I was wondering if there was a command that could tell me if an expression consisting of undermined functions was always positive (with real domain).
For example f1:=f(x)^2+g(y)^4 is always positive.
but f(x)^2-g(y)^2 is only positive on a restricted domain.
This looks like a bug I have not seen before. Any one seen this before?
Error, (in Handlers:-TrigExpOnly) cannot determine if this expression is true or false: tr_is_cos
Can others reproduce it? I am using Maple 2023.2 on windows 10
btw, I found that by doing int(evala(integrand),t) instead of int(integrand,t) then the error goes away but not all the time. Below are two examples. The first where evala() fixes it, but the second it does not fix it.
Physics:-Version()
`The "Physics Updates" version in the MapleCloud is 1585 and is the same as the version installed in this computer, created 2023, October 29, 6:31 hours Pacific Time.`
`Standard Worksheet Interface, Maple 2023.2, Windows 10, October 25 2023 Build ID 1753458`
integrand:=-(((sqrt(3)*sqrt(27983)*I + 276)*(-594 + 6*I*sqrt(3)*sqrt(27983))^(1/3) + 15*I*sqrt(3)*sqrt(27983) + (25*(-594 + 6*I*sqrt(3)*sqrt(27983))^(2/3))/2 + 2265)*(-150 + (-150 + (-594 + 6*I*sqrt(3)*sqrt(27983))^(2/3))*sqrt(3)*I - (-594 + 6*I*sqrt(3)*sqrt(27983))^(2/3) + 24*(-594 + 6*I*sqrt(3)*sqrt(27983))^(1/3))*(150 + (-150 + (-594 + 6*I*sqrt(3)*sqrt(27983))^(2/3))*sqrt(3)*I + (-594 + 6*I*sqrt(3)*sqrt(27983))^(2/3) - 24*(-594 + 6*I*sqrt(3)*sqrt(27983))^(1/3))*((sqrt(3)*sqrt(27983)*I + 276)*(-594 + 6*I*sqrt(3)*sqrt(27983))^(1/3) - 15*I*sqrt(3)*sqrt(27983) - 2265)*exp(-t*((-594 + 6*I*sqrt(83949))^(2/3)/3 + (-594 + 6*I*sqrt(83949))^(1/3) + 50)/(-594 + 6*I*sqrt(83949))^(1/3))*(-594 + 6*I*sqrt(3)*sqrt(27983))^(2/3)*((-594 + 6*I*sqrt(3)*sqrt(27983))^(2/3) + 12*(-594 + 6*I*sqrt(3)*sqrt(27983))^(1/3) + 150)*sin(t)*cos(t))/(10101630528*(sqrt(3)*sqrt(27983)*I - 99)^2*(sqrt(3)*sqrt(27983)*I + 27983/33)*exp(t)) - ((-594 + 6*I*sqrt(83949))^(2/3) + 12*(-594 + 6*I*sqrt(83949))^(1/3) + 150)*(2*I*sqrt(83949)*(-594 + 6*I*sqrt(83949))^(1/3) + 30*I*sqrt(83949) + 25*(-594 + 6*I*sqrt(83949))^(2/3) + 552*(-594 + 6*I*sqrt(83949))^(1/3) + 4530)*(-594 + 6*I*sqrt(83949))^(1/3)*(sqrt(83949)*(-594 + 6*I*sqrt(83949))^(1/3)*I - 15*I*sqrt(83949) + 276*(-594 + 6*I*sqrt(83949))^(1/3) - 2265)*exp(-t*((-594 + 6*I*sqrt(83949))^(2/3)/3 + (-594 + 6*I*sqrt(83949))^(1/3) + 50)/(-594 + 6*I*sqrt(83949))^(1/3))*(8*cos(t)^2/exp(t) - 4/exp(t))/(5196312*(sqrt(83949)*I + 27983/33)*(sqrt(83949)*I - 99)) + ((-594 + 6*I*sqrt(83949))^(2/3) + 12*(-594 + 6*I*sqrt(83949))^(1/3) + 150)*(2*I*sqrt(83949)*(-594 + 6*I*sqrt(83949))^(1/3) + 30*I*sqrt(83949) + 25*(-594 + 6*I*sqrt(83949))^(2/3) + 552*(-594 + 6*I*sqrt(83949))^(1/3) + 4530)*(-150 + (-594 + 6*I*sqrt(83949))^(2/3))*(-594 + 6*I*sqrt(83949))^(2/3)*exp(-t*((-594 + 6*I*sqrt(83949))^(2/3)/3 + (-594 + 6*I*sqrt(83949))^(1/3) + 50)/(-594 + 6*I*sqrt(83949))^(1/3))/(1154736*(sqrt(83949)*I + 27983/33)*(sqrt(83949)*I - 99)*exp(t)):
int(integrand,t)
Download handler_trig_exp_only_nov_18_2023.mw
But the trick of using evala() to avoid this error does not always work. Here is an example below. So need to find another workaround for this.
integrand2:=1/40406522112*I*(-594+6*I*3^(1/2)*27983^(1/2))^(2/3)*exp(t*(5/3*3^(1/2)*2^(1/2)
*sin(1/3*arctan(1/99*83949^(1/2))+1/6*Pi)-5*cos(1/3*arctan(1/99*83949^(1/2))+1/
6*Pi)*2^(1/2)-1))*(150+I*(-150+(-594+6*I*3^(1/2)*27983^(1/2))^(2/3))*3^(1/2)+(-\
594+6*I*3^(1/2)*27983^(1/2))^(2/3)-24*(-594+6*I*3^(1/2)*27983^(1/2))^(1/3))*(
2265+(276+I*(27983^(1/2)+92)*3^(1/2)-27983^(1/2))*(-594+6*I*3^(1/2)*27983^(1/2)
)^(1/3)+5*I*(-151+3*27983^(1/2))*3^(1/2)+15*27983^(1/2))*(2265-25*(-594+6*I*3^(
1/2)*27983^(1/2))^(2/3)+(276+I*(-276+27983^(1/2))*3^(1/2)+3*27983^(1/2))*(-594+
6*I*3^(1/2)*27983^(1/2))^(1/3)+15*I*(151+27983^(1/2))*3^(1/2)-45*27983^(1/2))*(
(-594+6*I*3^(1/2)*27983^(1/2))^(2/3)+12*(-594+6*I*3^(1/2)*27983^(1/2))^(1/3)+
150)*3^(1/2)*(-150+I*(-150+(-594+6*I*3^(1/2)*27983^(1/2))^(2/3))*3^(1/2)-(-594+
6*I*3^(1/2)*27983^(1/2))^(2/3)+24*(-594+6*I*3^(1/2)*27983^(1/2))^(1/3))/(I*3^(1
/2)*27983^(1/2)+27983/33)/(I*3^(1/2)*27983^(1/2)-99)^2/exp(t)*sin(t)*cos(t)-1/
20785248*I*(I*(-594+6*I*3^(1/2)*27983^(1/2))^(2/3)*3^(1/2)+(-594+6*I*3^(1/2)*
27983^(1/2))^(2/3)-150*I*3^(1/2)-24*(-594+6*I*3^(1/2)*27983^(1/2))^(1/3)+150)*
exp(5/3*3^(1/2)*sin(1/3*arctan(1/99*83949^(1/2))+1/6*Pi)*2^(1/2)*t-5*cos(1/3*
arctan(1/99*83949^(1/2))+1/6*Pi)*2^(1/2)*t-t)*(2265-25*(-594+6*I*3^(1/2)*27983^
(1/2))^(2/3)+(276+I*(-276+27983^(1/2))*3^(1/2)+3*27983^(1/2))*(-594+6*I*3^(1/2)
*27983^(1/2))^(1/3)+15*I*(151+27983^(1/2))*3^(1/2)-45*27983^(1/2))*(2265+(276+I
*(27983^(1/2)+92)*3^(1/2)-27983^(1/2))*(-594+6*I*3^(1/2)*27983^(1/2))^(1/3)+5*I
*(-151+3*27983^(1/2))*3^(1/2)+15*27983^(1/2))*(-594+6*I*3^(1/2)*27983^(1/2))^(1
/3)*3^(1/2)/(I*3^(1/2)*27983^(1/2)+27983/33)/(I*3^(1/2)*27983^(1/2)-99)*(8/exp(
t)*cos(t)^2-4/exp(t))+1/13856832*I*(-594+6*I*3^(1/2)*27983^(1/2))^(2/3)*(-450+I
*(-150+(-594+6*I*3^(1/2)*27983^(1/2))^(2/3))*3^(1/2)-3*(-594+6*I*3^(1/2)*27983^
(1/2))^(2/3))*exp(t*(5/3*3^(1/2)*2^(1/2)*sin(1/3*arctan(1/99*83949^(1/2))+1/6*
Pi)-5*cos(1/3*arctan(1/99*83949^(1/2))+1/6*Pi)*2^(1/2)-1))*(150+I*(-150+(-594+6
*I*3^(1/2)*27983^(1/2))^(2/3))*3^(1/2)+(-594+6*I*3^(1/2)*27983^(1/2))^(2/3)-24*
(-594+6*I*3^(1/2)*27983^(1/2))^(1/3))*(2265-25*(-594+6*I*3^(1/2)*27983^(1/2))^(
2/3)+(276+I*(-276+27983^(1/2))*3^(1/2)+3*27983^(1/2))*(-594+6*I*3^(1/2)*27983^(
1/2))^(1/3)+15*I*(151+27983^(1/2))*3^(1/2)-45*27983^(1/2))*3^(1/2)/(I*3^(1/2)*
27983^(1/2)+27983/33)/(I*3^(1/2)*27983^(1/2)-99)/exp(t):
int(integrand2,t);
int(evala(integrand2),t);
Download handler_trig_exp_version_2.mw
ps. send to Maplesoft support.
