Hello everyone!
I am struggling to figure out the cause of the problem with Explore command. To put it as simple as possible:
 a := <3, 4, 5>
Explore(a[i], i = 1 .. 3);
Error, (in Explore) bad index into Vector
I am pretty sure that this has to do with an attempt to evaluate A[i] with i not yet defined, but why does Explore behave this way? seq has no such problem:
seq(a[i], i = 1 .. 3);
3, 4, 5
But as soon as I put it into Explore, seq seems to forget all its "special evaluation rules":
Explore(seq(a[i], i = 1 .. 3), b = 1 .. 2);
It is probably for the same reason that I can't solve the problem with unevaluation quotes such as:
Explore('a[i]', i = 1 .. 3);
What am I doing wrong??
How to find characterstics for the PDE  yzp+2xq=xy  using maple.....plz help me
I am trying to  solve the system of equations
with(RealDomain);
solve(x^2+y^2+z^2-4*x+6*y-2*z-11 = 0, 2*x+2*y-z = -18], [x, y, z]);
I didn't get the result x = - 4/3, y = -19/3, z = 8/3.
How can I get the solution?
With Mathematica, I tried
Solve[{x^2 + y^2 + z^2 - 4*x + 6*y - 2*z - 11 == 0,
  2*x + 2*y - z == -18}, {x, y, z}, Reals]
And got the correct solution.
How to plot the solution of pde
pde:=diff(u(x,t),t) =K*diff(u(x,t),x, x);
I can't step further,  i can't insert boundary value problem, plz help me to solve pde.
Hear u(x,t)->infinity  when t->infinity  and diff(u(x,t),x) =0 when x=0 for all t
Please ignore my mistake,
If I have a procedure that for example produces a list of times it takes to work out the eigenvectors of a random nxn matrix from n=2..9.
Times:=[seq([n,time(LinearAlgebra[Eigenvectors](RandomMatrix(n)))],n=2..9)]:
If I want to make my data more accurate so that it works out the time it takes to find the eigenvector for each different sized matrix multiple times and then takes an average time (for each n), how would I do that?
Hi I'm trying to make a procedure that will multiply all the diagonal entries of any random matrix together, this is what I have tried so far:
with(ListTools):
Diag := proc(A)
local aux,V,i,n;
V:=[];
n:=RowDimension(A):
for i from 1 to n do
aux := 1;
aux := aux*U2(i,i);
but this just produces the last diagoinal entry of the matrix - how do I make the loop multiply the previous number by the next diagonal entry?
another option I've done is to make a list of the diagonal entries, but then I encounter the same problem with multiplication:
Diag:=proc(A)
local n, List;
n:=RowDimension(A);
List:=[seq(A(i,i),i=1..n)]:
any help would be greatly appreciated!
I need to convert a maple code into a clickable user interface one. How to do it?. Thank you.
Hi, I've created an array from a do loop, where the number in the array is the number of degrees for which I've calculated the answer, I now wish to graph the angle against the value in the array. i.e. the value a[50]=156.21 should graph to the point (50,156.21). Ideally as well I'd like for it to be joined up by a smooth curve of best fit, but I'll take what I can get, I can't seem to figure out how to plot it at all at the moment.
See code below:
for i from 50 by 5 to 85 do
ThetaBn := (1/180)*i*Pi;
s := cos(2*ThetaBn)*x+(2*sin(ThetaBn)*sin(ThetaBn))*sin(x);
a[i] := 180.0*fsolve(s = 0, x, 1 .. 6)*(1/Pi)
wordwheel.mws
The program below works fine, but comes up with an error message: wrong number (or type) of parameters in function $.  I'm confused as the Maple 7 Help on 'convert, bytes' the $ symbol is omitted.  The program works fine: it is just a little disconcerting, as this is just the start of a general Wordwheel program.
   The error seems to be related to the textplot command - but why?
# Wordwheel program - intended to be general
with(plottools):
#Number of letters, including the ? sign
nolett:=7:
#Angle of arc for each letter
ang:=2*Pi/nolett:
R:=5:
# Draw the circle
c:=circle([0,0], R, color=black):
#Draw the lines
for
i from 0 to nolett-1 do
  lin[i] := line([0,0], [R*cos(i*ang),R*sin(i*ang)], color=black,   linestyle=1):
end do:  #i
#Upper & lower case alphabets
#s_L := convert( [$97..122], 'bytes' ):   #a - z
s_U := convert( [$65..95], 'bytes' ):   #A-Z
#s_L[25];
tp1:=textplot([1,2,s_U[6]],align={ABOVE,RIGHT}):
plots[display](c,tp1, seq(lin[i], i=0..nolett-1), scaling=constrained, axes=none);
Warning, the name arrow has been redefined
Error, wrong number (or type) of parameters in function $
Download wordwheel.mws
E := proc (n::posint)
local L, x, y, z, p;
p := n; L := NULL;
assume(x::nonnegint, y::nonnegint, z::nonnegint);
assume(x <= y and y < =z);
for x from 1 to irem(p, 2) do
for y from x to irem(p, 2) do
for z from y to irem(p, 2) do
if x+y+z = p then L := L, [x, y, z] end if
end do
end do
return L end proc:
This procedure don't work. I would like E(9)={(1,4,4),(2,3,4),(3,3,3)} then E(2019), E(2022). Thank you.
Is this documenation wrong?
https://www.maplesoft.com/support/help/maple/view.aspx?path=Database%2fSQLite%2fFetchRow
It says that calling sequence is
     FetchRow( statement, column, valuetype  )
But below it only shows
statement
prepared statement obtained using Prepare command
valuetype
type of the output data, default is "auto"
With no column anywhere.  And none of examples show column in them.
And when I tried it by adding a column name that I know exist in my sqlite3 database, Maple gave an error that no such parameter allowed.
Does FetchRow support column name or is the above just a documenation error?
Maple 2019
Hello everyone!
Does anyone know if it is possible define a metric like the metric below?
Thanks in advance!
I would like to understand why the 'solve' command is unable to find any solution to the system of equation { x^2=2, x^3=2*sqrt(2) }  (which obviously has a unique solution x=sqrt(2) ). The syntax that I used is
> solve({x^2 = 2, x^3 = sqrt(2)^3}, [x]);
and the output is the empty list.
I suspect that this is related to the presence of the algebraic number sqrt(2). Does anyone have a better understanding ?
I am using Maple version 2018.0, build ID 1298750.
hi
how can i write the tittle on the plot exampe below pic
inequal({sqrt((1/2)*x) < y and sqrt(Pi/(2*x)) < y and y < sqrt(x) and y < sqrt(Pi/x)}, x = 1 .. 3, y = 0 .. 2);
I discovered incidentally that the command  Matrix(3, 3, `-`) (the number 3 is purely illustrative) returned the same result than the command Matrix(3, 3, (i,j) -> i-j).
In the same way `+` realizes (i,j) -> i+j), `*` realizes (i,j) -> i*j), ...
More surprisingly `.` realizes (i,j) -> i*j while I'm in worksheet mode, with "old" maple input style, and that the command 2.3 does not answer 6 but concatenates 2 and 3.
Is this a known behaviour or an undocumented feature?
First 738 739 740 741 742 743 744 Last Page 740 of 2459
