Hello everyone !
I would like to know if there's a way to get simplified expressions for multivariables expressions...
for a simple example :
expand((a+b)^2) returns a²+b²+2ab
how could I get (a+b)^2 from a²+b²+2ab ?
for a more complicated example :
factor([2*x^3 - 6*x*y*z + 2*y^3 + 2*z^3])
returns :
        [2 (x + y + z) (x²  - x y - x z + y²  - y z + z²)]
but since :
2*(x²  - x y - x z + y²  - y z + z²) = (x - y)^2 + (y - z)^2 + (z - x)^2
is there a way to get that kind of simplification ?
thank you for your time
Hello everybody,
In my code, i would like to create a square matrix M of dimension 'a' (which is a ColumnDimension of an imput matrix A):
Otherwise, i have an expression ('EXPR') on alpha[i](x) and beta[i](x), i=1..b, (where b is a ColumnDimension of an imput matrix B).
The matrix M that i want to get must be M:=(EXPR(alpha[i],beta[j])),i,j=1..a, evaluated for particular alpha[i](x) and beta[j](x) wich are stored in A and B respectively.
Below, is the code that i write:
Test := proc(A, B,EXPR)
local a, b, M, i, j, k;
a := LinearAlgebra['ColumnDimension'](A);
b := LinearAlgebra['ColumnDimension'](B);
M := Matrix(a);
for i to a do for j to a do
if evalb(i = j) then
M[i, j] := M[i, j] + eval(EXPR, {seq(alpha[k] = (t -> eval(A[k, i], x = t)), k = 1 .. b), seq(beta[k] = (t -> eval(B[j, k], x = t)), k = 1 .. b)}); else
if evalb(i < j) then
M[i, j] := M[i, j] + eval(EXPR, {seq(alpha[k] = (t -> eval(A[k, j], x = t)), k = 1 .. b), seq(beta[k] = (t -> eval(B[i,K], x = t)), k = 1 .. b)}); else
M[i, j] := M[i, j] + eval(EXPR, {seq(alpha[k] = (t -> eval(A[k, j], x = t)), k = 1 .. b), seq(beta[k] = (t -> eval(B[i, k], x = t)), k = 1 .. b)}); end if;
return M;
I tested the program for A, B and EXPR given by:
A := Matrix(2, 3, [[4, x, 1/4*x^2], [2, 3, x]]);
B := Matrix(3, 2, [[3, 5], [x, 2], [1/2*x^2, -x]]);
EXPR := alpha[1](1/2)*beta[1](1/2) + int(alpha[1](x + 1/2)*beta[2](1/2*x), x = -1/2 .. 1/2) + alpha[2](1/2)*beta[2](1/2);
Maple returns the following:  Error, (in anonymous procedure called from Test) bad index into Matrix.
I understood that the problem comes from the k that I wrote in bold in the code.
I would like to evaluate the EXPR for alpha[k]:=A[k, i] and beta[k]:=B[j,k] , but I don't really know how to interpret this for maple.
Could you help me please ?
Do you have an idea ?
Best regards,
I am an electrical engineer and have been using Matlab for years.  I am switching over to Maple and am converting my extensive library of Matlab scripts to Maple.
Among other things, I plan on using Maple, as I have Matlab, to determine component values based on design criteria (e.g. input voltage range, output voltage range, etc.) and to analyze the resulting circuit uncertainties.
I have generally released the uncertainty results to my clients and like to use the appropriate mathematical symbols to convey the information.
I would eventually like to generate a report for my client that shows the calculated component values and the resulting uncertainties (e.g. "R1 = 2.56kΩ ± 0.01%", "Total uncalibrated uncertainty (maximum) = ±(0.23452% of reading + 0.198°C)")
I see that outside of a code edit region, I can freely use the symbols from the "common symbols" palette to generate text as shown above.
Should I avoid trying to automate this (i.e. using printf() statements)?
