I just found a rather incredible error in versions 2025.1 and 2025.2.
The function works fine in version 2022.
The drag function in solve does not work, even for solving a very simple problem.
For example, in the equation 1 + 5x = 3x - 1, if I try to do 3x from right to left, a box opens with a good suggestion (subtract   1+2x = -1)
# subtract 3*x from both sides
((1)) + ~(3 * x)
we can see that the correct expression should be ((1)) - ~(3 * x)
I finally get:
1 + 8x = 6x -1 (it added and did not subtract 3x from both sides)
Please correct this...
I would like to plot multiple curves in a single graph with proper legends for different values of θ, similar to the sample figure. However, I am encountering an error while generating the legend. What modifications should I make to correct this? Additionally, how can I display labels such as θ=0.4, θ=0.5 etc., directly inside the plot as shown in the sample?
Graph_legend_error.mw
These are the original set up to solve for second order partial differetial equations:
E := 1.456*10^11;
rho := 7900;
a := sqrt(E/rho);
L := 0.03639;
f0 := 1/(2*L)*a;
f := f0 - 50;
A0 := 11.75*L/2*10^(-6);
d := 0.8*1000;
T0 := 5/f;
NULL;
PDE := diff(u(x, t), t, t) = a^2*diff(u(x, t), x, x) - d*diff(u(x, t), t);
IBC := {u(x, 0) = A0*cos(Pi*x/L), D[1](u)(0, t) = 0, D[1](u)(L, t) = 0, D[2](u)(x, 0) = 0};
pds := pdsolve(PDE, IBC, numeric, timestep = 2*10^(-7));
 I know it solves properly because I can plot it using pds:-plot without problem.  The question is how to extract the value at specific x and t.  I started to try some of the more intuitive way such as u(0,0) without getting an answer.  I tried a number of eval expression such as eval(pds,[x=0,t=0]), eval(u(x,t),[x=0,t=0]) and so on without success.
Then I tried using :-value as mentioned in an example from the internet, also resulting in an error.
val:=pds:-value(x=0,t=0)
It seems to be simple.  I guess I am too new with maple so be gentle.  Thank you.
My student licence  expired yesterday mar1. According to the description of my student licence it renews automatically. So I did not get active. But apparently it did not occur automatically. When starting Maple I get the message that my licence expired yesterday. To check whether the automatic renewal applies but did not work or whether I have to purchase a new licence for the next 12 months I tried to contact the customer support through online form.
I do not see any other channel to contact customer support by mail or phone, what can I do ?
Manfred
When I solve for Pr and q simultaneously using Maple, I obtain a solution that differs from my manual derivation. I suspect there may be an issue with the solve function or the way it is specified. Could anyone please suggest how this can be corrected?
Manually solving q* = (Cv-Cd+Ce*tau-Ci)/(4Cr-t) which is different from maple results.
Sheet:Question_1.mw
Hello Friends,
I have a function f(t) which I would like to convolve with itself.  I have no problem doing that typically, but my function contains two elliptic integrals (EllipticE and EllipticK), which clearly complicates matters.
My work in included.  As you can see, the plot on the (0,2) interval is continuous, and the area under the curve sums to unity via numerical integration.
with(Statistics)
f := proc (t) options operator, arrow; piecewise(t <= 0, 0, 0 < t and t < 2, (4/3)*t*((4+t^2)*EllipticE(sqrt(1-4/t^2))-8*EllipticK(sqrt(1-4/t^2)))/Pi^2, 2 <= t, 0) end proc
plot(f(t), t = 0 .. 2)
evalf(int(f(t), t = 0 .. 2))
1.000000000+0.*I
Download CircleDerivation2.mw
Are there any sort of transformations that I can employ which will permit me to convole this function with itself?  I realize a closed-form solution is probably not likely, but something approaching closed-form would be nice.  Via simulation, I have learned that the self-convolved function will have a continuous boundary on the (0, 2*sqrt(2)) interval.
