I have two questions:
1) How can I select only parts of an equation in a Maple Workbook? E.g. I have
4*x^2*(1 + x)^2*(x^2 + 6*x + 1)
and I want to select the text between the first "2" and the "6", but Maple always extends the selection to include the complete bracket. This is very annoying :)
2) How can I copy text from a maplesoft page into a workbook. E.g. I'm looking at
https://www.maplesoft.com/support/help/maple/view.aspx?path=updates/Maple2021/ODEsandPDEs
and I would like to select and copy some of the shown examples so that I can use them.
I believe I have found a bug or unintended behaviour:
The following second-order DE:
mplinput := ((x^4 + 4*x^3 + 10*x^2 + 4*x + 1)*diff(y(x), [x $ 0]))/(4*x^2*(1 + x)^2*(x^2 + 6*x + 1)) + 2*(x^2 + 5*x + 2)*diff(y(x), [x $ 1])/((1 + x)*(x^2 + 6*x + 1)) + diff(y(x), [x $ 2])=0:
can be solved by
with(DEtools):
hypergeometricsols(mplinput);
in terms of hypergeom functions. However,
dsolve(mplinput, [hypergeometricsols]);
does not find a solution, although it is supposed to use the same algorithm. One can trace this back to the sub-algorithm 'DEtools/2F1: --- find_2f1 ---' which is apparantly used by hypergeometricsols, but not by dsolve.
Another thing is that dsolve(mplinput, [hypergeometricsols]) in fact works in Maple2020, but does not in Maple2021 and Maple2022.
I installed syrup within Maple 2022 according to the procedure described in syrup's README file. The installation seems to run normally. After that I restarted Maple. When I now enter
with(Syrup);
it shows
[Draw, Library, Print, Solve, ToModelica, ToSpice, Version]
instead of
[deindex, makecheckttable, printdeck, reindex, syrup]
as described in the application center: https://www.maplesoft.com/applications/Preview.aspx?id=4680
Also the example which is decribed there doesn't work:
syrup(divider, dc, 'curr');
delivers no result.
I'm working on Windows 10 64 bit.
Could it be that syrup is not yet prepared for Maple 2022, as it seems not to be updated for a long time? Or is the description in the application center not up to date?
Many thanks for your help!
Best regards,
Michael
Hi,all
I am new in Maple,when I execute the "InversePlot" command ,all functions were correct except for exp(x), error occurs as follows, can anyone tell me what mistake I took?
Tks in advance!
with(Student[Calculus1]);
InversePlot(exp(x), -1 .. 1);
Error, (in Student:-Calculus1:-InversePlot) module does not export `IsTrigProc`
Tks for all you guys.
I have uninstall Maple and deleted the installed directory ,clear the register,reinstall Maple 2022, now all works well.
I think the problem is I installed Maple 2022 in the old directory of 2021for keeping my configuration,this caused much unexpected problem
I want to create a variable that is made up of a letter and an arrow on top. How to do that?
Also, how can I create a variable that is bold? I tried to type it as bold and then assign. But when I hit return it returns a normal symbol.
How to distinguish between a scalar variable and a vector variable in Maple?
I want to solve a differential equation and plot the particle densities versus the distance.
How can I do this in Maple?
DE.mw
Sincerely
Suppose I want to calculate gcd(g(x),f(x))=a(x)f(x)+b(x)g(x) for two polynomial, i.e finding the RHS representation of the gcd, then how to implement this in maple?
I know of the command GCD(f(x),g(x)) but how to find the RHS representation?
Many formulas use a capital D to define parameters. A popular example is the second moment of area "I" of a tube. In Maple we get
Both I and D are protected symbols in Maple and are therefore printed in roman. With the "local" command, I and D can be used as unprotected symbols. However, only the unprotected "I" is printed in italic (like other symbols or names do). D is still printed in roman, which spoils Maple's excellent printout (a bit).
I hope this inconsistency can be improved one day. For the time being, I am looking for better alternatives than my workaround with a fat white space in the attachment. Are there better workarounds?
