i have a Problem with maple. I have written this simple procedure
myPi_1:=proc(r)
local i,l;
l:=0;
for i from 1 to floor(r) do
    if isprime(i) and (i mod 4 = 1) then
        l:=l+1;
return l;
When i use it like this
k := myPi_1(80);
it works
But when i triy to plot it
plot(myPi_1(t), t = 0 .. 500, numpoints = 500, thickness = 2, color = black);
i get this message
Warning, expecting only range variable t in expression myPi_1(t) to be plotted but found name myPi_1
And no plot
Thank you for any Help
I want to calculate the following integral numerically with required precision.
First, the functions are defined:
G1:=-0.9445379894;
f:= (x) -> 0.9/abs(x-0.4)^(1/3)+0.1/abs(x-0.6)^(1/2);
U1 := unapply(-exp(-x)*(evalf(Int(f(t)*exp(t), t = 0 .. x))+G1)/2-exp(x)*(evalf(Int(f(t)*exp(-t), t = 0 .. x))+G1)/2, x);
U:= unapply(-exp(x)/2*(evalf(Int(f(t)*exp(-t),t=0..x))+G1)+exp(-x)/2*(evalf(Int(f(t)*exp(t),t=0..x))+G1), x);
Next, I calculate the integral in numerical form:
evalf(Int(U1(x)^2+U(x)^2-2*f(x)*U(x), x=0..1, digits=4, method = _Gquad));
If I specify digits=4, Maple return the answer -0.4291
If I use digits=5 or larger, Maple return someting like this
Is it possible to increase precision of calculation?
Please help me on this :
restart; with(PDETools), with(plots)
n := .3:
Eq1 := (1-n)*(diff(f(x, y), `$`(y, 3)))+(1+x*cot(x))*f(x, y)*(diff(f(x, y), `$`(y, 2)))-(diff(f(x, y), y))/Da+(diff(f(x, y), y))^2+n*We*(diff(f(x, y), `$`(y, 2)))*(diff(f(x, y), `$`(y, 3)))+sin(x)*(theta(x, y)+phi(x, y))/x = x*((diff(f(x, y), y))*(diff(f(x, y), y, x))+(diff(f(x, y), `$`(y, 2)))*(diff(f(x, y), x))):
Eq2 := (diff(theta(x, y), `$`(y, 2)))/Pr+Nt*(diff(theta(x, y), y))^2/Pr+Nb*(diff(phi(x, y), y))*(diff(theta(x, y), y))/Pr+(1+x*cot(x))*f(x, y)*(diff(theta(x, y), y)) = x*((diff(f(x, y), y))*(diff(theta(x, y), x))+(diff(theta(x, y), y))*(diff(f(x, y), x))):
Eq3 := Nb*(diff(phi(x, y), `$`(y, 2)))/(tau*Pr)+Nt*(diff(theta(x, y), `$`(y, 2)))/(tau*Pr)+(1+x*cot(x))*f(x, y)*(diff(phi(x, y), y)) = x*((diff(f(x, y), y))*(diff(phi(x, y), x))+(diff(phi(x, y), y))*(diff(f(x, y), x))):
ValWe := [0, 5, 10]:
bcs := {Nb*(D[2](phi))(x, 0)+Nt*(D[2](theta))(x, 0) = 0, f(0, y) = ((1/12)*y)^2*(6-8*((1/12)*y)+3*((1/12)*y)^2), f(x, 0) = 0, phi(0, y) = -.5*y, phi(x, 12) = 0, theta(0, y) = (1-(1/12)*y)^2, theta(x, 0) = 1, theta(x, 12) = 0, (D[2](f))(x, 0) = Da^(1/2)*(D[2, 2](f))(x, 0)+Da*(D[2, 2, 2](f))(x, 0), (D[2](f))(x, 12) = 0}:
pdsys := {Eq1, Eq2, Eq3}:
p1 := ans[1]:-plot(theta(x, y), x = 1, color = blue):
plots[display]({p1, p2, p3})
Download untitle_2_(1).mw
S[1] := .51-.67030*t+.4644645000*t^2-.2542824350*t^3+.1337509523*t^4
S[2] := .29-.37330*t+.2539795000*t^2-.1337383850*t^3+0.6737783824e-1*t^4
S[3] := 0.6e-1-0.6280e-1*t+0.3392700000e-1*t^2-0.7715060000e-2*t^3-0.2012235525e-2*t^4
V[1] := .14+.18480*t-.3482570000*t^2+.2511604200*t^3-.1217312553*t^4
V[2] := .37-0.9810e-1*t-.1638085000*t^2+.1665366350*t^3-0.8847577175e-1*t^4
V[3] := .59-.36870*t+0.126205000e-1*t^2+0.8559214500e-1*t^3-0.5666617885e-1*t^4
Iota[1] := 0.8e-1-.1000*t+0.6280600000e-1*t^2-0.2652762667e-1*t^3+0.8545290360e-2*t^4:
E[1] := 0.2040e-2*t-0.3584600000e-2*t^2+0.3405427000e-2*t^3-0.2270144502e-2*t^4:
R[n] := 0.5e-1+0.715e-1*t-0.1627750000e-1*t^2-0.3034627500e-1*t^3+0.2606816769e-1*t^4:
> Pls let someone help me plot S1;S2,S3 using Maple.
Download FINAL_RESULT.mw
To select a piece from a list, for example:
lst:=[1,2,3,4,5,6]
I want to get the list piece from second place to fifth place: [2,3,4,5].
