eq := diff(y(t), t, t)+9*y(t) = Dirac(t)
diff(diff(y(t), t), t)+9*y(t) = Dirac(t)
with(inttrans):
icon := y(0) = 0, (D(y))(0) = 0;
dsolve({eq, icon}, y(t), method = laplace);
y(t) = (1/3)*sin(3*t)
dsolve({eq, icon}, y(t));
y(t) = (1/3)*(Heaviside(t)-1/2)*sin(3*t)
Download Dirac_for_Primes.mw
I want to know is maple helpful to find a cjange coordinate to transform an old coordinate to a new coordinate? details are attached to the file:
changecoor.mw
Thanks guyz
Hi everyone,
I have a functional "L" which I want to solve Euler-Lagrange for it and then extermise that functionalexfun.mw by its equation of motions. I know the result must be same to a function like "A" but I cant obtain that. "a", "b" and "s" are constants and not important, I insist more on the shape of "A"
Thanks a lot
i am new user in maple .i want to calculate eigenvalues of a symmetrix matrix to find max or min value but i usually face a error code ' (in simpl/max) complex argument to max/min'
i know that a symmetrix matrix have real eigenvalues.
for example:
restart:with(LinearAlgebra):with(GraphTheory):interface(rtablesize=infinity):
SeidelMatrix:=proc(G::Graph) local J,B,A,S;
J:=Matrix(1..NumberOfVertices(G),1..NumberOfVertices(G),shape=constant[1]):
B:=IdentityMatrix(NumberOfVertices(G)):
A:=AdjacencyMatrix(G):
S:=J-B-MatrixScalarMultiply(A,2):
convert(S,Matrix,shape=symmetric,datatype=float):
return S:
E:=sort(eval(Eigenvalues(SeidelMatrix(CycleGraph(7)),output='list'))):
(min,max)(E);
Error, (in simpl/min) complex argument to max/min: (1/3)*(-28+(84*I)*3^(1/2))^(1/3)+(28/3)/(-28+(84*I)*3^(1/2))^(1/3)-1/3
I am trying to evaluate the following summation which gives the result 0. But I think answer is not correct.
restart; x := 0; evalf(Sum(Sum(x^(q-p), p = 0 .. q), q = 0 .. 10))
0.
Download zero.mw
A lot of efforts I performed to obtained the right results, somehow I remain sucessful but the results are not exactly same as expected. I request you to kindly see at the christoffel symbol. I also sent the right results.
some_mistakes_in_christoffel.mw
you can see the right results in the given below attachment
right_christoffel_symbols.pdf
as you can comprare the results of both file. the obtain crystoffel are not same as the requied.
is it possible to change ODE to PDE?
the ODE has diff(a(t),t) and diff(b(t),t)
how to convert to diff(t, a), diff(t, b) ?
Is there a built-in function in Maple 2015 that identifies and prints prime numbers in a specified integer range?
How can I write and solve a dirac_delta function in maple, for example in below equations:
F[0]:=0;
F[1]:=a;
F[2]:=b;
eq1:=sum((k-m+2)*(k-m+1)*F[k-m+2]*Dirac[m-1], m = 0 .. k);
eq2:=(k+1)*F[k+1]-Dirac[k];
for k from 0 to 10 do
F[k+3]:=solve(F[k+3]=(eq1+eq2)/((k+3)*(k+2)*(k+1)),F[k+3]);
Hi everybody,
I'm kind of new to Maple and i'm trying to solve a system of trigonometric equations inequality as follow:
f:= {((2*a*sin(S)*cos(S)^(2)))/(1-sin(S)^(3))<1,90> S>-90,a>1};
solve(f,{a,S});
Error, (in PiecewiseTools:-Convert) unable to convert
How can I solve the system?
Thanks a lot.
Since I am a very recent Maple user, I do not know why I obtained a wrong answer with the following two comands:
Exp:= Psi(rho(x,t),theta(x,t));
                  Psi(rho(x, t), theta(x, t))
Exp1:= diff(Exp,t);
     / d           \
     |--- rho(x, t)| D[1](Psi)(rho(x, t), theta(x, t))
     \ dt          /
          / d             \
    + |--- theta(x, t)| Psi(rho(x, t) + 1, theta(x, t))
          \ dt            /
Can someone, please, help me?
I am using Maple to model Gaussian Wave Packets and the do loop creates an array of plots. I want to animate these plots to show the movement of the wave packet and was wondering if there is a way to animate the array or perhaps another way to produce the animation.
I have a function "L" which is mentioned in the worksheet. I want to obtain equation of motion by solving Euler-Lagrange equation. How I can do this by maple? Have Maple an instruction to solve Euler-Lagrange equation?        ELEOM.mw
how to add two algebaric equations? I have two equation (1) and (2). i simply wrote (1) + (2) instead of adding the eqautions i got result is 3. i think there is some mistake of writng text for calling equation that was in bold.
adding_two_equations.mw
I am trying to evaluate the following triple integral but it takes much time so i kill the job.
restart; R := 5; KK := proc (theta) options operator, arrow; evalf(int(int(int(1/(R*sin(theta)^2+(R*cos(theta)+Z)^2+(2*R*k.sin(theta))*cos(p))^2, p = 0 .. 2*Pi), Z = 0 .. 60), k = 1 .. 10, numeric)) end proc; evalf(KK((1/6)*Pi))
Download int_maple_prime2.mw
First 1007 1008 1009 1010 1011 1012 1013 Last Page 1009 of 2467