Italic_I_and_D.mw
primes_integrale_exp.mwThe integral in x of
exp(-sqrt(x^2 + c))
was done by Maple 11 but return unevaluated in Maple 2021,
see attached worksheet
I am trying to solve the equation in the attached Maple file, but Maple cannot return a result.
Digits := 30
30
with(plots)
with(Statistics)
say the f(x) is a Beta with parameters alpha and beta
alpha := 10
10
beta := 100000
100000
"f(x):=PDF(BetaDistribution(alpha,beta),x)"
proc (x) options operator, arrow, function_assign; Statistics:-PDF(BetaDistribution(alpha, beta), x) end proc
f(x)
piecewise(x < 0, 0, x < 1, x^9*(1-x)^99999/Beta(10, 100000), 0)
semilogplot(PDF(BetaDistribution(alpha, beta), x), x = 0 .. 1)
fsolve(int(f(x), x = 0 .. y) = .1, y = 0 .. 1)
Download test_fsolve_integ.mw
On a shared cluster with 32 CPU cores, how do I limit Maple (called from the Linux command line) to use only 8 cores? (Certain built-in operations in Maple are parallelized by default.)
I try to sove the equation x^2-10*y^2=9 with tne procedure :
genpellsolve := proc(D::posint, N::integer)
local t, u, L1, L2, sols, x, y;
if type(sqrt(D), integer) then error "D must be a nonsquare integer"; end
if; t, u := pellsolve(D); if 0 < N then L1 := 0;
L2 := floor(sqrt(1/2*N*(t - 1)/D)); elif N < 0 then L1 := ceil(sqrt(-N/D));
L2 := floor(sqrt(-1/2*N*(t + 1)/D)); else return {[0, 0]}; end if;
sols := {}; for y from L1 to L2 do x := sqrt(N + D*y^2);
if type(x, integer) then sols := sols union {[x, y]};
if (x^2 + D*y^2) mod N <> 0 or (2*x*y) mod N <> 0 then sols := sols union {[-x, y]};
end do;  return sols;
This procedudure fails; I don't see why. Thank you for your help.
I upgraded to Maple 2022 and some of my old sheets from Maple 2021 don't work anymore. When I plot a histogram with a legend I get an error saying: Error, invalid input: Statistics:-Histogram expects value for keyword parameter legend to be of type list, but received data set 1.
OK so maybe Histogram changed in 2022 although I didn't think it did. I ran it in Maple 2021 and I received no such error message. I chose to comply with the error message and the plot is output without an error message, however the legend labels carry extra characters I don't want to be there.  My attempt at a solution was to first use square brackets to make the object a list, then use the typeset command to typeset the label.  Strangely, the typeset command was not recognized.
What am I doing wrong? All I want is to plot a histogram with a legend labelled by a string which I have done many times in the past. I have attached below, a maplesheet which explicitly shows the problematic behaviour.
N
with(Statistics)
with(LinearAlgebra)``
with(plots)``
Define Random Variable
X := RandomVariable(Normal(1, 2))
_R
Sample that variable and plot a histogram.
s := Sample(X, 1000)
Maple 2022 as opposed to Maple 2021 does not consider this a valid way to define the legend. It want's it defined in a list as requested in the pink error message.
Histogram(s, legend = "data set 1")
Maple 2022 as opposed to Maple 2021 does not consider this a valid way to define the legend. It works fine in Maple 2021. Maple 2022, want's it defined in a list. This works but, the square brackets and quotation marks appear when I don't want them to. The legend shouldn't have these extra quotations and brackets, just the desired name.
Histogram(s, legend = ["data set 1"], size = [300, 300])
I tried the typeset command. It doesn't seem to be recognized anymore.
Histogram(s, legend = [typeset("data set 1")], size = [300, 300])
What am I doing wrong? All I want is to plot a histogram with a legend labelled by a string.
Download legend_as_list.mw
First 321 322 323 324 325 326 327 Last Page 323 of 2427