I found small problem in Latex(). When putting solution of ODE inside a Vector, Latex() fails to convert and returns empty vector.
sol:=[dsolve(diff(diff(y(x),x),x)*y(x) = 1,y(x))];
sol:=convert(sol,Vector);
And now
Latex(sol)
               \left[\begin{array}{c} \\ \end{array}\right]
Empty array. But if not in a Vector, it works
Latex(sol)
# no problem here ====>
\left[
{\textcolor{gray}{\int}}_{}^{y \! \left(x \right)}\frac{1}{\sqrt{2 \ln \! \left(\mathit{\_a} \right)-2 \mathit{\_C1}}}\textcolor{gray}{d}\mathit{\_a} -x -\mathit{\_C2}
 = 0,
{\textcolor{gray}{\int}}_{}^{y \! \left(x \right)}-\frac{1}{\sqrt{2 \ln \! \left(\mathit{\_a} \right)-2 \mathit{\_C1}}}\textcolor{gray}{d}\mathit{\_a} -x -\mathit{\_C2}
 = 0\right]
This seems to happen on some solutions (may be those with Int because in this other example, it works with Vector):
sol:=[dsolve(diff(diff(y(x),x),x)*y(x)^2 = 0)];
And now
Latex(sol)
#now it works ===>
\left[\begin{array}{c}y \! \left(x \right)=0 \\y \! \left(x \right)=\mathit{\_C1} x +\mathit{\_C2}  \end{array}\right]
I am using Maple 2020.2 with Physics 897
Edit 1/2/2021
I found another strange problem with Latex conversion related to Vector. If the first entry is y(x)=0 in the vector, then it keeps this, but throws away the rest of the entries in the Vector.
This might be related to the same bug. Not sure. Here is an example
ode:=(2*cot(x)*diff(y(x),x)*y(x)+diff(y(x),x)^2-y(x)^2 = 0,singsol=all);
sol:=convert([dsolve(ode)],Vector)
Now watch what happens when converting sol to Latex
Latex(sol)
    \left[\begin{array}{c}y \! \left(x \right)=0 \\ \\ \end{array}\right]
Only reason I use Vector() is to display in Latex many solutions on top of each others, so easier to see instead of as a list() where they are all on one line, which might not fit the page.
I need to find an alternative to using Vector to do this.
Can I clear variables by a command instead of assigning them their quoted name?  For example, I know that I can clear M and B by:
M,B:='M','B'.
Is there a command like forget(M,B)?
I don't want all of ther variables cleared so I don't want to use restart.
I would like to use greek letters and other special symbols in printf() statements in a code edit region.
Is there a way that I can do that?
I have to create a function which records the angle and angular frequency of an aspherical moon orbiting a planet at each periapsis to create a Poincare section plot of theta agaisnt omega. I cannot get eval to work out the solutions to the ODEs to plot the points. Additionally I then have to create another function to plot the FFT of the angular frequency from an array.
This is what I have tried so far:
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/Project.mw .
Download Project.mw
For some reason every := on my work sheet has turned to "d" how to if fix this.
I have a vector that I would like to display with added text annotations.  For example with the vector <1,2>, I would like output to the display:
first: 1
second: 2
Is there a simple way to do this?
Hi, Very new to Maple. This is a math assignment, and well I am not exactly sure what is happening. I have had a buddy to help me, but things are not necessarily working.
