+FCy+FEy-81000.00000
SumMA := FCy*(LAB+LBC)-F5*(LAB+LBC)+FEy*(LAB+LBC+LCD+LDE)+M1-MA-QTria*Ctria;
4*FCy-358000.0000+7.5*FEy-MA
EIYac := EIYo+`EI&theta;o`*x+M1*(x+0)^3/factorial(3);
EIYo+`EI&theta;o`*x+2500.000000*x^3
EIYce := EIYac+FCy*(x-4)^3/factorial(3)-F5*(x-4)^3/factorial(3)-q5*(x-4)^5/((3.5)*factorial(5));
EIYo+`EI&theta;o`*x+2500.000000*x^3+(1/6)*FCy*(x-4)^3-10000.00000*(x-4)^3-28.57142857*(x-4)^5
EIYef := EIYce+FEy*(x-7.5)^3/factorial(3)+(1/3)*q5*(x-7.5)^5/factorial(5);
EIYo+`EI&theta;o`*x+2500.000000*x^3+(1/6)*FCy*(x-4)^3-10000.00000*(x-4)^3-28.57142857*(x-4)^5+(1/6)*FEy*(x-7.5)^3+33.33333333*(x-7.5)^5
`EI&theta;ac` := diff(EIYac, x);
`EI&theta;o`+7500.000000*x^2
`EI&theta;ce` := diff(EIYce, x);
`EI&theta;o`+7500.000000*x^2+(1/2)*FCy*(x-4)^2-30000.00000*(x-4)^2-142.8571428*(x-4)^4
(14)
`EI&theta;ef` := diff(EIYef, x);
`EI&theta;o`+7500.000000*x^2+(1/2)*FCy*(x-4)^2-30000.00000*(x-4)^2-142.8571428*(x-4)^4+(1/2)*FEy*(x-7.5)^2+166.6666666*(x-7.5)^4
(15)
Mac := diff(`EI&theta;ac`, x);
15000.00000*x
(16)
Mce := diff(`EI&theta;ce`, x);
-45000.00000*x+FCy*(x-4)+240000.0000-571.4285712*(x-4)^3
(17)
Mef := diff(`EI&theta;ef`, x);
-45000.00000*x+FCy*(x-4)+240000.0000-571.4285712*(x-4)^3+FEy*(x-7.5)+666.6666664*(x-7.5)^3
(18)
Vac := diff(Mac, x);
15000.00000
(19)
Vce := diff(Mce, x);
-45000.00000+FCy-1714.285714*(x-4)^2
(20)
Vef := diff(Mef, x);
-45000.00000+FCy-1714.285714*(x-4)^2+FEy+1999.999999*(x-7.5)^2
(21)
x := 0:
`EI&theta;o` = 0
EIYo = 0
(22)
x := 4:
EIYo+4*`EI&theta;o`+160000.0000
(23)
x := 7.5:
EIYo+7.5*`EI&theta;o`+610931.2500+7.145833333*FCy
(24)
SOL := solve({CF1, CF2, CF3, CF4, SumFY, SumMA}, {EIyo, FAy, FCy, FEy, MA, `EIy&theta;o`});
"SOL:="
(25)
Download Equacoes_universais_T12_-_4.mwEquacoes_universais_T12_-_4.mw
Dear Maple users
I am delighted that Maple has builtin commands to plot so many polyhedrons in 3D. Here I am talking about the polyhedraplot command in the plots package. I was however disappointed that the socalled Truncated Icosahedron is not supported (not present in the supported list ...). My first question is:
1. Why isn't it supported?
It seems more relevant than many of the other polyhedrons which are supported. It is a member of the Archimedian Solids (see https://en.wikipedia.org/wiki/Truncated_icosahedron). Besides it is the basic structure for soccer footballs. I found out that a TruncatedIcosahedron command is available in the geom3d package. This command is able to deliver data for the faces and more. With this command I succeded in writing a small program to actually plot this polyhedron in 3D:
with(geom3d):
TruncatedIcosahedron(football,point(C,(0,0,0)),1):
PlotFootball:=proc(tr::float)
    local i::integer,
         FootballFace::Vector(datatype=float[8]),
         plotFace::Vector(datatype=float[8]);
    for i from 1 to 32 do
        FootballFace[i]:=faces(football)[i];
        plotFace[i]:=polygonplot3d(Matrix(FootballFace[i]),axes=none,scaling=constrained,transparency=tr);
    display(seq(plotFace[i],i=1..32)):
PlotFootball(0.00);
Since I am not really experienced in programming in Maple, here is my last question:
2. Can I simplify something in my code above?
Best wishes,
Erik
People im with error to show a plot, this is a wor for universty about mechanic materials, and i'm with this error... do not show the plot... before, i've a error because the variable x has values, and i've to unassign to have this.. without unassign, has error in domin of the plot... i dont know how to do this ! And ive to send the work today.
