I am new to Maple. I'm having trouble with simple caluclations such as the one in the image. The answer (after simplificatoin and cancellations) should be (|a|^2+|b|^2)(x^2 + y^2 + z^2)  but it's not happening! The result shown is correct; only the simplification is missing. What step am I missing?
The calculation is so simple, a look at the picture should suffice for the expert,
(sorry! I still don't know how to pick-off a single tab out from the whole workbook).
Question-2: judging from the missing overbar (complex conj) on z, the "assuming" seems to only apply to z and not x and y.
if that is correct, then why?
Question-3: How can I implement the constraint (|a|^2+|b|^2)=1 (preferably)before or after this  multiplication? I tried assume((|a|^2+|b|^2)=1), and though it compiled it did not help with the simplification.
TYVM
i have on ode with some parameters. it is ok and it is solved. but when i substitute the parameter itself, it is not solved, can i use any assumption to solve this? tnx for the help.
ode := diff(T(x), x, x)+q/k = 0
diff(diff(T(x), x), x)+q/k = 0
dsolve(ode)
T(x) = -(1/2)*q*x^2/k+_C1*x+_C2
ics1 := -k*(D(T))(0) = h[1]*(T[inf1]-T(0)), -k*(D(T))(0.5e-1) = h[2]*(T(0.5e-1)-T[inf2])
dsolve({ics1, ode})
T(x) = -(1/2)*q*x^2/k-(1/40)*h[1]*(800*k*T[inf1]*h[2]-800*k*T[inf2]*h[2]-40*k*q-q*h[2])*x/((20*k*h[1]+20*k*h[2]+h[1]*h[2])*k)+(1/40)*(800*k*T[inf1]*h[1]+800*k*T[inf2]*h[2]+40*T[inf1]*h[1]*h[2]+40*k*q+q*h[2])/(20*k*h[1]+20*k*h[2]+h[1]*h[2])
ics2 := -k*(D(T))(0) = h[1]*(T[inf1]-T(0)), -k*(D(T))(L) = h[2]*(T(L)-T[inf2])
dsolve({ics2, ode})
Error, (in dsolve) found differentiated functions with same name but depending on different arguments in the given DE system: {T(L), T(x)}
Download ExactSol.mw
The problem of saving photos in eps format with a small size
When I draw a function diagram with Maple, when I save the photo in eps format, the size is high, but I want the size to be high and the volume to be low, what should I do? If anyone can and knows how to draw with MATLAB, write the code for me, I would be grateful
Update: partly resolved in Maple 2023. int_warning.mw still does not show the warning
There is a very helpful warning about using assumptions from the int command that does not appear in the attached case:
Warning, unable to determine if -1 is between 0 and x0; try to use assumptions or use the AllSolutions option
Warning, unable to determine if 1 is between 0 and x0; try to use assumptions or use the AllSolutions option
Using infolevel[int]:=5 in Maple 2022.2,  one can see that the integrals listed under int/ellalg/elltype are not the same.
My preference would be to have this warning always working. It's a reminder that Maple cannot give a general answer but that there might be solutions for a restricted real domain. The warning also does not reproduce when execution the corresponding help page
(Update: the warning reproduces in Maple 2023)
https://www.maplesoft.com/support/help/errors/view.aspx?path=Warning,%20unable%20to%20determine%20if%201%20is%20between%200%20and%20x__0;%20try%20to%20use%20assumptions%20or%20use%20the%20AllSolutions%20option
Sidenote: This kind of warning is so useful that I wonder if and how such warnings could be extended beyond  integration with piecewise solutions. (Maybe also to other commands. Maple often returns input unevaluated because there is no general solution in the complex domain, without informing the inexperienced user that there might be solutions available in the real domain.)
int_warning.mw
int_warning_with_infolevel.mw
My question is can the last step be equal to 1/6.
I want to output to 1/6. it outputs to sqrt(9)/18 - (See Below).
NULL"5)Square root: undefined - DNE (Limit does not exist):"
limit((sqrt(x+1)-3)/(x-8), x = 8)"(=)"1/6
limit((sqrt(x+1)-3)/(x-8), x = 8)Limit(((x+1)^(1/2)-3)/(x-8), x = 8) = (1/18)*9^(1/2)"(=)"Limit(((x+1)^(1/2)-3)/(x-8), x = 8) = 1/6
Download limit-sqrt-5.mw
I would like to know which of the more than 100 worksheets I have in a Windows 11 folder execute the events operation within dsolve numeric.
Is there a way to identify which of this large number of Maple worksheets contain a given phrase e.g. "events"?
What is the logic behind this?
expr:=(c[2]+x)^3;
simplify(expr)
Which is what expected. But
expr:=(c[2]+x)^3+a;
simplify(expr)
gives
Which does not look simpler to me. I expected it to be the same as before but with "a" added.  This is what Mathematica gives for comparison
I know I can use simplify with size option. But my question is, how did Maple decide that x^3 + 3*x^2*c[2] + 3*x*c[2]^2 + c[2]^3 + a is "simpler" than (c[2] + x)^3 + a ? It must use some logic which I am trying to understand.
