In the following example, the information in which range fsolve should search for a solution and the range in which a function is defined is somehow redundant. (This example has been adopted from here where fsolve without assumptions does not throw an error but evaluates forever.)
Why can’t fsolve not always assume that the range equals the domain of interest? This would make life easier and provide more solutions to inexperienced users who have not yet learned the need for assumptions.
If there are good reasons (and there probably are) that such an implicit assumption (i.e. range equals domain) would be too restrictive: can’t fsolve give a hint or provide an new option to use ranges as assumptions?
Example with incomplete elliptic integral of the first kind
f := proc (x__0) options operator, arrow; int(1/(sqrt(x__0-x)*sqrt(-x^2+1)), x = 0 .. x__0) end proc
Range := 0 .. 1; plot(f(x__0), x__0 = Range, labels = [x__0, 'f(x__0)'])
f(.5) = 1.524886838NULL
Defining the inverse of f
g := proc (y) options operator, arrow; fsolve(`assuming`([f(x__0) = y, x__0 = Range], [lhs(Range) <= x__0 and x__0 <= rhs(Range)])) end proc
x__0 = g(f(.5)) → x__0 = .5000000000NULL
Now without assumptions
h := proc (y) options operator, arrow; fsolve(f(x__0) = y, x__0 = Range) end proc
h(f(.5))
Error, (in fsolve) cannot determine if this expression is true or false: abs(Re(x))+abs(Im(x)) <= 0.
Download ranges_as_assumptions.mw
I am trying to obtain the solution of the differential equation f'''+ff''-f'^2-Mf'=0, with f(0)=0, f'(0)=1, and f'(5)=0 with M=0.5 using finite element method
But got this error. I attached the file also.
M := .5;
.5
a := 0;
b := 5;
5
N := 50;
50
h := (b-a)/N;
1/10
nodes := [seq(h*i+a, i = 0 .. N)];
[0, 1/10, 1/5, 3/10, 2/5, 1/2, 3/5, 7/10, 4/5, 9/10, 1, 11/10, 6/5, 13/10, 7/5, 3/2, 8/5, 17/10, 9/5, 19/10, 2, 21/10, 11/5, 23/10, 12/5, 5/2, 13/5, 27/10, 14/5, 29/10, 3, 31/10, 16/5, 33/10, 17/5, 7/2, 18/5, 37/10, 19/5, 39/10, 4, 41/10, 21/5, 43/10, 22/5, 9/2, 23/5, 47/10, 24/5, 49/10, 5]
elements := [seq([i, i+1], i = 0 .. N-1)];
[[0, 1], [1, 2], [2, 3], [3, 4], [4, 5], [5, 6], [6, 7], [7, 8], [8, 9], [9, 10], [10, 11], [11, 12], [12, 13], [13, 14], [14, 15], [15, 16], [16, 17], [17, 18], [18, 19], [19, 20], [20, 21], [21, 22], [22, 23], [23, 24], [24, 25], [25, 26], [26, 27], [27, 28], [28, 29], [29, 30], [30, 31], [31, 32], [32, 33], [33, 34], [34, 35], [35, 36], [36, 37], [37, 38], [38, 39], [39, 40], [40, 41], [41, 42], [42, 43], [43, 44], [44, 45], [45, 46], [46, 47], [47, 48], [48, 49], [49, 50]]
bilinear := proc (u, v, w) options operator, arrow; int(diff(u(x), `$`(x, 3))+u(x)*(diff(u(x), `$`(x, 2)))-(diff(u(x), x))^2-M*u(x)*(diff(u(x), x)), x = w[1] .. w[2])+int((diff(u(x), x))*(diff(v(x), x)), x = w[1] .. w[2]) end proc;
Llinear := proc (v, w) options operator, arrow; v(a)*(diff(w(x), x)) end proc, x = a;
proc (v, w) options operator, arrow; v(a)*(diff(w(x), x)) end proc, x = 0
K := CreateMatrix(N+1, N+1, 0);
CreateMatrix(51, 51, 0)
F := CreateVector(N+1, 0);
CreateVector(51, 0)
