I want to know if it is possible to use the declare command from the PDETools package for a function
f(x,y,z)
and still, having the notation $\frac{\partial f}{\partial x}$ instead of $f_x$ for the Maple command %diff(f(x,y,z),x)
Thanks !
Kevin
recurssion.mw
"f(x,t) :=(|Psi|)^(2)"
proc (x, t) options operator, arrow, function_assign; abs(Psi)^2 end proc
" a(t):=piecewise(0<= t<=1,1.5*t,1<= t<=2,1.5*(2-t))"
proc (t) options operator, arrow, function_assign; piecewise(0 <= t and t <= 1, 1.5*t, 1 <= t and t <= 2, 1.5*(2-t)) end proc
" y[a](t):=piecewise(0<= t<=0.1,a(t),0.1<= t<=0.2,-a(t))"
proc (t) options operator, arrow, function_assign; piecewise(0 <= t and t <= .1, a(t), .1 <= t and t <= .2, -a(t)) end proc
"y(t):=y[a](t)+mu(t)"
proc (t) options operator, arrow, function_assign; y[a](t)+mu(t) end proc
"w(t):=&int;x(t)*f(x,t) &DifferentialD;x"
proc (t) options operator, arrow, function_assign; int(x(t)*f(x, t), x) end proc
" v(t):=y(t)-w(t)*w(t)"
proc (t) options operator, arrow, function_assign; y(t)-w(t)^2 end proc
diff(K(x, t), t) = beta*v(t)*f(x, t)
Error, (in y[a]) too many levels of recursion
"map(int, , t)"
Error, invalid function arguments
"map(int,,t)"
Here psi is a general wave function from schrodinger wave equation.
Download recurssion.mw
The problem comes from the link https://www.mapleprimes.com/questions/234398-Convert-Maple-Code-To-Python-#comment287424.
We know that when we compile a C or C ++ function, it generates an executable file.  Then we are free from source code.  For example. the function below returns a square matrix A where    "A[i, j]" is the distance from vertex i to vertex j in the graph G. My computer system is Windows.
// C Program for Floyd Warshall Algorithm
#include <stdio.h>
// Number of vertices in the graph
#define V 4
/* Define Infinite as a large enough
  value. This value will be used
  for vertices not connected to each other */
#define INF 99999
// A function to print the solution matrix
void printSolution(int dist[][V]);
// Solves the all-pairs shortest path
// problem using Floyd Warshall algorithm
void floydWarshall (int graph[][V]) {
    /* dist[][] will be the output matrix
      that will finally have the shortest
      distances between every pair of vertices */
    int dist[V][V], i, j, k;
    /* Initialize the solution matrix
      same as input graph matrix. Or
       we can say the initial values of
       shortest distances are based
       on shortest paths considering no
       intermediate vertex. */
    for (i = 0; i < V; i++)
        for (j = 0; j < V; j++)
            dist[i][j] = graph[i][j];
    /* Add all vertices one by one to
      the set of intermediate vertices.
      ---> Before start of an iteration, we
      have shortest distances between all
      pairs of vertices such that the shortest
      distances consider only the
      vertices in set {0, 1, 2, .. k-1} as
      ----> After the end of an iteration,
      vertex no. k is added to the set of
      intermediate vertices and the set
      becomes {0, 1, 2, .. k} */
    for (k = 0; k < V; k++) {
        // Pick all vertices as source one by one
        for (i = 0; i < V; i++) {
            // Pick all vertices as destination for the
            // above picked source
            for (j = 0; j < V; j++) {
                // If vertex k is on the shortest path from
                // i to j, then update the value of dist[i][j]
                if (dist[i][k] + dist[k][j] < dist[i][j])
                    dist[i][j] = dist[i][k] + dist[k][j];
    // Print the shortest distance matrix
    printSolution(dist);
/* A utility function to print solution */
void printSolution(int dist[][V]) {
    printf ("The following matrix shows the shortest distances"
            " between every pair of vertices \n");
    for (int i = 0; i < V; i++) {
        for (int j = 0; j < V; j++) {
            if (dist[i][j] == INF)
                printf("%7s", "INF");
                printf ("%7d", dist[i][j]);
        printf("\n");
// driver program to test above function
int main() {
    /* Let us create the following weighted graph
            10
       (0)------->(3)
      5 |          |
        |          | 1
       (1)------->(2)
            3           */
    int graph[V][V] = { {0,   5,  INF, 10},
        {INF, 0,   3, INF},
        {INF, INF, 0,   1},
        {INF, INF, INF, 0}
    // Print the solution
    floydWarshall(graph);
    return 0;
The above functions will be packaged as the disall.exe , and then we will move them anywhere in my computer and run it in Powershell.  We don't have to deal with the source code unless we want to change it.
I mean can Maple do something like that?
with(GraphTheory);
G := Graph([1, 2, 3, 4, 5], {{1, 2}, {1, 3}, {1, 4}, {1, 5}, {2, 3}, {2, 5}, {3, 4}, {4, 5}});
AllPairsDistance(G);
For exmaple, can I package the above code snippet into an exe file?
