I have the following code, that solves a linear system
But I get the error
Error, (in rtable/Sum) invalid arguments
code.mw
Thank you for any help
Good day everyone,
I am trying to rotate the plots of pde solution using transplot, but it is giving me errors. Anyone with better suggestions should help. The code is attached below. Thanks
Transplot_not_working.mw
Let the square matrix A satisfy A^2023 = 0.
a. Prove: I-A is invertible.
b. If B is invertible, is B - A invertible?
This is not a Maple problem but it has something to do with math, specifically linear algebra, and I need help. Sorry if I bothered you. If possible please help me!
Dear all:
    I am trying to use the subs command to replace 5 varibles with other specific 5 varibles.
to be simple, here is issue.
Now I and using the stupid way(manually replace eachstep by my self) which did work but with some small issue such as  simplify or subs not work for replacements
all the steps I did are contained inside here:
ModelExtrinsicParasiticExtraction_QuestionsV2.mw
thanks for your help.
best regards
The following expression
limit(log(x)/x, x = 0)
returns undefined in Maple 2022.
I am not certain about if this limit exists, but shouldn't it be -infinity?
 For famous constants like pi and e, are the values stored or are they calculated?
with(Physics)
diff(x(t), `$`(t, 2)) = a(t)
diff(diff(x(t), t), t) = a(t)
dsolve(diff(diff(x(t), t), t) = a(t), arbitraryconstants = subscripted)
x(t) = Int(Int(a(t), t), t)+c__1*t+c__2
a(t) = 1.*Unit('m'/'s'^2), c__1 = 2*Unit('m'/'s'), c__2 = 3*Unit('m')
a(t) = 1.*Units:-Unit(m/s^2), c__1 = 2*Units:-Unit(m/s), c__2 = 3*Units:-Unit(m)
subs(a(t) = 1.*Units:-Unit(m/s^2), c__1 = 2*Units:-Unit(m/s), c__2 = 3*Units:-Unit(m), x(t) = Int(Int(a(t), t), t)+c__1*t+c__2)
x(t) = Int(Int(1.*Units:-Unit(m/s^2), t), t)+2*Units:-Unit(m/s)*t+3*Units:-Unit(m)
value(%)
x(t) = (1/2)*t^2*Units:-Unit(m/s^2)+2*Units:-Unit(m/s)*t+3*Units:-Unit(m)
Warning, units problem, not enough information to unambiguously deduce the units of the variables {t}; proceeding as if dimensionless
How can I provide the information to Maple that the unit of t is s?
Update: Temporarily disabling the warning would also be an option for the above case.
Download Unit_of_t.mw
How to improve this program ? Thank you.
Equation de la conique
eqcon := (45 - 27*cos(alpha))*x^2 - 54*sin(alpha)*x*y + (45 + 27*cos(alpha))*y^2 - 8;
Delta := (-54*sin(alpha))^2 - 4*(45 - 27*cos(alpha))*(45 + 27*cos(alpha));
expand(%);
simplify(%);
Discriminant : Δ<0 ce qui correxpond à une ellipse
Eq := simplify(expand(subs(x = cos(alpha/2)*X - sin(alpha/2)*Y, y = sin(alpha/2)*X + cos(alpha/2)*Y, eqcon)));
kx := coeff(Eq, X, 2);
ky := coeff(Eq, Y, 2);
k := -tcoeff(Eq);
EQ := X^2/(sqrt(1/kx^2)*k) + Y^2/(sqrt(1/ky^2)*k) = 1;
Calcul du grand et du petit axe
a := 1/sqrt(coeff(lhs(EQ), X, 2));
b := 1/sqrt(coeff(lhs(EQ), Y, 2));
print(X^2/('a^2') + Y^2/('b^2') = 1);
!Edits: I have found  a existing polynomial algorithm, but I still have difficulty implementing it. 2022/10/26
The edge connectivity of a connected graph G  is the minimum number of edges whose deletion from the graph G disconnects G. Below we are concerned with a particular kind of edge-cut.
  • For a connected graph G=(V ,E), an edge set S ⊂ E is a restricted-edge-cut, if G−S is disconnected and every connected component of  G−S has at least 2 vertices.
Clearly, a restricted-edge-cut is an edge cut with a special requirement.
  • The restricted-edge-connectivity of G, denoted by κres(G), is defined as the cardinality of a minimum restricted-edge-cut.
For example, a graph g is as follows.
Clearly, its edge-connectivity is 1 since (0,3) or (0,4) is a edge cut of g. But we can find that  if we remove the edge (0,3), then "3" is a isolated vertex. Similarly, "4" is a isolated vertex if we remove  (0,4). It is not difficult to find g has exactly the two cut-edges (0,3) and (0,4).