for e in elements do x1 := nodes[e[1]]; x2 := nodes[e[2]]; h := x2-x1; Ke := bilinear(proc (x) options operator, arrow; piecewise(x < x1+(1/2)*h, 1-(x-x1)/h, (x2-x)/h) end proc, proc (x) options operator, arrow; piecewise(x < x1+(1/2)*h, (x-x1)/h, (x2-x)/h) end proc, [x1, x2]); Fe := Llinear(proc (v) options operator, arrow; v(x)*piecewise(x = x1, 1, x <> x1) end proc, [x1, x2]); for i in [e[1], e[2]] do for j in [e[1], e[2]] do K[i, j] := K[i, j]+Ke[i-e[1]+1, j-e[1]+1] end do; F[i] := F[i]+Fe[i-e[1]+1] end do end do
K[1, 1] := 1;
K[N+1, N+1] := 1;
u := LinearSolve(K, F)
Error, (in LinearAlgebra:-LinearSolve) invalid input: LinearAlgebra:-LinearSolve expects its 1st argument, A, to be of type {Matrix, list({Matrix, Vector})} but received K
f := unapply(u(x), x);
proc (x) options operator, arrow; u(x) end proc
Download FEM.mw
Given a graph G and a vertex v find the shortest self returning walk from that visits all vertices starts at v and comes back to v.
In the below graph the shortest self returning walk which visits all vertices and comes back to first to started vertex
A function which takes a graph G  and  vertex v as input and returns the length of the  shortest self returning walk of that vertex in the below example 10
I am sorry for the error i just saw the change after reading more in deep
For the vertex 7 the shortest self returning walk from that visits all vertices starts at 7 and comes back to 7 It is a walk so edges can repeat
The closed walk which passes through all vertices minimum from vertex 7 is so length 10. is what it means
so it returns 10.
A function which takes a matrix as input and k the number of places to round to Given a matrix
Matrix(17, 17, [[0, 1.67136411, 3.04642520, 3.03792037, 4.46305818, 4.48953189, 11.44947182, 11.44363094, 5.99694026, 10.05030814, 10.04436470, 12.86806872, 12.86675621, 8.65792026, 11.48220112, 11.47942388, 10.13243670], [1.67136411, 0, 1.37506109, 1.36655626, 2.79169407, 2.81816777, 9.77810770, 9.77226682, 4.32557615, 8.37894403, 8.37300059, 11.19670460, 11.19539209, 6.98655615, 9.81083701, 9.80805976, 8.46107258], [3.04642520, 1.37506109, 0, 2.74161735, 1.41663298, 4.19322886, 8.40304661, 8.39720573, 5.70063724, 7.00388294, 6.99793950, 12.57176570, 12.57045318, 5.61149506, 11.18589810, 11.18312085, 9.83613367], [3.03792037, 1.36655626, 2.74161735, 0, 4.15825033, 1.45161152, 11.14466396, 11.13882308, 2.95901989, 9.74550028, 9.73955684, 9.83014835, 9.82883584, 8.35311240, 8.44428075, 8.44150350, 7.09451633], [4.46305818, 2.79169407, 1.41663298, 4.15825033, 0, 5.60986184, 6.98641363, 6.98057275, 7.11727022, 5.58724996, 5.58130652, 13.98839867, 13.98708616, 4.19486208, 12.60253107, 12.59975383, 11.25276665], [4.48953189, 2.81816777, 4.19322886, 1.45161152, 5.60986184, 0, 12.59627548, 12.59043460, 1.50740837, 11.19711180, 11.19116836, 8.37853683, 8.37722432, 9.80472392, 6.99266923, 6.98989199, 5.64290481], [11.44947182, 9.77810770, 8.40304661, 11.14466396, 6.98641363, 12.59627548, 0, 5.58361857, 14.10368385, 6.98420414, 