In the following code, the evalf prints -32.16...
restart; S := 8;
sigma := 8/sqrt(2*Pi);
iprec := 151;
evalf(log[2](-(sum(log(round(2^iprec*exp(-j^2/(2*sigma^2)))/2^iprec*exp(-j^2/(2*sigma^2))))*round(2^iprec*exp(-j^2/(2*sigma^2)))/2^iprec, j = 0 .. 7))));
Change the last line to evalf[20](log[2](....)), and re-run *just that line*. It now prints -66.67...
Change the last line to evalf[200](log[2](...)) and re-run *just that line* again. It now prints -151.24... (I have strong evidence to support that the true value is near -151, so I believe this answer.)
Now remove the precision indicator from the command completely and re-run just the last line. It *still* prints -151.24...!
My two questions are: why do I need evalf[200] to get the first three digits of the answer to be correct? and why does setting the evalf precision and then removing it cause the previous precision to persist?
hello everyone. I have an undergradute project i'm currently working on and I'm stuck where I have to use the Differential Transforms Method to solve a problem with boundary conditions at infinity
Digits := 5;
F[0] := 0; F[1] := 0; F[2] := (1/2)*A; T[0] := 1; T[1] := B; M := 2; S := 1;
for k from 0 to 10 do F[k+3] := (2*(sum((r+1)*F[r+1]*(k+1-r)*F[k+1-r], r = 0 .. k))-T[k]-3*(sum((k+1-r)*(k+2-r)*F[r]*F[k+2-r], r = 0 .. k))-M*(k+1)*F[k+1])*factorial(k)/factorial(k+3);
T[k+2] := (-3*(sum((k+1-r)*F[r]*T[k+1-r], r = 0 .. k))-S*T[k])*factorial(k)/factorial(k+2)
end do; f := 0; t := 0;
f := f+F[k]*x^k;
t := t+T[k]*x^k end do;
print(f);
print(t);
but the problem is that i cant seem to evaluate
or higer diagonal pade-approximant. any help will be greatly appreciated. thank you.
Please help, here is my code:
findproot:=proc(f,var,k)
local i,g,B,n,L,tk;
readlib(rootbound):readlib(realroot):
B:=rootbound(f,var);
g:=expand(subs(var=B*var,f));
if B<1 then g:=numer(g);fi;
n:=degree(g,var);
L:=zero_one(g,var,n,1/B/2^k);
tk:=k+1:
while has(L,0) do
L:=zero_one(g,var,n,1/B/2^tk);
tk:=tk+1:
if L=[] then RETURN([]);fi;
L:=map(proc(x,y) [op(1,x)*y,op(2,x)*y];end,L,B);
end:
I dont know why i cant run this code, it always report:
Error, (in findproot) improper op or subscript selector
Hello, i am recently doing a lot of my (really simple) equation manipulations with Maple and would like to include an expectation operator E( ) in my symbolic equations. As maple threads E() as a function, differentiating is not very convenient, as i have to replace all D(E) ... manually. I tried defining some properties of E() via the define() function, but when trying to set the behavior of d E(f(x))/dx I am not sure how to use (diff()=result) in the define() function. Any help or ideas are greatly appreciated!
How can I solve this equation 18 *9^(x^2 + 2* x) + 768* 4^((x + 3)* (x - 1)) - 5 *6 ^((x + 1)^2)?
I tried
A:=18 *9^(x^2 + 2* x) + 768* 4^((x + 3)* (x - 1)) - 5 *6 ^((x + 1)^2);
solve(A=0);
I see that, the equation has three solutions: x = -2, x = -1 and x = 0. I check
f:=x->18 *9^(x^2 + 2* x) + 768* 4^((x + 3)* (x - 1)) - 5 *6 ^((x + 1)^2);
f(-2);
f(-1);
f(0);
Another question, Maple can not solve inequality
18 *9^(x^2 + 2* x) + 768* 4^((x + 3)* (x - 1)) - 5 *6 ^((x + 1)^2) > = 0.