Based on the definition of the restricted-edge-cuts, neither {(0,3)} nor  {(0,4)} are restricted-edge-cuts A minimum restricted-edge-cut is {(0,1),(0,2)} since every connected component of G-{(0,1),(0,2)} has  (at least) 2 vertices.
So  κres(g) is 2.  My problem is:
Given a graph G, how to calculate the restricted-edge-connectivity of  G?  Moreover, how to find a minimum restricted-edge-cut?
A specific graph that I want to test is as follows. (it has 16 vertices and 56 edges.) I would like to calculate its restricted-edge-connectivity and find a minimum restricted-edge-cut.
g:=ConvertGraph("O~tIID@wL~j`PbOqgLJ@p");
DrawGraph(g, stylesheet=[vertexborder=false,vertexpadding=15,edgecolor = "Black",
     vertexcolor="Black",edgethickness=2])
EdgeConnectivity(g)
6
One option I came up with is to find all 6-edge subsets first. Test if they satisfy  the restricted condition (one by one). Then continue to increase to 7 or more. But this violent calculation may get stuck in the first step. That is, test all the minimum edge cut sets (Note that we will consider 32468436 edge-subsets!) I was referring to the efficiency aspect.
with(Iterator):
C:=Combination(58,6):
K:=Edges(g):
#sub:=seq( K[[seq(c[]+1)]], c=C); # do not run this code since it has 32468436 members.
Any language is acceptable.( C or C++, Python. )
PS: Some time ago, I also asked a related question (but with some differences) on mathematica stack (Find all the minimum edge cuts of a graph). Although Bob Hanlon  gave a reply, the actual result is not good.
Edits: The following literature gives a polynomial algorithm for computing the restricted-edge-connectivity of a given  graph. The heart of it is to computing the least cardinality of some  edge-pairs's edge separator. I'm stuck here.
  • Esfahanian A H, Hakimi S L. On computing a conditional edge-connectivity of a graph[J]. Information processing letters, 1988, 27(4): 195-199.
How to implement this algorithm is my current concern.
Hi All,
I solved a high degree polynomial equation for two variables and obtained a list of solutions as under:
{s = 0.01291429045, t = 0.06099359500}, {s = -0.6944124361, t = 0.8895072341}, {s = 0.3000821715, t = -0.06855860577}, {s = 0.1246366197, t = -0.06899397557}, {s = 43.29465387, t = -10.98020355}, {s = 7.400522990*10^6, t = -1.879497900*10^6}, {s = 7.442623977*10^6, t = -1.890190214*10^6}
In the second stage, I have to plug these solutions into another expression andsolve for second stage decision variables. However, I am only interested in the solutions where both s and t are non negative. How can I reduce the set to have a smaller subset?
Thanks for help
I use to write modules with option package and store them in a .mla files.
Let's assume M is the name of the module and P1, P2, ..., PN are the procedures M contains.
Each time one of these procedures hass to call another one, I write
Pm := proc(...)
 a := M:-Pn(...)
instead of simply
Pm := proc(...)
 a := Pn(...)
It seemed to me that the first method sometimes saved me a lot of trouble
Is it a common/necessary/safer/useless practice to write a:=M:Pn(...) instead of a:=Pn(...) ?
 {[[b/(sin(x-y-z))=a/(sin(z)),],[(a^(2)+b^(2)+2 abcos(x-y))cos(m(y+z)+n)=acos(mx+n)+bcos(my+n),]];
Why cannot this group of equations be solved in Maple software?
I have 5 procedures saved in my library. Say Proc1, Proc2, Proc3, Proc4 and Proc5. They all work ok.
Proc5 calls Proc4 which calls Proc3 which calls Proc2 which calls Proc1. That is fine if I read them all in to the dodument.
Is it ok ok to put read commands in procedures 5..2 so I don't have to manually load them all myself into a new document or is there a better way to do this. These procedures are not part of a package.
