How to express sin(-(1/6)*Pi+(1/2)*arccos(1/3)) in radicals with Maple? The use of the applyrule command is not desired. Here is one of  my tries:
>convert(expand(sin(-(1/6)*Pi+(1/2)*arccos(1/3))), radical);
-(1/2)*cos((1/2)*arccos(1/3))+(1/2)*sqrt(3)*sin((1/2)*arccos(1/3))
Hi guys,
I'm studying a system of six differential equations. Given the fact that the system cannot be solved symbolically, I've tried the numeric procedure, and it works. I proceeded like this :
soleqd:=dsolve(sysd2,numeric,var);
then i checked if maple could calculate the solutions for given values of t. It works for t=0, t=0.5, t=1,t=2,...,t=5. The solutions are all real numbers.
But when i try to draw a graphic representation of the solutions, it doesn't work. I do :
ff1:=t->subs(soleqd(t),u[1](t));
gg1:=t->subs(soleqd(t),nu[1](t));
Then :
plot(['ff1(t)','gg1(t)',t=0..5],u[1]=0...1,nu[1]=0...1);
(The square brackets are indices)
Now maple answers that it is "unable to evaluate the function to numeric values in the region". I went to the help page but no solution seems to work. I can't figure it out by myself. Does anybody notice something wrong with my code ?
Thank you for your time,
Best regards,
Louis
The model of fixed-bed adsorption column
Fluid phase:
PDE:= diff(U(x, tau),tau)+ psi*Theta*diff(U(x, tau),x)-(1/Pe)*psi*Theta*diff(U(x, tau),$(x, 2))=-3*psi*xi*(U(x, tau)-Q/K);
IBC:={U(x, 0) = 0,U(0, tau) = 1+(1/Pe)*(D[1](U))(0, tau),(D[1](U))(1, tau)=0};
Particle:
PDE:= diff(Q(r, tau), tau) = diff(Q(r, tau), $(r, 2))+(2/r)*diff(Q(r, tau),r);
IBC:={Q(r, 0) = 0,(D[1](Q))(0, tau) = 0,(1/K)*(D[1](Q))(1, tau)=xi*(U-Q(1, tau)/K)};
Pe:=0.01:
psi:=6780:
Theta:=3.0:
xi:=10000:
I will really appreciate your help. Thanks in anticipation.
Hi guys,
I'm trying to draw a phase portrait based on a system of differential equations, but executing the DEplot command gives me the response in the title.
The command I entered is this one :
DEplot(sysdif,[u(t),nu(t)],t=0..50,{[u(0)=0.831,nu(0)=0.7]},linecolor=red,numpoints=1000, thickness=1, u=0.5...1, nu=0.6...1, color=black);
the system of equation is this one :
eqd1 := diff(u(t), t) = u(t)*[-gamma + (rho)/(mu - nu(t)) - delta*u(t) + pii - (tau)/(alpha + epsilon*exp(-beta*((omega-u(t))/(kappa-u(t)))))] ;
eqd2 := diff(nu(t), t) = nu(t)*[(omega-u(t))/(kappa-u(t)) - (tau)/(alpha+epsilon*exp(-beta*((omega-u(t))/(kappa-u(t)))))] ;
the model is calibrated. I understand that maple cannot store a kind of number but even changing the parameters won't help. I've been looking for people with same error message but using solutions provided by forum members don't work. Before getting that error message i did have the one with "vars must be declared as a list ..." so I did :
u:='u' ;
nu:='nu';
but now I have the error  "unable to store  '[HFloat(0.005711776872341132)]' when datatype=float[8]".
Does anybody have an idea of the solution to my problem ?
Thanks for your time,
best regards,
Louis
I'm just using it this way:
with(QDifferenceEquations):
QPochhammer(-1,5,10)
Error, (in QDifferenceEquations:-QPochhammer) wrong type of arguments
Am I doing something terribly wrong???
     I'm trying to numerically solve a PDE in Maple for different boundary conditions, however I'm having trouble even getting Maple to numerically solve it for simple boundary conditions.