Why aren't all the variables in fin 1 equation?
And the answers are different from the solutions?
with(student)
eq1 := 12*gamma^3*rho[3]^2*(diff(w(psi), `$`(psi, 2)))+(-3*gamma*rho[2]^2+4*omega*rho[3]^2)*w(psi)+gamma*rho[3]^2*(rho[1]+2*rho[3])*w(psi)^3
12*gamma^3*rho[3]^2*(diff(diff(w(psi), psi), psi))+(-3*gamma*rho[2]^2+4*omega*rho[3]^2)*w(psi)+gamma*rho[3]^2*(rho[1]+2*rho[3])*w(psi)^3
"w(psi):=kappa[0]+sum(kappa[i]*((diff(E,psi))^(i))/((E(psi))^(i)),i=1..1)+sum(h[i]*(((diff(E,psi))^())/((E(psi))^()))^(-i),i=1..1);"
proc (psi) options operator, arrow, function_assign; kappa[0]+sum(kappa[i]*(diff(E, psi))^i/E(psi)^i, i = 1 .. 1)+sum(h[i]*((diff(E, psi))/E(psi))^(-i), i = 1 .. 1) end proc
"E(psi):=((epsilon[1]*jacobiCN(Zeta[1]*psi))+(epsilon[2]*jacobiSN(Zeta[2]*psi)))/((epsilon[3]*jacobiCN(Zeta[3]*psi))+(epsilon[4]*jacobiSN(Zeta[4]*psi))) ;"
proc (psi) options operator, arrow, function_assign; (varepsilon[1]*jacobiCN(Zeta[1]*psi)+varepsilon[2]*jacobiSN(Zeta[2]*psi))/(varepsilon[3]*jacobiCN(Zeta[3]*psi)+varepsilon[4]*jacobiSN(Zeta[4]*psi)) end proc
fin1 := simplify(eq1)
kappa[0]*(gamma*rho[3]^2*(rho[1]+2*rho[3])*kappa[0]^2-3*gamma*rho[2]^2+4*omega*rho[3]^2)
Sol := solve(fin1, {omega, Zeta[1], Zeta[2], Zeta[3], Zeta[4], epsilon[1], epsilon[2], epsilon[3], epsilon[4], h[1], kappa[0], kappa[1]})
{omega = omega, Zeta[1] = Zeta[1], Zeta[2] = Zeta[2], Zeta[3] = Zeta[3], Zeta[4] = Zeta[4], h[1] = h[1], kappa[0] = 0, kappa[1] = kappa[1], varepsilon[1] = varepsilon[1], varepsilon[2] = varepsilon[2], varepsilon[3] = varepsilon[3], varepsilon[4] = varepsilon[4]}, {omega = -(1/4)*gamma*(kappa[0]^2*rho[1]*rho[3]^2+2*kappa[0]^2*rho[3]^3-3*rho[2]^2)/rho[3]^2, Zeta[1] = Zeta[1], Zeta[2] = Zeta[2], Zeta[3] = Zeta[3], Zeta[4] = Zeta[4], h[1] = h[1], kappa[0] = kappa[0], kappa[1] = kappa[1], varepsilon[1] = varepsilon[1], varepsilon[2] = varepsilon[2], varepsilon[3] = varepsilon[3], varepsilon[4] = varepsilon[4]}
for i to 2 do Case[i] := allvalues(Sol[i]) end do
Download 0123.mw
Since C2=D1.D1inv should be equal to I. But return is just an expression (see attached). Further, how to obtain residue for a function C2?
residue.mw
MmaTranslator:-Mma:-Chop  does not seem to work as advertised.. It is supposed to work like Mathematica's Chop, but it does not. Is this by design or is it a bug?
MmaTranslator:-Mma:-Chop(((1.378834798932344*10^(-15))*I)*t) ;
returns the same input (1.378834799*10^(-15))*I*t but
MmaTranslator:-Mma:-Chop(((1.378834798932344*10^(-15))*I));
now returns 0.
But compare to Mathematica:
This makes it not very useful to use if one has to remove all symbols from an expression first, Any workaround? Here is an actual example where I wanted to use it
ode:=[diff(x(t), t) = -3*x(t) + 4*y(t), diff(y(t), t) = 5*x(t) + 9*z(t), diff(z(t), t) = y(t) + 6*z(t)];
sol:=dsolve(ode):
evalf[16](sol);
gives
Gives
{x(t) = (0.8172764110864494 - (7.853170607134887*10^(-16))*I)*c__1*exp((1.894304969211800 - (1.378834798932344*10^(-15))*I)*t) - (1.150854759654687 + (3.398186702482929*10^(-16))*I)*c__2*exp((-6.475677505300665 + (3.730232887526917*10^(-17))*I)*t) + (0.3780227930126823 + (9.268277369231981*10^(-16))*I)*c__3*exp((7.581372536088866 + (1.198480681985453*10^(-15))*I)*t), y(t) = c__1*exp((1.894304969211800 - (1.378834798932344*10^(-15))*I)*t) + c__2*exp((-6.475677505300665 + (3.730232887526917*10^(-17))*I)*t) + c__3*exp((7.581372536088866 + (1.198480681985453*10^(-15))*I)*t), z(t) = (-0.2435641206911610 + (1.431838044809606*10^(-16))*I)*c__1*exp((1.894304969211800 - (1.378834798932344*10^(-15))*I)*t) + (-0.08015596744746927 + (4.286632781083632*10^(-16))*I)*c__2*exp((-6.475677505300665 + (3.730232887526917*10^(-17))*I)*t) + (0.6323620634472722 - (5.261170533293161*10^(-16))*I)*c__3*exp((7.581372536088866 + (1.198480681985453*10^(-15))*I)*t)}
But Chop does not work on this.
Maple 2023.2
There seems to be a consensus about using ListTools:-SearchAll to locate an item in a list. However, this subroutine does not work on other expressions; A simple instance is that “ListTools:-SearchAll(1, [[1], 1]);” only outputs  while what I need is  (because both “op([1, 1], [[1], 1])” and “op([2], [[1], 1])” are ). And actually, I hope that there is a more general version in Maple.
For example, I intend to do something like
expr, elem := ToInert(eval(`print/Diff`)), '_Inert_NAME'("_syslib"):
SearchAll(elem, expr);
List:=[[[[cS,[[[cS,cS],cS],[[[cS,cS],[[cK,cK],cS]],cS]]],cS],cS],[[[cS,[[cK,cS],cK]],cK],cS]]:
items:=Or([[[identical(cS),anything],anything],anything],[[identical(cK),anything],anything]):
SearchAll(items,List);
In other words, I need all positions of an operand of an expression (cf. op).
