i did a lot of trail to avoid for find my parameter in the last step of that i get this `[Length of output exceeds limit of 1000000]` and i don't know how to fix it i need to find that parameter but when i do substitution  is said this there is any way for hundle this situation
help-parameter.mw
I have Maple 2016 and Matlab 2016b installed on my Windows destop.
When I run
with(Matlab);
openlink()
in a Maple worksheet the following error window appears.
After closing the window I also see the following error message,
Error, (in Matlab:-openlink) there was a problem finding or loading matlink.dll. Refer to ?Matlab,setup for help configuring your system to work with the Matlab-link.
How to fix the connection from Maple to Matlab?
Like i said before i have to change it to Maple 2025 should i download the 2025? and will my data disappear? or not?
Best regards MR
My goal is to export images of curves where the output image has no background or equivalently, a fully transparent background. Is there a standard way to perform this task? I know that I can do this with the help of external software but I want to do it at the export stage in maple and avoid increasing the number of tools needed to perform the job. Eventually, I may want to generate many thousdands of curves/images with transparent backgrounds.
Below I show how to make a plot while choosing a background with the color blue. I have found no way to select a fully transparent background. I expect this background transparency will be applied at the export image stage.
how_do_I_plot_with_no_background.mw
To give an explicit example of what a plot with no background looks like, I make a plot in an unrelated software of a curve with no background. It's impossible to differentiate a white background from a transparent background in this environment, so we also show the same image embedded in an unrelated colored background also generated in an unrelated software.
In the image below, we can see how a image of a curve with a transparent background can be embedded over top of any other image without the blue square shown the the first example.
Getting an error while solving. Can we get a condition like  delta ( > or <)  delta3 × constant?
Note: All parameters are positive and greater than zero.          tau, tau1, delta, delta3, delta0 are between 0 and 1.
ineq := (1-delta-tau1)*d*Cv+w*delta*d+Rm*tau1*d+s2*d*(delta0-delta-tau1)+g1*tau1^2*d^2+g2*delta^2*d^2 <= R0m*tau1^2*d^2+(1-delta[3]-tau1)*d*Cv+w*delta[3]*d+s2*d*(delta0-delta[3]-tau1)+g2*(delta[3]+tau1)^2*d^2
temp := collect(ineq,delta);
g2*delta^2*d^2+(-Cv*d-d*s2+d*w)*delta+(1-tau1)*d*Cv+Rm*tau1*d+s2*d*(delta0-tau1)+g1*tau1^2*d^2 <= R0m*tau1^2*d^2+(1-delta[3]-tau1)*d*Cv+w*delta[3]*d+s2*d*(delta0-delta[3]-tau1)+g2*(delta[3]+tau1)^2*d^2
new := simplify(temp - remove(depends,lhs(temp),delta) - select(depends,rhs(temp),delta));
-d*(d*g2*delta[3]^2+(2*d*g2*tau1-Cv-s2+w)*delta[3]+(-delta^2*g2+g2*tau1^2)*d+(-w+Cv+s2)*delta+(-Cv-s2)*tau1+s2*delta0+Cv) <= -d*(d*(g1-R0m)*tau1^2+(-Cv+Rm-s2)*tau1+s2*delta0+Cv)
simplify(solve(new,delta));
Error, invalid input: simplify uses a 1st argument, s, which is missing
Download Q_on_solve.mw
I hope everyone is fine and doing well. I want to constrcut the set of monomials {p[0],p[1],...,p[m-1]} for any value of m for example, for m=6 the monoial is define as:
p[0]:=1;
p[1]:=x;
p[2]:=y;
p[3]:=x^2;
p[4]:=x*y;
p[5]:=y^2;
and similarly for m=10 the monomials should be given as:
p[0]:=1;
p[1]:=x;
p[2]:=y;
p[3]:=x^2;
p[4]:=x*y;
p[5]:=y^2;
p[6]:=x^3;
p[7]:=x^2*y;
p[8]:=x*y^2;
p[9]:=y^3;
I am waiting for your positive response. Please take care and thanks
A classical probability result says that if G1 and G2 are two independent Gamma random variables with same scale parameter (let's say 1 to simplify) and shape parameters a1 and a2 respectively, then Gk / (G1 + G2 ) is a Beta random variable with parameters (ak , a3-k ) (k=1..2).
In the attached file it is shown that (Maple 2015) function Statistics:-PDF fails in computing the PDF of Gk.
Noting strange here if you observe that even in the extremely simple case Z = X / (X+Y), where both X and Y are independent Uniform random variable with support [0, 1), Maple 2015 already fails in computing PDF(Z).
An alternative to Statistics:-PDF is to write explicitely the double integration which defines CDF(Z) (to begin with, and later PDF(Gk)) and ask Maple to do the integrations.
This approach works for Z but requires helping Maple when X and Y are still independent Uniform random variables but with respective non instanciated supports [0, a1) and [0, a2).
Applying to the Gamma-Gamma case the recipies I introduced in the Uniform-Uniform case does not give any result, unless in the very particular case where the shape parameters a1 and a2 are (strictly) positive integers.
All the details are in X_over_(X_plus_Y).mw
Do you have any idea how to prove with Maple the probability result mentioned at the head of this question?
PS: The "classical method" to do compute PDF(Z) consists in changing the integration variables < x1, x2 > into < x1 = v1v2, x2 = v2 (1-v1) > (see for instance Stack exchange)... but even after having dome it I still cannot get the desired result.
I use Maple 2024 (X86 64 LINUX), and am trying to calculate the sum of the prime factors of integers.
My code is as simple as something like this:
SumPrimeFactors := proc(n)
    local f, L, p;
    f := ifactor(n);
    L := [op(f)];
    return add(convert(op(1, p), integer), p in L);  # Sum base primes
However, the above code returns the following result when I set n = 360:
> SumPrimeFactors(360);
                                     5 +  (2) +  (3)
while what I had expected is just an integer, 10 (= 5+2+3).
It seems the operation convert(op(1, p), integer) is not working properly, and "(2)" is recognized as an expression, not an integer, even after the convert operation.
I have no idea how I should rectiy it.
I would be glad if someone gives me a way to get it solved.
Thank you very much.
I encountered a strange issue during running in Maple. Is it possible for the comparison table to display values exceeding 8 GB when the system has only 8 GB of RAM? Is this an inconsistency?
Is there any difference in the algorithm used to compute reduced Gröbner bases (via the Basis command) between Maple 18 and the newest version of Maple? Have there been any significant optimizations, changes to default strategies, or efficiency improvements?
