I am attempting to have the piecewise function
Render using either mathML or Letex in maple, using the syntax:
f := piecewise(-Pi <= x and x < 0, 1, 0 <= x and x < Pi, 0);
la := latex(f);
mml := MathML[ExportPresentation](f);
Unfortunately, as you will notice the latex produces some really annoying "and" words amongst the code.  While the MathML produces some equally annoying "&wedge;", and symbols, amongst the code.
Any help would be appreciated.
Mark
I have a question about the Import of .txt file:
I can import the following .txt, but everytime I want to convert in a matrix or something else, maple chrashes.
I need some parts (smaller matrices) of this data (for example: all values from coloumn 200-400 and row 100-600)
I hope somebody can help me
Martin
-Validierung-Stahl-AI-.txt
Hey
i want to solve these 3 eqations
21000 = ((10/1000)/60)*4181*983*(x-y)
H = -((10/1000)/60)*4181*ln(1-((x-y)/(x-40)))
H = 124+102'ln(x-40)+(7+2*ln(x-40))
with the result of:
H,x,y
how do i do that?
Hi everyone, I am trying to plot field lines but I face problem in plotting field plot. kindly help me if anyone can do it. Find the code in the attached file. Thank you.
Field_lines.mw
tomleslie 2300Mohsen 20 @Carl Love @Markiyan Hirnyk @maple fan 175 @asa12 405  @Adri van der Meer 1253
f:=5*x^3-5*x+1;
5*x^3-5*x+1
s:=[solve(f)]; evalf(%);  # All the roots are real
[(1/30)*(-2700+(300*I)*219^(1/2))^(1/3)+10/(-2700+(300*I)*219^(1/2))^(1/3), -(1/60)*(-2700+(300*I)*219^(1/2))^(1/3)-5/(-2700+(300*I)*219^(1/2))^(1/3)+((1/2)*I)*3^(1/2)*((1/30)*(-2700+(300*I)*219^(1/2))^(1/3)-10/(-2700+(300*I)*219^(1/2))^(1/3)), -(1/60)*(-2700+(300*I)*219^(1/2))^(1/3)-5/(-2700+(300*I)*219^(1/2))^(1/3)-((1/2)*I)*3^(1/2)*((1/30)*(-2700+(300*I)*219^(1/2))^(1/3)-10/(-2700+(300*I)*219^(1/2))^(1/3))]
[.8788850663-0.2e-9*I, -1.088033915-0.2598076212e-9*I, .2091488484+0.2598076212e-9*I]
max(s);  # ?
Error, (in simpl/max) complex argument to max/min: (1/30)*(-2700+(300*I)*219^(1/2))^(1/3)+10/(-2700+(300*I)*219^(1/2))^(1/3)
type(s,list(realcons)); # Wrong, the type realcons should not be purely syntactic; or is it?
R:=convert(s,RootOf):
max(R);  #  For nested RootOfs fails
Error, (in simpl/max) complex argument to max/min: (1/30)*RootOf(_Z^3+2700-300*RootOf(_Z^2+1, index = 1)*RootOf(_Z^2-73, index = 1)*RootOf(_Z^2-3, index = 1), index = 1)+10/RootOf(_Z^3+2700-300*RootOf(_Z^2+1, index = 1)*RootOf(_Z^2-73, index = 1)*RootOf(_Z^2-3, index = 1), index = 1)
sort(s): evalf(%);  # Wrong
[.8788850663-0.2e-9*I, .2091488484+0.2598076212e-9*I, -1.088033915-0.2598076212e-9*I]
Workaround
S:=[seq(RootOf(f,x,index=i),i=1..3)];
[RootOf(5*_Z^3-5*_Z+1, index = 1), RootOf(5*_Z^3-5*_Z+1, index = 2), RootOf(5*_Z^3-5*_Z+1, index = 3)]
evalf(S);
[.2091488484, .8788850662, -1.088033915]
min(S);max(S);  # OK
sort(S);   # Wrong!
r:=(sqrt(2)+I)^3 + (sqrt(2)-I)^3;
(2^(1/2)+I)^3+(2^(1/2)-I)^3
type(r,realcons);  # Purely syntactic?
type(expand(r),realcons);
max(r,13);  # Even for such a simple expression?