It may be manually checked that the "indices" of  in  include [5,1,1,2,1,1,1,2,1,2,1,2], [5,1,2,2,1,1,1,1,2,1,2], and [5,2,2,1,1,3,1,2], since
patmatch(op([5, 1, 1, 2, 1, 1, 1, 2, 1, 2, 1, 2], expr), elem);
patmatch(op([5, 1, 2, 2, 1, 1, 1, 1, 2, 1, 2], expr), elem);
patmatch(op([5, 2, 2, 1, 1, 3, 1, 2], expr), elem);
Similarly, after some manual searchs,
[[1], [1, 1, 1, 2], [1, 1, 1, 2, 2], [1, 1, 1, 2, 2, 1, 2], [2], [2, 1, 1, 2]]:
convert(typematch~(map2(`?[]`, List, `%`), items), `and`);
It turns out that all "indices" in  of  are [1][1,1,1,2][1,1,1,2,2][1,1,1,2,2,1,2][2], and [2,1,1,2].
But isn't there such a  command that can eliminate the need to manually retrieve them?
When the original poster receives or finds the answer to the question he/she posed, should he/she
  1. Reply to it
  2. Answer to it?
I have seen "true answers" that were converted to a reply, despite addressing the initial answer correctly. In case there are no other answers, the question will still be listed under unanswered question which is incorrect.
What practice should be applied in MaplePrimes for "true answers"?
I'm stucked in trying to prove that rel(n)  is true for each integer n > 1.
rel := n -> (n-3)^(n/(n-1))*2^(n/(n-1))-((n-1)*2^(n/(n-1))-4*2^(1/(n-1)))*(n-3)^(1/(n-1)) = 0
proc (n) options operator, arrow; (n-3)^(n/(n-1))*2^(n/(n-1))-((n-1)*2^(n/(n-1))-4*2^(1/(n-1)))*(n-3)^(1/(n-1)) = 0 end proc
Download Prove_It_True.mw
Do you have any idea to do this?
TIA
Would Any one be able to give some explanation as to why calling a proc, which does not change anything globally but only acts on the input given, returns different answer the second time it is called with the same exact input? I am not able to understand this result at all.
Maple 2023.2 on windows 10.
W:=Matrix(3, 3, [[x^(1/12*(44+12*69^(1/2))^(1/3)-5/3/(44+12*69^(1/2))^(1/3)+2/3)*cos(1/2*3^(1/2)*(-1/6*(44+12*69^(1/2))^(1/3)-10/3/(44+12*69^(1/2))^(1/3))*ln(x)),-x^(1/12*(44+12*69^(1/2))^(1/3)-5/3/(44+12*69^(1/2))^(1/3)+2/3)*sin(1/2*3^(1/2)*(-1/6*(44+12*69^(1/2))^(1/3)-10/3/(44+12*69^(1/2))^(1/3))*ln(x)),x^(-1/6*(44+12*69^(1/2))^(1/3)+10/3/(44+12*69^(1/2))^(1/3)+2/3)],[x^(1/12*(44+12*69^(1/2))^(1/3)-5/3/(44+12*69^(1/2))^(1/3)+2/3)*(1/12*(44+12*69^(1/2))^(1/3)-5/3/(44+12*69^(1/2))^(1/3)+2/3)/x*cos(1/2*3^(1/2)*(-1/6*(44+12*69^(1/2))^(1/3)-10/3/(44+12*69^(1/2))^(1/3))*ln(x))-1/2*x^(1/12*(44+12*69^(1/2))^(1/3)-5/3/(44+12*69^(1/2))^(1/3)+2/3)*3^(1/2)*(-1/6*(44+12*69^(1/2))^(1/3)-10/3/(44+12*69^(1/2))^(1/3))/x*sin(1/2*3^(1/2)*(-1/6*(44+12*69^(1/2))^(1/3)-10/3/(44+12*69^(1/2))^(1/3))*ln(x)),-x^(1/12*(44+12*69^(1/2))^(1/3)-5/3/(44+12*69^(1/2))^(1/3)+2/3)*(1/12*(44+12*69^(1/2))^(1/3)-5/3/(44+12*69^(1/2))^(1/3)+2/3)/x*sin(1/2*3^(1/2)*(-1/6*(44+12*69^(1/2))^(1/3)-10/3/(44+12*69^(1/2))^(1/3))*ln(x))-1/2*x^(1/12*(44+12*69^(1/2))^(1/3)-5/3/(44+12*69^(1/2))^(1/3)+2/3)*3^(1/2)*(-1/6*(44+12*69^(1/2))^(1/3)-10/3/(44+12*69^(1/2))^(1/3))/x*cos(1/2*3^(1/2)*(-1/6*(44+12*69^(1/2))^(1/3)-10/3/(44+12*69^(1/2))^(1/3))*ln(x)),x^(-1/6*(44+12*69^(1/2))^(1/3)+10/3/(44+12*69^(1/2))^(1/3)+2/3)*(-1/6*(44+12*69^(1/2))^(1/3)+10/3/(44+12*69^(1/2))^(1/3)+2/3)/x],[x^(1/12*(44+12*69^(1/2))^(1/3)-5/3/(44+12*69^(1/2))^(1/3)+2/3)*(1/12*(44+12*69^(1/2))^(1/3)-5/3/(44+12*69^(1/2))^(1/3)+2/3)^2/x^2*cos(1/2*3^(1/2)*(-1/6*(44+12*69^(1/2))^(1/3)-10/3/(44+12*69^(1/2))^(1/3))*ln(x))-x^(1/12*(44+12*69^(1/2))^(1/3)-5/3/(44+12*69^(1/2))^(1/3)+2/3)*(1/12*(44+12*69^(1/2))^(1/3)-5/3/(44+12*69^(1/2))^(1/3)+2/3)/x^2*cos(1/2*3^(1/2)*(-1/6*(44+12*69^(1/2))^(1/3)-10/3/(44+12*69^(1/2))^(1/3))*ln(x))-x^(1/12*(44+12*69^(1/2))^(1/3)-5/3/(44+12*69^(1/2))^(1/3)+2/3)*(1/12*(44+12*69^(1/2))^(1/3)-5/3/(44+12*69^(1/2))^(1/3)+2/3)/x^2*3^(1/2)*(-1/6*(44+12*69^(1/2))^(1/3)-10/3/(44+12*69^(