I am trying to use Maple to view some 120,000 x 120,000 matrices with rational entries on a linux box with 504GB of RAM. Unfortunately when I run the command
read "/home/user/source_file.txt"
maple issues an Execution stopped: Stack limit reached error. Running the kernelopts command seems to indicate that the default stack limit is 8160 on this system. I have tried setting
kernelopts(stacklimit=13560)
but the same error is always issued at around 7 GB of RAM usage (according to htop). Is there any way around this in Maple?
How to solve the given system of equations using the collocation method. I already tried numerical method.
Kindly help me.
M := 0.1e-1;
0.1e-1
6.3
de1 := diff(y(x), `$`(x, 3))+y(x)*(diff(y(x), `$`(x, 2)))-(diff(y(x), `$`(x, 2)))^2-M*(diff(y(x), x)) = 0;
diff(diff(diff(y(x), x), x), x)+y(x)*(diff(diff(y(x), x), x))-(diff(diff(y(x), x), x))^2-0.1e-1*(diff(y(x), x)) = 0
de2 := (diff(z(x), `$`(x, 2)))/Pr+y(x)*(diff(z(x), x))+Hs*z(x) = 0
.1587301587*(diff(diff(z(x), x), x))+y(x)*(diff(z(x), x))+z(x) = 0
bc := y(0) = 0, (D(y))(0) = 1, (D(y))(5) = 0, z(0) = 1, z(5) = 0;
sol := dsolve(eval([de1, de2, bc]), numeric);
proc (x_bvp) local res, data, solnproc, _ndsol, outpoint, i; option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; _EnvDSNumericSaveDigits := Digits; Digits := 15; if _EnvInFsolve = true then outpoint := evalf[_EnvDSNumericSaveDigits](x_bvp) else outpoint := evalf(x_bvp) end if; data := Array(1..4, {(1) = proc (outpoint) local X, Y, YP, yout, errproc, L, V, i; option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; X := Vector(50, {(1) = .0, (2) = 0.538450712436539e-1, (3) = .1082766859915131, (4) = .16331444031270473, (5) = .2189790463606035, (6) = .2752924234461127, (7) = .33227779889470094, (8) = .38995982000331736, (9) = .4483646786278111, (10) = .5075202501873479, (11) = .5674562491788733, (12) = .6282044036635384, (13) = .6897986516330131, (14) = .7524176453724036, (15) = .816715733668989, (16) = .8829036702135253, (17) = .9511585880378444, (18) = 1.0216871515791115, (19) = 1.0947329467114486, (20) = 1.170586433436612, (21) = 1.2495986390793312, (22) = 1.3322004686809672, (23) = 1.4189307352844525, (24) = 1.5100425310518173, (25) = 1.605556044446249, (26) = 1.706170701849191, (27) = 1.8128032039007311, (28) = 1.9266829029680352, (29) = 2.049525210932362, (30) = 2.1836360719075385, (31) = 2.3285917464945434, (32) = 2.485839068288575, (33) = 2.6591632259916818, (34) = 2.8548144648261875, (35) = 3.0721020019341, (36) = 3.305701178649673, (37) = 3.559949463816246, (38) = 3.7970789219278824, (39) = 3.990153302379728, (40) = 4.15720355507037, (41) = 4.306208343595448, (42) = 4.427174986030093, (43) = 4.526423733667591, (44) = 4.612636841962476, (45) = 4.689904237648306, (46) = 4.7605405732587975, (47) = 4.826006890793816, (48) = 4.88729546673539, (49) = 4.945116721690995, (50) = 5.0}, datatype = float[8], order = C_order); Y := Matrix(50, 5, {(1, 1) = .0, (1, 2) = 1.0, (1, 3) = -1.016912631477338, (1, 4) = 1.0, (1, 5) = 4.938383111325546, (2, 1) = 0.5239768838140454e-1, (2, 2) = .9467292622483128, (2, 3) = -.9622772113928727, (2, 4) = 1.2552137152775404, (2, 5) = 4.513346170739063, (3, 1) = .10253029316475297, (3, 2) = .895783706943777, (3, 3) = -.9101344320647631, (3, 4) = 1.4856388355002517, (3, 5) = 3.9305405877166715, (4, 1) = .1504792351703645, (4, 2) = .8470745536097423, (4, 3) = -.860373451742725, (4, 4) = 1.6829551945815935, (4, 5) = 3.223524805389885, (5, 1) = .19632323217740202, (5, 2) = .8005166268083528, (5, 3) = -.8128903023040563, (5, 4) = 1.8406334092867063, (5, 5) = 2.4329926016781056, (6, 1) = .24013840636663933, (6, 2) = .75602811722521, (6, 3) = -.7675871163117387, (6, 4) = 1.9543101701250922, (6, 5) = 1.6030729437227047, (7, 1) = .2819983835793791, (7, 2) = .7135303716905912, (7, 3) = -.7243714778269336, (7, 4) = 2.021973234344372, (7, 5) = .7775670166921098, (8, 1) = .3219743854445238, (8, 2) = .6729477074610013, (8, 3) = -.6831558741457402, (8, 4) = 2.04395171767529, (8, 5) = -0.34653255090257517e-2, (9, 1) = .36013531525388137, (9, 2) = .6342072469341395, (9, 3) = -.6438572302054374, (9, 4) = 2.0227281462789084, (9, 5) = -.7064433677651218, (10, 1) = .3965478383244555, (10, 2) = .5972387696518396, (10, 3) = -.6063965109971585, (10, 4) = 1.9626055145558932, (10, 5) = -1.3061198107940517, (11, 1) = .4312764574697176, (11, 2) = .5619745789945647, (11, 3) = -.5706983801552904, (11, 4) = 1.8692736251817776, (11, 5) = -1.786473233829117, (12, 1) = .46438358410487035, (12, 2) = .528349381415236, (12, 3) = -.5366909051394194, (12, 4) = 1.7493236289925442, (12, 5) = -2.1406810006817762, (13, 1) = .49592960543014786, (13, 2) = .49630017642071433, (13, 3) = -.5043053012120328, (13, 4) = 