Hi, I wanna plot some geometrical graphics with maple (v. 11), and i'm having problems with the easiest one: a point If you want to plot a point, for example with(geometry); point(p, 1, 1); draw(p(symbol = point), axes = normal, view = [-6 .. 6, -6 .. 6]) Ok well, now i want maple to plot the axis, as maple help says:
globalopts: the set of options allowed for globalopts is the same as that for plot except for the adaptive and sample options.
Then i try with(geometry); point(p, 1, 1); draw(p(symbol = point), axes = normal, view = [-6 .. 6, -6 .. 6], gridlines = true)
I have a problem with evalm. For example: A:=matrix([[1,2],[a,3]]); a:=5; evalm(A); There is still 'a' in the matrix and not 5 instead of a. Why? How should I do?
Ive searched on google and on this forum and cant find any clear steps on how to do the following:
I need to solve: 2s^2 - 12s + 16 <= 0
I know how to solve it without this app but I would like to know how to make maple 11 show all of the steps to get to the answer.. for example.
going from that problem to
s^2 -6s + 8 <= 0 like step 1. divide by 2
(s-2)(s-4) step 2 factor
s = 2 and s = 4 solve for s.
Is there anyway to get maple 11 to do this? Thanks in advance.
How does Maple send a plot to a ps file?
Thanks to you, I now find myself anticipating the "silver" leaf - I'm pretty close, you know. :-) My biggest decision now is whether I should delay the inevitable for a while, or just "go for it"
How would I generate all possible strings of letters from a given string of letters? (For example, if a given string of letters is "AA", then all possible strings of letters are "A" and "AA". If a given string of letters is "ABA", then all possible strings of letters in lexicographic order are "A", "AA", "AAB", "AB", "ABA", "B", "BA", "BAA".) I know that I first need to convert the string of letters to a list of letters, but I can't figure out the correct coding. Thanks for any advice!
How would I find and check 10 distinct solutions to the matrix equation Matrix(2, 4, {(1, 1) = 1, (1, 2) = 2, (1, 3) = 3, (1, 4) = 4, (2, 1) = 5, (2, 2) = 6, (2, 3) = 7, (2, 4) = 8}) Vector(4, {(1) = x[1], (2) = x[2], (3) = x[3], (4) = x[4]}) = Vector(2, {(1) = 10, (2) = 10}) ? I know that I need to use LinearSolve, but I'm not sure how to do it exactly...
Unless calculus has changed, when evaluating a definite integral, i.e., one with limits, first one performs the integration on the expression and then one evaluates the result for the upper limit and subtracts the result evaluated for the lower limit. That of course means that the indefinite integral (without limits) has to be produced before evaluating the result using the limits. Considering that, here is the confusing situation I have run into. Maple returns an answer, complicated to be sure, but an answer to int(sin(x)*sin(x^3+x), x = 0 .. infinity) suggesting that it CAN integrate sin(x)*sin(x^3+x)
Hello everybody, I tried to plot the output of my algorithm as follows below, defining two vectors representing the output values of each algortihm iteration. However, in this little example this is easy, because I know the number of steps, i.e. 3. However, how can I work out this problem, if I don't know the number of steps in advance? That is, how can I define a vector which grows in size with the number of algoithm steps, but which keeps the old values of the previous steps as well? > restart: with(stats): Digits := 14: > > N := 4: > L := 0.002: > beta:=0.85: > beta:=0.85:
I am trying to plot surfaces implicitly using implicitplot3d with their color dependent on the value of a function f(x,y,z). I have been unable to use the procedures listed in the help file for Plot3d Color Functions, but on the web I see examples of people using something like implicitplot3d(...., color=z). Did this used to work in an older version of Maple (I'm using 10)? John Starrett
How do I give variables superscripts that are not indices? I am an economist so, for example, t[H]^N where t is tariffs, H is the home country and N means Nash equilibrium.
Maple Professionals: I created an algorithm in maple, which calculates and prints out 2 values after each iteration, i.e. SFR and I (see code below). I wish to create a graph, which displays and connects the output of the iterations. That is, the y-axis should represent the variable SFR and the x-axis should represent the variable I. SFR ranges from 0 to 1 and I can range from 0 to infinity. I would be more than grateful, if someone could help me to create this graph within the code below. Thanks so much in advance, Nic > restart: with(stats): Digits := 14: > N := 4: > L := 0.002:
Dear folks... Can you find me some way to do this substitution in a better/easy way ?? Hw := subs(cos(w) = (1/z+z)*1/2, cos(2*w) = (1/z^2+z^2)*1/2, cos(3*w) = (1/z^3+z^3)*1/2, cos(4*w) = (1/z^4+z^4)*1/2, cos(4*w) = (1/z^4+z^4)*1/2, cos(5*w) = (1/z^5+z^5)*1/2, cos(6*w) = (1/z^6+z^6)*1/2, cos(7*w) = (1/z^7+z^7)*1/2, cos(8*w) = (1/z^8+z^8)*1/2, Hw) The list is already big and I've to add more for sin functions... cos (n*w/2) is later on the list... is there something like subs(cos(n*w) = (1/z^n+z^n)*1/2,Hw) ??? Or rather to do a z-transform directly ??
Anybody can explain me how to author a question in Maple TA environment using Flash Images. Thanks Ivan
I have a list of data and errors for which I want to do a chi-squared minimization for an arbitrary function. Is there a simple way to do this?
First 2351 2352 2353 2354 2355 2356 2357 Last Page 2353 of 2457