4.19901549, 20.97481231, 20.97349980, 5.59181627, 19.58894471, 19.58616747, 18.23918029], [11.44363094, 9.77226682, 8.39720573, 11.13882308, 6.98057275, 12.59043460, 5.58361857, 0, 14.09784297, 4.19891293, 6.98410159, 20.96897143, 20.96765892, 5.59130081, 19.58310383, 19.58032659, 18.23333941], [5.99694026, 4.32557615, 5.70063724, 2.95901989, 7.11727022, 1.50740837, 14.10368385, 14.09784298, 0, 12.70452017, 12.69857674, 6.87112846, 6.86981595, 11.31213229, 5.48526086, 5.48248361, 4.13549644], [10.05030814, 8.37894403, 7.00388294, 9.74550028, 5.58724996, 11.19711180, 6.98420414, 4.19891293, 12.70452017, 0, 5.59817917, 19.57564863, 19.57433612, 6.99097994, 18.18978103, 18.18700379, 16.84001661], [10.04436470, 8.37300059, 6.99793950, 9.73955684, 5.58130652, 11.19116836, 4.19901549, 6.98410159, 12.69857673, 5.59817917, 0, 19.56970519, 19.56839268, 6.99056705, 18.18383759, 18.18106035, 16.83407317], [12.86806871, 11.19670460, 12.57176569, 9.83014835, 13.98839867, 8.37853683, 20.97481232, 20.96897144, 6.87112846, 19.57564864, 19.56970520, 0, 5.47162962, 18.18326076, 6.88344719, 4.18501750, 5.53368276], [12.86675620, 11.19539209, 12.57045318, 9.82883584, 13.98708616, 8.37722432, 20.97349980, 20.96765892, 6.86981595, 19.57433612, 19.56839268, 5.47162962, 0, 18.18194824, 4.18355276, 6.88198245, 5.53331719], [8.65792026, 6.98655615, 5.61149506, 8.35311240, 4.19486208, 9.80472392, 5.59181627, 5.59130081, 11.31213229, 6.99097994, 6.99056705, 18.18326075, 18.18194824, 0, 16.79739315, 16.79461591, 15.44762873], [11.48220112, 9.81083701, 11.18589810, 8.44428075, 12.60253108, 6.99266923, 19.58894472, 19.58310384, 5.48526086, 18.18978104, 18.18383760, 6.88344719, 4.18355276, 16.79739316, 0, 5.57088509, 6.91955036], [11.47942387, 9.80805976, 11.18312085, 8.44150350, 12.59975383, 6.98989199, 19.58616748, 19.58032660, 5.48248361, 18.18700380, 18.18106036, 4.18501750, 6.88198245, 16.79461592, 5.57088509, 0, 6.92064952], [10.13243670, 8.46107258, 9.83613367, 7.09451633, 11.25276665, 5.64290481, 18.23918030, 18.23333942, 4.13549644, 16.84001662, 16.83407318, 5.53368276, 5.53331719, 15.44762874, 6.91955036, 6.92064952, 0]])
Convert all the digits in the matrix to k decimal places where k I can specify After converting to decimal places it should not show zero's at the end of the decimal places. Kind help
[sqrt(-3)^1, sqrt(-3)^7];
map(indets, %, radnumext),
map(indets, %, radext),
map(indets, %, radical);
Is this going to be fixed/removed?
Please check the following examples, first without using Units, and the second using it:
No Units:
With Units:
Why does the with(Units) doesn't compute the value? How can I make it work?
Can I force the output of maple to follow a specific width?
For example, I want the output to go to a new line after 10 characters of output
So instead of
seq(i,i=1..20)
I want the output as
1,2,3,4,5,/
6,7,8,9,10/
,11,12,13,/
14,15,16,1/
7,18,19,20
I am trying make atomic variables stand out in the document, I thought they used to automatically change to a purple type colour.
