in maple 11, i have two problems with simplification of powers of "negative" variables.
problem i: A^(1/2) *A^2 <> A^(-3/2)*A^4
the two following expressions should be equal but differ by a minus sign:
f:=proc ()
local s;
s := time();
FileTools[Text][WriteString]('default', "a");
FileTools[Flush]('default');
while time() < s+20 do  end do
f();
In the codes above, I intended that the string "a" is outputed immediately after the function FileTools[Text][WriteString] is called.  But in execution, the output does not appear until 20 seconds elapse.
How can I force the output appear immediately?
hi im a new user to maple 12 and i am having some trouble evaluating limits.
The forum is on "How do I ...", and my question is
"How do I get MapleTA to be reliable in marking symbolic answers?"
It is OK at marking wrong answers wrong. The difficulty I'm having is that too many equivalent correct answers are also marked wrong.
The class sizes are around 500 students, and it is very tedious checking their grumbles about mismarking.
Examples:
I had an instance, using MapleSoft's IntroToCalcUnit1 questions, where
Hi i'm working on a simulation and have got stuck. The simulation is for cyclists cycling on a circular track. There is a section of track which is treacherous and all cyclists who pass through this point must observe a certain maximum speed until they have cleared this area and can continue round the track as fast as they can although keeping a safe distance behind the cyclist in front. It is assumed for simplicity that cyclists cannot overtake each other. These are my workings so far: >bicycle := (pl,sl,len) -> (pl+sl) mod len: > >vel:= proc(pl,len,vmax) > local n;
For the set of functions
   compiletable - create lookup table
   tablelook - perform table lookup
   insertpattern - append to lookup table
I observe these behaviors:
1. The function tablelook( ) only seems to work when the table has been been intiailized with compiletable( ).
2. The function insertpattern( )  nevers seems to work.
Hi...
I'm trying to write the following lines in a more "decent" way, but I don'tknow how to
I don't know how to start or what should I use, can someone give me a tip????
Thanks a lot!!
So today I'm trying to play around with matrix norm until I've come across this "bug" (I assume)... with(LinearAlgebra): r:=Matrix([2*x,x^2,x^3/3]); dr:=Matrix(map(diff, r, x)); MatrixNorm(r,2); MatrixNorm(dr,2); My question is that why does Maple spit out "x" and "xbar" while obviously, it should all be "x". And what's the command to make it just in terms of "x"
Hi I have been given an example of a iteration exercise for my course however with very little accompaning rescources to solve it. I have tried numerous methods and most vary around my most recent attempt but still to no avail. None of my fellow students and myself combined still can't manage to solve this. I was wondering if you could give some insight as to what we need to do differently from what we are currently.
The question is as follows:
I am trying to plot a 3d curve using the "plot3d" command.  When I type in this command along with a function and x,y bountries (x=-5..5,y=-5..5) the x and y axis do not range from -5 to 5.  How do you fix this?  Also, is it possible for the z axis to be scaled?
How do I fix this? i have to hand this assignment in by tuesday x_x. so far maple11 isn't giving me a decimal answer because it thinks e is also a variable. I was also having trouble trying to make composite functions but i found a little way around it so it isn't that much of a deal for me, however if you can point out my mistake to me and what i should have done instead, i will greatly appreciate it.
here's an image of my question+what i've done so far.
I am new to Maple and have some questions about the LPSolve function.
I have read the help about the function but still don't understand how it works.
I would like to use LPSolve to solve a matrix maximization problem.
Which is listed in the help as : LPSolve(c, [A, b], [bl, bu], maximize)
Can anyone give me an example of how this function is used and what math equation does it apply to?
Thank you for helping.
I have the expression 1 - mul( (365 -n)/365, n=1..2).
What I want is to run the command with values of n always starting from n=1 - but also get values for n=1..3, n=1..5, n=1..i where i < 366.
I would truly appreciate help in this - I'm sure it's simple, I just can't make it work :)
Best regards,
Troels
"Equate - convert a pair of rectangular objects into a list of equations" How can I do the opposite? e.g. converting [a=2, b=4, c=3] into [2,4,3]
Hello, I want to solve a DE in x(t) where the RHS of the equation is a random number that changes with time. For example: x''(t) + 10 x(t) = f(t) where f(1)=1, f(2)= 6, f(3)= -2...etc. I tried to use ran() but it solves it for a fixed random number, while I want it to be time dependent . Is there a way I can do that? Thanks
First 2229 2230 2231 2232 2233 2234 2235 Last Page 2231 of 2457
