Please I need programme to solve this nonlinear couple ode with values of k_1 from 1.5 to 2.5 and eta from 0.0 to 2.0 real_work_3.mw Thanks for your help.
When I check the length of the optimal tour found by TravelingSalesman (GraphTheory package), it's different from the given result. What goes wrong?
See attached file.
restart: with(GraphTheory):
G := GRAPHLN(undirected,weighted,[1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13,
14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25],Array(1..25, [{17, 19},{10, 22
},{10, 14, 23},{6, 12, 14},{6, 7, 19},{4, 5},{5, 13, 15, 16},{12, 13, 14, 15},
{20, 25},{2, 3},{22, 25},{4, 8, 13},{7, 8, 12},{3, 4, 8},{7, 8, 21, 23},{7, 17
, 18},{1, 16, 18, 19},{16, 17, 25},{1, 5, 17},{9, 21, 22},{15, 20, 24},{2, 11,
20, 24},{3, 15, 24},{21, 22, 23},{9, 11, 18}]),`GRAPHLN/table/2`,Matrix(25, 25
, {(12, 13) = 137, (14, 4) = 920, (3, 14) = 902, (5, 6) = 561, (17, 18) = 443,
(22, 11) = 670, (16, 17) = 573, (19, 17) = 330, (18, 17) = 280, (10, 2) = 1630
, (16, 18) = 727, (23, 15) = 760, (17, 1) = 900, (4, 6) = 1216, (16, 7) = 600,
(14, 8) = 260, (12, 4) = 580, (1, 19) = 665, (4, 12) = 733, (19, 5) = 750, (8,
14) = 368, (11, 25) = 1366, (24, 22) = 300, (17, 19) = 495, (21, 15) = 930, (6
, 4) = 1110, (11, 22) = 1049, (12, 8) = 100, (15, 21) = 995, (17, 16) = 520, (
1, 17) = 866, (15, 23) = 833, (5, 19) = 930, (9, 20) = 184, (19, 1) = 630, (7,
15) = 598, (13, 8) = 110, (24, 21) = 250, (3, 10) = 471, (24, 23) = 550, (2,
10) = 1682, (13, 12) = 80, (8, 12) = 202, (21, 24) = 287, (23, 3) = 590, (15,
8) = 410, (14, 3) = 800, (23, 24) = 688, (7, 13) = 526, (8, 15) = 477, (20, 21
) = 245, (2, 22) = 547, (15, 7) = 990, (22, 20) = 420, (10, 3) = 300, (4, 14)
= 933, (5, 7) = 690, (18, 25) = 328, (25, 18) = 270, (21, 20) = 130, (25, 9) =
240, (7, 16) = 406, (20, 9) = 140, (6, 5) = 380, (8, 13) = 236, (20, 22) = 452
, (22, 2) = 500, (9, 25) = 227, (13, 7) = 640, (7, 5) = 670, (25, 11) = 1640,
(3, 23) = 518, (22, 24) = 495, (18, 16) = 700}, storage = sparse));
GRAPHLN(undirected, weighted, [1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25], Array(%id = 4487072130), `GRAPHLN/table/2`, Matrix(%id = 4488755818))
P:=TravelingSalesman(G);
15471, [1, 19, 5, 6, 4, 14, 3, 10, 2, 22, 11, 25, 9, 20, 21, 24, 23, 15, 8, 12, 13, 7, 16, 18, 17, 1]
add(GetEdgeWeight(G,{P[2][i],P[2][i+1]}),i=1..nops(P[2])-1);
16570
Download traveling_salesman_e.mw
I came to know that Chrome no longer supports MathML. Will this be an issue with Maple T.A.9/9.5? Should I require my students to switch to Firefox instread?
We're programming with Maple objects, and would like to have a Maple object that is appliable (i.e. acts as an operator).  We're really after partial differential operator (PDO) objects, but I give a simpler example below.  The problem is this: the ?ModuleApply proc needs to be non-static (so that each object has its own ?ModuleApply), and it may want to refer to the object instance, via ?thismodule.  Code like this works great when it is typed at the command line or read in from .mpl file, but it barfs as soon as saved to a .mla.  Why is that?  And is there an easy fix / workaround?