Someone can help me about this?
Value of variables:
functions
plot algoritm...
plot algoritm
Thanks !
in page 137 of an introduction to groebner bases
how to eliminate the redundant solution (y^2-x*z, 0, -x^2+y*w)
from 3 of them?
eliminate({y,y^2-x*z,-z}, {x, y, z, w});
eliminate({-x,0,y}, {x, y, z});
eliminate({w,-x^2+y*w,-x}, {x, y, z, w});
ma := allstructs(Permutation([1, 1, 1, 2, 2, 2, 3, 3, 3]), size = 3);
above is fast
but below is very slow.
ma2 := allstructs(Permutation(ma), size = 3);
just for all combinations of matrix , replicateM in haskell is the fastest.
in maple, ma2 := allstructs(Permutation(ma), size = 3); is very slow
What is the best source of learning maple for an abecedarian to become a professional?
I can't understand difference between plots!
Please expailn it.
plot({sqrt(x+2*sqrt(x-1))+sqrt(x-2*sqrt(x-1)), sqrt(x-2*sqrt(x-1)), sqrt(x+2*sqrt(x-1))}, x = -3 .. 3)
Let us define a piecewise-linear continuous function:
restart; VP := Vector[row](16, {(1) = 10, (2) = 177.9780267, (3) = 355.9560534, (4) = 533.9340801, (5) = 711.9121068, (6) = 889.8901335, (7) = 1067.868160, (8) = 1245.846187, (9) = 1423.824214, (10) = 1601.802240, (11) = 1779.780267, (12) = 1957.758294, (13) = 2135.736320, (14) = 2313.714347, (15) = 2491.692374, (16) = 2669.670400}); VE := Vector[row](16, {(1) = 5.444193931, (2) = .4793595141, (3) = .3166653569, (4) = .2522053489, (5) = .2123038784, (6) = .1822258228, (7) = .1544240625, (8) = .1277082078, (9) = .1055351619, (10) = 0.8639065510e-1, (11) = 0.6936612570e-1, (12) = 0.5388339810e-1, (13) = 0.3955702170e-1, (14) = 0.2612014630e-1, (15) = 0.1338216460e-1, (16) = 0.1203297900e-2}); for i to 15 do p[i] := VE[i+1] < x and x <= VE[i], (VP[i+1]-VP[i])*(x-VE[i])/(VE[i+1]-VE[i])+VP[i] end do; g := unapply(piecewise(seq(p[i], i = 1 .. 15)), x);
for i to 15 do print(fsolve(g(x) = VP[i])) end do;
Why doesn't the fsolve command work if i = 4, 7, 9, 11, 14? There are workarounds:
print(DirectSearch:-SolveEqutions(g(x) = VP[i]));
and/or
VP := convert(VP, rational); VE := convert(VE, rational); print(solve(g(x) = VP[i]));
 How to explain such behavior of the fsolve command? That was asked but not answered in http://forum.exponenta.ru/viewtopic.php?t=13524&sid=025a140e7e00b99803c86060a5c0c33c .
strange_behavior.mw
Edit. Replaced worksheet.
I have a problem with the adaptive question designer: when I use the multiple choice question type then occasionally parts of the question environment appear multiple times in the text, duplicating each time I reopen the question to edit. This happens in particular if the answers are a bit longer (4-5 lines each). So far I couldn't figure out how to fix this, does anyone have a similar problem?
Many thanks for your help!
Please help me to solve this integration
restart; with(LinearAlgebra); int(exp(-(ln(z/(snr*B^2))+4*sigma^2)^2/(32*sigma^2))*eta^2*(y/z)^((1/2)*eta^2-1)/(z*sqrt(32*Pi*sigma^2)*(2*sqrt(y*z))*(2*A[o]^(eta^2))), z, z = y/A[o]^2 .. infinity);
First 1290 1291 1292 1293 1294 1295 1296 Last Page 1292 of 2471