1/2))^(1/3))*sin(1/2*3^(1/2)*(-1/6*(44+12*69^(1/2))^(1/3)-10/3/(44+12*69^(1/2))^(1/3))*ln(x))+1/2*x^(1/12*(44+12*69^(1/2))^(1/3)-5/3/(44+12*69^(1/2))^(1/3)+2/3)*3^(1/2)*(-1/6*(44+12*69^(1/2))^(1/3)-10/3/(44+12*69^(1/2))^(1/3))/x^2*sin(1/2*3^(1/2)*(-1/6*(44+12*69^(1/2))^(1/3)-10/3/(44+12*69^(1/2))^(1/3))*ln(x))-3/4*x^(1/12*(44+12*69^(1/2))^(1/3)-5/3/(44+12*69^(1/2))^(1/3)+2/3)*(-1/6*(44+12*69^(1/2))^(1/3)-10/3/(44+12*69^(1/2))^(1/3))^2/x^2*cos(1/2*3^(1/2)*(-1/6*(44+12*69^(1/2))^(1/3)-10/3/(44+12*69^(1/2))^(1/3))*ln(x)),-x^(1/12*(44+12*69^(1/2))^(1/3)-5/3/(44+12*69^(1/2))^(1/3)+2/3)*(1/12*(44+12*69^(1/2))^(1/3)-5/3/(44+12*69^(1/2))^(1/3)+2/3)^2/x^2*sin(1/2*3^(1/2)*(-1/6*(44+12*69^(1/2))^(1/3)-10/3/(44+12*69^(1/2))^(1/3))*ln(x))+x^(1/12*(44+12*69^(1/2))^(1/3)-5/3/(44+12*69^(1/2))^(1/3)+2/3)*(1/12*(44+12*69^(1/2))^(1/3)-5/3/(44+12*69^(1/2))^(1/3)+2/3)/x^2*sin(1/2*3^(1/2)*(-1/6*(44+12*69^(1/2))^(1/3)-10/3/(44+12*69^(1/2))^(1/3))*ln(x))-x^(1/12*(44+12*69^(1/2))^(1/3)-5/3/(44+12*69^(1/2))^(1/3)+2/3)*(1/12*(44+12*69^(1/2))^(1/3)-5/3/(44+12*69^(1/2))^(1/3)+2/3)/x^2*3^(1/2)*(-1/6*(44+12*69^(1/2))^(1/3)-10/3/(44+12*69^(1/2))^(1/3))*cos(1/2*3^(1/2)*(-1/6*(44+12*69^(1/2))^(1/3)-10/3/(44+12*69^(1/2))^(1/3))*ln(x))+1/2*x^(1/12*(44+12*69^(1/2))^(1/3)-5/3/(44+12*69^(1/2))^(1/3)+2/3)*3^(1/2)*(-1/6*(44+12*69^(1/2))^(1/3)-10/3/(44+12*69^(1/2))^(1/3))/x^2*cos(1/2*3^(1/2)*(-1/6*(44+12*69^(1/2))^(1/3)-10/3/(44+12*69^(1/2))^(1/3))*ln(x))+3/4*x^(1/12*(44+12*69^(1/2))^(1/3)-5/3/(44+12*69^(1/2))^(1/3)+2/3)*(-1/6*(44+12*69^(1/2))^(1/3)-10/3/(44+12*69^(1/2))^(1/3))^2/x^2*sin(1/2*3^(1/2)*(-1/6*(44+12*69^(1/2))^(1/3)-10/3/(44+12*69^(1/2))^(1/3))*ln(x)),x^(-1/6*(44+12*69^(1/2))^(1/3)+10/3/(44+12*69^(1/2))^(1/3)+2/3)*(-1/6*(44+12*69^(1/2))^(1/3)+10/3/(44+12*69^(1/2))^(1/3)+2/3)^2/x^2-x^(-1/6*(44+12*69^(1/2))^(1/3)+10/3/(44+12*69^(1/2))^(1/3)+2/3)*(-1/6*(44+12*69^(1/2))^(1/3)+10/3/(44+12*69^(1/2))^(1/3)+2/3)/x^2]]):
foo:=proc(W::Matrix,x::symbol)
   local W1:=W,W_det,W1_det;
   local F:=2*x^3-ln(x):
   W_det := LinearAlgebra:-Determinant(W);
   #change the first column
   W1[1..3,1] := Vector['column']([0,0,F/x^3]):
   W1_det := simplify(LinearAlgebra:-Determinant(W1)):
   simplify(W1_det/W_det);
foo(W,x);
-x^(-(1/12)*((44+12*3^(1/2)*23^(1/2))^(2/3)+20*(44+12*3^(1/2)*23^(1/2))^(1/3)-20)/(44+12*3^(1/2)*23^(1/2))^(1/3))*(x^3-(1/2)*ln(x))*(3^(1/2)*((44+12*3^(1/2)*23^(1/2))^(2/3)+20)*cos((1/12)*3^(1/2)*((44+12*3^(1/2)*23^(1/2))^(2/3)+20)*ln(x)/(44+12*3^(1/2)*23^(1/2))^(1/3))+3*sin((1/12)*3^(1/2)*((44+12*3^(1/2)*23^(1/2))^(2/3)+20)*ln(x)/(44+12*3^(1/2)*23^(1/2))^(1/3))*((44+12*3^(1/2)*23^(1/2))^(2/3)-20))*3^(1/2)*(3^(1/2)*23^(1/2)+11/3)/((44+12*3^(1/2)*23^(1/2))^(1/3)*(11*3^(1/2)*23^(1/2)+207))
foo(W,x)
Download why_different_answer.mw
Hi there
I am using the Determinant() function in maple to calculate the determinant of 32 by 32 matrix consisting of variables like x1,x2, x3... as well as the products of these variables. This determinant calculation works very well less for 16x16 matrices. However in the 32 by 32 case it takes days and still no result (attached and below you can see the matrix) My first question is that problem actually solvable in reasonable time like within 2 days and do you have any advice how I can achieve this goal.
Thx
Rgds
Birol
1,x5,x4,x4*x5,x1,x1*x5,x1*x4,x1*x4*x5,x2*x5,x2,x2*x4*x5,x2*x4,x1*x2*x5,x1*x2,x1*x2*x4*x5,x1*x2*x4,x1*x3,x1*x3*x5,x1*x3*x4,x1*x3*x4*x5,x3,x3*x5,x3*x4,x3*x4*x5,x1*x2*x3*x5,x1*x2*x3,x1*x2*x3*x4*x5,x1*x2*x3*x4,x2*x3*x5,x2*x3,x2*x3*x4*x5,x2*x3*x4
x5,1,x4*x5,x4,x1*x5,x1,x1*x4*x5,x1*x4,x2,x2*x5,x2*x4,x2*x4*x5,x1*x2,x1*x2*x5,x1*x2*x4,x1*x2*x4*x5,x1*x3*x5,x1*x3,x1*x3*x4*x5,x1*x3*x4,x3*x5,x3,x3*x4*x5,x3*x4,x1*x2*x3,x1*x2*x3*x5,x1*x2*x3*x4,x1*x2*x3*x4*x5,x2*x3,x2*x3*x5,x2*x3*x4,x2*x3*x4*x5