a := 0;
                             a := 0
b := 1;
                             b := 1
p := plot({Fresnelf(x), Fresnelg(x)}, x = a .. b);
plots[display](p);
A := [a, g(a)];
B := [a, f(a)];
                         A := [0, g(0)]
                         B := [0, f(0)]
C := [b, g(b)];
D_ := [b, f(b)];
                         C := [1, g(1)]
                        D_ := [1, f(1)]
left_line := plot([A, B]);
right_line := plot([D_, C]);
plots[display](p, left_line, right_line, view = [0 .. b + 0.5, 0 .. 0.2]);
What is the letter O doing inside this pde solution by Maple 2020.2 and what does it mean? There is no O in the PDE itself and it is not a name of a mathematical special function
pde :=  diff(w(x,y),x)+ (a*x^2*y+b*y^3)*diff(w(x,y),y) = 0;
sol:=pdsolve(pde,w(x,y));
lprint(sol)
w(x,y) = _F1(1/9*(2*2^(2/3)*3^(5/6)*b*x*O*y^2-3*2^(2/3)*3^(1/3)*b*x*GAMMA(1/3,-\
2/3*x^3*a)*GAMMA(2/3)*y^2+9*O*GAMMA(2/3)*exp(2/3*x^3*a))/O/GAMMA(2/3)/y^2)
I have aproc that takes a supplied electrical resistance and calculates the closest standard resistor value to it.
I would like the proc to work whether the supplies resistance has Units(ohm) or if it is free of units.  I am new to programming in Maple.  I have come up with the following but if there is a better way to do this, it would help me to get up to speed with Maple more quickly.
David
Hi Everyone,
First time asking a question on this website. I am a bit confused about an error I am getting in a pretty straightforward simulation I am trying to generate. It is part of an overall State Machine I am working on but I have isolated the issue to the Angle Sensor and have simplified the issue to ask my question. The issue is as follows:
When simulating the To_Box_5_error.msim file I get the following error
Preparing for integration......
Generating code (derivatives)
(in MapleSim:-CreateDataRecord) internal error occurred during simulation: check console on verbose for more details (5.508s)
This file consits of the angle sensor feeding back to the two <= blocks.
However when simulating the To_Box_5_works.msim file the simulation completes without issue. The difference in the second file is that I feed back the angle sensor value to only one <= block while the second I ijust feed in a constant.
Why would feeding back the same signal to both of these blocks not complete the simulation? The error does not occur for the position sensors that are also in the model.
Any suggestions would be greatly appreciated.
Mike
Just to inform me about the possibility of easily way to build a probability tree with Maple? like this example ( for example)
Please see this example. This Latex generated gives Latex compile error.
Latex:-Settings(UseImaginaryUnit=i,
      UseColor = false,
      powersoftrigonometricfunctions= mixed, ## computernotation,
      leavespaceafterfunctionname = true,
      cacheresults = false,
      spaceaftersqrt = true
L:=3;
c:=4;
h:=1/10;
b:=Pi*c/L;
f:=piecewise(0<x and x<L/3,3*h/L*x,L/3<x and x<L,h);
pde := diff(u(x,t),t$2) + b*diff(u(x,t),t) = c^2*diff(u(x,t),x$2);
bc  := u(0,t)=0,D[1](u)(L,t)=0;
ic  := D[2](u)(x,0)=0,u(x,0)=f;
sol:=pdsolve([pde,bc,ic],u(x,t));
The Latex generated does not compile:
Latex(sol)
u \left(x , t\right) =
\Mapleoverset{\infty}{\Mapleunderset{n =0}{\sum}}\left\{\begin{array}{44}\frac{4 \,{\mathrm e}^{-\frac{2 t \pi}{3}} \left(t \pi +\frac{3}{2}\right) \sin \left(\frac{\pi  x}{6}\right)}{5 \pi^{2}} & n =0 \\\frac{3 \sin \left(\frac{\left(1+2 n \right) \pi  x}{6}\right) \left(\sqrt{3}\, \sin \left(\frac{\pi  n}{3}\right)+\cos \left(\frac{\pi  n}{3}\right)\right) \left(\left(2 \sqrt{n}\, \sqrt{n +1}+i\right) {\mathrm e}^{\frac{2 i \pi  \left(-2 \sqrt{n}\, \sqrt{n +1}+i\right) t}{3}}-{\mathrm e}^{\frac{2 i \pi  \left(2 \sqrt{n}\, \sqrt{n +1}+i\right) t}{3}} \left(-2 \sqrt{n}\, \sqrt{n +1}+i\right)\right)}{10 \sqrt{n}\, \sqrt{n +1}\, \pi^{2} \left(1+2 n \right)^{2}} & \mathit{otherwise}  \end{array}\right.