So under Format, styles , I set the style to size 14, Bold, dark green.  The font changed on the existing ones but not the colour.
On new ones no setting occours just default text. I then restored to default settings under styles and they all turned purple including the new ones.
Then I made another one but no adoption of the default style (purple) occured.
This fiddlyness needs to be improved
Has anyone any suggestions to make the atomic variables adope their default colour etc?
in phase portrait 3d , i use 4 initial condition, How  can I draw each initial condition in diferent colour. it very helpfull so i can see the moving of each IC. Thank you
Hello! I've been trying to solve system of non-linear differential equations. The equations are quite messy, so I've attached the file itself dsolve.mw. I have read about the similar problems, but they all are related to some expressions having multiple branches. I'm not quite sure where this problem occurs (if it does) here and how to solve it.
For example if we have : a*b+c*(d+e)+f+g+h*(k*p+l):
is there a way to write a loop or script so it could give me: [a*b,c*(d+e),f,g,h*(k*p+l)]:
hi Maplers
I want to solve the following differential equation numerically. but i get error
eqn := (diff(H(K),K))^3+4*K^4*H(K)^4*diff(H(K),K)+8*K^4*H(K)^5=0;
ics := H(0)=1/2;
sol := dsolve({eqn,ics},numeric);
Error, (in DEtools/convertsys) unable to convert to an explicit first-order system
Dear Friends
On 22 March 2018, I received:
ORDER REFERENCE INFORMATION
Customer: Universidad Nacional Autonoma De Mexico, UNAM
Order Date: 3/21/2018
Order Number: 889668
Customer Purchase Order: 10972
For instaling MAPLE 18
Please see the at bottom of the mail
I am trying to reinstall MAPLE 18. Unfortunately the download link
It's no longer available. Please send me a link to download Version MAPLE 18. Thank you very much for your time and consideration.
Best Regards
Oscar Jaramillo-Salgado
El 22 mar 2018, a las 11:05, license@maplesoft.com escribió:
Dear Oscar Jaramillo Salgado,
Here is your copy of Maple 2018. And this is not a release to ignore!
People use Maple to do many different things, so it’s inevitable that each new release will include some features you care about and some features you really don’t need. However, Maple 2018 contains a large number of substantial enhancements to how you interact with Maple, which means you’ll benefit from this release no matter what you use Maple for.
You are receiving this email because you are a member of the Maplesoft Elite Maintenance Program (EMP). While you participate in this program, you are entitled to new product releases as they come out.
If you are a MapleSim user, note that, unlike in previous years, this email contains only your Maple entitlement information. If you are still an active EMP member when MapleSim is released, we will send your MapleSim information to you at that time.
How to retrieve your Entitlement
The purchase code(s) required to activate your product(s) are included below in addition to download link(s) to access the installation files.
If you would like a physical copy of your product(s) shipped to you, please go to http://www.maplesoft.com/entitlements. You will need the email address that this email was sent to along with the order number.
Downloads:
Maple 2018: http://www.maplesoft.com/downloads/?d=3818426C1C82FED050562AB71F77C087&pr=Maple2018
Product: Maple2018 Single User Entitlement Download for 1 user(s) (includes 1 home use license(s))
The following Purchase Codes activate this product:
[Purchase code deleted]
For the Maplesoft terms and conditions that govern your license to the above noted products, please refer to the Maplesoft End User License Agreement (EULA) found during installation. The Maplesoft EULA can also be found online at http://www.maplesoft.com/documentation_center/Maplesoft_EULA.pdf . You should review the entire Maplesoft EULA prior to activating your products.
SUPPORT
It is important that you follow the installation instructions contained with each product. If you experience any problems during installation, please visit the Maplesoft online technical support center at http://www.maplesoft.com/support.