nans:=dsolve({(-y^4+y^2)*diff(U(y),y,y)+(-2*y^2+14.2)*diff(U(y),y)*y-15.2*U(y)*(U(y)-1)*(U(y)+1) = 0, DU(.99999) = -.3401375821,U(.99999)= 0.3000034013},numeric);
Error, (in dsolve/numeric/process_input) invalid specification of initial conditions, got DU(.99999) = -.3401375821
Mapleprimes issue
Trying to upload a mw file throws this error message
I use
Typesetting:-Unsuppress('all'):
Typesetting:-Settings(prime=t,'typesetprime'=true):
to make the math easier to read. (also the latex looks better this way).
But it has no effect when on the plot title. Here is screen shot and code
In this below, I get same title if I use   plot(t,'title'=typeset(the_title));   or plot(t,'title'=the_title);  Instead of dy/dt,  I wanted it to show as y'(t) like it does in worksheet.
Is there a way to make the title of the plot show the math in the nicer format shown in the worksheet automatically? It looks like Typesetting:-Settings does not extend to plots, which is too bad.
code
the_title:=diff(y(t),t$2)+c*diff(y(t),t)+k*y(t)=0;
Typesetting:-Settings(prime=t,'typesetprime'=true): #this says to use y'(t) instead of dy/dt
plot(t,'title'=typeset(the_title),size=[300,300]);
#or
plot(t,'title'=the_title,size=[300,300]);
Is this a Maple bug? I do not see what I am doing wrong:
Explore( plots:-textplot([0,0," CRITICAL DAMPING"],'axes'=none),
   initialvalues=[c=1,k=.1],
   parameters=[[c=0..10],[k=0..10]]
Moving any slider gives the internal error.  Why?
Download internal_error_explore_feb_28_2026.mw
Here is a small movie
To help debug things, and to make it easier to add more logic such as if then else and so on, I moved the main body of Explor to a separate proc where the plot is made after doing some checking.
So instead of writing
Explore(plot(.....),
 parameters=[
   [c=0..10,....],
   [k=0..10,...]]
It now became
foo:=proc(c,k}
.....#some debug print messages added here, and some checking...
   plot(....)
Explor( foo(c,k),
  parameters=[
    [c=0..10,....],
    [k=0..10,...]]
Two problems.
1) My print lines inside foo() do not print to worksheet. Only the initial time they do. When I mean initial time, it is when Explore starts and does initalization. I see the print lines only then.
But after that, as I change the slider, which should make a call to foo(), I see nothing printed on the screen in my worksheet any more.
It is as if Explor stopped calling my foo().  But at same time, I see do see in the the display of Explore itself that it is calling foo as expected, since the call it display is changes and the result of the call changes as slider is changed. So call is being made.
This is what shows inside Explore...
foo(5,2)=10
foo(3,2)=6
and so on
Why then the print messages from foo() are not printed in the worksheet any more? Where are the print message going to then?
2) How to make Explor only show the _result_ of calling foo() and not show the call itself as it does now?
ie. instead of showing foo(5,2)=10  I just wanted to see the result of foo, which is 10 in this example.
Doing rhs(foo(c,k)) did not work
Here is worksheet to see yourself.
foo:=proc(c,k)
   print("c=",c," k=",k);
   c*k;
Explore(foo(c,k),
   parameters=[
     [c=0..10,'controller' = 'slider','minorticks'=1,
      'snaptoticks'=true, 'label' = "Damping c",'showlabels'=false],
     [k=0..10,'controller' = 'slider','minorticks'=1,
      'snaptoticks'=true, 'label' = "Stiffness k",'showlabels'=false]]
"c=", 10, " k=", 10
"c=", 0, " k=", 0
"c=", 1, " k=", .1
Download explore_feb_28_2026.mw
Here is small movie
ps. I am thinking now Explore only works with "plot" as its first argument. But help says expr can be anything.