Gives
\documentclass[11pt]{article}
\usepackage{amsmath}
\usepackage{maplestd2e}
\begin{document}
\end{document}
This, using latest TeXLive on Linux, gives  Illegal character in array arg.
lualatex foo5.tex
This is LuaHBTeX, Version 1.12.0 (TeX Live 2020)
 restricted system commands enabled.
(./foo5.tex
LaTeX2e <2020-10-01> patch level 2
 L3 programming layer <2020-12-07> xparse <2020-03-03> (/usr/local/texlive/2020/texmf-dist/tex/latex/base/article.cls
Document Class: article 2020/04/10 v1.4m Standard LaTeX document class
(/usr/local/texlive/2020/texmf-dist/tex/latex/base/size11.clo)) (/usr/local/texlive/2020/texmf-dist/tex/latex/amsmath/amsmath.sty
For additional information on amsmath, use the `?' option.
(/usr/local/texlive/2020/texmf-dist/tex/latex/amsmath/amstext.sty (/usr/local/texlive/2020/texmf-dist/tex/latex/amsmath/amsgen.sty)) (/usr/local/texlive/2020/texmf-dist/tex/latex/amsmath/amsbsy.sty) (/usr/local/texlive/2020/texmf-dist/tex/latex/amsmath/amsopn.sty)) (/mnt/g/public_html/styles/maplestd2e.sty
Package: maple2e 2005/03/17 v1.16
Defining Maple Utility Macros
(/mnt/g/public_html/styles/mapleenv.def)
Defining Maple Plot Environemnts
 ...Defaults to "dvips" Driver
(/usr/local/texlive/2020/texmf-dist/tex/latex/graphics/epsfig.sty (/usr/local/texlive/2020/texmf-dist/tex/latex/graphics/graphicx.sty (/usr/local/texlive/2020/texmf-dist/tex/latex/graphics/keyval.sty) (/usr/local/texlive/2020/texmf-dist/tex/latex/graphics/graphics.sty (/usr/local/texlive/2020/texmf-dist/tex/latex/graphics/trig.sty) (/usr/local/texlive/2020/texmf-dist/tex/latex/graphics-cfg/graphics.cfg) (/usr/local/texlive/2020/texmf-dist/tex/latex/graphics-def/dvips.def))))
Defining Automatic Style Generation Macros
Defining Maple Spreadsheet Environments
Maple Spreadsheet and Table Support
) (/usr/local/texlive/2020/texmf-dist/tex/latex/l3backend/l3backend-luatex.def) (./foo5.aux) (/usr/local/texlive/2020/texmf-dist/tex/latex/base/ts1cmr.fd)
! LaTeX Error: Illegal character in array arg.
See the LaTeX manual or LaTeX Companion for explanation.
Type  H <return>  for immediate help.
 ...haracter\or Missing @-exp\or Missing p-arg\fi \space in array arg.
Type  H <return>  for immediate help\@err@
l.8 \Mapleoverset{\infty}{\Mapleunderset{n =0}{\sum}}\left\{\begin{array}{44}
fyi. No errors are generated from the old latex() command.
The following is another example, with the same Latex error.
      UseColor = false,
c:=3;
f:=piecewise(4<x and x<5,1,true,0);
pde := diff(u(x, t), t$2) = c^2*(diff(u(x, t), x$2));
bc  := eval( diff(u(x,t),x),x=0)=0;
ic  := u(x,0)=f(x),eval(diff(u(x,t),t),t=0)=0;
sol:=pdsolve([pde, bc,ic],u(x,t)) assuming x>0,t>0;
Latex(sol);  #gives Latex that do not compile
Maple 2020.2, with Physics 897
First 491 492 493 494 495 496 497 Last Page 493 of 2458
