Hi all
Assume that we have following special matrix(Namely ATilde) for arbitrary vectore  z=[a0,a1,a2,a1*,a2*]:
atild.mws
and we want to use this as a general function for other arbitrary vector. is ther any way?
for example z1=[x,y,t,s,u]?
thanks for any help
best wishes
Mahmood   Dadkhah
Ph.D Candidate
can you help in that please?
How can I use this small procedure (root_of_cheb) as a sub-procedure in  the next procedure (EvalInt) ?
is it possible?
root_of_cheb:=proc(n)
   local xk,b,k:
   xk:=(k,n)->cos((2*k-1)*Pi/(2*n));
   sort([seq(evalf(xk(k,n)),k=1..n)]):
end:
EvalInt:=proc(f,n)
   local xk:
   evalf((Pi/n)*add(f(xk(i,n)),i=1..n)):
end:
Hope all to be in good health.
I have written following program to obtain minimum  under som constraints but it doesn't work due to some unknown error.
can any one help me?
Program1.mws
best wishes
Mahmood   Dadkhah
Ph.D Candidate
   d ph
   ---- = (1 - yc) pc + yh prj + urd prd + ugd pgd - yc ph,
    dt
     d pc                        d pa
     ---- = yc ph - (2 - yc) pc, ---- = pc ya - pf,
      dt                          dt
     d prj                 d prd
     ----- = pa yrj + prj, ----- = pa yrd - prd urd,
      dt                    dt
     d pgd
     ----- = pa ygd - pgd ugd,
      dt
     d pf
     ---- = (1 - ygd - yrj - yrd) pa + (1 - yh) prj
      dt
ics := ph(0) = 1, pc(0) = 0, pa(0) = 0, prj(0) = 0, prd(0) = 0, pgd(0) = 0, pf(0) = 0;
i write this equations in maple
but i get this error
Error, (in dsolve) ambiguous input: the variables {pa, pc, pf, pgd, ph, prd, prj} and the functions {pa(0), pc(0), pf(0), pgd(0), ph(0), prd(0), prj(0)} cannot both appear in the system
can anyone help me?
with(PDEtools);
Es := 0.117108e12;
Ef := 0.78125e11;
l := 0.150e-6;
s := 0.500000e-3;
f := 0.5898334197e-6;
o := 0.9e-5;
d := 0.10e-17;
cb := 0.1e7/(19.9);
R := 8.3144621;
T := 298;
PDE := diff(u(x, t), t)-(diff(u(x, t)+o^2*Es*cb*u(x, t)^2/(9*R*T), x, x)) = 0;
IBC := {u(1, t) = 1, u(x, 0) = 0, (D[1](u))(1, t) = l*f/(d*cb)};
S := pdsolve(PDE, IBC, numeric, time = t, range = 0 .. 1, timestep = 0.1e-4, spacestep = 0.1e-6);
p1 := S:-plot(t = .1, numpoints = 100);
Error, (in pdsolve/numeric/plot) unable to compute solution for t>HFloat(0.0):
matrix is singular
p2 := S:-plot(t = .2, numpoints = 50, color = green);
matrix is singular
p3 := S:-plot(t = .3, numpoints = 50, color = blue);
matrix is singular
plots[display]({p1, p2, p3});
Error, (in plots:-display) expecting plot structures but received: {p1, p2, p3}
i have 3 equations that i need help graphing, i have tried but do not know much about maple.
the equations are x= sin u [7+cos((u/3)-2v)+2cos((u/3)+v)], y=cos u [7+cos((u/3)-2v)+2cos((u/3)+v)],
and z=sin((u/3)-2v)+2sin((u/3)+v) the limits are u from -pi to pi, and v is also from -pi to pi. please help
of the cut-off sphere
Изображение?
Of course, with Maple.
What do I have to change to get this animation?
L:=[seq([i,i^2], i=1..4)]:
plots:-animate(plot, [ L[m], m=1..k,
                                style=point, view=[0..4,0..16]
                                k=1..4
Thank you for your help.
