Is there a way to change the default settings for ArrayTools[RandomArray](distribution= )  ?
There are two distribution values available uniform, which is on the unit interval and normal which draws from a normal distribution on the unit interval.
Can we modify those settings?  Such that using distribution=uniform (or normal) is forced to some user setting outside the unit interval?
Unable to open these maple files, please help
I have a question in Maple TA that is asking for an answer in radians, and when I post the answer that I get it does not accept it...I'm assuming I'm doing the problem correctly, but my answer is not in the correct format.
How to speedup them? There are more than 20 functions that are evaluated one by one. Is option 'remember' + permanent remembered item of pure symbolic calculation can speedup this process? How also efficiently to do simlify itself? Can i actually use more kernels in one session or to paralilize available one?
Hello everyone
I have a function, constructed by numerically solving a set of differential equations.  I need to find a best fit for this function with an analitic model with two parameters. I tried to extract some points of this function and then using nonlinearfit:
xvalues:=Vector([seq(105 ..106,104);
yvalues:=Vector([seq(evalf(function),x=105 ..106,104)]);
with(Statistics):
I have a derivation to do for my PhD thesis, and it is long and tedious. It is essentially a case of splitting sums, making substitutions and then simplifying. I believe maple can do this for me, but have not found how yet. Any suggestions would be more than welcome. I have done this for a third order problem (three nested sums) and the derivation runs to many pages. I now need to do so for the 4th order problem, and it is a more than daunting prospect
In polar coordinate, when we differentiate er, it becomes e[theta]. However it seems Maple can't do this, even I have set it into polar coordinate.
How can I allow maple to do this?
Any Example can help see the difference between contour and simple integration?
int(XXXX, x, method = contour);
int (XXX, x)
which example can help to see the difference?
Why that Find / Replace doesn't work?
Wnat to rename some variables but it doesn't seem to find text in eval-cells at all :(
hi
I wan`t use maple to solve my problem
x1[n]= ej*( Π/6) *n
Hey, so i guess i dont really know whats going on. I am trying to install Maple 10 on my Macbook Pro. I get an error message Uncaught exception in main method: java.lang.NoClassDefFoundError: org/apache/crimson/parser/XMLReaderImpl when i try to open the program. Any help?
Want to do smth like that:
Call EvalMapleStatement from c dll.
expression always has form like "F(0.4, 0.7, 0.9);" i.e. maple defined function called. All i need it's value without any kind of caching. But memory usage dramatically grows. Help to overcome it!
Tried already EvalMapleStatement ("forget(F);") - do not work. I'm out of ideas what maple also caches. F itself is complicated enought. And not known a priori. How to clear all caches of other functions that f might call?
How to make maple to change ln(exp(x)) = x?  for example exp(ln(x)) = x, or ln(exp(x+1)) = x+1
How can I most succinctly and straightforwardly get Maple to simplify f below to g below?
> f:=(6*x^2-6*x+6)^(1/2)*(2*x^2-2*x+2)^(1/2);
                          (1/2)                 (1/2)
          /   2          \      /   2          \
          \6 x  - 6 x + 6/      \2 x  - 2 x + 2/
> g:=simplify(f) assuming x::real;
                        (1/2) / 2        \
                     2 3      \x  - x + 1/
> simplify(g-f...
First 1839 1840 1841 1842 1843 1844 1845 Last Page 1841 of 2457