Is there a function?
How do cylinder (3D plot) from Excel file(csv)?
I have table in the Excel:
Angel(A)  length(cylinder) Function(sin(A)*EXP(1-L/1000)
1                 5                          0,05
2               10                          0,1
360         1000                      0
Please help me..
I don't understand how contourplot chooses it's view range. I would like a contour plot to go from r=0..10 and display axes from [-10..10, -10..10].
plots:-contourplot(r*sin(phi), r = 0 .. 10, phi = 0 .. Pi, coords = spherical, grid = [80, 80]);
doesn't produce a plot with range [-10..10]. Adding view doesnt compute anything differeently, just makes the axes bigger.plots:-
contourplot(r*sin(phi), r = 0 .. 10, phi = 0 .. Pi, coords = spherical, grid = [80, 80], view=[-10..10,-10..10]);
I want more contour lines near the endpoints of the range. why is it focused in the middle?
any help is appreciated,
Hi everyone,
I am making a model of the solar system (not to scale) in Maple for a school project. I need to add an animation to make the planets move on the orbits I have for each of them. How do I do this?
I uploaded pictures on a Photobucket account of how I've done it so far to help. This is my first time using Maple so I know that I probably did some things inefficiently.
Photobucket URL: http://i1070.photobucket.com/albums/u492/nmsnyder007/Capture1_zpsfmitm0ou.jpg
I have a program:
Running abb(1,3) gives error: Error, (in abb) illegal use of a formal parameter
Might be a silly question: Is it not allowed? Do I have to define a local variable for b in order to change it?
Hey there!
this is the formula:
diff(ca(t), t) = -3.600000000*10^20*exp(-15098.13790/(340-20*ca(t)))*ca(t), ca(0) = 2
I can easily plot it by solving DE numerically, however I can't seem to find a way to determine what 't' is at ca(t)=0.2
thank you so much in advance!
Kind regards,
Gerard
Download 2222222222222222222.mw
> restart;
> A[0] := 10^(-3); a := 10^5;
> sys := diff(R(theta), theta) = A[0]*exp(2*mu(theta))*sin(theta)/(2*a), R(theta) = 2*exp(-2*mu(theta))*(1-(diff(mu(theta), `$`(theta, 2)))-cot(theta)*(diff(mu(theta), theta)));
> cond := R(0) = 10^(-5), mu(0) = 118.92, (D(mu))(0) = 0;
> F := dsolve({cond, sys}, [R(theta), mu(theta)], numeric);
> with(plots);
> odeplot(F, [theta, R(theta)], 0 .. 3.14, color = black, thickness = 3, linestyle = 4)
> odeplot(F, [theta, mu(theta)], 0 .. 3.14, color = blue, thickness = 3, linestyle = 1)
After last two lines maple writes:
Warning, cannot evaluate the solution past the initial point, problem may be complex, initially singular or improperly set up
And gives me empty plots. I can't figure out where an error can be. Some things I noticed:
Maple doesn't calculate the system before and after zero. If I change the range from 0..3.14 to -10..10 or to 0.00001..0.00001, it gives me 2 errors for 1 plot.
Also if I change the condition mu(0) = 118.92 to mu(0) = 1 or mu(0) = 50 or mu(0) = 80, it works. After ~80 it gives an error. I can't imagine where could appear a division by 0 or some other mistake.
Hello People in mapleprimes,
I have a question about collecting part of expression.
Please teach me an answer to this.
I want to modify a1 to b1.
e3.mw
Dears,
I have a question and I hope someone will be able to answer it.
I would like to create a matrix of functions depending on the number of the line or the arrow. I think the best is to show with a very basic example:
I have the following program
n:=4:
R:=Matrix(1,n):
for i from 1 to n do: R(1,i):=x->i*x:end do:
So, I have a matrix, one row, n columns. At the ith column, I want to have the function f(x)=i*x.
Unfortutanely, with my program, I obtain for example for the first column the function f(x)=11*x. At the second column, I get the same result. It seems that I can define matrices of functions but it is impossible in the definition of the function to use the number of the column. Do you have any idea about how to write a program?
Any help would be very appreciated.
For a 2D parametric plot with only one parameter, in Maple we use plot([x,y,range]) but what about the case x and y are expressed by more than one parameter? How should I assign the range? For example I tried the following one
h := k[1]*k[3]+k[1]*k[4]+k[2]*k[4]:
x := k[2]/h:
y := (k[3]+k[4])/h:
A := seq(k[i] = 1 .. 2, i = 1 .. 4):
plot([x, y, A]);
But then I encountered the following error:
Error, (in plot) incorrect first argument [k[2]/(k[1]*k[3]+k[1]*k[4]+k[2]*k[4]), (k[3]+k[4])/(k[1]*k[3]+k[1]*k[4]+k[2]*k[4]), k[1] = 0.1e-2 .. 1000, k[2] = 0.1e-2 .. 1000, k[3] = 0.1e-2 .. 1000, k[4] = 0.1e-2 .. 1000]
For one parameter the above method doesn't make an error like the following:
x := t+1:
y := t^2:
A := t = 1 .. 2:
plot([x, y, A]);
So for more than one parameter, there should be another way to ask the plot. Does anyone know how to do that?
I want to plot a simple power function in diferent pieces by using diferent range and  for different values of parameter a[i] at i=0,1,2 define in the attached sheet.
plot_at_different_intervals.mw
First 1019 1020 1021 1022 1023 1024 1025 Last Page 1021 of 2459