I m trying to simplify an expression involving square roots in Maple. But instead of giving the expected output it is not simplifying it. Please find the attached maple file for reference. I calculated manually and the result is 1. Please help me out for this. Thanx in advance.
Sunit
temp := (1/2)*(a*r*t-b*p)*sqrt(p+v*sqrt(a*r))*sqrt(b)/(sqrt(a*b*r*t)*sqrt(a*r*t*(p+v*sqrt(a*r))))+(1/2)*(a*r*v*t-v*b*p+p*t*sqrt(a*r)-b*v^2*sqrt(a*r))*sqrt(b)/(sqrt(a*b*r*t*(p+v*sqrt(a*r)))*sqrt(t*(p+v*sqrt(a*r))))+(1/2)*b*(p+v*sqrt(a*r))/(a*r*t)
(1/2)*(a*r*t-b*p)*(p+v*(a*r)^(1/2))^(1/2)*b^(1/2)/((a*b*r*t)^(1/2)*(a*r*t*(p+v*(a*r)^(1/2)))^(1/2))+(1/2)*(a*r*v*t-v*b*p+p*t*(a*r)^(1/2)-b*v^2*(a*r)^(1/2))*b^(1/2)/((a*b*r*t*(p+v*(a*r)^(1/2)))^(1/2)*(t*(p+v*(a*r)^(1/2)))^(1/2))+(1/2)*b*(p+v*(a*r)^(1/2))/(a*r*t)
simplify(temp)
-(1/2)*(-(p+v*(a*r)^(1/2))^(1/2)*b^(1/2)*(a*b*r*t*(p+v*(a*r)^(1/2)))^(1/2)*(t*(p+v*(a*r)^(1/2)))^(1/2)*a^2*r^2*t^2+(p+v*(a*r)^(1/2))^(1/2)*b^(3/2)*(a*b*r*t*(p+v*(a*r)^(1/2)))^(1/2)*(t*(p+v*(a*r)^(1/2)))^(1/2)*a*r*t*p-b^(1/2)*(a*b*r*t)^(1/2)*(a*r*t*(p+v*(a*r)^(1/2)))^(1/2)*a^2*r^2*t^2*v+b^(3/2)*(a*b*r*t)^(1/2)*(a*r*t*(p+v*(a*r)^(1/2)))^(1/2)*a*r*t*v*p-b^(1/2)*(a*b*r*t)^(1/2)*(a*r*t*(p+v*(a*r)^(1/2)))^(1/2)*a*r*t^2*p*(a*r)^(1/2)+b^(3/2)*(a*b*r*t)^(1/2)*(a*r*t*(p+v*(a*r)^(1/2)))^(1/2)*a*r*t*v^2*(a*r)^(1/2)-b*(a*b*r*t)^(1/2)*(a*r*t*(p+v*(a*r)^(1/2)))^(1/2)*(a*b*r*t*(p+v*(a*r)^(1/2)))^(1/2)*(t*(p+v*(a*r)^(1/2)))^(1/2)*p-b*(a*b*r*t)^(1/2)*(a*r*t*(p+v*(a*r)^(1/2)))^(1/2)*(a*b*r*t*(p+v*(a*r)^(1/2)))^(1/2)*(t*(p+v*(a*r)^(1/2)))^(1/2)*v*(a*r)^(1/2))/((a*b*r*t)^(1/2)*(a*r*t*(p+v*(a*r)^(1/2)))^(1/2)*(a*b*r*t*(p+v*(a*r)^(1/2)))^(1/2)*(t*(p+v*(a*r)^(1/2)))^(1/2)*a*r*t)
Download question.mw
Hi there, this is my first post in this forum. I hope you can help me with my problem :)
I've created a little program to solve a problem for my class. This is the first time, I wrote a program with Maple, so please don't laugh.