1.6097582709295248, (13, 5) = -2.3703112091517946, (14, 1) = .5260392137265275, (14, 2) = .46569879325333513, (14, 3) = -.4734077198356524, (14, 4) = 1.4571855527545918, (14, 5) = -2.4840706437151705, (15, 1) = .5550249899686894, (15, 2) = .4362259970506212, (15, 3) = -.44367242988215233, (15, 4) = 1.2966009526912445, (15, 5) = -2.4948251356156317, (16, 1) = .582947323077621, (16, 2) = .4078186772916242, (16, 3) = -.41503308219069956, (16, 4) = 1.133618168947713, (16, 5) = -2.4170112399060972, (17, 1) = .6098379764681325, (17, 2) = .3804427617884565, (17, 3) = -.3874529846540737, (17, 4) = .9734125833836331, (17, 5) = -2.267713799142949, (18, 1) = .6357288212995027, (18, 2) = .35406397565685854, (18, 3) = -.3608955340280772, (18, 4) = .8203928722713415, (18, 5) = -2.0653717123140347, (19, 1) = .6606520558243368, (19, 2) = .32864756458000216, (19, 3) = -.33532390992055233, (19, 4) = .6780764948146691, (19, 5) = -1.8284211343980543, (20, 1) = .6846405020881483, (20, 2) = .30415792526822016, (20, 3) = -.310700681058048, (20, 4) = .5490330762061609, (20, 5) = -1.5741295655423746, (21, 1) = .7077280179775027, (21, 2) = .2805580974006707, (21, 3) = -.2869872780487047, (21, 4) = .4348909698491685, (21, 5) = -1.3176869854655087, (22, 1) = .7299500860736533, (22, 2) = .25780904339388555, (22, 3) = -.2641432592769831, (22, 4) = .33639815254557953, (22, 5) = -1.071588245625372, (23, 1) = .7513446824807472, (23, 2) = .2358685927532746, (23, 3) = -.2421252475321414, (23, 4) = .2535257527268136, (23, 5) = -.845310470542935, (24, 1) = .7718600373416271, (24, 2) = .2147861043754655, (24, 3) = -.2209818389817886, (24, 4) = .18588236390672697, (24, 5) = -.6461214157898081, (25, 1) = .7913984364444584, (25, 2) = .1946582172929835, (25, 3) = -.20080896597698863, (25, 4) = .13250101521230842, (25, 5) = -.47835610933187955, (26, 1) = .8100007854235601, (26, 2) = .1754386620756086, (26, 3) = -.18155930417548316, (26, 4) = 0.9154569608003324e-1, (26, 5) = -.3421381651798363, (27, 1) = .8277118076501322, (27, 2) = .15707596816855374, (27, 3) = -.16318052643948905, (27, 4) = 0.6105466126293412e-1, (27, 5) = -.23553722921336775, (28, 1) = .8445805217874315, (28, 2) = .13951234873701424, (28, 3) = -.14561421333147123, (28, 4) = 0.39087681110023476e-1, (28, 5) = -.15525672367643156, (29, 1) = .8606634863301678, (29, 2) = .12267930610986412, (29, 3) = -.12879150739256892, (29, 4) = 0.23832991063636576e-1, (29, 5) = -0.9724838130607329e-1, (30, 1) = .8760079352865905, (30, 2) = .10651370141941992, (30, 3) = -.1126492397968819, (30, 4) = 0.13691444825679132e-1, (30, 5) = -0.5727653723318041e-1, (31, 1) = .8903192581096104, (31, 2) = 0.9131052167272624e-1, (31, 3) = -0.9748175032923309e-1, (31, 4) = 0.74131272943985405e-2, (31, 5) = -0.3172088613075896e-1, (32, 1) = .9035329750439559, (32, 2) = 0.7712276927556598e-1, (32, 3) = -0.8334133909913169e-1, (32, 4) = 0.3755698608845979e-2, (32, 5) = -0.1640104680740198e-1, (33, 1) = .9157173948547132, (33, 2) = 0.6385549523046109e-1, (33, 3) = -0.7013295494960084e-1, (33, 4) = 0.17491668487648983e-2, (33, 5) = -0.7780056793655609e-2, (34, 1) = .9269514730577374, (34, 2) = 0.51386320628059305e-1, (34, 3) = -0.57734884774429875e-1, (34, 4) = 0.7271289957321933e-3, (34, 5) = -0.32884474837452868e-2, (35, 1) = .9368471128429581, (35, 2) = 0.4010243173621042e-1, (35, 3) = -0.4653193161278045e-1, (35, 4) = 0.27013268380656147e-3, (35, 5) = -0.12396732969434932e-2, (36, 1) = .9450380185477333, (36, 2) = 0.30399509190318585e-1, (36, 3) = -0.36915005251636664e-1, (36, 4) = 0.9182614553853198e-4, (36, 5) = -0.42674003103921183e-3, (37, 1) = .9516679912394145, (37, 2) = 0.22101471191290013e-1, (37, 3) = -0.28706677187926227e-1, (37, 4) = 0.27971094145282712e-4, (37, 5) = -0.1315582904251911e-3, (38, 1) = .9561612871284315, (38, 2) = 0.16032468497041725e-1, (38, 3) = -0.22716201697191084e-1, (38, 4) = 0.9108284297335907e-5, (38, 5) = -0.4337758039619726e-4, (39, 1) = .958858965635045, (39, 2) = 0.12038500162795706e-1, (39, 3) = -0.18782005182342264e-1, (39, 4) = 0.3608857075468415e-5, (39, 5) = -0.17441599450102097e-4, (40, 1) = .9606217197165348, (40, 2) = 0.914514325386327e-2, (40, 3) = -0.1593723322791538e-1, (40, 4) = 0.15973572885621025e-5, (40, 5) = -0.7881196067433009e-5, (41, 1) = .9618157889669987, (41, 2) = 0.693594504796013e-2, (41, 3) = -0.13768928625667299e-1, (41, 4) = 0.7578240406846033e-6, (41, 5) = -0.3856388483481057e-5, (42, 1) = .9625579336916471, (42, 2) = 0.53653148882890234e-2, (42, 3) = -0.12229837199143657e-1, (42, 4) = 0.40466831691457055e-6, (42, 5) = -0.21455723871656463e-5, (43, 1) = .9630321047416508, (43, 2) = 0.4208610204678467e-2, (43, 3) = -0.11097927826763769e-1, (43, 4) = 0.23599512230457527e-6, (43, 