Here is an example worksheet, that creates a basic "compute mod p" object
BugThismoduleMLA.mw
The issue seems to be that, for code typed at command line, ?thismodule is resolved when I would expect, i.e. in the instance object; but saving to the .mla seems to cause ?thismodule to be resolved then-and-there, which means it resolves to the prototype object.  For this particular case there is an easy workaround, but we really want to refer to ?thismodule if possible.  Is there a way to do that?
BTW I'm running Maple 17.02 (sorry don't have access to 18 yet).
Ian and Tracy
One annoying feature in using document mode that I found is this. As I hit the return key to execute one command and automatically jump to the command below it (a feature that I like), but after few returns, I find myself at the bottom edge of the window, with the cursor pointing at the last command in the window.
Now when hitting return, the current command is execuated, and the next command below it appears, and it is also at the bottom edge of the window.  The cursor is from now on, always sitting at the bottom edge of the window, and I am not able to fully see the rest of the command and what is below it any more.
What would be better, is to try to keep the window centered, so that as I hit a return, the actual cursor remains in the middle of the window, and the window itself scrolls up. This way the command I am about to evaluate, and anything below it, remain in full view.
What I end up doing now, is when I get to the bottom of the window, is to manually scroll the window down using the mouse, so that now the cursor is up higher, and I can see more the commands which I am about to evaluate, then I repeate this process.
Is there  a way to configure Maple to try to keep the window centered? it is really very annoying to have to keep adjusting the window every few returns, and when one has 100 commands to evaluate, one by one (since I want to see the result before I go to the next command), this process gets tiring.
(does Maple do any usability studies and evaluation on its user interface by any independent outside group?)
HI.
I need your remarks in this problem.
I have ode. diff(y(x),x)=f(x,y);  x in [0,a]; h:=a/(2*N); stepsize.
When the the true solution is not Known, we can test the rate of convergence, of numerical solution. The Numerical solution generated when the stepsize is 2*h denoted by y_i^(2h) and the numerical solution with step size h will be denoted by y_i^(h).
if we define the epsilon(h):=sqrt (  1/(N+1)*add(  (y_i^(2h) -y_(2i)^(h) )^2, i=0..N));
 If we useForward Euler ( it's Known that the golbal error isof order 1 and local error of order 2) in the case when the exact solution is know.
But, If we use epsilon(h), and for the same method can some one know the order of Error =h^?????.
g:=0.88641:
e:=2.53128:
eq:=tan(g)= e*sin(f)/(1+e*cos(f)):
fsolve(eq,f);
gives  1.19749
What command/option do I need to get both solutions like with Mathematica:
g = 0.886461;
e = 2.53128;
eq = Tan[g] == (e Sin[f])/(1 + e Cos[f]);
NSolve[eq, f]
  (*   {{f -> -2.56623}, {f -> 1.19756}} *)
I took a calculus 1 class in 2002, so i have many maple worksheets i would like to view on my new dell venue 8 pro. can the player read the .mws ext ?  Donald Altringer
ps. I have maple 8 on my laptop but not on th tablet and i don't  have a way of installing it
I have the following function:
and I want to calculate it for a certain set of r, theta and t, but when I use subs, the theta variable is also subsituted int the integral's parameters and I get the folllowing result:
I really don't understand why it does that given that there is no issue for the r variable...
P-S: please forgive my poor English : I'm a French student...
Florent
Please I need your help to simplify by the coefficient a in this Matrix
I have The matrix A defined by  A:=Matrix(2,2, [[a,a],[3*a,4*a]]);
I want with maple transform A to  A:=a*Matrix(2,2, [[1,1],[3,4]]);
Thanks for your Help.
I try to solve these two nonlinear odes, but no desire outcome. Please helpreal_work1.mwreal_work1.mw  or real_work1.mw
Thanks for your answer. I have a simple question:
Let A be a Matrix, X[1] and X[2] two vectors.
I have this equation:  X[2]= X[1]+ A*X[1]+A*X[2];  Using Maple how can I  writte X[2] =P*X[1]; where P is a matrix to be founded.
Here, P:=(Id-A)^(-1)*A; But how using maple.