I've posted the Maple code below:
restart; randomize():
with(plots): with(plottools): with(LinearAlgebra): with(Statistics): with(MTM):
s:={1=2, 3=2}:
Realisierung:=proc(np,volfrac)
local m, h, adresses, rndmAdrs, omega: omega:=Vector[row](np,s);
adresses:=Vector(np-nops(s));
h:=1;
for m from 1 to np do
if(omega[m]=0) then
adresses[h]:=m;
h:=h+1;
end if
od;
randomize():
rndmAdrs:=Shuffle(adresses);
for m from 1 to volfrac*np do
omega[rndmAdrs[m]]:=1
for m from 1 to np -(volfrac*np+nops(s)) do
omega[rndmAdrs[m+int8(volfrac*np)]]:=2
omega;
end:
RealMatrix:=proc(np,nr,volfrac)
local m, alle:
alle:=Matrix(nr,np); for m from 1 to nr do
randomize();
alle[m]:=Realisierung(np,volfrac); od;
alle;
end:
RealMatrix(5,5,0.4);
I used the Shuffle function from Statistics-package to randomly permutate the components in the Vector adresses. Which works fine. By setting Randomize(); I get randomly results vor this permutation, when I execute the whole worksheet.
But when the "Realisierung" procedure is called in the for loop of the "RealMatrix" procedure, always the same Permutation is calculated.
This leads to the fact, that every row in my matrix looks the same.
Like in the example
2 1 2 2 1
2 1 2 2 1
2 1 2 2 1
2 1 2 2 1
2 1 2 2 1
but the lines should be randmly like
2 1 2 2 1
2 2 2 1 1
2 1 2 1 2
2 1 2 2 1
Obvioulsy the problem is in the randomize()-command. I tried to place it directly after "restart" and directly before the Shuffling is executed.
But I had no succes.
Maybe one of you can help me?
Would be great!
a=1-(1+x)*exp(-x);
SS:=solve(%,x,allsolutions);
evalf(eval(SS,[_Z2=0,a=0.3]));evalf(eval(SS,[_Z2=-1,a=0.3]));
I know there are two branches for the lambertw function meet my demand.
I wonder whether there is a method to find the _Z2 value with SS::real, for the above commands, they are 0&-1.
thank you for any advice.
How to avoid the error described in the title
Hi All,
I want to solve for G, but cant seem to figure it out. Can anyone tell me what am I missing or doing wrong?
SSD:= ((155/9)*2.5)+((155/9)^2/(2*9.807*0.346));
Lc:= 2*SSD-(2*(sqrt(1.08)+sqrt(0.6))^2)/(G+0.04);
Ls:= 2*SSD-(2*(0.6+SSD*tan(Pi/180)))/(G);
Lcon:= 202-Lc-Ls;
Eq:= (G-0.043)(Lc/2)+(-G)(Ls/2)+G*Lcon-0.043*Lc=14;
fsolve(Eq);
thank you
Hi everyone!
I'm curious how to obtain in Maple 2015 same result as in Maple 18.
Here is my code:
L0 := ImportMatrix("C:\\Test.txt", source = delimited, delimiter = "\t", datatype = float[8]):
plot(L0[() .. (), 1], L0[() .. (), 2], axes = box, size = [600, 320]);
This is result which I get by Maple 18:
This is result which I get by Maple 2015:
My Test file:Test.txt
bags.mw
$15 is spread among four different bags. How  can you can make any whole number of dollars from $1 to $15 by selecting some of these bags of money, without taking any money out of the bags.
How is the money distributed ?
One bag must have $1 in it.
To be able to make $2, and each bag is different, so one bag must have $2 in it.
 can now make $3, but can’t make $4, so the third bag must have $4 in it.
With $1, $2 and $4 in three bags, can make every total up to $7. The last bag has the rest of his money in it – $8.
so the answer is $[1,2,4,8]
wondering how to do this with maple procedure. unsurprisingly my code doesn't work
First 1317 1318 1319 1320 1321 1322 1323 Last Page 1319 of 2471