5) = -0.13185086023573497e-5, (44, 1) = .9633548330674003, (44, 2) = 0.3291032013106795e-2, (44, 3) = -0.10201119562353245e-1, (44, 4) = 0.14351096807189318e-6, (44, 5) = -0.8585799100739333e-6, (45, 1) = .9635794225798572, (45, 2) = 0.25318181431538732e-2, (45, 3) = -0.9459930001639555e-2, (45, 4) = 0.8857046151520711e-7, (45, 5) = -0.5807183930298681e-6, (46, 1) = .9637351936467563, (46, 2) = 0.18861028334058306e-2, (46, 3) = -0.8830217058260243e-2, (46, 4) = 0.54176953171370387e-7, (46, 5) = -0.40321204700634103e-6, (47, 1) = .9638401434562422, (47, 2) = 0.1326072836040432e-2, (47, 3) = -0.828462376949864e-2, (47, 4) = 0.318508859340672e-7, (47, 5) = -0.28512654551555526e-6, (48, 1) = .9639061617395365, (48, 2) = 0.8331693356556849e-3, (48, 3) = -0.7804900784463723e-2, (48, 4) = 0.16983012204335007e-7, (48, 5) = -0.20411108581207533e-6, (49, 1) = .963941530746681, (49, 2) = 0.39433359612162176e-3, (49, 3) = -0.7378210574196815e-2, (49, 4) = 0.69058956940428584e-8, (49, 5) = -0.14716673870893628e-6, (50, 1) = .963952255758426, (50, 2) = .0, (50, 3) = -0.6995152048687603e-2, (50, 4) = .0, (50, 5) = -0.10635754806174274e-6}, datatype = float[8], order = C_order); YP := Matrix(50, 5, {(1, 1) = 1.0, (1, 2) = -1.016912631477338, (1, 3) = 1.0441113000581643, (1, 4) = 4.938383111325546, (1, 5) = -6.300000001197, (2, 1) = .9467292622483128, (2, 2) = -.9622772113928727, (2, 3) = .9858658256476173, (2, 4) = 4.513346170739063, (2, 5) = -9.397726517168355, (3, 1) = .895783706943777, (3, 2) = -.9101344320647631, (3, 3) = .9306188716382228, (3, 4) = 3.9305405877166715, (3, 5) = -11.898421382065955, (4, 1) = .8470745536097423, (4, 2) = -.860373451742725, (4, 3) = .8781815609789202, (4, 4) = 3.223524805389885, (4, 5) = -13.658581076246108, (5, 1) = .8005166268083528, (5, 2) = -.8128903023040563, (5, 3) = .8283850614020614, (5, 4) = 2.4329926016781056, (5, 5) = -14.605204201259696, (6, 1) = .75602811722521, (6, 2) = -.7675871163117387, (6, 3) = .7810774091586878, (6, 4) = 1.6030729437227047, (6, 5) = -14.737398181156987, (7, 1) = .7135303716905912, (7, 2) = -.7243714778269336, (7, 3) = .736120927464283, (7, 4) = .7775670166921098, (7, 5) = -14.11984902259275, (8, 1) = .6729477074610013, (8, 2) = -.6831558741457402, (8, 3) = .6933901181953316, (8, 4) = -0.34653255090257517e-2, (8, 5) = -12.86986662367746, (9, 1) = .6342072469341395, (9, 2) = -.6438572302054374, (9, 3) = .6527699319356851, (9, 4) = -.7064433677651218, (9, 5) = -11.140371532431427, (10, 1) = .5972387696518396, (10, 2) = -.6063965109971585, (10, 3) = .6141543418494605, (10, 4) = -1.3061198107940517, (10, 5) = -9.101399121783686, (11, 1) = .5619745789945647, (11, 2) = -.5706983801552904, (11, 3) = .5774451625788978, (11, 4) = -1.786473233829117, (11, 5) = -6.922501599763635, (12, 1) = .528349381415236, (12, 2) = -.5366909051394194, (12, 3) = .5425510675586522, (12, 4) = -2.1406810006817762, (12, 5) = -4.757927035769672, (13, 1) = .49630017642071433, (13, 2) = -.5043053012120328, (13, 3) = .5093867676411815, (13, 4) = -2.3703112091517946, (13, 5) = -2.7357798403575755, (14, 1) = .46569879325333513, (14, 2) = -.4734077198356524, (14, 3) = .47780288184693964, (14, 4) = -2.4840706437151705, (14, 5) = -.9479420024892491, (15, 1) = .4362259970506212, (15, 2) = -.44367242988215233, (15, 3) = .44745677095276526, (15, 4) = -2.4948251356156317, (15, 5) = .5549628621234142, (16, 1) = .4078186772916242, (16, 2) = -.41503308219069956, (16, 3) = .4182730703373508, (16, 4) = -2.4170112399060972, (16, 5) = 1.7348439985152488, (17, 1) = .3804427617884565, (17, 2) = -.3874529846540737, (17, 3) = .39020778707321313, (17, 4) = -2.267713799142949, (17, 5) = 2.5800100903859544, (18, 1) = .35406397565685854, (18, 2) = -.3608955340280772, (18, 3) = .36321791869790376, (18, 4) = -2.0653717123140347, (18, 5) = 3.10352774783306, (19, 1) = .32864756458000216, (19, 2) = -.33532390992055233, (19, 3) = .3372610306662744, (19, 4) = -1.8284211343980543, (19, 5) = 3.338204225824109, (20, 1) = .30415792526822016, (20, 2) = -.310700681058048, (20, 3) = .31229476274132867, (20, 4) = -1.5741295655423746, (20, 5) = 3.3306826139938144, (21, 1) = .2805580974006707, (21, 2) = -.2869872780487047, (21, 3) = .28827621621397953, (21, 4) = -1.3176869854655087, (21, 5) = 3.135340081336959, (22, 1) = .25780904339388555, (22, 2) = -.2641432592769831, (22, 3) = .2651611467004155, (22, 4) = -1.071588245625372, (22, 5) = 2.8085890119139396, (23, 1) = .2358685927532746, (23, 2) = -.2421252475321414, (23, 3) = .2429028386476426, (23, 4) = -.845310470542935, (23, 5) = 2.4040407789305567, (24, 1) = .2147861043754655, (24, 2) = -.2209818389817886, (24, 3) = .2215478846918326, (24, 4) = -.6461214157898081, (24, 5) = 1.9708474985101825, (25, 1) = .1946582172929835, (25, 