Hello! I have the following PDE: PDE := { diff(alpha[1](u, v), u) = -I*exp(I*u)*beta[1](u, v), diff(alpha[1](u, v), v) = -I*exp(-I*v)*beta[2](u, v), diff(alpha[2](u, v), u) = I*exp(-I*u)*beta[2](u, v), diff(alpha[2](u, v), v) = -I*exp(I*v)*beta[1](u, v), diff(beta[1](u, v), u) = (1/8*(I*exp(-I*v)*alpha[2](u, v)+(2*I)*beta[1](u, v)+(2*I)*exp(-I*(v+u))*beta[2](u, v)))*(a-1)-(1/8*(-I*exp(-I*u)*alpha[1](u, v)-(2*I)*beta[1](u, v)+(2*I)*exp(-I*(v+u))*beta[2](u, v)))*b, diff(beta[1](u, v), v) = (1/8*(I*exp(-I*u)*alpha[1](u, v)+(2*I)*beta[1](u, v)-(2*I)*exp(-I*(v+u))*beta[2](u, v)))*(a-1)-(1/8*(I*exp(-I*v)*alpha[2](u, v)+(2*I)*beta[1](u, v)+(2*I)*exp(-I*(v+u))*beta[2](u, v)))*b,
How do I, with Maple, differentiate the following y = (x- 1)^2/x Curious
Hi I wish to thank all those who generously helped me with my last prob. Now I have another. These are mainly related to the use of Maple with the application in question. How do I use Maple to differentiate the following: A=pi.r^2. I am not doing homework. I can do it without MAPLE. However I want to master Maple. Never used it before. The answer I get with Maple is different to the one I get myself: 2pi.r Curious Please replace this text with the link to your file. The link can be found in the File Manager
The paper that Wayne Bell is using dates from 1962, so it’s not surprising that Professor Robert Israel found its format for elliptic integrals differs from those of Maple and Mathematika. Indeed, it differs from those of Professor LM Milne-Thompson (circa 1960) in A&S chapter 17. It belongs to an earlier era, though - according to an antique textbook of mine (circa 1930s) - the format would have been reversed, i.e. F(k,beta) and E(k,beta). It’s curious that Maple adopted a format, resembling but differing from that of A&S. Does anyone know the reason?
How do I format a variable with the superscript bar over the variable?
Fedderik van der Bos created a worksheet for the Finite Element Method that is available in the download section for engineering applications; problem is, it uses a maple package (FEM) that is not posted on the site. The application is dated 2000. Does anyone have a copy of this package?
Hi, I'm trying to do a piechart. the following code generates one alright but I have no idea how I can make the labels be outside instead of inside the piechart. any ideas?? with(Statistics); PieChart([England = 341, Spain = 237, Germany = 93, France = 91, Unknown = 56, Wales = 40, Ireland = 39, Sweden = 35, Russia = 31, Other = 244], color = orange .. green); thanks Antje
Does anyone know a way to get Maple to take advantage of the type of matrix you are giving it? I have a block toeplitz matrix and am using Maple to find the eigenvalues and eigenvectors. Thanks in advance :D
Hello, In Maxima integrate(5-(5-x)^2, x) gives... -x^3/3 + 5*x^2 - 20*x However, in Maple 11 int(5-(5-x)^2,x); gives 5*x + (1/3)*(5-x)^3 They're different by 125/3. Why is this? Ty
I am trying to plot an equation containing special functions - namely, elliptic integrals. The goal is to plot equation (16) of the attached file. Any suggestions/guidance is appreciated. View 4865_Equation_16.mw on MapleNet or Download 4865_Equation_16.mw
View file details Download 4865_Lo_p693.pdf
I was wondering if Maple can read an inputfile the way tecplot can, or at least plot a huge list of coordinates WITHOUT using the pointplot command (it will take me to long to put all of my coordinates in pointplot's correct input format). I have a list of about 5000 coordinates (x and y) and I want to see y vs x in a 2D graph. Any help is GREATLY appreciated Thanks.
Is there a way to choose the colours? If using it with 'implicitplot' on something like y - x it gives brute red and yellow ...
Hi, I have 2 columns A and B of random numbers each of length N drawn from the same distribution ( I am using a normal distribution but even an uniform distribution will do ). How do I check using Maple that the 2 dimensional random numbers generated as the 2-tuple {A[i],B[i]} (i=1 to sample size N ) are good quality random numbers.
Hello! I have a quasilinear first-order PDE system and Maple gives me only the trivial zero-solution after some seconds of computations. I know from theory that there are nontrivial solutions to the PDE, too. Can I get them somehow (from for example Maple)? This is the PDE: PDE := {diff(alpha[1](u, v), u) = -I*exp(I*u)*beta[1](u, v), diff(alpha[1](u, v), v) = -I*exp(-I*v)*beta[2](u, v), diff(alpha[2](u, v), u) = I*exp(-I*u)*beta[2](u, v), diff(beta[2](u, v), v) = 1/4*I*exp(I*u)*alpha[2](u, v)+1/2*I*exp(I*(v+u))*beta[1](u, v)+1/2*I*(beta[2])(u, v), diff(alpha[2](u, v), v) = -I*exp(I*v)*beta[1](u, v),
I'm having trouble performing what I had supposed was a simple calculation. I'm trying to calculate pairs of values that lie on the binodal (liquid-gas coexistence) curve of the van der Waals phase diagram. I have an equation, that I need to solve for the two variables vg, and vl, based on two constraints. Unfortunately, while the code I have written returns answers, they are wrong, and do not even satisfy the constraints. My code is below - I'd be exceptionally greatful if someone could point out what I am doing wrong, or suggest a better way. > kbd := 1: > bd := 0.5: > ad:=2:
First 2337 2338 2339 2340 2341 2342 2343 Last Page 2339 of 2457
