Triing to solve some 2 differential equations system (plan mechanical movement), using "output=" as last option, I am interrested by the values of the second derivatives of the coordinates. The "output" runs fine to get t, x(t), y(t), dx/dt(t) and dy/dt(t). To get d^2x/dt^2 and d^2y/dt^2, I thought it would work to write something like (A is the times array) this :
dsol := dsolve(dsys, type = numeric,  {diff(x(t),t,t), diff(y(t),t,t},output = A),
But if I do this, I get next error message :
Error, (in dsolve/numeric/process_input) dependent variables must be functions of a single unknown, the independent variable. Got [diff(diff(x(t), t), t), diff(diff(y(t), t), t)]
Could you please help me ?
I generated a few plots using the plot command. When I try to animate them using the display command, only the first plot appears and not the rest. I can't figure out what the problem is. Any help is appreciated. I have attached below the commands I am using to generate the plots and animate them:
with(OrthogonalExpansions):
f := x -> x;
L := 1:
fexplt:=plot(f(x),x=-L..L):
fs := n->FourierSeries(f(x),x=-L..L,n,'Coefficients');
fs(n);
                  n
                 \          (1 + i)
                  )   2 (-1)        sin(Pi i x)
                -----           Pi i
                i = 1
nmax := 25:
display([seq(plot([f(x),fs(m)],x=-L..L),m=1..5)],insequence=true);
If I just use
seq(plot([f(x),fs(m)],x=-L..L),m=1..5);
I get all the five plots output to the screen.  So, I know the plots are there. It's the animation part that doesn't seem to work. I am using Maple 2015 on a linux mint desktop.
Hello all,
I am looking for a maple command to do the following
#outline of idea, is a user would pre-define a number of rows and a single Matrix command would automatically generate a Matrix based on the data the user provides.
numRows:= ;#user would enter a number here
row1:=[1,2,3];  #user enters data for each row
row2:=[4,5,6,7];
row4:=['red','blue',7];
#user will enter a few more rows to match numRows, specified above
Matrix([[row1],[row2],[row3],....,[rown]]);#this matrix command would be generated based on the above entered data
I was thinking some form of counter could do this?  Any suggestions would be appreciated.
First I want to thank you for paying attention to my post.
I'm trying to determine the maximum of the following function:
Maple Code:
(1/4)*(-1/4+alpha*(-1+b)*e^2+((1-b)*alpha+(1/4)*b)*e)^2/((-1+e)^2*(b*e-1)*alpha*e*(-1+b))(1/4)*(-1/4+alpha*(-1+b)*e^2+((1-b)*alpha+(1/4)*b)*e)^2/((-1+e)^2*(b*e-1)*alpha*e*(-1+b))
e is my variable and I want to study it in [0,1[. I have a several parameters restriction like b in [0,1[ and alpha>1.
When I value this function for specific values (b=0.1, alpha=4 for instance) I get the equation and its associated graphic representation:
Maple Code:
-0.6944444445e-1*(-1/4-3.6*e^2+3.625000000*e)^2/((-1+e)^2*(.1*e-1)*e)
I'm only interested in the domain where e is betweeen 0 and 1. I clearly on the graph see that there is a maximum and when 1) I compute roots of the expression I get 2) following solutions:
1)
2)
    0.9324708634, 0.07447358108, 0.6965691592, 1.345632810,
      -0.07419084270.
Here: 0.6965691592 corresponds to the maximum I'm looking for.
So now when I try to get a generalization of this function according to my parameters and when I compute the first derivative with respect to e
1)
2)
3)...
the last is very big so I do not write it here.
To sum-up: I see that the solution I'm looking for exists but when it comes to use parameters I cannot define correct roots.
RootOf has the option index=real[i]  for the i-th real root:
evalf([seq(RootOf(x*(x^2-1)*(x^2-4)+1/100, x, index=real[i]), i=1..5)]);
     [-2.000416306, -0.9983310082, -0.002500019532, 1.001664362, 1.999582971]
This option does not seem to be documented. Why? Or, is it?
Hi !
I am importing a matrix from a text file. I am using the command,
ImportMatrix("Filelocation/Filename.txt", 'source' = 'delimited', 'delimiter' = " ");
I see the following error:
Error, (in ImportMatrix) cannot interpret file
I think it is because of the huge size.(700 MB, and 28 GB respectively)
How to import such a matrix in maple?
thanks,
I just found that Maple 17 and Maple 16 do not have the option "output=string" in the latex command.