2) = -.20080896597698863, (25, 3) = .20119072468789445, (25, 4) = -.47835610933187955, (25, 5) = 1.5502363494870965, (26, 1) = .1754386620756086, (26, 2) = -.18155930417548316, (26, 3) = .18178134653653813, (26, 4) = -.3421381651798363, (26, 5) = 1.1691948647879093, (27, 1) = .15707596816855374, (27, 2) = -.16318052643948905, (27, 3) = .163265092403284, (27, 4) = -.23553722921336775, (27, 5) = .843584392498727, (28, 1) = .13951234873701424, (28, 2) = -.14561421333147123, (28, 3) = .14558155088667368, (28, 4) = -.15525672367643156, (28, 5) = .579846478687003, (29, 1) = .12267930610986412, (29, 2) = -.12879150739256892, (29, 3) = .12866019319975472, (29, 4) = -0.9724838130607329e-1, (29, 5) = .3771503810083066, (30, 1) = .10651370141941992, (30, 2) = -.1126492397968819, (30, 3) = .11243661620708013, (30, 4) = -0.5727653723318041e-1, (30, 5) = .22984451471051648, (31, 1) = 0.9131052167272624e-1, (31, 2) = -0.9748175032923309e-1, (31, 3) = 0.9720567649632728e-1, (31, 4) = -0.3172088613075896e-1, (31, 5) = .13122010765127654, (32, 1) = 0.7712276927556598e-1, (32, 2) = -0.8334133909913169e-1, (32, 3) = 0.8301865455597775e-1, (32, 4) = -0.1640104680740198e-1, (32, 5) = 0.6969808445659362e-1, (33, 1) = 0.6385549523046109e-1, (33, 2) = -0.7013295494960084e-1, (33, 3) = 0.697791531221788e-1, (33, 4) = -0.7780056793655609e-2, (33, 5) = 0.3386354889433578e-1, (34, 1) = 0.51386320628059305e-1, (34, 2) = -0.57734884774429875e-1, (34, 3) = 0.5736461661467379e-1, (34, 4) = -0.32884474837452868e-2, (34, 5) = 0.14622944136188972e-1, (35, 1) = 0.4010243173621042e-1, (35, 2) = -0.4653193161278045e-1, (35, 3) = 0.4615955076341791e-1, (35, 4) = -0.12396732969434932e-2, (35, 5) = 0.5614885492478633e-2, (36, 1) = 0.30399509190318585e-1, (36, 2) = -0.36915005251636664e-1, (36, 3) = 0.3655279612231743e-1, (36, 4) = -0.42674003103921183e-3, (36, 5) = 0.19621942697003233e-2, (37, 1) = 0.22101471191290013e-1, (37, 2) = -0.28706677187926227e-1, (37, 3) = 0.2836431384167678e-1, (37, 4) = -0.1315582904251911e-3, (37, 5) = 0.6125409350740502e-3, (38, 1) = 0.16032468497041725e-1, (38, 2) = -0.22716201697191084e-1, (38, 3) = 0.22396703157973173e-1, (38, 4) = -0.4337758039619726e-4, (38, 5) = 0.20391637652164134e-3, (39, 1) = 0.12038500162795706e-1, (39, 2) = -0.18782005182342264e-1, (39, 3) = 0.18482442781990245e-1, (39, 4) = -0.17441599450102097e-4, (39, 5) = 0.8262561468904556e-4, (40, 1) = 0.914514325386327e-2, (40, 2) = -0.1593723322791538e-1, (40, 3) = 0.15655099226423174e-1, (40, 4) = -0.7881196067433009e-5, (40, 5) = 0.3763299224344935e-4, (41, 1) = 0.693594504796013e-2, (41, 2) = -0.13768928625667299e-1, (41, 3) = 0.13502115795304808e-1, (41, 4) = -0.3856388483481057e-5, (41, 5) = 0.18593261137575973e-4, (42, 1) = 0.53653148882890234e-2, (42, 2) = -0.12229837199143657e-1, (42, 3) = 0.11975148890593406e-1, (42, 4) = -0.21455723871656463e-5, (42, 5) = 0.10461587263954827e-4, (43, 1) = 0.4208610204678467e-2, (43, 2) = -0.11097927826763769e-1, (43, 3) = 0.1085291089737409e-1, (43, 4) = -0.13185086023573497e-5, (43, 5) = 0.6512757251742076e-5, (44, 1) = 0.3291032013106795e-2, (44, 2) = -0.10201119562353245e-1, (44, 3) = 0.9964270993547896e-2, (44, 4) = -0.8585799100739333e-6, (44, 5) = 0.4306718669414423e-5, (45, 1) = 0.25318181431538732e-2, (45, 2) = -0.9459930001639555e-2, (45, 3) = 0.9230202345693167e-2, (45, 4) = -0.5807183930298681e-6, (45, 5) = 0.29672863441924835e-5, (46, 1) = 0.18861028334058306e-2, (46, 2) = -0.8830217058260243e-2, (46, 3) = 0.8606824708215374e-2, (46, 4) = -0.40321204700634103e-6, (46, 5) = 0.2106799928695533e-5, (47, 1) = 0.1326072836040432e-2, (47, 2) = -0.828462376949864e-2, (47, 3) = 0.8066948681837108e-2, (47, 4) = -0.28512654551555526e-6, (47, 5) = 0.15306828052634482e-5, (48, 1) = 0.8331693356556849e-3, (48, 2) = -0.7804900784463723e-2, (48, 3) = 0.75924401275222035e-2, (48, 4) = -0.20411108581207533e-6, (48, 5) = 0.11324938030775855e-5, (49, 1) = 0.39433359612162176e-3, (49, 2) = -0.7378210574196815e-2, (49, 3) = 0.7170544922301032e-2, (49, 4) = -0.14716673870893628e-6, (49, 5) = 0.85021168502143e-6, (50, 1) = .0, (50, 2) = -0.6995152048687603e-2, (50, 3) = 0.6791924748889848e-2, (50, 4) = -0.10635754806174274e-6, (50, 5) = 0.6458986698603491e-6}, datatype = float[8], order = C_order); errproc := proc (x_bvp) local outpoint, X, Y, yout, L, V, i; option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; Digits := 15; outpoint := evalf(x_bvp); X := Vector(50, {(1) = .0, (2) = 0.538450712436539e-1, (3) = .1082766859915131, (4) = .16331444031270473, (5) = .2189790463606035, (6) = .2752924234461127, (7) = .33227779889470094, (8) = .38995982000331736, (9) = .4483646786278111, (10) = .5075202501873479, (11) = .5674562491788733, (12) = .6282044036635384, (13) = .6897986516330131, (14) = .7524176453724036, (15) = .816715733668989, (16) = .8829036702135253, (17) = .9511585880378444, (18) = 