x4,x4*x5,1,x5,x1*x4,x1*x4*x5,x1,x1*x5,x2*x4*x5,x2*x4,x2*x5,x2,x1*x2*x4*x5,x1*x2*x4,x1*x2*x5,x1*x2,x1*x3*x4,x1*x3*x4*x5,x1*x3,x1*x3*x5,x3*x4,x3*x4*x5,x3,x3*x5,x1*x2*x3*x4*x5,x1*x2*x3*x4,x1*x2*x3*x5,x1*x2*x3,x2*x3*x4*x5,x2*x3*x4,x2*x3*x5,x2*x3
x4*x5,x4,x5,1,x1*x4*x5,x1*x4,x1*x5,x1,x2*x4,x2*x4*x5,x2,x2*x5,x1*x2*x4,x1*x2*x4*x5,x1*x2,x1*x2*x5,x1*x3*x4*x5,x1*x3*x4,x1*x3*x5,x1*x3,x3*x4*x5,x3*x4,x3*x5,x3,x1*x2*x3*x4,x1*x2*x3*x4*x5,x1*x2*x3,x1*x2*x3*x5,x2*x3*x4,x2*x3*x4*x5,x2*x3,x2*x3*x5
x1,x1*x5,x1*x4,x1*x4*x5,1,x5,x4,x4*x5,x1*x2*x5,x1*x2,x1*x2*x4*x5,x1*x2*x4,x2*x5,x2,x2*x4*x5,x2*x4,x3,x3*x5,x3*x4,x3*x4*x5,x1*x3,x1*x3*x5,x1*x3*x4,x1*x3*x4*x5,x2*x3*x5,x2*x3,x2*x3*x4*x5,x2*x3*x4,x1*x2*x3*x5,x1*x2*x3,x1*x2*x3*x4*x5,x1*x2*x3*x4
x1*x5,x1,x1*x4*x5,x1*x4,x5,1,x4*x5,x4,x1*x2,x1*x2*x5,x1*x2*x4,x1*x2*x4*x5,x2,x2*x5,x2*x4,x2*x4*x5,x3*x5,x3,x3*x4*x5,x3*x4,x1*x3*x5,x1*x3,x1*x3*x4*x5,x1*x3*x4,x2*x3,x2*x3*x5,x2*x3*x4,x2*x3*x4*x5,x1*x2*x3,x1*x2*x3*x5,x1*x2*x3*x4,x1*x2*x3*x4*x5
x1*x4,x1*x4*x5,x1,x1*x5,x4,x4*x5,1,x5,x1*x2*x4*x5,x1*x2*x4,x1*x2*x5,x1*x2,x2*x4*x5,x2*x4,x2*x5,x2,x3*x4,x3*x4*x5,x3,x3*x5,x1*x3*x4,x1*x3*x4*x5,x1*x3,x1*x3*x5,x2*x3*x4*x5,x2*x3*x4,x2*x3*x5,x2*x3,x1*x2*x3*x4*x5,x1*x2*x3*x4,x1*x2*x3*x5,x1*x2*x3
x1*x4*x5,x1*x4,x1*x5,x1,x4*x5,x4,x5,1,x1*x2*x4,x1*x2*x4*x5,x1*x2,x1*x2*x5,x2*x4,x2*x4*x5,x2,x2*x5,x3*x4*x5,x3*x4,x3*x5,x3,x1*x3*x4*x5,x1*x3*x4,x1*x3*x5,x1*x3,x2*x3*x4,x2*x3*x4*x5,x2*x3,x2*x3*x5,x1*x2*x3*x4,x1*x2*x3*x4*x5,x1*x2*x3,x1*x2*x3*x5
x2*x5,x2,x2*x4*x5,x2*x4,x1*x2*x5,x1*x2,x1*x2*x4*x5,x1*x2*x4,1,x5,x4,x4*x5,x1,x1*x5,x1*x4,x1*x4*x5,x1*x2*x3*x5,x1*x2*x3,x1*x2*x3*x4*x5,x1*x2*x3*x4,x2*x3*x5,x2*x3,x2*x3*x4*x5,x2*x3*x4,x1*x3,x1*x3*x5,x1*x3*x4,x1*x3*x4*x5,x3,x3*x5,x3*x4,x3*x4*x5
x2,x2*x5,x2*x4,x2*x4*x5,x1*x2,x1*x2*x5,x1*x2*x4,x1*x2*x4*x5,x5,1,x4*x5,x4,x1*x5,x1,x1*x4*x5,x1*x4,x1*x2*x3,x1*x2*x3*x5,x1*x2*x3*x4,x1*x2*x3*x4*x5,x2*x3,x2*x3*x5,x2*x3*x4,x2*x3*x4*x5,x1*x3*x5,x1*x3,x1*x3*x4*x5,x1*x3*x4,x3*x5,x3,x3*x4*x5,x3*x4
x2*x4*x5,x2*x4,x2*x5,x2,x1*x2*x4*x5,x1*x2*x4,x1*x2*x5,x1*x2,x4,x4*x5,1,x5,x1*x4,x1*x4*x5,x1,x1*x5,x1*x2*x3*x4*x5,x1*x2*x3*x4,x1*x2*x3*x5,x1*x2*x3,x2*x3*x4*x5,x2*x3*x4,x2*x3*x5,x2*x3,x1*x3*x4,x1*x3*x4*x5,x1*x3,x1*x3*x5,x3*x4,x3*x4*x5,x3,x3*x5
x2*x4,x2*x4*x5,x2,x2*x5,x1*x2*x4,x1*x2*x4*x5,x1*x2,x1*x2*x5,x4*x5,x4,x5,1,x1*x4*x5,x1*x4,x1*x5,x1,x1*x2*x3*x4,x1*x2*x3*x4*x5,x1*x2*x3,x1*x2*x3*x5,x2*x3*x4,x2*x3*x4*x5,x2*x3,x2*x3*x5,x1*x3*x4*x5,x1*x3*x4,x1*x3*x5,x1*x3,x3*x4*x5,x3*x4,x3*x5,x3
x1*x2*x5,x1*x2,x1*x2*x4*x5,x1*x2*x4,x2*x5,x2,x2*x4*x5,x2*x4,x1,x1*x5,x1*x4,x1*x4*x5,1,x5,x4,x4*x5,x2*x3*x5,x2*x3,x2*x3*x4*x5,x2*x3*x4,x1*x2*x3*x5,x1*x2*x3,x1*x2*x3*x4*x5,x1*x2*x3*x4,x3,x3*x5,x3*x4,x3*x4*x5,x1*x3,x1*x3*x5,x1*x3*x4,x1*x3*x4*x5
x1*x2,x1*x2*x5,x1*x2*x4,x1*x2*x4*x5,x2,x2*x5,x2*x4,x2*x4*x5,x1*x5,x1,x1*x4*x5,x1*x4,x5,1,x4*x5,x4,x2*x3,x2*x3*x5,x2*x3*x4,x2*x3*x4*x5,x1*x2*x3,x1*x2*x3*x5,x1*x2*x3*x4,x1*x2*x3*x4*x5,x3*x5,x3,x3*x4*x5,x3*x4,x1*x3*x5,x1*x3,x1*x3*x4*x5,x1*x3*x4
x1*x2*x4*x5,x1*x2*x4,x1*x2*x5,x1*x2,x2*x4*x5,x2*x4,x2*x5,x2,x1*x4,x1*x4*x5,x1,x1*x5,x4,x4*x5,1,x5,x2*x3*x4*x5,x2*x3*x4,x2*x3*x5,x2*x3,x1*x2*x3*x4*x5,x1*x2*x3*x4,x1*x2*x3*x5,x1*x2*x3,x3*x4,x3*x4*x5,x3,x3*x5,x1*x3*x4,x1*x3*x4*x5,x1*x3,x1*x3*x5
x1*x2*x4,x1*x2*x4*x5,x1*x2,x1*x2*x5,x2*x4,x2*x4*x5,x2,x2*x5,x1*x4*x5,x1*x4,x1*x5,x1,x4*x5,x4,x5,1,x2*x3*x4,x2*x3*x4*x5,x2*x3,x2*x3*x5,x1*x2*x3*x4,x1*x2*x3*x4*x5,x1*x2*x3,x1*x2*x3*x5,x3*x4*x5,x3*x4,x3*x5,x3,x1*x3*x4*x5,x1*x3*x4,x1*x3*x5,x1*x3
x1*x3,x1*x3*x5,x1*x3*x4,x1*x3*x4*x5,x3,x3*x5,x3*x4,x3*x4*x5,x1*x2*x3*x5,x1*x2*x3,x1*x2*x3*x4*x5,x1*x2*x3*x4,x2*x3*x5,x2*x3,x2*x3*x4*x5,x2*x3*x4,1,x5,x4,x4*x5,x1,x1*x5,x1*x4,x1*x4*x5,x2*x5,x2,x2*x4*x5,x2*x4,x1*x2*x5,x1*x2,x1*x2*x4*x5,x1*x2*x4