For more information on activation, refer to the FAQ page at: http://www.maplesoft.com/support/FAQs/Activation.
For further assistance, please contact the Maplesoft Customer Support Department via the online form located at http://www.maplesoft.com/support/supportforms.aspx. For customers outside the USA and Canada, please contact the local office or Maplesoft reseller for your region. Visit http://www.maplesoft.com/contact for contact information.
Please refer to your order number (889668) in any correspondence to customer service.
Kind Regards,
Maplesoft Customer Service
© Maplesoft, a division of Waterloo Maple, Inc., 615 Kumpf Drive, Waterloo, ON, Canada, N2V 1K8, customerservice@maplesoft.com. To opt out of all commercial email communications from Maplesoft, please click here.
I'm learning about simplifications in Maple and I'm trying to make it simplify simple trigonometric expressions like sin(x) / cos(x) to tan(x), but it doesn't.
I tried the commands simplify(sin(x) / cos(x)), simplify(sin(x) / cos(x), trig) and nothing works. It still returns:
simplify(sin(x)/cos(x), trig)
I managed to make it work using convert(sin(x)/cos(x), tan):
BUT it creates more problems than it solves, because if I have something like sin(x)/cos(x)*sin(x), I would like it to simplify as tan(x)*cos(x), but instead it converts everything to tan and I get a much more complicated expression:
convert(sin(x)/cos(x)*sin(x), tan)
Can someone help me please?
Why did the last line is(ysol2[1]>0) give false?
Maple does not recognize the assumption?
interface(showassumed=0);
assume(theta>1,alpha>0,sigma1>0,beta>0,sigma2>0,delta>0,x>0,y>0,z>0);
f:=((theta*x-1)*(1-x)-y);
g:=y/(1+beta*y^2);
h:=(alpha*x-sigma1)*(1+beta*y^2);
j:=(delta*g-sigma2);
dxdt:=x*f;
dydt:=g*(h-z);
dzdt:=z*j;
(theta*x-1)*(1-x)-y
y/(beta*y^2+1)
(alpha*x-sigma1)*(beta*y^2+1)
delta*y/(beta*y^2+1)-sigma2
x*((theta*x-1)*(1-x)-y)
y*((alpha*x-sigma1)*(beta*y^2+1)-z)/(beta*y^2+1)
z*(delta*y/(beta*y^2+1)-sigma2)
case0; x = 0, y = 0, z = 0
E0:=<0,0,0>;
Vector[column](%id = 36893490685786064044)
"case1: z=0 ,  h(x,y)=0,  f(x,y)=0 :   From y=(theta*x-1)*(1-x)=y -> 1/(theta)<x and x<1"
xsol1:=solve(h=0,x) assuming x>1/theta and x<1;
ysol1:=solve(subs(x=xsol1,f)=0,y)assuming xsol1>1/theta and xsol1<1;
E1:=<xsol1,ysol1,0>;
xsol1 := sigma1/alpha
ysol1 := -(-sigma1*theta+alpha)*(alpha-sigma1)/alpha^2
Vector[column](%id = 36893490685786055012)
case2; g(y) = 0, h(x, y) = 0
ysol:=[solve(j=0,y)];
ysol2:=simplify(subs(sigma2=delta*eta,ysol)) assuming (1-4*beta*eta^2>0 and eta>0);
Warning, solve may be ignoring assumptions on the input variables.
[(1/2)*(delta+(-4*beta*sigma2^2+delta^2)^(1/2))/(beta*sigma2), -(1/2)*(-delta+(-4*beta*sigma2^2+delta^2)^(1/2))/(beta*sigma2)]
[(1/2)*(1+(-4*beta*eta^2+1)^(1/2))/(beta*eta), (1/2)*(1-(-4*beta*eta^2+1)^(1/2))/(beta*eta)]
is(ysol2[1]>0)
Download Project_v1.mw
First 250 251 252 253 254 255 256 Last Page 252 of 2457