1.0216871515791115, (19) = 1.0947329467114486, (20) = 1.170586433436612, (21) = 1.2495986390793312, (22) = 1.3322004686809672, (23) = 1.4189307352844525, (24) = 1.5100425310518173, (25) = 1.605556044446249, (26) = 1.706170701849191, (27) = 1.8128032039007311, (28) = 1.9266829029680352, (29) = 2.049525210932362, (30) = 2.1836360719075385, (31) = 2.3285917464945434, (32) = 2.485839068288575, (33) = 2.6591632259916818, (34) = 2.8548144648261875, (35) = 3.0721020019341, (36) = 3.305701178649673, (37) = 3.559949463816246, (38) = 3.7970789219278824, (39) = 3.990153302379728, (40) = 4.15720355507037, (41) = 4.306208343595448, (42) = 4.427174986030093, (43) = 4.526423733667591, (44) = 4.612636841962476, (45) = 4.689904237648306, (46) = 4.7605405732587975, (47) = 4.826006890793816, (48) = 4.88729546673539, (49) = 4.945116721690995, (50) = 5.0}, datatype = float[8], order = C_order); Y := Matrix(50, 5, {(1, 1) = .0, (1, 2) = .0, (1, 3) = 0.15143863606013115e-13, (1, 4) = .0, (1, 5) = 0.5209145281927147e-8, (2, 1) = -0.8264612893080438e-16, (2, 2) = 0.10601022236424583e-14, (2, 3) = 0.13448281300622448e-13, (2, 4) = 0.2531723244828144e-9, (2, 5) = 0.5151764399789821e-8, (3, 1) = -0.9818312986936232e-16, (3, 2) = 0.2024546298845675e-14, (3, 3) = 0.11603414280085763e-13, (3, 4) = 0.5031439996715309e-9, (3, 5) = 0.49505227176451794e-8, (4, 1) = -0.16400920960349306e-15, (4, 2) = 0.22923225644852182e-14, (4, 3) = 0.9858996413953448e-14, (4, 4) = 0.7435382816273587e-9, (4, 5) = 0.4613790921382858e-8, (5, 1) = 0.16695611005256184e-15, (5, 2) = 0.2920750522546946e-14, (5, 3) = 0.8715810892933721e-14, (5, 4) = 0.968257325936286e-9, (5, 5) = 0.4156299767076735e-8, (6, 1) = 0.3785488577501235e-15, (6, 2) = 0.34710943442817573e-14, (6, 3) = 0.7739663648523766e-14, (6, 4) = 0.11717218646887862e-8, (6, 5) = 0.359812314472648e-8, (7, 1) = 0.5735291564092602e-15, (7, 2) = 0.5559621333708256e-14, (7, 3) = 0.64794162714847054e-14, (7, 4) = 0.1349065434755046e-8, (7, 5) = 0.29635492365957813e-8, (8, 1) = 0.7392908645452232e-15, (8, 2) = 0.3999400361865862e-14, (8, 3) = 0.6347742731734012e-14, (8, 4) = 0.14963058193845247e-8, (8, 5) = 0.2279713504762398e-8, (9, 1) = 0.6831780723045333e-15, (9, 2) = 0.5442883341070182e-14, (9, 3) = 0.56555333890748366e-14, (9, 4) = 0.1610546333661808e-8, (9, 5) = 0.15751280801152935e-8, (10, 1) = 0.12805951228799598e-14, (10, 2) = 0.5552725838454675e-14, (10, 3) = 0.494213125294359e-14, (10, 4) = 0.16900532451603174e-8, (10, 5) = 0.8780983197662242e-9, (11, 1) = 0.1589045835010457e-14, (11, 2) = 0.54573811395900386e-14, (11, 3) = 0.4370346233896689e-14, (11, 4) = 0.1734384141772804e-8, (11, 5) = 0.21511245732875356e-9, (12, 1) = 0.1938397406295573e-14, (12, 2) = 0.65363028178274735e-14, (12, 3) = 0.39915199224484734e-14, (12, 4) = 0.17443804487181745e-8, (12, 5) = -0.3906337574991102e-9, (13, 1) = 0.25746355641282846e-14, (13, 2) = 0.6686301295711723e-14, (13, 3) = 0.3776993739734716e-14, (13, 4) = 0.17221022298538633e-8, (13, 5) = -0.9204760276081012e-9, (14, 1) = 0.24021854692179305e-14, (14, 2) = 0.68388696506603025e-14, (14, 3) = 0.3589227807197002e-14, (14, 4) = 0.16706007423685053e-8, (14, 5) = -0.13619565204084925e-8, (15, 1) = 0.27844846589144917e-14, (15, 2) = 0.6806482863864933e-14, (15, 3) = 0.3255802330557269e-14, (15, 4) = 0.15931710762978012e-8, (15, 5) = -0.1710057839046858e-8, (16, 1) = 0.3170168392339236e-14, (16, 2) = 0.7058625852330826e-14, (16, 3) = 0.3059882244808441e-14, (16, 4) = 0.14936064638531152e-8, (16, 5) = -0.19605804146242323e-8, (17, 1) = 0.418450905753915e-14, (17, 2) = 0.7320624596592493e-14, (17, 3) = 0.25290623286820664e-14, (17, 4) = 0.1376224007726725e-8, (17, 5) = -0.2113726736115561e-8, (18, 1) = 0.522802446903785e-14, (18, 2) = 0.7583088387046541e-14, (18, 3) = 0.2656436255857598e-14, (18, 4) = 0.12456454647509306e-8, (18, 5) = -0.2174149264673966e-8, (19, 1) = 0.5599963613653709e-14, (19, 2) = 0.7792902420006349e-14, (19, 3) = 0.2298977816983502e-14, (19, 4) = 0.1106554758169108e-8, (19, 5) = -0.21502682643665226e-8, (20, 1) = 0.5865892702136685e-14, (20, 2) = 0.8092855141368515e-14, (20, 3) = 0.2509193086994891e-14, (20, 4) = 0.9634933725685698e-9, (20, 5) = -0.205341703724594e-8, (21, 1) = 0.6816420131570755e-14, (21, 2) = 0.7846294298633722e-14, (21, 3) = 0.22775440990284527e-14, (21, 4) = 0.8206611972083126e-9, (21, 5) = -0.1896857216112942e-8, (22, 1) = 0.7301012092886368e-14, (22, 2) = 0.7949612920729695e-14, (22, 3) = 0.19113297564801313e-14, (22, 4) = 0.6817767801598973e-9, (22, 5) = -0.16947933473596584e-8, (23, 1) = 