Is there a way to make the x, y and z axes thicker in 3d plots?
I want to do a Monte Carlo study with the following probability distribution:
P(X=x):=(x-1)*q^(x-2)*(p^2+(2*(1-p-q))*p)+binomial(x-1, x-3)*q^(x-3)*((1-p-q)^3+(1-p-q)^2*p);
with x = 2. 3, ... infinity and parameters p and q with 0 < p+q < 1. For the Monte Carlo study I ave to generate samples with specified values of p and q. For this I have yo do something similar to:
use Statistics in T:=[1/2,0,0,0,0,0,1/2];
d:=Distribution(ProbabilityTable(T));
Hello Everyone,
I am using Maple for printing out my calculations which already look good. I wonder if there is there a way to draw a box around some important resutls or equations, something like the "\boxed" command in LaTeX?
thanks.
Hi.
I would like some help with this. As so many others  i get this meassage "There were problems during the loading process. Your worksheet may be incomplete." when i treid to open my, almost done, Math assignment.
so i looked the problem op and found that i could retrive alot of my work by changing some lines of code. I could not find the problem.
Any help?
-JRR
ps. I realy realy realy hope you guys can help me!
By setting zeta_t:=`&zeta;&tilde;`: %; I can get ζ˜ as output.
However I don't find it satisfactory. I would like to have the tilde above the ζ without shift.
Thank you in advance for your suggestions.
I cannot make a worksheet function as it should in MapleNet 11. It contains a graph and a slider to adjust the graph. It looks fine, but when I try to read the value of the slider I get an error message "Error: ecslider17 not found". The worksheet works perfectly in "offline Maple".
Any suggestions how to fix this will be most welcome.
I have been running up against a memory limitation when running maple.java v15 from a Linux Ubuntu workstation.  The memory indicator in Maple gets up to 39.36M but will not go above that.  After I reach this limit I am still able to perform further computations but Maple gets slow and eventually crashes.  Here is one of the lines from the error message:
Exception in thread "AWT-EventQueue-0" java.lang.OutOfMemoryError: GC overhead limit exceeded
I have been using the DirectSearch package contributed by Dr. Sergey N. Moiseev.  It works very well for the problems I have been working on and would like to use it in Matlab.  Is anyone aware of a Matlab version, how I may convert this to a Matlab file, or call Maple from Malab?
I would like to write some functions and algebra that work with dual numbers.
http://en.wikipedia.org/wiki/Dual_number
http://en.wikipedia.org/wiki/Dual_quaternion
I have not found a library that supports this.
The basis of dual numbers it is epsilon^2=0, similar to i,j,k in complex algebra where i^2=-1,i*j=-1 etc.
somehow Maple does not integrate a procedure in the correct way. And I don't know why. Could you please help?
This procedure creates a matrix of a special form
P:=proc(n,k,A,d,Lambda)
local p,i,j,m,off,eps:
if n<6 then print("n greater 6"): return: end if:
if (n mod 4)<>2 then print("n has to be n (mod 4) = 2 "): return: end if:
eps:=proc(m,A,Lambda,k) (k+m*Lambda*2)^2+A/2 end proc:
hi
i have written the followin code that achieve Y from determinant of matric aa. but when i change digit my result changes. i dont know why?
> restart;
> with(LinearAlgebra);
> Digits := 100;
> NULL;
> upsilon := .38;
> rho := 0.122e4;
> l := 0.176e-4;
> h := 2*0.176e-4;
> L := 20*h;
> NULL;
> E := 0.144e10;
> lambda := E*upsilon/((1+upsilon)*(1-2*upsilon));
Hiim using maple 14 and tried to apply the sum of vector's elements, y appears a error (Error, unsupported type of index, n)
a := Vector(5, {(1) = 1, (2) = 2, (3) = 3, (4) = 4, (5) = 5});
> sum(a(n), n = 1 .. 5);
please need some help
Dear All Members;
In my research I faced with this problem and I appreciate if any of you specialists be able to help me in this issue. I brought the question here:
question.pdf
Please let me know that is it possible to finde this derivative of Bi-variate Normal distribution in Maple? If yes, could you please help me to do this?
Sincerely;
Hello all,
I have a system of linear equations that I need to solve. My problem is that the right hand side of the equations are numbers that are published in existing research and are thus rounded results. For example, say I have the following equation:
x + y = 0.133 and some others
What I want to do is find the range of my variables x and y such that, when the calculations are done, the result (rounded to 3 decimals) will equal...
hi
i write the following code
> restart;
nn:=2;
NB:=0.5;
Le:=2;
Pr:=2;
b:=13;
aa:=-0.2;
                              -0.2
for iu from 0 by 1 to 20 do
Nt:=aa+0.2;
sol := dsolve({diff(G(x), x, x)+Le*f(x)*(diff(G(x), x))+(Nt/NB)*diff(T(x), x, x...
First 1853 1854 1855 1856 1857 1858 1859 Last Page 1855 of 2457