x1*x3*x5,x1*x3,x1*x3*x4*x5,x1*x3*x4,x3*x5,x3,x3*x4*x5,x3*x4,x1*x2*x3,x1*x2*x3*x5,x1*x2*x3*x4,x1*x2*x3*x4*x5,x2*x3,x2*x3*x5,x2*x3*x4,x2*x3*x4*x5,x5,1,x4*x5,x4,x1*x5,x1,x1*x4*x5,x1*x4,x2,x2*x5,x2*x4,x2*x4*x5,x1*x2,x1*x2*x5,x1*x2*x4,x1*x2*x4*x5
x1*x3*x4,x1*x3*x4*x5,x1*x3,x1*x3*x5,x3*x4,x3*x4*x5,x3,x3*x5,x1*x2*x3*x4*x5,x1*x2*x3*x4,x1*x2*x3*x5,x1*x2*x3,x2*x3*x4*x5,x2*x3*x4,x2*x3*x5,x2*x3,x4,x4*x5,1,x5,x1*x4,x1*x4*x5,x1,x1*x5,x2*x4*x5,x2*x4,x2*x5,x2,x1*x2*x4*x5,x1*x2*x4,x1*x2*x5,x1*x2
x1*x3*x4*x5,x1*x3*x4,x1*x3*x5,x1*x3,x3*x4*x5,x3*x4,x3*x5,x3,x1*x2*x3*x4,x1*x2*x3*x4*x5,x1*x2*x3,x1*x2*x3*x5,x2*x3*x4,x2*x3*x4*x5,x2*x3,x2*x3*x5,x4*x5,x4,x5,1,x1*x4*x5,x1*x4,x1*x5,x1,x2*x4,x2*x4*x5,x2,x2*x5,x1*x2*x4,x1*x2*x4*x5,x1*x2,x1*x2*x5
x3,x3*x5,x3*x4,x3*x4*x5,x1*x3,x1*x3*x5,x1*x3*x4,x1*x3*x4*x5,x2*x3*x5,x2*x3,x2*x3*x4*x5,x2*x3*x4,x1*x2*x3*x5,x1*x2*x3,x1*x2*x3*x4*x5,x1*x2*x3*x4,x1,x1*x5,x1*x4,x1*x4*x5,1,x5,x4,x4*x5,x1*x2*x5,x1*x2,x1*x2*x4*x5,x1*x2*x4,x2*x5,x2,x2*x4*x5,x2*x4
x3*x5,x3,x3*x4*x5,x3*x4,x1*x3*x5,x1*x3,x1*x3*x4*x5,x1*x3*x4,x2*x3,x2*x3*x5,x2*x3*x4,x2*x3*x4*x5,x1*x2*x3,x1*x2*x3*x5,x1*x2*x3*x4,x1*x2*x3*x4*x5,x1*x5,x1,x1*x4*x5,x1*x4,x5,1,x4*x5,x4,x1*x2,x1*x2*x5,x1*x2*x4,x1*x2*x4*x5,x2,x2*x5,x2*x4,x2*x4*x5
x3*x4,x3*x4*x5,x3,x3*x5,x1*x3*x4,x1*x3*x4*x5,x1*x3,x1*x3*x5,x2*x3*x4*x5,x2*x3*x4,x2*x3*x5,x2*x3,x1*x2*x3*x4*x5,x1*x2*x3*x4,x1*x2*x3*x5,x1*x2*x3,x1*x4,x1*x4*x5,x1,x1*x5,x4,x4*x5,1,x5,x1*x2*x4*x5,x1*x2*x4,x1*x2*x5,x1*x2,x2*x4*x5,x2*x4,x2*x5,x2
x3*x4*x5,x3*x4,x3*x5,x3,x1*x3*x4*x5,x1*x3*x4,x1*x3*x5,x1*x3,x2*x3*x4,x2*x3*x4*x5,x2*x3,x2*x3*x5,x1*x2*x3*x4,x1*x2*x3*x4*x5,x1*x2*x3,x1*x2*x3*x5,x1*x4*x5,x1*x4,x1*x5,x1,x4*x5,x4,x5,1,x1*x2*x4,x1*x2*x4*x5,x1*x2,x1*x2*x5,x2*x4,x2*x4*x5,x2,x2*x5
x1*x2*x3*x5,x1*x2*x3,x1*x2*x3*x4*x5,x1*x2*x3*x4,x2*x3*x5,x2*x3,x2*x3*x4*x5,x2*x3*x4,x1*x3,x1*x3*x5,x1*x3*x4,x1*x3*x4*x5,x3,x3*x5,x3*x4,x3*x4*x5,x2*x5,x2,x2*x4*x5,x2*x4,x1*x2*x5,x1*x2,x1*x2*x4*x5,x1*x2*x4,1,x5,x4,x4*x5,x1,x1*x5,x1*x4,x1*x4*x5
x1*x2*x3,x1*x2*x3*x5,x1*x2*x3*x4,x1*x2*x3*x4*x5,x2*x3,x2*x3*x5,x2*x3*x4,x2*x3*x4*x5,x1*x3*x5,x1*x3,x1*x3*x4*x5,x1*x3*x4,x3*x5,x3,x3*x4*x5,x3*x4,x2,x2*x5,x2*x4,x2*x4*x5,x1*x2,x1*x2*x5,x1*x2*x4,x1*x2*x4*x5,x5,1,x4*x5,x4,x1*x5,x1,x1*x4*x5,x1*x4
x1*x2*x3*x4*x5,x1*x2*x3*x4,x1*x2*x3*x5,x1*x2*x3,x2*x3*x4*x5,x2*x3*x4,x2*x3*x5,x2*x3,x1*x3*x4,x1*x3*x4*x5,x1*x3,x1*x3*x5,x3*x4,x3*x4*x5,x3,x3*x5,x2*x4*x5,x2*x4,x2*x5,x2,x1*x2*x4*x5,x1*x2*x4,x1*x2*x5,x1*x2,x4,x4*x5,1,x5,x1*x4,x1*x4*x5,x1,x1*x5
x1*x2*x3*x4,x1*x2*x3*x4*x5,x1*x2*x3,x1*x2*x3*x5,x2*x3*x4,x2*x3*x4*x5,x2*x3,x2*x3*x5,x1*x3*x4*x5,x1*x3*x4,x1*x3*x5,x1*x3,x3*x4*x5,x3*x4,x3*x5,x3,x2*x4,x2*x4*x5,x2,x2*x5,x1*x2*x4,x1*x2*x4*x5,x1*x2,x1*x2*x5,x4*x5,x4,x5,1,x1*x4*x5,x1*x4,x1*x5,x1
x2*x3*x5,x2*x3,x2*x3*x4*x5,x2*x3*x4,x1*x2*x3*x5,x1*x2*x3,x1*x2*x3*x4*x5,x1*x2*x3*x4,x3,x3*x5,x3*x4,x3*x4*x5,x1*x3,x1*x3*x5,x1*x3*x4,x1*x3*x4*x5,x1*x2*x5,x1*x2,x1*x2*x4*x5,x1*x2*x4,x2*x5,x2,x2*x4*x5,x2*x4,x1,x1*x5,x1*x4,x1*x4*x5,1,x5,x4,x4*x5
x2*x3,x2*x3*x5,x2*x3*x4,x2*x3*x4*x5,x1*x2*x3,x1*x2*x3*x5,x1*x2*x3*x4,x1*x2*x3*x4*x5,x3*x5,x3,x3*x4*x5,x3*x4,x1*x3*x5,x1*x3,x1*x3*x4*x5,x1*x3*x4,x1*x2,x1*x2*x5,x1*x2*x4,x1*x2*x4*x5,x2,x2*x5,x2*x4,x2*x4*x5,x1*x5,x1,x1*x4*x5,x1*x4,x5,1,x4*x5,x4
x2*x3*x4*x5,x2*x3*x4,x2*x3*x5,x2*x3,x1*x2*x3*x4*x5,x1*x2*x3*x4,x1*x2*x3*x5,x1*x2*x3,x3*x4,x3*x4*x5,x3,x3*x5,x1*x3*x4,x1*x3*x4*x5,x1*x3,x1*x3*x5,x1*x2*x4*x5,x1*x2*x4,x1*x2*x5,x1*x2,x2*x4*x5,x2*x4,x2*x5,x2,x1*x4,x1*x4*x5,x1,x1*x5,x4,x4*x5,1,x5
x2*x3*x4,x2*x3*x4*x5,x2*x3,x2*x3*x5,x1*x2*x3*x4,x1*x2*x3*x4*x5,x1*x2*x3,x1*x2*x3*x5,x3*x4*x5,x3*x4,x3*x5,x3,x1*x3*x4*x5,x1*x3*x4,x1*x3*x5,x1*x3,x1*x2*x4,x1*x2*x4*x5,x1*x2,x1*x2*x5,x2*x4,x2*x4*x5,x2,x2*x5,x1*x4*x5,x1*x4,x1*x5,x1,x4*x5,x4,x5,1
Download VarchenkoMatrix.txt
In an old question, @nm asked how to . While the answer in that question was almost up to the mark, there remains a regret.