0.7517850272435388e-14, (23, 2) = 0.844440889491318e-14, (23, 3) = 0.210172135546369e-14, (23, 4) = 0.5499764453689152e-9, (23, 5) = -0.14614844738189918e-8, (24, 1) = 0.9093082110941868e-14, (24, 2) = 0.8617808603338214e-14, (24, 3) = 0.1973966157355317e-14, (24, 4) = 0.4281530842561462e-9, (24, 5) = -0.12106705564003452e-8, (25, 1) = 0.9614190502196018e-14, (25, 2) = 0.8848373195710656e-14, (25, 3) = 0.2086102522252812e-14, (25, 4) = 0.3188261735784484e-9, (25, 5) = -0.9556847653193206e-9, (26, 1) = 0.1041568490829814e-13, (26, 2) = 0.893833612887857e-14, (26, 3) = 0.1856000845238865e-14, (26, 4) = 0.22345041334248272e-9, (26, 5) = -0.708864527271831e-9, (27, 1) = 0.1152901561368169e-13, (27, 2) = 0.89795369925252e-14, (27, 3) = 0.2071787429729606e-14, (27, 4) = 0.14287136200501294e-9, (27, 5) = -0.4806758343384607e-9, (28, 1) = 0.13495965110034514e-13, (28, 2) = 0.9150624849596765e-14, (28, 3) = 0.18643959445317172e-14, (28, 4) = 0.7730346102119082e-10, (28, 5) = -0.27925524569939634e-9, (29, 1) = 0.1447846668412635e-13, (29, 2) = 0.9061416074595552e-14, (29, 3) = 0.2277139811068211e-14, (29, 4) = 0.26236748156626518e-10, (29, 5) = -0.10967840766932284e-9, (30, 1) = 0.1637043045937391e-13, (30, 2) = 0.8735733718415329e-14, (30, 3) = 0.27774780827091533e-14, (30, 4) = -0.11566251997979936e-10, (30, 5) = 0.26584437011128173e-10, (31, 1) = 0.19157667101419045e-13, (31, 2) = 0.8123059896172982e-14, (31, 3) = 0.36940270461759766e-14, (31, 4) = -0.3338327910770145e-10, (31, 5) = 0.11387033083646781e-9, (32, 1) = 0.218389656225817e-13, (32, 2) = 0.6857924190366744e-14, (32, 3) = 0.5214825473490382e-14, (32, 4) = -0.40398750655901706e-10, (32, 5) = 0.14926462934637388e-9, (33, 1) = 0.2627628563699054e-13, (33, 2) = 0.401556619991872e-14, (33, 3) = 0.8152745438393999e-14, (33, 4) = -0.3804768632584147e-10, (33, 5) = 0.14874007073963709e-9, (34, 1) = 0.36370999494014086e-13, (34, 2) = -0.386548921701265e-14, (34, 3) = 0.1631808180318328e-13, (34, 4) = -0.33000222761584506e-10, (34, 5) = 0.13693032069292921e-9, (35, 1) = 0.5509262327612127e-13, (35, 2) = -0.18890089391438668e-13, (35, 3) = 0.3161707194631968e-13, (35, 4) = -0.16646067039944626e-10, (35, 5) = 0.7219686567800556e-10, (36, 1) = 0.7409383620236018e-13, (36, 2) = -0.36040651044841214e-13, (36, 3) = 0.4898335208487011e-13, (36, 4) = 0.32784502413364445e-11, (36, 5) = -0.14735420939556755e-10, (37, 1) = 0.10169362342003957e-12, (37, 2) = -0.6040877776984526e-13, (37, 3) = 0.7350859063809685e-13, (37, 4) = 0.6987192987396587e-11, (37, 5) = -0.31593308676975374e-10, (38, 1) = 0.9107063627312493e-13, (38, 2) = -0.46451392159979334e-13, (38, 3) = 0.5970703758877559e-13, (38, 4) = 0.31960324368762172e-11, (38, 5) = -0.14549863332219355e-10, (39, 1) = 0.7795348303548032e-13, (39, 2) = -0.307504836025312e-13, (39, 3) = 0.4400477767345146e-13, (39, 4) = -0.24540000756116013e-12, (39, 5) = 0.14204634414083795e-11, (40, 1) = 0.7037299697401581e-13, (40, 2) = -0.2113986584686098e-13, (40, 3) = 0.3446868361893824e-13, (40, 4) = -0.6711604095422506e-12, (40, 5) = 0.33730077034860774e-11, (41, 1) = 0.6567420110784044e-13, (41, 2) = -0.1487071052735246e-13, (41, 3) = 0.281975245609803e-13, (41, 4) = -0.4840307488210744e-12, (41, 5) = 0.24565250659311624e-11, (42, 1) = 0.6459712022715409e-13, (42, 2) = -0.11097162630862281e-13, (42, 3) = 0.24423024403583574e-13, (42, 4) = -0.28608148225793283e-12, (42, 5) = 0.14964581624333766e-11, (43, 1) = 0.640280502136775e-13, (43, 2) = -0.8548606846495986e-14, (43, 3) = 0.21881466472077222e-13, (43, 4) = -0.16940774104908874e-12, (43, 5) = 0.9262688645940507e-12, (44, 1) = 0.6244301847516393e-13, (44, 2) = -0.66219479488107194e-14, (44, 3) = 0.1995701245760364e-13, (44, 4) = -0.10237686507119983e-12, (44, 5) = 0.5948441235731513e-12, (45, 1) = 0.6185753483413617e-13, (45, 2) = -0.5051468771290501e-14, (45, 3) = 0.18395260491368303e-13, (45, 4) = -0.6239441019233403e-13, (45, 5) = 0.3942092903383439e-12, (46, 1) = 0.6165132946892792e-13, (46, 2) = -0.37441003592832135e-14, (46, 3) = 0.1709672398590452e-13, (46, 4) = -0.3763161671814335e-13, (46, 5) = 0.26764102662748244e-12, (47, 1) = 0.6198151724876583e-13, (47, 2) = -0.26188562204839776e-14, (47, 3) = 0.15967252338380992e-13, (47, 4) = -0.21819149987483318e-13, (47, 5) = 0.18495665706484231e-12, (48, 1) = 0.6094944363926368e-13, (48, 2) = -0.1640899643671393e-14, (48, 3) = 0.15000579561151843e-13, (48, 4) = -0.11483823318682457e-13, (48, 5) = 0.1293625847432827e-12, (49, 1) = 0.6143323589996598e-13, (49, 2) = -0.7734412660573863e-15, (49, 3) = 0.14134062292410381e-13, (49, 4) = -0.4614422689930712e-14, (49, 5) = 0.9108760894060782e-13, (50, 1) = 0.6135526225959751e-13, (50, 2) = .0, (50, 3) = 0.13373226403332908e-13, (50, 4) = .0, (50, 5) = 0.6421709636688081e-13}, datatype = float[8], order = C_order); if not type(outpoint, 'numeric') then if outpoint = "start" or outpoint = "left" then return X[1] elif outpoint = "right" then return X[50] elif outpoint = "order" then return 8 elif outpoint = "error" then return HFloat(5.209145281927147e-9) elif outpoint = "errorproc" then error "this is already the error procedure" elif outpoint = "rawdata" then return [5, 50, [y(x), diff(y(x), x), diff(diff(y(x), x), x), z(x), diff(z(x), x)], X, Y] else return ('procname')(x_bvp) end if end if; if outpoint < X[1] or X[50] < outpoint then error "solution is only defined in the range %1..