Given: f := (R1 + Rc)/(4*C*Rf*R1)
Where ...
R1 := 10^5
R2 := 300*10^3
R3 := 75*10^3
Rf := 10^4
Rc := R2
C := 10^(-6)
Now to find the value of "f" enter...
f=
and I get ...
25.000 + 2.500*10^(-4)*Rc
But ...if I enter ...
(R1 + Rc)/(4*C*Rf*R1) =
I get 100.000
Which I think is the correct answer.
Why isn't Maple Flow 2022 returning 100 when I ask for the value of "f" ?
I'm sure I'm doing something incorrect so maybe some kind soul will give me some guidance.
Thanks for any help.
PS - Is there an easy way to enter a set of equations from Maple Flow  2022... like the above... without having to copy and paste each one individually?
hallo evert body please how i do calculate this integral
in maple 18
ttp.pdf
int_{0}^{2\pi}(\cos^{i}(\theta)-\cos^{i+2}(\theta))d\theta
I want to extract the coefficients of Chebyshev of an arbitrary function, for example, exp(x). I know that we can use the following command to make a Chebyshev series expansion of exp(x):
chebyshev(exp(x),x);
the above returns the sum of nth Chebyshev polynomials multiplied by Chebyshev coefficients as the following:
1.26606587775201*T(0, x) + 1.13031820798497*T(1, x) + 0.271495339534077*T(2, x) + 0.0443368498486638*T(3, x) + 0.00547424044209371*T(4, x) + 0.000542926311913993*T(5, x) + 0.0000449773229542760*T(6, x) + 3.19843646244580*10^(-6)*T(7, x) + 1.99212480641582*10^(-7)*T(8, x) + 1.10367717095000*10^(-8)*T(9, x) + 5.50589697979079*10^(-10)*T(10, x)
I like to take the coefficients 1.266,1.1303, 0.2714, 0.04433, and so on. How can I do it?
Why GenerateMatrix produces wrong results?
N := 2:
a := 1:
with(ArrayTools):
Qa := [-0.5379667864e-1*(diff(tau[1, 1](t), t, t))+7.862351349*10^(-11)*tau[2, 1](t)-8.050993899*10^(-12)*(diff(tau[2, 1](t), t, t))+.1166068042*(diff(tau[1, 2](t), t))+2.181309895*10^(-11)*(diff(tau[2, 2](t), t))+.5309519363*tau[1, 1](t) = 0, -1.265965258*10^(-11)*(diff(tau[1, 1](t), t, t))+.4884414390*tau[2, 1](t)-0.4948946475e-1*(diff(tau[2, 1](t), t, t))+2.738892495*10^(-11)*(diff(tau[1, 2](t), t))+.1340883970*(diff(tau[2, 2](t), t))+1.246469610*10^(-10)*tau[1, 1](t) = 0, 3.649366137*10^(-10)*tau[2, 2](t)-9.135908950*10^(-12)*(diff(tau[2, 2](t), t, t))-5.160677740*10^(-11)*(diff(tau[2, 1](t), t))+1.953765755*tau[1, 2](t)-0.4948946473e-1*(diff(tau[1, 2](t), t, t))-.3476543209*(diff(tau[1, 1](t), t)) = 0, 2.246672656*tau[2, 2](t)-0.5690888318e-1*(diff(tau[2, 2](t), t, t))-.3198194887*(diff(tau[2, 1](t), t))+4.602903411*10^(-10)*tau[1, 2](t)-1.159417294*10^(-11)*(diff(tau[1, 2](t), t, t))-8.175817372*10^(-11)*(diff(tau[1, 1](t), t)) = 0]
Q1 := [seq(seq(diff(tau[i, j](t), t), i = 1 .. M), j = 1 .. N)]
[diff(tau[1, 1](t), t), diff(tau[2, 1](t), t), diff(tau[1, 2](t), t), diff(tau[2, 2](t), t)]
CR := GenerateMatrix(simplify(Qa), Q1)
CR := Matrix(4, 4, {(1, 1) = 0, (1, 2) = 0, (1, 3) = .1166068042, (1, 4) = 0.2181309895e-10, (2, 1) = 0, (2, 2) = 0, (2, 3) = 0.2738892495e-10, (2, 4) = .1340883970, (3, 1) = -.3476543209, (3, 2) = -0.5160677740e-10, (3, 3) = 0, (3, 4) = 0, (4, 1) = -0.8175817372e-10, (4, 2) = -.3198194887, (4, 3) = 0, (4, 4) = 0}), Vector(4, {(1) = 0.5379667864e-1*(diff(diff(tau[1, 1](t), t), t))-0.7862351349e-10*tau[2, 1](t)+0.8050993899e-11*(diff(diff(tau[2, 1](t), t), t))-.5309519363*tau[1, 1](t), (2) = 0.1265965258e-10*(diff(diff(tau[1, 1](t), t), t))-.4884414390*tau[2, 1](t)+0.4948946475e-1*(diff(diff(tau[2, 1](t), t), t))-0.1246469610e-9*tau[1, 1](t), (3) = -0.3649366137e-9*tau[2, 2](t)+0.9135908950e-11*(diff(diff(tau[2, 2](t), t), t))-1.953765755*tau[1, 2](t)+0.4948946473e-1*(diff(diff(tau[1, 2](t), t), t)), (4) = -2.246672656*tau[2, 2](t)+0.5690888318e-1*(diff(diff(tau[2, 2](t), t), t))-0.4602903411e-9*tau[1, 2](t)+0.1159417294e-10*(diff(diff(tau[1, 2](t), t), t))})
Download GenMatrix.mw
I use Maple 2020 on a Windows 10 PC.
