woud like to find H(x)
just for one of definition H(x) + H(y) = H(x+y), but it seems require to duplicate one more set of differential system
Error, (in dsolve) found differentiated functions with same name but depending on different arguments in the given DE system: [{a(x), a(y)}, {b(x), b(y)}]
eq2a := a(x)*(diff(c(x), x))+b(x);
eq3a := a(x)*(diff(b(x), x))+c(x)*(diff(b(x), x));
eq4a := a(x)*(diff(c(x), x))+a(x)*(diff(b(x), x))+b(x);
eq2b := a(y)*(diff(c(y), y))+b(y);
eq3b := a(y)*(diff(b(y), y))+c(y)*(diff(b(y), y));
eq4b := a(y)*(diff(c(y), y))+a(y)*(diff(b(y), y))+b(y);
inis := diff(a(x),x)=H(a(x)), diff(b(x),x)=H(b(x)), diff(c(x),x)=H(c(x)), a(1) = b(1), b(1) = c(1), a(0) = b(0), b(0) = c(0);
inis := diff(a(x),x)=H(a(x)), diff(b(x),x)=H(b(x)), diff(c(x),x)=H(c(x));
inio := diff(a(y),y)=H(a(y)), diff(b(y),y)=H(b(y)), diff(c(y),y)=H(c(y)),H(a(x)) + H(b(x)) = H(a(x)+b(x));
sol := dsolve([eq2a=1, eq3a=exp(a), eq4a=0, eq2b=1, eq3b=exp(b), eq4b=0, inis, inio], [a(x), b(x), c(x), a(y), b(y), c(y), H(a(x)), H(b(x)), H(a(y)), H(b(y))]);
I have a function c(k), I want to graph it where the x-axis has the units k/K (where K is a constant, about 0.0027). I was wondering how that is possible to do because for the life of me I can't figure out how to get maple to allow for relative units like that. Here's my code:
K:=0.0027
c := sqrt(9.8*K/k+0.7197e-1*k/K*(1/1000))
cmin:=(0.7197e-1*(4*9.8)*(1/1000))^(1/4);
C:=c/cmin
plot(C, k = 0 .. 4, 0 .. 4)
Hello all,
here the programme I think there are some mistakes couldnot know where please any comment will be helpful:
# Firstly, set the size limit for the grid, which shall define how many
# points there are in both the vertical and horizontal direction
size=40;
# limit is a variable used to set an unobtainable upper bound
limit=size+1;
# x defined, starting at 1, and two other variables ud (upper diagonal) and
# dd (downward diagonal) begin at 0. All three are used to iterate through
# line creation
x=1;
ud=0;
dd=0;
# Iteration through x, using the line function to create a number of
# horizontal lines up to the limit point
while(x<(limit))
line([0, size], [x, x]);
x=x+1;
end
# Now iterating through the diagonals pointing upwards, using two sets of
# lines, both starting from the line going through the origin. The first
# iterates through the lines that pass through positive x values at y=0,
# the second iterates through the lines passing through negative x values
# at y=0
# ud must be increased by 2 each time to ensure that equilateral triangles
# are formed.
while(ud<(limit))
line([(ud), (size)], [0, (size-ud)]);
line([0, (size-ud)], [(ud), (size)]);
ud=ud+2;
end
# Similar to before, except this time iterating through downward pointing
# diagonals.
while(dd<(limit))
line([(dd), 0], [0, (dd)]);
line([(size), (dd)], [(dd), (size)]);
dd=dd+2;
end
# xvector and yvector set up as two vectors holding x and y co-ordinates of
# points respectively.
xvector = zeros(1, limit);
yvector = zeros(1, limit);
# Reinitiallising x and y values for iterative purposes.
x=0;
y=0.5;
n=1;
# The program now iterates through potential y values for the potential
# points. Then it tests the value of y to see what orientation the lattice
# is at that point, then randomly selects x values to enter, iterating
# between all the possible x values in the orientation before moving on to
# the next y value.
while(y<size)
if(mod(y,1)==0.5)
x=0.5;
while(x<size)
z=rand;
if(z>0.5)
xvector(n) =x;
yvector(n) =y;
n=n+1;
end
x=x+1;
end
elseif(mod(y,2)==1)
x=0;
while(x<size)
z=rand;
if(z>0.5)
xvector(n) =x;
yvector(n) =y;
n=n+1;
end
x=x+2;
end
x=1;
while(x<size)
z=rand;
if(z>0.5)
xvector(n) =x;
yvector(n) =y;
n=n+1;
end
x=x+2;
end
end
y=y+0.5;
end
# The program then enters the two co-ordinate vectors saved previously into
# the scatter function.
hold;
scatter(xvector, yvector);
Hello everyone, Im now doing my fyp project in cryptography. I need to encrypt a message by using genetic operator, mutation and crossover and decrypt it after that.