Error, (in simpl/max) complex argument to max/min: (2^(1/2)+I)^3+(2^(1/2)-I)^3
Download TryHarder.mw
So I've got a function and try to find an extrema (and there is one on the plot), but Maple gives me empty brackets.
First, earlier it gave me 2 x-coordinates with extrema (both empty), but now (after reloading) it gives one and empty.
Second, how do I set an interval, if I want to look for extrema from x=0 to x=1, for example? I tried extrema (V, {0,1}, x) and (V, {x=0, x=1}, x), but nothing seems to work.
2.mw
Hi everybody,
I use the Grid package to do intensive computations.
For some reason I'm ignorant about, the test case described in the Grid[Server][StartServer]
 help page doesn't work with Maple 2015 (neither on Mac OS X, neither on Windows 7 ; here is the mw file run on MAC Os X)
Could someone explain me why (probably something I did not read with enough attention ... some license maybe) ?
GridServer.mw
I need to calculate sum w2(x,y),
v2 := proc (x, y) options operator, arrow; sin(x)*cos(y) end proc;
u2 := proc (x, y) options operator, arrow; 3*sin(x)-cos(y) end proc;
w2 := proc (x, y) options operator, arrow; diff(v2(x, y), x)-(diff(u2(x, y), y)) end proc;
L1 := proc (x, y) option inline; abs(w2(x, y)) end proc; CodeTools:-Usage(evalhf(add(add(abs(w2(x, y)), x = 0 .. 10), y = 0 .. 10)));
Error, (in CodeTools:-Usage) unable to evaluate built-in function `diff` in evalhf
 but it is error , how  can be rewritten properly?
I created the following plot
plot([BesselJ(0, x), BesselJ(1, x)], x = 0 .. 10, color = [red, blue]);
What I want to do mext is calculate all x values on this interval wherethe two paths intersect
 Calculate all x values on this interval where
I have a question as this:
Examples as following:(come from MAPLE‘s help )
with(LinearAlgebra);
Ax := <1.00004, 1.99987, -0.12e-3>;
b := <1., 2., 0.>;
Add(Ax, b, 1, -1);
result is this:[0.400000000000400e-4, -0.129999999999963e-3, -0.120000000000000e-3]'
I think result is :[0.400000000000400e-4, -0.13e-3, -0.120000000000000e-3]'
Is this a bug of MAPLE?
I am trying to solve the function
f :=  sqrt(1-x2)
L := int(sqrt(1+(diff(f(x), x))2), x = 0 .. 5)
Maple is returning an answer with Pi:  (1/2)*Pi+I*ln(5+2*sqrt(6))
How do I convert this into a numerical format?
Dear Friends
Is there a way to solve a complicated integration in less possible time?
_________________________________________________________________________________
Digits := 100:
tm := time():
m := 6:
a := 0.1:
b := 10*a:
E := 1:
h := 1:
nu := 0.3:
w := (r-b)^2*(r-a)^2*add(add(W[n, i]*r^n*t^(i-n), n = 0 .. i), i = 0 .. m):
ur := -z*(diff(w, r)):
ut := -z*(diff(w, t))/r:
er := diff(ur, r)+(1/2)*(diff(w, r))^2:
et := ur/r+(diff(ut, t))/r+(diff(w, t))^2/(2*r^2):
grt := diff(ut, r)-ut/r+(diff(ur, t))/r+(diff(diff(w, t), r))/r:
u := -(1/2)*E*(2*er*et*nu+er^2+et^2)/(nu^2-1)+(1/2)*E*grt^2/(2*(1+nu)):
PI := int(int(int(u*r, z = -(1/2)*h .. (1/2)*h), t = 0 .. 2*Pi), r = a .. b)-0.5*P*(int(int(r*(diff(w, r))^2, r = a .. b), t = 0 .. 2*Pi)):
Time = time()-tm;
I am looking for a window bat file to run my maple input file.mw
How can I find all roots of sin(sqrt(x)) as the search interval is not constant and depens on x for this function?
Is there a 3D globe available for Maple?  Specifically, a globe depicting the Earth's continents and oceans, that can be grabbed and rotated with the mouse like any other 3D Maple plot?
First 901 902 903 904 905 906 907 Last Page 903 of 2459