I have tried to use Maple to solve ordinary differential equations but i have this error. Could you please help me to fix this problem
> eq1 := diff(v1(t), t) = v2(t);
> eq2 := diff(v2(t), t) = -v1(t)+(3*(v1(t)^2-1))*v2(t);
> init1 := v1(0) = 2;
> init2 := v2(0) = 0;
> with(DEtools);
> DEplot({eq1, eq2}, [v1(t), v2(t)], 0 .. 3*Pi, {[0, 0, 0]}, scene = [v1, v2], stepsize = .1);
Error, (in DEtools/DEplot/direction) division by zero
thank you
b := 1;
h := 1;
A := b*h;
E := 210*10^9;
qr := 100;
Dp := (1/12)*E*b*h^3;
R := 20;
teta := 3;
sys1 := {(E.A+Dp/R^2)*(diff(u(t), `$`(t, 2))) = -E*A*(diff(w(t), t))/R+Dp*(diff(w(t), `$`(t, 3)))/R, -Dp*(diff(w(t), `$`(t, 4))) = E*A*(diff(u(t), t))/R-Dp*(diff(u(t), `$`(t, 3)))/R+E*A/R-100};
dsolve(sys1);
#THİS GAVE ME THE RESULTS LİKE THAT:
{u(t) = (1/4801)*_C3*(-1+sqrt(4801))^(3/2)*exp(-(1/20)*sqrt(-1+sqrt(4801))*t)-(1/4801)*_C4*(-1+sqrt(4801))^(3/2)*exp((1/20)*sqrt(-1+sqrt(4801))*t)-(1/4801*I)*_C5*(1+sqrt(4801))^(3/2)*exp(-(1/20*I)*sqrt(1+sqrt(4801))*t)-(1/4801)*_C6*(-1+sqrt(4801))^(3/2)*exp((1/20)*sqrt(-1+sqrt(4801))*t)+(1/4801)*_C3*sqrt(-1+sqrt(4801))*exp(-(1/20)*sqrt(-1+sqrt(4801))*t)-(1/4801)*_C4*sqrt(-1+sqrt(4801))*exp((1/20)*sqrt(-1+sqrt(4801))*t)+(1/4801*I)*_C5*sqrt(1+sqrt(4801))*exp(-(1/20*I)*sqrt(1+sqrt(4801))*t)-(1/4801)*_C6*sqrt(-1+sqrt(4801))*exp((1/20)*sqrt(-1+sqrt(4801))*t)-(104999999/105000000)*t+_C1, w(t) = _C2+_C3*exp(-(1/20)*sqrt(-1+sqrt(4801))*t)+_C4*exp((1/20)*sqrt(-1+sqrt(4801))*t)+_C5*exp(-(1/20*I)*sqrt(1+sqrt(4801))*t)+_C6*exp((1/20)*sqrt(-1+sqrt(4801))*t)}
#SO THERE ARE 6 UNKOWN(C1...C6) SO I NEED 6 CONDITION. MY BOUNDRY CONDITIONS:
bs := u(0) = 0, (D(u))(0) = 0, w(0) = 0, (D(w))(0) = 0, w(teta) = 0, (D(w))(teta) = 0;
> r := dsolve({bs, sys1});
Error, (in dsolve) invalid arguments; expected an equation, or a set or list of them, received: {{-17500000000*(diff(diff(diff(diff(w(t), t), t), t), t)) = 10500000000*(diff(u(t), t))-875000000*(diff(diff(diff(u(t), t), t), t))+10499999900, 210043750000*(diff(diff(u(t), t), t)) = -10500000000*(diff(w(t), t))+875000000*(diff(diff(diff(w(t), t), t), t))}}
I tried to change the equations row. But ı dont understand where something wrong.I tried so many times. May u please find where ıt is wrong?
I would like to know whether it is possible to change the color of animations that have already been produced and assigned to a variable.
Let's take for example
P := plots:-animate(plot, [sin(x+t), x = -Pi .. Pi], t = -Pi .. Pi, frames = 8)
is there a command to change the color of the curve AFTER it has been produced?
The calculus to generate all my plots took 4 hours so I would like not to have them calculated again.
Thx
First 1485 1486 1487 1488 1489 1490 1491 Last Page 1487 of 2463