Maple 2022.2 on windows 10
My Maple Program run perfectly  with Window 10.  My new Laptop has Window 11 and I get system  crash wenn I applied
plot3d(...) .
So I think It is somethink with the Grapics Redering ?
Can somebody help ?
Betriebsystemname    Microsoft Windows 11 Home
Version    10.0.22621 Build 22621
Weitere Betriebsystembeschreibung     Nicht verfügbar
Betriebsystemhersteller    Microsoft Corporation
Systemname    ELIPAN
Systemhersteller    SAMSUNG ELECTRONICS CO., LTD.
Systemmodell    750XED
Systemtyp    x64-basierter PC
System-SKU    SCAI-A5A5-A5A5-ADLP-PCFG
Prozessor    12th Gen Intel(R) Core(TM) i5-1235U, 1300 MHz, 10 Kern(e), 12 logische(r) Prozessor(en)
BIOS-Version/-Datum    American Megatrends International, LLC. P08CFG.033.220913.HQ, 13.09.2022
SMBIOS-Version    3.4
Version des eingebetteten Controllers    255.255
BIOS-Modus    UEFI
BaseBoard-Hersteller    SAMSUNG ELECTRONICS CO., LTD.
BaseBoard-Produkt    NP750XED-KC5DE
BaseBoard-Version    SAMSUNG_SW_REVISION_12345+10.0.22000
Plattformrolle    Mobil
Sicherer Startzustand    Ein
PCR7-Konfiguration    Erweiterung zum Anzeigen erforderlich
Windows-Verzeichnis    C:\WINDOWS
Systemverzeichnis    C:\WINDOWS\system32
Startgerät    \Device\HarddiskVolume1
Gebietsschema    Deutschland
Hardwareabstraktionsebene    Version = "10.0.22621.819"
Benutzername    ELIPAN\Pan
Zeitzone    Mitteleuropäische Zeit
Installierter physischer Speicher (RAM)    16,0 GB
Gesamter physischer Speicher    15,7 GB
Verfügbarer physischer Speicher    8,28 GB
Gesamter virtueller Speicher    16,7 GB
Verfügbarer virtueller Speicher    6,98 GB
Größe der Auslagerungsdatei    1,00 GB
Auslagerungsdatei    C:\pagefile.sys
Kernel-DMA-Schutz    Ein
Virtualisierungsbasierte Sicherheit    Wird ausgeführt...
Virtualisierungsbasierte Sicherheit – erforderliche Sicherheitseigenschaften
Virtualisierungsbasierte Sicherheit – verfügbare Sicherheitseigenschaften    Allgemeine Virtualisierungsunterstützung, Sicherer Start, DMA-Schutz, UEFI-Code Readonly, SMM Security Mitigations 1.0, Modusbasierte Ausführungssteuerung, APIC-Virtualisierung
Virtualisierungsbasierte Sicherheit – konfigurierte Dienste    Durch Hypervisor erzwungene Codeintegrität
Virtualisierungsbasierte Sicherheit – ausgeführte Dienste    Durch Hypervisor erzwungene Codeintegrität
Windows Defender-Anwendungssteuerungsrichtlinie    Erzwungen
Windows Defender-Anwendungssteuerungs-Richtlinie für den Benutzermodus    Aus
Unterstützung der Geräteverschlüsselung    Erweiterung zum Anzeigen erforderlich
Es wurde ein Hypervisor erkannt. Features, die für Hyper-V erforderlich sind, werden nicht angezeigt.
Directly via maple code.
 The following code:
for i to np do
    pl_pp[i] := point([h_p[i], m_p[i]], color = red);
    pl_np[i] := point([h_n[i], m_n[i]], color = blue);
    pl_pn[i] := point([-h_n[i], -m_n[i]], color = red);
    pl_nn[i] := point([-h_p[i], -m_p[i]], color = blue);
end do
Gives following error:
Error, (in plottools:-point) incorrect arguments for creating points structure, try providing the dimension option
Please Help,
I am trying to plot some movement equations, but the following error keeps happening:
when I tryed to rewrite the equation the error became:
Can someone help me with those errors?
Here is the code
pp.mw
I find it difficult to use dsolve to solve system of ordinary differential equations with assigned parameters and initial conditions. The error message "Error, (in dsolve/numeric) 'parameters' must be specified as a list of unique unassigned names" kept coming up.
