ut + 1/2(u^2)x −uxx =0, u(x,0)=x.
Your MaplePrimes post The package ODECSplines - Description was deleted by a moderator for the following reason: 3. If you believe this was done in error, please contact Maplesoft customer service: https://www.maplesoft.com/contact.
Does anyone know what is ment by reason 3. ?
"By clicking “Accept,” you agree to our website's cookie use as described in our Cookie Policy. You can change your cookie settings at any time by clicking “Preferences.”
Where is the "Preferences" button/check that I am supposed to click?  This is very irritating because each "Recent Questions" I click on to review, this banner pops up.
u'''-u=x+2 u'(0)=2, u''(0)=2
my answer is so different but  and i want remove this lambert in my test? can we do something for giving question exactly solve the question by model i have a book of ode which a lot of time i do some trail but have a problem? how i can remove this issue specially for bernoli and  other type?
with(DEtools, odeadvisor)
ode := diff(y(x), x)+x/y(x)+2 = 0
Student:-ODEs:-Type(ode)
odeadvisor(ode)
[[_homogeneous, `class A`], _rational, [_Abel, `2nd type`, `class A`]]
Student:-ODEs:-Type(ode); W := dsolve(ode); odetest(W, ode)
y(x) = -x*(LambertW(-c__1*x)+1)/LambertW(-c__1*x)
Download test.mw
I want both Pc and r(Pc) to be greater than or equal to zero. The only constraint is that all parameters for which I’ve provided data must remain positive. Can we identify the key parameters that significantly affect Pc? Also, what condition ensures that Pc ≥ 0? Ideally, I’d like Pc to be less than or equal to Pu. Could you suggest what changes in the numerical values I should make to ensure Pc becomes a positive value?
Attaching file: Q2.mw
Can we include a graph that shows how Pc changes with respect to variations in the most sensitive parameters?
With the new GUI:
I get all files (*.*) listed by default.
Other file types to filter are not listed.
Is this the same on other machines?
Can I do something about it?
I'm struggling to find the Undo botton, according to the help file they should reside under "View" menu - select Toolbar.
I can't find any "Toolbar" in the View menu.
How do I make indents in Maple 2025 for more readable layout?
Haven't used that much in 2024, but according to help this should be in Format - Tab settings. I don't find that in 2025 unfortunately.
I know of 3 ways to remove RootOf, but sometimes they give different result. How does one decide which to use? This is done in code. So method to decide can't depend on looking at the screen and see which result one "likes" more than the other.
Is allvalues() the one to use all the time? Could one of these 3 methods fail, and then one has to try the next one?
`The "Physics Updates" version in the MapleCloud is 1859 and is the same as the version installed in this computer, created 2025, April 6, 14:34 hours Pacific Time.`
e:=y*4^(1/3)*((4*x^2*RootOf(_Z^2*y - 4*_Z*x + y) - y^2*RootOf(_Z^2*y - 4*_Z*x + y) - x*y)/y^2)^(1/3) - _C2;
y*4^(1/3)*((4*x^2*RootOf(_Z^2*y-4*_Z*x+y)-y^2*RootOf(_Z^2*y-4*_Z*x+y)-x*y)/y^2)^(1/3)-_C2
convert(e,radical)
y*4^(1/3)*((4*x^2*(2*x+(4*x^2-y^2)^(1/2))/y-y*(2*x+(4*x^2-y^2)^(1/2))-x*y)/y^2)^(1/3)-_C2
DEtools:-remove_RootOf(e)
(1/16)*(c__2^3+4*x*y^2)^2/(y*(4*x^2-y^2)^2)-(c__2^3+4*x*y^2)*x/(y*(4*x^2-y^2))+y = 0
allvalues( e)
y*4^(1/3)*((4*x^2*(2*x+(4*x^2-y^2)^(1/2))/y-y*(2*x+(4*x^2-y^2)^(1/2))-x*y)/y^2)^(1/3)-c__2, y*4^(1/3)*((-4*x^2*(-2*x+(4*x^2-y^2)^(1/2))/y+y*(-2*x+(4*x^2-y^2)^(1/2))-x*y)/y^2)^(1/3)-c__2
Download removing_rootof_april_7_2025.mw
I am studying the Julia sets. I have tried the following two codes to generate Julia Sets. The first one I found in Maple Help, and the second one from http://ftp.informatik.rwth-aachen.de/maple/mfrjulfn.htm. I am wondering if there exists another code to generate the Julia set. My question is just for educational purposes, because those two codes work fine.
with(Fractals:-EscapeTime); with(ImageTools); bl, ur := -2.0-1.5*I, 2.0+1.5*I; c := -1; J := Julia(700, bl, ur, c, cutoff = 4, iterationlimit = 6000, output = layer1); Embed(J)
restart; julfn_zsqrd := proc (x, y) local c, z, m; c := evalf(0); z := evalf(x+I*y); for m from 0 to 50 while abs(z) < 2 do z := -z^2+z end do; m end proc; plot3d(0, -1.0 .. 2.0, -2.0 .. 2.0, style = patchnogrid, orientation = [-90, 0], grid = [250, 250], scaling = constrained, color = julfn_zsqrd)
Download Julia_Sets.mw
With the new Maple-2025 the GUI-fonts are tiny and more or less not readable on a 5K Monitor. The old solution using this options here:
JVM_OPTIONS="-Dsun.java2d.pmoffscreen=false -Djogamp.gluegen.UseTempJarCache=false -Dswing.plaf.metal.userFont=\"Tahoma-36\" -Dswing.plaf.metal.controlFont=\"Tahoma-36\" "
does not change the GUI fonts, as it has worked up to Maple 2024.
Is there a single-source fractional calculus toolbox, or collection of tools, available for Maple ? There appears to be the odd routine for fractional derivatives or DE's, but nothing of a systemic nature.
Is there a special command in Maple (whatever the version) which returns all functions available?
ex: ?*sol* which at least will return solve,dsolve etc.
Thank you and kind regards to everyone.
Jean-Michel
As I was numerically investigating this recent question I incidentally discovered a strange behaviour of Maple 2015 (which maybe exists in more recent versions?)
The attached worksheet presents an erratic behaviour (plus a remanance isssue because saving it, and opening it again changes the displays).
Note that this strange behaviour seems to occur only when tickmarks use the atomic name `#mo("2")`.
display_issue.mw
Here is a pdf print of this same worksheet: as I hope you will see (because I don't know what you are about to see when opening the attached worksheet) its content differs from the worksheet's.
display_issue.pdf
Here are 3 screen captures which show what MY worksheet looks like
PAGE 1
PAGE 2
There is a typo in the comment below: read "void" instead of "coid", sorry for the mistake.
PAGE 3
Is this a Maple 2015 issue which has been fixed in earlier versions?
Is there a way to fix these issues?
First 23 24 25 26 27 28 29 Last Page 25 of 2429