As the instance listed below shows, Maple, by default, draws arrows on a rectangular grid (rather than on a hexagonal mesh):
  # Example of a three-dimensional vector field:
vf__2d := VectorCalculus:-VectorField([sin(x)*(cos(x) + cos(y)),
                                       sin(y)*(cos(x) - cos(y))], 'cartesian'[x, y]):
  # Example of a two-dimensional vector field:
vf__3d := VectorCalculus:-VectorField([1 - (sin(u - v) + sin(u - w)),
                                       1 - (sin(v - w) + sin(v - u)),
                                       1 - (sin(w - u) + sin(w - v))], 'cartesian'[u, v, w]):
  # Phase portrait.
Student:-VectorCalculus:-PlotVector(vf__2d, (x, y) =~ -Pi .. Pi,
                                            'grid' = [`$`](25, 2),
                                          'arrows' = 'THICK',
                                   'fieldstrength' = log[63],
                                           'color' = ColorTools:-Color("#0072BD"),
                                            'axes' = "box"(*, …omitted…*));
Note that I have changed some of the options in order to make the layout of arrows more prominent.
However, according to the help page of Mma's VectorPoints, among the following methods of location generation, Mma by default uses Hexagonal for 2D field vectors and FaceCenteredCubic for 3D field vector:
Here is a collection of different settings available in Mma:
So if the requirement is to get the Maple's output looking like Mathematica's (see the beginning), the number and placement of vectors to plot should be thought of as well. In Maple, “the number of vectors” can be controlled by the plot (or plot3d) opinion , but how do I specify “the placement of vectors” (e.g., Mma's "Hexagonal" and "Mesh")?
Although there exists an  chapter in the documentation, randomly positioned arrows do not fit the bill. Is there any workaround?
This is linear ode, third order, Euler type and inhomogeneous ode.
If I solve the homogeneous ode only, then ask Maple to give me a particular solution, then add these, I get much much smaller solution which Maple verifies is correct.
Now when asking Maple to solve the original inhomogeneous ode as is, the solution is much more complicated and much longer with unresolved integrals.
Why does not Maple give the simpler solution? Both are verified to be correct.
This is my theory: When asking maple to find only the particular solution, it seems to have used a different and advanced method to find yp. Which is new to me and trying to learn it. It is based on paper "D'Alembertian Solutions of Inhomogeneous Equations (differential, difference, and some other).
Undetermined coefficients method can't really be used on ode's such as this because its coefficients are not constant.
Now, when asking Maple to solve the inhomogeneous ode, it seems to have used variation of parameters method, which results in integrals, which can be hard to solve.
My question is: Why does not Maple give the same much shorter answer when asked to solve the ode as is? Should it not have done so? Any thoughts on why such large difference in answer? Why it did not use the same method to find yp when asked to solve the whole ode as that leads to much smaller and more elegant solution.
ps. debugging this, it uses LinearOperators:-dAsolver:-dAlembertianSolver which is called from ODEtools/particularsol/linear to find yp when calling DETools:-particularsol(ode); but for some reason, it does not do this when asking it to solve the whole ode directly (if it did, then one will expect same answer to result, right?)
#the ode
ode:=x^3*diff(y(x), x, x, x) + x^2*diff(y(x), x, x) + 2*x*diff(y(x), x) - y(x) = 2*x^3 - ln(x);
x^3*(diff(diff(diff(y(x), x), x), x))+x^2*(diff(diff(y(x), x), x))+2*x*(diff(y(x), x))-y(x) = 2*x^3-ln(x)
# find y_h
yh:=dsolve(lhs(ode)=0);
y(x) = c__1*x^(-(1/6)*((44+12*69^(1/2))^(2/3)-4*(44+12*69^(1/2))^(1/3)-20)/(44+12*69^(1/2))^(1/3))+c__2*x^((1/12)*(-20+(44+12*69^(1/2))^(2/3)+8*(44+12*69^(1/2))^(1/3))/(44+12*69^(1/2))^(1/3))*sin((1/12)*(3^(1/2)*(44+12*69^(1/2))^(2/3)+20*3^(1/2))*ln(x)/(44+12*69^(1/2))^(1/3))+c__3*x^((1/12)*(-20+(44+12*69^(1/2))^(2/3)+8*(44+12*69^(1/2))^(1/3))/(44+12*69^(1/2))^(1/3))*cos((1/12)*(3^(1/2)*(44+12*69^(1/2))^(2/3)+20*3^(1/2))*ln(x)/(44+12*69^(1/2))^(1/3))
#find particular solution
yp:=DETools:-particularsol(ode);
y(x) = (2/17)*x^3+ln(x)+3
#test particular solution is correct
odetest(yp,ode);
#find general solution = yh+ yp
y_general:=y(x)=rhs(yh)+rhs(yp);
y(x) = c__1*x^(-(1/6)*((44+12*69^(1/2))^(2/3)-4*(44+12*69^(1/2))^(1/3)-20)/(44+12*69^(1/2))^(1/3))+c__2*x^((1/12)*(-20+(44+12*69^(1/2))^(2/3)+8*(44+12*69^(1/2))^(1/3))/(44+12*69^(1/2))^(1/3))*sin((1/12)*(3^(1/2)*(44+12*69^(1/2))^(2/3)+20*3^(1/2))*ln(x)/(44+12*69^(1/2))^(1/3))+c__3*x^((1/12)*(-20+(44+12*69^(1/2))^(2/3)+8*(44+12*69^(1/2))^(1/3))/(44+12*69^(1/2))^(1/3))*cos((1/12)*(3^(1/2)*(44+12*69^(1/2))^(2/3)+20*3^(1/2))*ln(x)/(44+12*69^(1/2))^(1/3))+(2/17)*x^3+ln(x)+3
#test general solution is correct
odetest(y_general,ode);
#now solve the ode directly using Maple. Why this solution is much more complicated?
y_general_direct_method:=dsolve(ode);