Goal: to make a 3D parametric plot of a complex function u(x,t) obtained by pdsolve.  I tried to follow one example of a plot of a complex expression/function.  I was unable to get any plot.  I got some warning and error.  Please let me know what have I done wrong.
I follow this example so that I can get a 3D parametric plot of a complex function u(x,t) for a fix x:
complexplot(exp(t*I), t = 0 .. 2*Pi, scaling = constrained);
plot([cos(t), sin(t), t = 0 .. 2*Pi], scaling = constrained);
z := t -> exp(t*I);
spacecurve([Re(z(t)), Im(z(t)), t], t = 0 .. 4*Pi, axes = normal, labels = ["Re", "Im", "t"]);
It was successful.  With the following pde, I obtain an analytical solution using pdsolve.
a := 3;
L := 2*Pi;
d := 0.5;
T0 := 2*Pi;
IBC := u(x, 0) = cos(Pi*x/L), D[2](u)(x, 0) = 0, D[1](u)(0, t) = 0, D[1](u)(L, t) = 0;
pds := pdsolve({IBC, PDE}, u(x, t));
It fail 2D plotting using the following:
complexplot(u(0, t), t = 0 .. 6);
So I break down the pds with the following:
RP := Re(pds);
IP := Im(pds);
RP0 := eval(RP, x = 0);
RP0t := unapply(RP0, t);
IP0 := eval(IP, x = 0);
IP0t := unapply(IP0, t);
And I was hopeful as the following give me real numbers when I approximate them:
RP0t(1);
                     Re(u(0, 1)) = 0.20248
RP0t(2);
                     Re(u(0, 2)) = -0.57765
But it fails in both 2D and 3D plot:
plot([RP0t(t), t = 0 .. 6])
spacecurve([RP0t(t), IP0t(t), t], t = 0 .. 6, axes = normal)
Dear sir,
i want to draw velocity and temperature plots for fluid and dust phases. but getting error in that showing 12 BC need only 8
i have tried with 8 Bc also but showing different error how to rectify it
dust_phase_work_error.mw
I have two equations developed in different ways and I want to compare them.
The first is a development done using maple, while the second is an algebraic analysis.
I need to find out if both are identical and, therefore, if the subtraction would be equal to zero.
How should I proceed?
I had thought about simplifying the first and comparing it with the second; is that a good approach?
with(plots)
H0 := -S1^2*eta1-S2^2*eta2-S1*gamma1-S2*gamma2
Z0 := exp(-beta*H0)
exp(-beta*(-S1^2*eta1-S2^2*eta2-S1*gamma1-S2*gamma2))
Z0 := add(Z0, S1 = [-2, -1, 0, 1, 2])
Z0 := add(Z0, S2 = [-2, -1, 0, 1, 2])
G0 := -ln(Z0^((1/2)*N))/beta
G01 := -ln((2*exp(4*beta*eta1)*cosh(2*beta*gamma1)+2*exp(beta*eta1)*cosh(beta*gamma1)+1)^((1/2)*N)*(2*exp(4*beta*eta2)*cosh(2*beta*gamma2)+2*exp(beta*eta2)*cosh(beta*gamma2)+1)^((1/2)*N))/beta
Teste := G0-G01
Download TESTE_MAPLE.mw
my question is a little bit long but is not complicated, i want find thus  unkown but  realy i am don't know how apply on it by maple, i have two best paper which explain very well i just want to find thus dimensional Lie algebra which is be invariant or not satisfy condition or not which i have to used or which i have not to use it also the importan part how find them in paper 1 first , for equation fisher
How find eq(29) which is i think is two -dimensional Lie algebra of equation, also the best part is reduction which by apply this we can change PDE to ode but i don't know how apply eq(31) or even find it yet  is related to eq(27-28)  and by replacing equation eq(34) we can get our ode i am just loking for the ode, for the eq(76) and eq(85) have same procedures,  i will mention the paper link too
Lie.mw
paper-1
paper-2
3 4 5 6 7 8 9 Last Page 5 of 2457