I hace set
currentdir();
      "C:\Users\Ronan\Documents\maple\Alibrary\Procedures"
which is where the procedures are stored. If I just load Proc5 it doesn't find the other procedures
dear all,
I am trying to use the solve to get symbolic answer.
to be simple, here is issue:
I have 15equations with 16 varibles.
the 15 equation as follows:
first 4 equation set
equList_Ya :=
[ Va1 Ya11 + Va2 Ya12 + Va3 Ya13 + Va4 Ya14 = Ia1,
  Va1 Ya21 + Va2 Ya22 + Va3 Ya23 + Va4 Ya24 = Ia2,
  Va1 Ya31 + Va2 Ya32 + Va3 Ya33 + Va4 Ya34 = Ia3,
  Va1 Ya41 + Va2 Ya42 + Va3 Ya43 + Va4 Ya44 = Ia4]
2nd 4 equation set
equList_Yb :=
[ Vb1 Yb11 + Vb2 Yb12 + Vb3 Yb13 + Vb4 Yb14 = Ib1,
  Vb1 Yb21 + Vb2 Yb22 + Vb3 Yb23 + Vb4 Yb24 = Ib2,
  Vb1 Yb31 + Vb2 Yb32 + Vb3 Yb33 + Vb4 Yb34 = Ib3,
  Vb1 Yb41 + Vb2 Yb42 + Vb3 Yb43 + Vb4 Yb44 = Ib4]
the 3rd 4 equation set
equList_ConnectCondition :=
[Ia3 = -Ib1, Ia4 = -Ib2, Va3 = Vb1,  Va4 = Vb2]
the 4th 3 equation set
 equList_Y11Condition := [Va2 = 0, Vb3 = 0, Vb4 = 0]
so total equation number is 4+4+4+3=15
equList_Y11all := {Ia3 = -Ib1, Ia4 = -Ib2, Va2 = 0, Va3 = Vb1, Va4 = Vb2, Vb3 = 0,
 Vb4 = 0, Va1*Ya11 + Va2*Ya12 + Va3*Ya13 + Va4*Ya14 = Ia1,
 Va1*Ya21 + Va2*Ya22 + Va3*Ya23 + Va4*Ya24 = Ia2,
 Va1*Ya31 + Va2*Ya32 + Va3*Ya33 + Va4*Ya34 = Ia3,
 Va1*Ya41 + Va2*Ya42 + Va3*Ya43 + Va4*Ya44 = Ia4,
 Vb1*Yb11 + Vb2*Yb12 + Vb3*Yb13 + Vb4*Yb14 = Ib1,
 Vb1*Yb21 + Vb2*Yb22 + Vb3*Yb23 + Vb4*Yb24 = Ib2,
 Vb1*Yb31 + Vb2*Yb32 + Vb3*Yb33 + Vb4*Yb34 = Ib3,
 Vb1*Yb41 + Vb2*Yb42 + Vb3*Yb43 + Vb4*Yb44 = Ib4}
the 16 varible is
var_Y11 :=
[ Va1, Va2, Va3, Va4,
  Ia1, Ia2, Ia3, Ia4,
  Vb1, Vb2, Vb3, Vb4,
  Ib1, Ib2, Ib3, Ib4]
I hope to get Ia1=f(Va1) to calculate Y11(=Ia1/Va1)
but the solve give nothing:
Y11_all := solve(equList_Y11all, {Ia1}, symbolic = true);
Y11_all := NULL
Question1: why the above solve output nothing???
since not work,so I try another way:
polys_Y11 := map(lhs - rhs = 0, equList_Y11all);
    polys_Y11 := {Va2 = 0, Vb3 = 0, Vb4 = 0, Ia3 + Ib1 = 0,
      Ia4 + Ib2 = 0, Va3 - Vb1 = 0, Va4 - Vb2 = 0,
      Va1 Ya11 + Va2 Ya12 + Va3 Ya13 + Va4 Ya14 - Ia1 = 0,
      Va1 Ya21 + Va2 Ya22 + Va3 Ya23 + Va4 Ya24 - Ia2 = 0,
      Va1 Ya31 + Va2 Ya32 + Va3 Ya33 + Va4 Ya34 - Ia3 = 0,
      Va1 Ya41 + Va2 Ya42 + Va3 Ya43 + Va4 Ya44 - Ia4 = 0,
      Vb1 Yb11 + Vb2 Yb12 + Vb3 Yb13 + Vb4 Yb14 - Ib1 = 0,
      Vb1 Yb21 + Vb2 Yb22 + Vb3 Yb23 + Vb4 Yb24 - Ib2 = 0,
      Vb1 Yb31 + Vb2 Yb32 + Vb3 Yb33 + Vb4 Yb34 - Ib3 = 0,
      Vb1 Yb41 + Vb2 Yb42 + Vb3 Yb43 + Vb4 Yb44 - Ib4 = 0}
and solve it with
what I expected is Ia1=f(Va1) which Va1 as indepentent,but the above solution have no Va1
Question2: is the (22) give the right answer for Ia1 ? what is the indepent var for the above solution?
here is my full maple worksheet
CoupleLineSeriesConnect_Question.mw
thx for your help.
best regards
First 299 300 301 302 303 304 305 Last Page 301 of 2458
