if there is a set of identities, such as a+b = b+a, a^2 = 2*a + 1
and one input or a few input,
how to make use of these identities to derive some output?
any algorithm can do this?
I'm new here and I couldn't find similar problem in this forum.
I want to use variable (red marked) with unit definite integrals but it doesn't work. I put the file with units and file without units (to check correct solution) in this post.
What to do?
Files:
01_referat(units).mw
01_referat(without_u.mw
Is there any simple way in maple 16 to fix the axis width and height on inline plot? The PlotSetup seems dosen't function properly in my windows7 home 64 bit! Thank you.
Hello my friends
I have a problem in displaying the mesh grid in my plot3d graphs in maple 17. For instance, I when I type:
plot3d(x^2-y^2, x = -1 .. 1, y = -1 .. 1)
The graph has no mesh grid on it. I mean I am not seeing the black lines on the 3d surface. Can anyone help me to display the mesh grid please? Thanks.
which method i input a series of random number it output a periodic waveform
how to express bosonic and fermonic with physics package in maple?
what are the difference between upperscript and underscript?
lambda1:=(1/(K+2))*(S+sqrt(2*alpha*(K+2)+S^2));
lambda2:=(1/(K+2))*(S-sqrt(2*alpha*(K+2)+S^2));
where K>=0, S (-15, 15) and alpha (-15, 15). While plotting for small values of S and alpha, I get complex roots.
  • How we can avoid the complex roots?
  • Is it possible to impose a condition in plotting?
    solve(lambda1=lambda2,S);
    solve(lambda1=lambda2,alpha);
    solve(lambda1=lambda2,K);
  • How to single out the range of S and alpha for which we have complex roots?
How to prove  that there exists an integer number x s.t. x>0, x < 4*99! and x*(x+1) is divisible by 100! with Maple?
I know that was solved by C++ code.
Consider the ring R of upper-triangular matrices over the field of 3 elements.  I would like to have a multiplication table for this ring. Is it possible to generate such a table in Maple?  Thank you.
i wanted a taylor series  of the expression sin(xy) my code;
mtaylor(sin(x*y),[x=1,y=2],6); and it worked like a charm
sin(2)+2*cos(2)*(x-1)+cos(2)*(y-2)-2*sin(2)*(x-1)^2+(-2*sin(2)+cos(2))*(y-2)*(x-1)-(1/2)*sin(2)*(y-2)^2-(4/3)*cos(2)*(x-1)^3+(-2*sin(2)-2*cos(2))*(y-2)*(x-1)^2+(-sin(2)-cos(2))*(y-2)^2*(x-1)-(1/6)*cos(2)*(y-2)^3+(2/3)*sin(2)*(x-1)^4+(-2*cos(2)+(4/3)*sin(2))*(y-2)*(x-1)^3+(-2*cos(2)+(1/2)*sin(2))*(y-2)^2*(x-1)^2+(-(1/2)*cos(2)+(1/3)*sin(2))*(y-2)^3*(x-1)+(1/24)*sin(2)*(y-2)^4+(4/15)*cos(2)*(x-1)^5+((4/3)*sin(2)+(2/3)*cos(2))*(y-2)*(x-1)^4+(-(1/3)*cos(2)+2*sin(2))*(y-2)^2*(x-1)^3+(-(1/6)*cos(2)+sin(2))*(y-2)^3*(x-1)^2+((1/12)*cos(2)+(1/6)*sin(2))*(y-2)^4*(x-1)+(1/120)*cos(2)*(y-2)^5
now i need to plot the darn thing. so i tried to use tayplot function but i get nothing. is there a special package i need to use tayplot etc..?
Hello dear all,
I use maple 16, x64. When I run this code:
Student[Calculus1][ApproximateInt](cos(y/(-1+y)), y = 0 .. 1, method = lower, iterations = 1)
it results in "0.0667344650", exactly equal with the result of executing
Student[Calculus1][ApproximateInt](cos(y/(-1+y)), y = 0 .. 1, method = lower, iterations = 10000000000)
Any idea?
Best regards
How to do composition for finite group?
is the composition like permutation group ?
if express finite group like permutation group,
if so, can elements in first row duplicate? can the second row duplicate?
however, do not know how to map when there are more than or equal two choices
my guess is that
if finite group can be expressed into permutation group
for example 3*3 matrx, each column is a permutation group
then there will be 3 permutation groups, when do composition , first column's permutation group composite with first column's permutation group , second composite with second etc
is it right?
A  stupid question.
I noticed that there are some difference between the Vector and the Nx1/1xN Matrix, for example:
It confused me. Why Maple should distinguish the vector and the Nx1/1xN matrix?
If it is due to the need of vector analysis, I refered to VectorCalculus of Maple Help and it seems that Maple used the additional package and command to handle the question about vector analysis, for example:
I'd appreciate any help on this topic. Thank a lot.
i understand quotient group is
G/(normal subgroup)
= G composite with inverse permutation group of normal subrgoup
is this understanding correct?
If do not have subgroup or normal subgroup, how to do quotient group?
if i shift second row many times in order to find Subgroup satisfy G*Subgroup = Subgroup*G
after find Subgroup then test
inverse(g)*Subgroup*g = Subgroup
how to test whether inverse(g)*Subgroup*g belong to Subgroup?
or just use equal in inverse(g)*Subgroup*g = Subgroup?
a*b - b*a    where a , b are permutation group
how to minus this?
if a + b , then how to plus permutation group
First 1493 1494 1495 1496 1497 1498 1499 Last Page 1495 of 2463