PS. We can easy to solve the above inequality with Mathematica
Reduce[18 9^(x^2 + 2 x ) + 768 4^((x + 3) (x - 1)) - 5 6 ^((x + 1)^2) >= 0 , x, Reals]
I got x <= -2 || x == -1 || x >= 0
How to generate all basis of a set? (rather an the one basis that basis generates)
Please help in writing finite difference algorithm for a nonlinear PDE using Maple.
for a[j], b[j] known at time n, I want to compute A[j]  for a[j] at time n+1 according to the equation below
EQs:=A[j]-theta*tau*(A[j-1]-2*A[j]+A[j+1])=a[j]+sqrt(a[j])*b[j]*h^2/tau+(1-theta)*tau*(a[j-1]-2*a[j]+a[j+1]) ;
hi guys , i have this warning for solving a complicated equation with 7 parameters. how can i overcome to this warning ?
odesys := {(1/4)*(-4*r^(2+p+a)*p*a-11*r^(2+a+c)*a*c-4*r^(2+p+c)*p*c+22*r^(2+a+n)*a*n+8*r^(2+p+n)*p*n-22*r^(2+a+c)*a+8*r^(2+p+a)*p-8*r^(2+p+c)*p+22*r^(2+b)*b+32*r^(2+p)*p^2+32*r^(2+p)*p+22*r^(2+b)*b^2+22*r^(2+2*a)*a+65*r^(2+2*a)*a^2-8*r^(2+p+c)*p^2+8*r^(2+p+a)*p^2-22*r^(2+a+c)*a^2)/r^4+(1/4)*(4*r^(a+n)*n^2-2*r^(n+c)*n*c-4*r^(n+c)*n^2+3*r^(2*n)*n^2-4*r^(a+c)*c+8*r^(a+n)*n+4*r^(2*c)*c-8*r^(n+c)*n+4*r^m*m^2-4*r^d*d+8*r^m*m+4*r^m-4*r^d)/r^2}
res := op(odesys);
SOL1 := solve(identity(res = 0, r), {a, b, c, d, m, n, p})
Download sol.mw
Dear I want to define a general operator D for Fractional derivative whose behave like this
(D^alpha)(t^beta) = GAMMA(1+beta)*t^(beta-alpha)/GAMMA(1+beta-alpha)
How to generate an undirected graph with a given set of its verticies and a given list/set of the degrees of its verticies?
guys, i have this equation which a, n, c, phi[0] are parameters and r is variable. maple solved this equation with n=0,c=c,phi[0]=5/4-1/4 c but i obtained another solution for this equation : a = 1, c = 5, n = 1, phi[0] = 1 ( you can check).
odesys := {5*r^a+4*n-c*r^n-4*phi[0]}
res := op(odesys);
SOL := solve(identity(res = 0, r), [a, n, c, phi[0]]);
[[a = 0, n = 0, c = c, phi[0] = 5/4-(1/4)*c]]
eval(5*r^a+4*n-c*r^n-4*phi[0], [a = 1, c = 5, n = 1, phi[0] = 1])
how can i get all solutions for a equation like this ?
Download eq000.mw
Concerning the 3D visualization of my multibody systems, in the visualization windows, i can see both :
- the display of geomtry of the elements which has been defined as simple forms (as cylindrical geometry)
- the display of the geometry of the elements where the display of the geometry has been defined with CAD.
However, concerning the 3D animation, i have only see the components where the display of the geometry is defined as simple forms (as cylindrical geometry).
Have you some ideas why I can not see the elements which has been defined with CAD ?
For your information, the CAD geometries have been defined with STL files and, in the CAD geometry component, I let the box "Transparent" empty.
Thank you for your help
As I am beginner in maple, how to verify Bianchi Identities?
For Riemannian manifold,
1) R(X, Y)*Z+R(Y, Z)*X+R(Z, X)*Y = 0
2) ((&nabla;)[X]R)(Y,Z)W+((&nabla;)[Y]R)(Z,X)W+((&nabla;)[Z]R)(X,Y)W=0
I am not getting how to define vector fields. From my previous question I understood defining vector fields particularly. From that post I tried to verify the proof, but I cant. Please tell me about how to define vector fields without taking examples.
Thank in advance.
Hi, does anyone know how to plot a Bode diagram (phase and amplitude plot)? I am not looking for preparation of data but rather for the technicality of producing a plot that looks like I want, given I have data in the right form (which in my case are three Vectors: frequency, amplitude and phase).
Below is a rough sketch of what I am looking for. Note that the amplitude is on a log scale. It would be acceptable having to take the log of the data "by hand" to allow both vertical scales to be linear (I'd just convert the amplitudes to dB). The important things are the common frequency scale (horizontal) and the separation of amplitude and phase. I know plots has  dualaxisplot, and I know I can use plots:-transform to move a curve around, but I want the two axes on the left side, below each other, rather on the left and right. I'd like the frequency scale in the middle between the two curves, although I could settle on that scale to be below both curves.
I had some look around the Maple applications but did not find anything looking like this.
Mac Dude
First 1301 1302 1303 1304 1305 1306 1307 Last Page 1303 of 2471