%2", X[1], X[50] end if; V := array([1 = 4, 2 = 0]); if Digits <= trunc(evalhf(Digits)) then L := Vector(4, 'datatype' = 'float'[8]); yout := Vector(5, 'datatype' = 'float'[8]); evalhf(`dsolve/numeric/lagrange`(50, 5, X, Y, outpoint, var(yout), var(L), var(V))) else L := Vector(4, 'datatype' = 'sfloat'); yout := Vector(5, 'datatype' = 'sfloat'); `dsolve/numeric/lagrange`(50, 5, X, Y, outpoint, yout, L, V) end if; [x = outpoint, seq('[y(x), diff(y(x), x), diff(diff(y(x), x), x), z(x), diff(z(x), x)]'[i] = yout[i], i = 1 .. 5)] end proc; if not type(outpoint, 'numeric') then if outpoint = "start" or outpoint = "left" then return X[1] elif outpoint = "method" then return "bvp" elif outpoint = "right" then return X[50] elif outpoint = "order" then return 8 elif outpoint = "error" then return HFloat(5.209145281927147e-9) elif outpoint = "errorproc" then return eval(errproc) elif outpoint = "rawdata" then return [5, 50, "depnames", X, Y, YP] else error "non-numeric value" end if end if; if outpoint < X[1] or X[50] < outpoint then error "solution is only defined in the range %1..%2", X[1], X[50] end if; if Digits <= trunc(evalhf(Digits)) and (_EnvInFsolve <> true or _EnvDSNumericSaveDigits <= trunc(evalhf(Digits))) then V := array( 1 .. 6, [( 1 ) = (7), ( 2 ) = (0), ( 3 ) = (false), ( 4 ) = (false), ( 5 ) = (false), ( 6 ) = (false)  ] ); L := Matrix(7, 2, {(1, 1) = .0, (1, 2) = .0, (2, 1) = .0, (2, 2) = .0, (3, 1) = .0, (3, 2) = .0, (4, 1) = .0, (4, 2) = .0, (5, 1) = .0, (5, 2) = .0, (6, 1) = .0, (6, 2) = .0, (7, 1) = .0, (7, 2) = .0}, datatype = float[8], order = C_order); yout := Vector(5, {(1) = .0, (2) = .0, (3) = .0, (4) = .0, (5) = .0}, datatype = float[8]); evalhf(`dsolve/numeric/hermite`(50, 5, X, Y, YP, outpoint, var(yout), var(L), var(V))) else if _EnvInFsolve = true then Digits := _EnvDSNumericSaveDigits end if; V := array( 1 .. 6, [( 1 ) = (7), ( 2 ) = (0), ( 3 ) = (false), ( 4 ) = (false), ( 5 ) = (false), ( 6 ) = (false)  ] ); L := Matrix(7, 2, {(1, 1) = 0., (1, 2) = 0., (2, 1) = 0., (2, 2) = 0., (3, 1) = 0., (3, 2) = 0., (4, 1) = 0., (4, 2) = 0., (5, 1) = 0., (5, 2) = 0., (6, 1) = 0., (6, 2) = 0., (7, 1) = 0., (7, 2) = 0.}, order = C_order); yout := Vector(5, {(1) = 0., (2) = 0., (3) = 0., (4) = 0., (5) = 0.}); `dsolve/numeric/hermite`(50, 5, X, Y, YP, outpoint, yout, L, V) end if; [outpoint, seq(yout[i], i = 1 .. 5)] end proc, (2) = Array(0..0, {}), (3) = [x, y(x), diff(y(x), x), diff(diff(y(x), x), x), z(x), diff(z(x), x)], (4) = 0}); solnproc := data[1]; if not type(outpoint, 'numeric') then if outpoint = "solnprocedure" then return eval(solnproc) elif member(outpoint, ["start", "left", "right", "errorproc", "rawdata", "order", "error"]) then return solnproc(x_bvp) elif outpoint = "sysvars" then return data[3] elif procname <> unknown then return ('procname')(x_bvp) else _ndsol := pointto(data[2][0]); return ('_ndsol')(x_bvp) end if end if; try res := solnproc(outpoint); [x = res[1], seq('[y(x), diff(y(x), x), diff(diff(y(x), x), x), z(x), diff(z(x), x)]'[i] = res[i+1], i = 1 .. 5)] catch: error  end try end proc
print(sol(0));
[x = 0., y(x) = HFloat(0.0), diff(y(x), x) = HFloat(0.9999999999999998), diff(diff(y(x), x), x) = HFloat(-1.0169126314773378), z(x) = HFloat(0.9999999999999998), diff(z(x), x) = HFloat(4.938383111325545)]
odeplot(sol, [x, diff(y(x), x)], x = 0 .. 5)
odeplot(sol, [x, z(x)], x = 0 .. 5)
Download Code.mw
Could anyone help me with the syntax to create a Region Plot (Feasibility or Preference Map) that displays: Regions based on conditions like:
  • When   and  πR>πD ​ ​, then Strategy 1 is preferred.
    and  When ​, πR<πD then Strategy 2 is better.
  • When ​,πR<πD then Strategy 2 is preferred.
    and When ​,πR>πD then Strategy 1 is better.
I’d also like the plot to visually highlight the regions based on strategy​, and vice versa.
File : Regional_plot.mw
Could someone tell me how to insert an entry (empty cell) between two already filled entries or above an already filled entry in Document Mode?
Oliveira
First 30 31 32 33 34 35 36 Last Page 32 of 2457