And I need a way to convert the Latex generated to the screen to a string and save it to a variable like I can do with Maple 2017
Here is an example. In current Maple 2017 this works
result_of_int:=int((-5+3*x)^2/(2*x-1)^(7/2),x):
my_latex:= latex(result_of_int,output=string);
But in Maple 16, it gives an error
If I remove the output, then the result is not string.
How to capture the above output which is on the screen and save it as string in a variable?
I do not want to send the output to a file as is. I need to first convert it to a string, and save
it to variable first.
how do you answer people's questions on here to get the points?
I have a problem with solving of my differential equation second order. Whenever I Try to draw a plot of it I have this "Warning, cannot evaluate the solution past the initial point, problem may be complex, initially singular or improperly set up".
All "A", "B", "C", "K" and Vare constants which can be any number except Vwhich is only a positive number.
v[0] := 500; C[0] := 1; B[0] := 1; K[1] := 1; C[1] := 1; K[2] := 1; C[2] := 1; eqn := x(t) = v[0]*t-C[0]*B[0]*K[1]*C[1]*(D(x))(t)*t^2/(1+C[0]*x(t))^2-C[0]*B[0]*K[2]*C[2]*(C[0]*x(t)*((D@@2)(x))(t)-2*C[0]*(D(x))(t)^2)/(1+C[0]*x(t))^3;
sln := dsolve({eqn, x(0) = 0, (D(x))(0) = 500}, numeric);
plots[odeplot](sln, t = 0 .. 1);
I would like to implement a persistent variable inside a procedure. That is:
  1. A variable that is first initialized if it does not exist.
  2. Its value is kept over multiple call of the procedure where it is defined.
As an example, the following procedure counts the number of times it is called:
CountProc := proc ()
     global m;
     if `not`(m::integer) then
          m := 0;
     m := m+1;
     return m;
CountProc(); CountProc(); CountProc();
That’s almost what I need, except the variable "m" should be local instead of global. How to do that?
Hello dear!
Hope you all are fine. I am trying to sloution the system of nonlinear system of ODEs (see attached file) but my solutions not converging please see and fix the problem. I am waiting your quick response.
Graph.mw
Is there a possiblity to print exponents in the axis labeling?
Say I have large numbers in 10^6. Then I want to write
labels=["x","y [10^6]"]
However I only found the e-notation within
sprintf("%0.0e", 10^6)
for example, which is not really what I want though.
applyrule((x::anything < y::anything) = 0, a < b);
applyrule('x::anything < y::anything' = 0, a < b);
applyrule(`<`(x::anything, y::anything) = 0, a < b);
applyrule('`<`(x::anything, y::anything)' = 0, a < b);
                             a < b
                             a < b
                             a < b
All quotes matter, no doubt, but why is `<` different from the infix "<" and why does it need uneval?
restart; CodeTools:-Usage(plots:-inequal({abs(abs(x-y)-abs(x+y)) >= 2*y-x+1, (x+1)^2+(y+1)^2 <= 2},
optionsimplicit = [gridrefine = 2, rational = true], x = -3 .. 1, y = -3 .. 0., scaling = constrained));
memory used=0.57GiB, alloc change=184.01MiB, cpu time=16.22s, real time=17.24s, gc time=1.58s
Mathematica 11.2.0.0 says
113053/146523-8/169 sqrt(22)+32/289 sqrt(30)-3/169 sqrt(214-24 sqrt(22))-
2/169 sqrt(1177-132 sqrt(22))-1/289 sqrt(94-16 sqrt(30))-
4/289 sqrt(705-120 sqrt(30))+1/146523 293046(Pi)-
arcsin(1/13 sqrt(2) (3+sqrt(22)))-arcsin(1/17 sqrt(2) (1+2 sqrt(30)))
(see Area.pdf).
I have a big vector composed of different real values elements. I want to extract the value of elements that are between specified interval (x1<val<x2) and their corresponding element numbers. How is it possible in Maple in simplest way?
For example suppose R:=[ 4,-1,9,11,-4,2,4,1,-1,2.2,112,44,-134,0.124,34,41,7,97,13.22123]:
I want the elements that their values are in the interval of -2<val<3 and their corresponding element numbers.
Namely: vals:=[-1,2,1,-1,2.2,0.124] and their corresponding numbers: Numbs:=[2,6,8,9,10,14]
First 951 952 953 954 955 956 957 Last Page 953 of 2463
