I would like to try the polynomial fit curve to the data points that I get below.  The data is for melting temperatures vs bond energy.
> with (Statistics):
> Temperatures := <801, 2800, 1410, 3551, -39, 660, 1538, 3410, -189, -101, -78, 0>:
> BondEnergy :=  <3.3, 5.2, 4.7, 7.4, .7, 3.4, 4.2, 8.8, 0.08, .32, .36, .52>:
> BondEnergyFit := Fit (a+b*t+c*t^2+d*t^3, Temperatures, BondEnergy, t)
Is there a way to find out what packages (i.e. statistics, or calculus, etc.) that are in my Maple installation? I bought a student version of Maple, now I need to use Statistics (with (Statistics): ) but don't really know If I have Statistics package installed or not. Thanks
I have tried to programme a bubble sort procedure below and i'm a bit stuck and not sure where i've gone wrong. Many thanks.
 bubblesort:=proc(C)
local n,o,r,k,i:
n:=rtable_dims(C):
o:=rhs(n):
r:=lhs(n):
for i from r to o - 1 do
if C[i] > C[i+1] then
(C[i], C[i+1] ) := (C[i+1], C[i]);
(C[i], C[i+1] ) := (C[i], C[i+1] );
fi:
return(C);
 C:=rtable(1..6,random(1..50));
bubblesort(C);
C:=[44 5 38 37 3 15]
[5 38 37 3 15 44]
Hola,
How to ensure that the coefficients are displayed in a more understandable?
Below, you will see a serie that I would like to obtain in Maple.  Any way I trie I am stick with Pi.  Any ideas?
Mario Lemelin
messagerie : mario.lemelin@cgocable.ca
téléphone :  (819) 376-0987
I am trying to plot a two variable expression in single 2D plot but have been unsuccessful.
I already have an equation in two variables that is obtained through a lengthy process of calculations:
DEQ = A*D + B*Ne, where A and B are constants, and D and Ne are variables.
I can easily plot a 3D graph of this, but I'd also like to plot what are essentially slices of the 3D graph onto a 2D graph. Actually to plot several slices on a single 2D graph.
I have tried to do the following but have been unsuccessful:
Below is my attempt at a cocktail sort, there are two lines of code missing as i am unsure as what to put there. I think the rest is correct.
Please check and see if you can spot what i need to include.
Hi Maple users,
I have a license for the Global Optimization Toolbox (GOT) 12 (i.e. for Maple 12). However, it seems it cannot be installed under Maple 13. As the GOT is essentially a frontend for an external library, I find this restriction a bit artificial and annoying. I don't see a reason why I should buy a new license for something that is practically the same that I already bought...!? Do I overlook something? Is there a simple way of installing the GOT 12 under Maple 13? Thanks for any hint!
quantum
Is anyone aware of Maple code intended to do some of the floating-point stress tests like are done in Kahan's paranoia code? (See here.)
I realize that modern Maple claims to comply with IEEE 854, 754, etc. But I like to check some things for myself. Call me paranoid. ;)
acer
How do I get a,b,c,d to the function a*b^x*c^y*d^z-x-2*y-3*z  get the minimum with {0<x<1,-1<y<1,-1<z<0}?
Thanks in advance !
I read a lot of guides, forums and etc, i've been trying to add/remove shiftenters and i've got always the same error. Every parenthesis is checked. Please tell me, where is the mistake?
I have problem with Inverse Fourier Transformation. I have an expression S, Maple can't calculate its Inverse Fourier Transform:
restart;with(inttrans);
S:=Heaviside(-w)*exp(-(9/640000000*I)*w)/w^2;
invfourier(S,w,t);
I have Maple 13.
Thanks for help in advance.
I have programmed a bisection procedure below, and i was just wondering how i would change this into a recursive version of the method. I don't really understand what is ment by recursive?
bisection:=proc(f,X,Y,Z)
local a,b,c,d;
a:=X:
b:=Y:
d:=Z:
while(abs(b-a)>d) do
c:=(a+b)/2:
if sign(f(c))=sign(f(a)) then a:=c else b:=c
fi:
print(evalf((a+b)/2)):
Many thanks!!!
convert Arg[I*Sinh[1 + I]]to Pi - ArcTan[Cot[Abs[Tanh[1 - I]]]]
arg(I*sinh(1+I))
arctan(cot(abs(tanh(1-I))))
First 2077 2078 2079 2080 2081 2082 2083 Last Page 2079 of 2457