For example:
message:=elgamal;
m:=convert(message,bytes);
with(Bits):
for i from 1 to l do
bit[i]:=Split(M[i]);
After that I will use genetic operator to change some bit for each character.
The output I might get will be something like this [1,1,1,1,1,1,1] , after that I need to convert it back to Ascii key value by join function, but sometime it might exceed 127 which out of the range of Ascii key value. Any command can solve this problem or any method can be used which will not affect the original message? Thank you.
Hello, anyone know how to convert a word to 8 bits binary number ?
For example:
Here is my code:
message:=Hello
>m:=[104,101,108,108,111]
with(Bits):
for i from 1 to 5 do:
mb[i]:=Split(m[i]);
>mb[1]:=[0,0,0,1,0,1,1] mb[2]:=[1,0,1,0,0,1,1] mb[3]:=[0,0,1,1,0,1,1] mb[4]:=[0,0,1,1,0,1,1]
  mb[5]:=[1,1,1,1,0,1,1]
Anycommand can add additional one column when split the words into binary to form 8 bit in each row? Any help will be highly appreciated. Thank you.
 How get another solutions ? f:=exp(x2*(a-x))
I would like to start using maple workbook to manage my projects but i can't figure out the paths. suppose i have a workbook named: WorkBookTest.maple
and inside this i have a folder containing Data in which i have an excel workbook DataTest.xlsx
and also i have a folder containing Documents in which i have a maple worksheet Document.mw
and also i have a folder containing Code in which i have a mathematica notebook Code.nb
Now inside the maple worksheet, to import the excel data i use the command: Import("this:///Data/DataTest.xlsx")
and it works
Now inside the mathematica workbook, to import the excel data i use the command: Import["this:///Data//DataTest.xlsx"]
and it fails
so if i have other program like mathematica notebook inside maple workbook that wants to call a file with data, how should i define the path?
Does Maple have something similar to c-means clusteirng in Matlab?
http://www.mathworks.com/help/fuzzy/fcm.html
 How would I go about doing something like this in Maple?
The docs for the package geometry say:
The command with(geometry,distance) allows the use of the abbreviated form of this command.
I am new to Maple. What is the abbreviated form of the distance command?
aa3 := Normalize(<<aa2[1,1],aa2[2,1],aa2[3,1]>,<aa2[1,2],aa2[2,2],aa2[3,2]>,<aa2[1,3],aa2[2,3],aa2[3,3]>>, Euclidean);
the result is one column
how to normalize to a matrix form?
I have a problem with finding a interval where parametr "a" is changing.
My funcion:
                 exp(x2(a-x)) for xcR.
I did this, and I don't know what's next.
g:=x->exp(x2(a-x));
dg:=diff(g(x),x);
solve(dg=0,x);
                      0,2/3a
g(0);
g(2/3a);
Hi, all. I need to built a user interface for my program. First, I create two label and two text area for both the value of x and y. After that I assign a button to random generate the value for x and y within the range with x <y. I write the code below into click action of the button.
use DocumentTools in
Do(%x=RandomTools[Generate](integer(range=1..7);
Do(%y=RandomTools[Generate](integer(range=1..7);
while %x>= %y do
end use;
This code can generate two random number and insert inside the boxes created. When the button is clicked, two random number generated but the error dialog box shown on the screen with message : Error in component button with caption "generate" cannot determine if this expression is true or false: %y=%x. What I want is only the true value of x<y will be inserted to the text boxes.
Any suggestion? Any help will be highly appreciated. Thank you.
For example,
I have original bit :=[10000000]. after encryption by using technique cryptography, I get thecipher text:=[11110011]. Then I need to measure the total flipped bit in the cipher text with the original bit. Have any method can calculate the total flipped bit? Can someone help me? Thank you.
For example, I havd matrix m:=[0 1 0 1 0 1 0], I want to convert it back to m:=[0,1,0,1,0,1,0]. Can someone help to solve? Thank you.
I have two inter-related expressions of the form,
(i) T=f(w)
(ii) E=g(w)
where the limits of w in both expressions are same. Now I need to plot a graph T Vs E
Any suggestions???
First 1168 1169 1170 1171 1172 1173 1174 Last Page 1170 of 2459