Pls see the uploaded equation for more understanding
interface(imaginaryunit = F)
I
I
I
sqrt(-4)
2*I
Suscep := diff(S(t), t) = theta*epsilon+v__2*S__v(t)-S(t)*lambda-S(t)*(µ+v__1)
diff(S(t), t) = theta*varepsilon+v__2*S__v(t)-S(t)*lambda-S(t)*(µ+v__1)
Vacc := diff(S__v(t), t) = (1-theta)*epsilon+v__1*S(t)-(µ+alpha+v__2)*S__v(t)-(1-w)*S__v(t)*lambda
Immun := diff(V(t), t) = alpha*S__v(t)+`ρ__A`*A(t)+(1-k)*`ρ__Q`*Q(t)+`ρ__I`*(I)(t)-µ*V(t)
Exp := diff(E(t), t) = S(t)*lambda+(1-w)*S__v(t)*lambda-(q__E+delta+µ)*E(t)
Asymp := diff(A(t), t) = delta*a*E(t)-(`ρ__A`+µ)*A(t)+k*`ρ__Q`*Q(t)
Inf := diff((I)(t), t) = delta*(1-a)*E(t)-(`ρ__I`+q__I+`δ__I`+µ)*(I)(t)
Quar := diff((I)(t), t) = q__E*E(t)+q__I*(I)(t)-(`ρ__Q`+`δ__Q`+µ)*Q(t)
init_conds := S(0) = S_0, S__v(0) = S__v*_0, V(0) = V_0, E(0) = E_0, A(0) = A_0, (I)(0) = I_0, Q(0) = Q_0
S(0) = S_0, S__v(0) = S__v*_0, V(0) = V_0, E(0) = E_0, A(0) = A_0, I(0) = I_0, Q(0) = Q_0
sys := {Asymp, Exp, Immun, Inf, Quar, Suscep, Vacc, init_conds}
sol := dsolve(sys, numeric, parameters = [`δ__Q`, `δ__I`, a, k, epsilon, v[1], q[E], q[I], q[A], eta[A], eta[Q], rho[A], rho[Q], rho[I], v[2], alpha, mu, delta, alpha, beta, w, lambda, S_0, S__v*_0, V_0, E_0, A_0, I_0, Q_0], method = rkf45)
sol(parameters = [delta = .125, `δ__Q` = 0.6847e-3, epsilon = .464360344, `δ__I` = 0.2230e-8, a = .6255, q[E] = 0.18113e-3, k = .15, v__1 = 0.5e-1, v__2 = 0.6e-1, `ρ__Q` = 0.815e-1, `ρ__A` = .1, `ρ__I` = 0.666666e-1, q__I = 0.1923e-2, q__A = 0.4013e-7, `η__A` = .1213, `η__Q` = 0.3808e-2*alpha and 0.3808e-2*alpha = .4, w = .5925, mu = 0.464360344e-4, lambda = 0.1598643e-7, S_0 = 1.0, S__v*_0 = 0.6e-4, V_0 = 0.35e-4, E_0 = 0.5e-4, I_0 = 0.32e-4, A_0 = 0.15e-4, Q_0 = 0.1e-4])
sol(parameters = [delta = .125, delta__Q = 0.6847e-3, varepsilon = .464360344, delta__I = 0.2230e-8, a = .6255, q[E] = 0.18113e-3, k = .15, v__1 = 0.5e-1, v__2 = 0.6e-1, rho__Q = 0.815e-1, rho__A = .1, rho__I = 0.666666e-1, q__I = 0.1923e-2, q__A = 0.4013e-7, eta__A = .1213, false, w = .5925, mu = 0.464360344e-4, lambda = 0.1598643e-7, S_0 = 1.0, S__v*_0 = 0.6e-4, V_0 = 0.35e-4, E_0 = 0.5e-4, I_0 = 0.32e-4, A_0 = 0.15e-4, Q_0 = 0.1e-4])
Evaluate*the*system*at*t = 2
sol(2)
sol(2)
sol(1)
sol(1)
sol(.1)
sol(.1)
sol(.3)
sol(.3)
sol(.5)
sol(.5)
sol(.7)
sol(.7)
sol(.9)
sol(.9)
sol(1.1)
sol(1.1)
(14)
sol(1.3)
sol(1.3)
(15)
sol(1.5)
sol(1.5)
(16)
Download Covid19_Simulation.mw
Dear Maple community,
I am trying to define an operator in Maple that multiplies to an expression and substitutes the indices.
The issue is that I don't want to add the expression as input of the operator/function, sth like:
p := proc(i, j, z) option operator; subs({i = j, j = i}, z); end proc
I want it to act on expression, like:
P(i,j)*X(i,j,k)=X(j,i,k)
and X can be any tensor or matrix.
Hi Guys, can someone explain how to resubstitute equations I already stated, into my final form (e.g. a derivative)?
I'm unable to substitute my g(x) expression (eq. (2)) into my derivative of f(x) (eq. (4). It only works if I state explicitly which variables to substitute via algsubs (last statement). However, for that I have to rename g(x)-->h(x). Can someone explain what I'm doing wrong here? I'd love to be able to tell maple just to use already given equations (that is g(x), eq. (2)) to simplify my derivative.
Thanks guys!
First 274 275 276 277 278 279 280 Last Page 276 of 2469