I have cylindrical coordinates, r, z, theta, and I treat r = r(z, theta) for convenience to plot my solution surface. The initial coundary condition is that at z = epsilon (z = 0 is singular) , r = constant and of course r is periodic in theta. This is just a circle, and the analytical solution is know to be a half-sphere  r = sqrt(R^2 - z^2). I entered my initial boundary conditions into Maple, but it doesn't like the periodic one
IBC := { r(epsilon, theta) = R - epsilon__r,
              r(z, 0) = r(z, 2*Pi) };
pdsolve(
  PDE,
  IBC,
  numeric,
  indepvars = [z, theta],
  time = z,
  range = 0..2*Pi);
Error, (in pdsolve/numeric/par_hyp) Incorrect number of boundary conditions, expected 2, got 1
I'm not sure how to make this work, and then generalize it to more arbitrary intial slices r(epsilon, theta) = f(theta).
Here's the attached worksheet, ForMaplePrimesSUbmission.mw
Any help is appreciated,
I have written some statements in maple and when integrating a vector I encounter an error . whats the problem? the error is:
Error, (in evalf/Ei/taylor) unsupported type of index, 1.
F1 := ScalarMultiply(Phi^%T, f);
F := int(F1, x = 0 .. 1);
which f is exp(x-t) and Phi is a vectror.
I want to define variables with indices, possibly zero. So for example I define mu[01] and mu[10]...
My problem is that mu[01] automatically becomes mu[1] in Maple's output, so that I could not distinguish it from mu[001]...
Is there any way to address it?
Manuele
r := sqrt(x^2+y^2+z^2);
divE := diff(e*x/(4*Pi*r^3), x)+diff(e*x/(4*Pi*r^3), y)+diff(e*x/(4*Pi*r^3),z);
simplify(divE);
I want to simplify an expression via simplify();
However since the expression is very long (length(expression)=2713899) Maple is taking too long...So far one hour.
I have already simplified several expressions of a similar kind with lengths of up to 400.000 which worked fine within minutes.
Is there any way to speed up the process. Am I making a mistake?
of a square matrix having its entries 1,2,...16? See http://oeis.org/A085000 for info.
I want to plot this contour 4x^2+9y^2=160  onto the same f(x,y)=4x^2+9y^2.  The error I keep getting is
Error, (in plot3d) first argument must be either in standard or parametric form
I think the developers should pay attention to this problem.
This simple expression with Threads:-Map executed perfectly on my machine with 8-threaded CPU and 16 GB RAM:
Threads:-Map(proc (i) options operator, arrow; ln(i)/2. end proc, [`$`(1 .. 10^7)]);
But the similar expression with Grid:-Map never be executed:
Grid:-Map(proc (i) options operator, arrow; ln(i)/2. end proc, [`$`(1 .. 10^7)]);
Maple or freezed, or crashed every time. Although the consuming of memory is not reached even 50%.
The similar problem exist for Grid:-Seq too. With `$`(1 .. 3*10^6) Grid:-Map and Grid:-Seq executed normally. With `$`(1 .. 5*10^6) - 50/50. But not with `$`(1 .. 10^7).
Is this a real bug of Grid:-Map and Grid:-Seq ?
Or is exist a way to fix this problem?
Updated:
I got a new error behavior of Grid:-Map in this case instead crash or freeze:
Grid:-Launch(numnodes = 8);
st := time[real](); Grid:-Map(proc (i) options operator, arrow; ln(i)/2. end proc, [`$`(1 .. 10^7)]);
time[real]()-st;
`System error, `, "bad id"
2267.482
I hope this helps developers to fix this bug.
I can;t seem to get DSOLVE working.  Will some kindly soul please send me a complete example, starting with an f(x) & clearly documented?   Many thanks.
AB
Suppose I have a file, test.txt, which the content is
2 0.0 0.0 0.0
1 0.0 0.0 1.6
I would like to save
Z:=2;
C[1,1]:=2;C[2,1]:=0.0;C[3,1]:=0.0;C[4,1]:=0.0;
C[1,2]:=1;C[2,2]:=0.0;C[3,2]:=0.0;C[4,2]:=1.6;
However, if I use readdata("...",4), seems it do not work.
Is there any flexible command in maple can readfile with different column? Thank you very much!
First 1311 1312 1313 1314 1315 1316 1317 Last Page 1313 of 2471