y(x) = -(Int(-(5/2)*(x^(-(1/400)*69^(1/2)*(44+12*69^(1/2))^(2/3)+(11/1200)*(44+12*69^(1/2))^(2/3)+(1/12)*(44+12*69^(1/2))^(1/3)+2/3))^2*(44+12*69^(1/2))^(1/3)*(3*(44+12*69^(1/2))^(1/3)*69^(1/2)*cos((1/1200)*(44+12*69^(1/2))^(1/3)*3^(1/2)*(3*(44+12*69^(1/2))^(1/3)*69^(1/2)-11*(44+12*69^(1/2))^(1/3)+100)*ln(x))^2+3*(44+12*69^(1/2))^(1/3)*69^(1/2)*sin((1/1200)*(44+12*69^(1/2))^(1/3)*3^(1/2)*(3*(44+12*69^(1/2))^(1/3)*69^(1/2)-11*(44+12*69^(1/2))^(1/3)+100)*ln(x))^2-11*(44+12*69^(1/2))^(1/3)*cos((1/1200)*(44+12*69^(1/2))^(1/3)*3^(1/2)*(3*(44+12*69^(1/2))^(1/3)*69^(1/2)-11*(44+12*69^(1/2))^(1/3)+100)*ln(x))^2-11*(44+12*69^(1/2))^(1/3)*sin((1/1200)*(44+12*69^(1/2))^(1/3)*3^(1/2)*(3*(44+12*69^(1/2))^(1/3)*69^(1/2)-11*(44+12*69^(1/2))^(1/3)+100)*ln(x))^2+100*cos((1/1200)*(44+12*69^(1/2))^(1/3)*3^(1/2)*(3*(44+12*69^(1/2))^(1/3)*69^(1/2)-11*(44+12*69^(1/2))^(1/3)+100)*ln(x))^2+100*sin((1/1200)*(44+12*69^(1/2))^(1/3)*3^(1/2)*(3*(44+12*69^(1/2))^(1/3)*69^(1/2)-11*(44+12*69^(1/2))^(1/3)+100)*ln(x))^2)*(-2*x^3+ln(x))/(x^3*(3*3^(1/2)*23^(1/2)+11)*(11*3^(1/2)*23^(1/2)-207)), x))*x^((1/200)*69^(1/2)*(44+12*69^(1/2))^(2/3)-(11/600)*(44+12*69^(1/2))^(2/3)-(1/6)*(44+12*69^(1/2))^(1/3)+2/3)+(Int(-(5/6)*x^((1/200)*69^(1/2)*(44+12*69^(1/2))^(2/3)-(11/600)*(44+12*69^(1/2))^(2/3)-(1/6)*(44+12*69^(1/2))^(1/3)+2/3)*x^(-(1/400)*69^(1/2)*(44+12*69^(1/2))^(2/3)+(11/1200)*(44+12*69^(1/2))^(2/3)+(1/12)*(44+12*69^(1/2))^(1/3)+2/3)*(44+12*69^(1/2))^(1/3)*(3*(44+12*69^(1/2))^(1/3)*69^(1/2)*3^(1/2)*cos((1/1200)*(44+12*69^(1/2))^(1/3)*3^(1/2)*(3*(44+12*69^(1/2))^(1/3)*69^(1/2)-11*(44+12*69^(1/2))^(1/3)+100)*ln(x))-9*(44+12*69^(1/2))^(1/3)*69^(1/2)*sin((1/1200)*(44+12*69^(1/2))^(1/3)*3^(1/2)*(3*(44+12*69^(1/2))^(1/3)*69^(1/2)-11*(44+12*69^(1/2))^(1/3)+100)*ln(x))-11*(44+12*69^(1/2))^(1/3)*3^(1/2)*cos((1/1200)*(44+12*69^(1/2))^(1/3)*3^(1/2)*(3*(44+12*69^(1/2))^(1/3)*69^(1/2)-11*(44+12*69^(1/2))^(1/3)+100)*ln(x))+33*(44+12*69^(1/2))^(1/3)*sin((1/1200)*(44+12*69^(1/2))^(1/3)*3^(1/2)*(3*(44+12*69^(1/2))^(1/3)*69^(1/2)-11*(44+12*69^(1/2))^(1/3)+100)*ln(x))+100*3^(1/2)*cos((1/1200)*(44+12*69^(1/2))^(1/3)*3^(1/2)*(3*(44+12*69^(1/2))^(1/3)*69^(1/2)-11*(44+12*69^(1/2))^(1/3)+100)*ln(x))+300*sin((1/1200)*(44+12*69^(1/2))^(1/3)*3^(1/2)*(3*(44+12*69^(1/2))^(1/3)*69^(1/2)-11*(44+12*69^(1/2))^(1/3)+100)*ln(x)))*(-2*x^3+ln(x))*3^(1/2)/(x^3*(3*3^(1/2)*23^(1/2)+11)*(11*3^(1/2)*23^(1/2)-207)), x))*x^(-(1/400)*69^(1/2)*(44+12*69^(1/2))^(2/3)+(11/1200)*(44+12*69^(1/2))^(2/3)+(1/12)*(44+12*69^(1/2))^(1/3)+2/3)*cos((1/1200)*(44+12*69^(1/2))^(1/3)*3^(1/2)*(3*(44+12*69^(1/2))^(1/3)*69^(1/2)-11*(44+12*69^(1/2))^(1/3)+100)*ln(x))+(Int(-(5/6)*x^((1/200)*69^(1/2)*(44+12*69^(1/2))^(2/3)-(11/600)*(44+12*69^(1/2))^(2/3)-(1/6)*(44+12*69^(1/2))^(1/3)+2/3)*x^(-(1/400)*69^(1/2)*(44+12*69^(1/2))^(2/3)+(11/1200)*(44+12*69^(1/2))^(2/3)+(1/12)*(44+12*69^(1/2))^(1/3)+2/3)*(44+12*69^(1/2))^(1/3)*(3*(44+12*69^(1/2))^(1/3)*69^(1/2)*3^(1/2)*sin((1/1200)*(44+12*69^(1/2))^(1/3)*3^(1/2)*(3*(44+12*69^(1/2))^(1/3)*69^(1/2)-11*(44+12*69^(1/2))^(1/3)+100)*ln(x))+9*(44+12*69^(1/2))^(1/3)*69^(1/2)*cos((1/1200)*(44+12*69^(1/2))^(1/3)*3^(1/2)*(3*(44+12*69^(1/2))^(1/3)*69^(1/2)-11*(44+12*69^(1/2))^(1/3)+100)*ln(x))-11*(44+12*69^(1/2))^(1/3)*3^(1/2)*sin((1/1200)*(44+12*69^(1/2))^(1/3)*3^(1/2)*(3*(44+12*69^(1/2))^(1/3)*69^(1/2)-11*(44+12*69^(1/2))^(1/3)+100)*ln(x))-33*(44+12*69^(1/2))^(1/3)*cos((1/1200)*(44+12*69^(1/2))^(1/3)*3^(1/2)*(3*(44+12*69^(1/2))^(1/3)*69^(1/2)-11*(44+12*69^(1/2))^(1/3)+100)*ln(x))+100*3^(1/2)*sin((1/1200)*(44+12*69^(1/2))^(1/3)*3^(1/2)*(3*(44+12*69^(1/2))^(1/3)*69^(1/2)-11*(44+12*69^(1/2))^(1/3)+100)*ln(x))-300*cos((1/1200)*(44+12*69^(1/2))^(1/3)*3^(1/2)*(3*(44+12*69^(1/2))^(1/3)*69^(1/2)-11*(44+12*69^(1/2))^(1/3)+100)*ln(x)))*(-2*x^3+ln(x))*3^(1/2)/(x^3*(3*3^(1/2)*23^(1/2)+11)*(11*3^(1/2)*23^(1/2)-207)), x))*x^(-(1/400)*69^(1/2)*(44+12*69^(1/2))^(2/3)+(11/1200)*(44+12*69^(1/2))^(2/3)+(1/12)*(44+12*69^(1/2))^(1/3)+2/3)*sin((1/1200)*(44+12*69^(1/2))^(1/3)*3^(1/2)*(3*(44+12*69^(1/2))^(1/3)*69^(1/2)-11*(44+12*69^(1/2))^(1/3)+100)*ln(x))+c__1*x^((1/200)*69^(1/2)*(44+12*69^(1/2))^(2/3)-(11/600)*(44+12*69^(1/2))^(2/3)-(1/6)*(44+12*69^(1/2))^(1/3)+2/3)+c__2*x^(-(1/400)*69^(1/2)*(44+12*69^(1/2))^(2/3)+(11/1200)*(44+12*69^(1/2))^(2/3)+(1/12)*(44+12*69^(1/2))^(1/3)+2/3)*cos((1/1200)*(44+12*69^(1/2))^(1/3)*3^(1/2)*(3*(44+12*69^(1/2))^(1/3)*69^(1/2)-11*(44+12*69^(1/2))^(1/3)+100)*ln(x))+c__3*x^(-(1/400)*69^(1/2)*(44+12*69^(1/2))^(2/3)+(11/1200)*(44+12*69^(1/2))^(2/3)+(1/12)*(44+12*69^(1/2))^(1/3)+2/3)*sin((1/1200)*(44+12*69^(1/2))^(1/3)*3^(1/2)*(3*(44+12*69^(1/2))^(1/3)*69^(1/2)-11*(44+12*69^(1/2))^(1/3)+100)*ln(x))
#test the above
odetest(y_general_direct_method,ode);
Download why_such_difference_in_dsolve_answer.mw
Hi i study as an marine engenieer and use phasors alot.
I came across Acers startup code to use.
At the moment i have been been using the gym package for my calculations. Is there a way to setup this startup code to function every time when i load maple? Also how does it go about using units in general?
I currently have an issue where it outputs some strange format i can not understand
I do not know why there is added so many decimals. I work on a macOS computer and have thought about using mathCAD for the ease of use instead of all of this. I am hoping for a helping hand to stay with maple because this is what i know and have used the last 3 years.
I'm confused.  How come the two "is" aren't "true"?
assume(x <= y);
is(-5*x <= -5*y);
is(-5*(x <= y));
THis came up in another maple forum.  Any one knows why
expr := -(r0+Delta_r)^2*(46*r0-41*Delta_r)*r0^5;
subsop(1=a,2=b,3=c,4=d, expr);
gives error Error, improper op or subscript selector
but changing the order works ok
subsop(4=d,3=c,2=b,1=a, expr);
               # a*b*c*d
Looked at help and nothing there I could see that would explain this.
Maple 2023.2.
Update
This bug is still not fixed. 2 years later.
Will check again in 5 more years around the year 2030 and I bet that this bug will still not be fixed.
First 183 184 185 186 187 188 189 Last Page 185 of 2457