The command ssystem("CMD") enables to launch any Windows command accessible from the shell.
But how to launch a PowerShell command?
For instance ssystem("get-process") returns -1 (not surprising in fact for get-process is not a shell process).
How can I tell Maple that this command is to be found in the PowerShell ?
And even, I this possible for, in the ssystem help page, it's said that not all the command can be launched by ssystem
TIA
I have quite a big code with lot of functions how to convert all together to python in one go
Or any other way of advice
As recoding is difficult. Can you help with a small sample program with 2 simple functions returning values
Graph theory and it's algorithms, linear algebra , have used in my program codings mainly
In small function kind take to a create a small graph find allpairshortestpath
It would help to understand how it converts
Please help sorry to disturb in your busy schedule
I am just starting with Maple after using Mathcad for nearly 30 years. I want to recreate something I have used a lot in Mathcad: select certain rows in array based on a specified criterion. For example, I want to save just the rows that have a certain value in a certain column and save the new array for use later. I am slowly learning how to do it Maple--for instance, I learned that I need to change the variable printlevel if I want to get the output from nested loops.
I currently have the following code:
k := 1;
rows := RowDimension(M);
for i to rows do
   if M[i, 3] = "A" then
      row(out, k) := row(M, i);
       k := k + 1;
out;
This doesn't seem to work, though. When I try to display out, I just get the name out instead a matrix of values.
I would appreciate it if someone could give me some idea of what I am doing wrong (with Maple, that is).
John
I have the following summation to do,
d(l,m')=\sum_{N=-l'}^{l'}d(l',N,m')=d^{l'}_{00}(\dfrac{\pi}{2})d^{l'}_{0m'}(\dfrac{\pi}{2})f_{m'0}+\sum_{N=1}^{l'}((-1)^{l'}+1)d^{l'}_{0N}(\dfrac{\pi}{2})d^{l'}_{Nm'}(\dfrac{\pi}{2})f_{m'N}
where  d^{l'}_{0N} are the rotation matrix functions and  f_{m'N} is a piecewise function which takes a certain value at N=0, another value for N even and it takes 0 as a value for N odd.
The prblem is that I don't know how to write a summation for N even only so that in that case i can replace f_{m'N} by its expression for N even. The other way is to write f_{m'N} as a piecewise function but in that case, i don't know how to do it (I tried to use assuming N even ..) but got wrong answer.
Thank you for helping me solving my proble.
Best regards.
I'm trying to enter an equation (Navier-Stokes) in Maple using the Physics[Vectors] package. I am having trouble with the term
$(u\cdot \nabla) u$
but Maple returns an error when entering the commands :
( u_(t,x,y,z) . %Nabla) u_(t,x,y,z)
I tried other combinations of this without success, like :
( u_(t,x,y,z) . %Nabla)(u_(t,x,y,z))
( u_(t,x,y,z) %. %Nabla) u_(t,x,y,z)
( u_(t,x,y,z) %. %Nabla) (u_(t,x,y,z))
Could you please give me some help with this?
I have a small problem with the display of fraction and x_dot at the same time.
This the exemple :
with(Typesetting);
compactdisplay = flase;
Settings(typesetprime = false);
Settings(typesetdot = true);
diff(1/2*LongExpression*x(t), t);
The Results
when I choose the typesetting level : Extended. I got this result :
And when I choose the typesetting level : Maple Standrad. I got this result
What I  want to have is mix of both, it mean like this
Hi please, how can I pair two lists and form another list?
P := [.6286420119, -.6286420119, 0., 0., 0., 0., 0., 0., 0., 0., 0.]
Q = [2.106333379, 2.106333379, 4.654463885, 7.843624703, 10.99193295, 14.13546782, 17.27782732, 20.41978346, 23.56157073, 26.70327712, 29.84494078]
I want to pair them into something like this:
W := [ [.6286420119,2.106333379], [-.6286420119,  2.106333379] ... ]
Then use pointplot(W) and  display(seq(pointplot(W[j], j = 1 .. 20), insequence = true):
Hello Everyone.
Hope you are fine. I have two following queries
1. Are there any builtin commands in Maple, so that we can apply the finite difference method directly to the PDE's?
2. We all know about "BurdenFaires, and Burden's NUMERICAL ANALYSIS" book. The important Maple codes are discussed on this book. Is there any website where I can take these codes on Maple files?
I am waiting for kind response.
First 300 301 302 303 304 305 306 Last Page 302 of 2427
