I am interested in plot the so-called "free space diagram", please see https://en.wikipedia.org/wiki/Fr%C3%A9chet_distance for a formal definition. Essentially, given two curves (i.e., two polygonal from [0,1] to the plane) the "free space" is the points (s,t) in the square [0,1]x[0,1] such that the distance from P(s) to Q(t) (if P and Q are the parametrizations of the curves) is less or equal than a prefixed epsilon>0. An image can be the following (the free space is, in the image, the area not colored in black):
I have found nothing about this topic in Maple, any suggestion will be welcome!
Hello guys
I have a simple but crucial question about variation, especially in cosmology and gravity. suppose we have the action such as
S=int(sqrt(-g)*F(R,RµναβRµναβ),d^4x) where g is determinant metric gµν and d^4x is space in 4D and F is an arbitrary function of R (Ricci scalar) and scalar which created by Riemann tensor. How we can define this action in the maple 18 and take variation with respect to the metric.
how to write in mape
if x not real set x =b
Is there a place to read about rules for naming constants of integrations for solution of ODE so that Maple odetest will not have problem verifying solution of an ODE?
It seems Maple does not like some constant names. If I use C or C1 or C[1] or A etc... odetest does not give back zero, even thought the solution is exactly the same as Maple's, except Maple uses _C1.
I read one is not supposed to use _ constants in own code, since these are reserved for Maple.
So what is one supposed to use? Here is an example
ode:=2*sqrt(x)*diff(y(x),x)=sqrt(1-y(x)^2):
my_sol:=y(x)=sin(sqrt(x)+(1/2)*C1);
Compare to Maple own solution
maple_sol:=dsolve(ode,y(x));
You can see, there is no difference, except the name of the constant.  Yet, Maple does not odetest my solution
odetest(my_sol,ode);
I tried naming my constant to C, C[1], A, Z, etc.. I got tired trying. Only when I use _C1 does Maple give zero for odetest.
What is so special about _C1?  And if one can't use _ symbols as Maple says, what is one to to do?
Maple 2018.1, Physics version `2018, July 21, 4:16 hours, version in the MapleCloud: 78, version installed in this computer: 78`
Both the equation defining a PDE and its boundary conditions involve functions that are the result of the numerical resolution process of an ODE system.
The PDE solution is obtained. However, when I want to calculate the value of the solution at some point the following error message is displayed: "Error, (in solnproc) unable to compute solution for t>HFloat(1.8936825887327868e15): unable to store HFloat(undefined)+HFloat(undefined)*I when datatype=float[8]".
I tried to formulate the problem differently. However, the error appeared again.
Where am I going wrong?
I've attached the PDE.mw file to the conference.
Thank you for your help.
I would like to do the following operation:
Apparently, Maple does not do this operation.
Does anyone know how to do this?
When 3d-Plotting a function say f(z)=sqrt(z)=sqrt(x+I*y) then Maple automatically only plots the principal branch.
In the example above is it possible to plot the second surface too?
Is it also possible to plot the full continuous Riemann surface as in
https://en.wikipedia.org/wiki/Riemann_surface#/media/File:Riemann_sqrt.svg
or
http://mathworld.wolfram.com/RiemannSurface.html
From answer posted in https://www.mapleprimes.com/questions/225137-Internal-Symbol-Z1--Causes-Error-
I've learned to use
subsindets(expr, 'suffixed(_)', f->n);
To replace in a Maple generated solution which contains system suffix, such as _Z, _Z1, etc... returned by Solve and Maple calls, with a symbol that I find easier to read. The above works in some cases but not others. For example, it works on this result
expr:=signum(0, _Z, 1);
                      signum(0, n, 1)
But not on this one
expr:=RootOf(signum(0, _Z, 1));
I do not want to use pattern matching, since the result is something I do not know what it will be. I just want to replace all those Maple symbols that start with _Z in the solution by another symbol. I can't use subs() either, since I do not know what the symbol will be.
What is the correct way to do this?
Should this generate an error?
r:=evalc(Im(1/ln(x)));
solve(r,{x});
This did not help. Same error as above.
r:=evalc(Im(1/ln(x))):
solve(r,{x}) assuming x::real;
This made Maple not give an error
solve(r,{x}) assuming x::real, x>0;
       {x = x}
Also this worked, but NULL returned
solve(r,{x}) assuming x::real, x<0;
Also this worked with NULL returned
solve(r,{x}) assuming   x<0;
Is this how Maple generally works? i.e It generates an exception error when it is not able to solve something? Or does it normally echo back the input back if it can't solve something? Or at least return NULL if it can't solve it? I am havin hard time figuring which method to use to check if Maple is able to solve something or not, because each time it seems to do something different.
Should one then put a try/catch around each Maple call, and treat the try section as if Maple was not able to solve the equation whatever it was?
Essentially I have this trigonometric equation and I want to solve (get the roots of) it within the range -Pi..Pi:
v := a+b*cos(t)-c*(d*(1-(a+b*cos(t))^2-d^2*sin(t)^2)^(1/2)+e*sin(t)) = 0;
v1 := t > -Pi;
v2 := t < Pi;
Where t is the variable and a..e are constants.  At the moment I am trying the following:
solve({v, v1,v2}, t, allsolutions, explicit);
My problem is that Maple tries to solve this - I get Evaluating in the bottom left corner of the window - but never seems to return with a solution even after using 52,000s and 5GB of memory: I am using a late model macbook.
Can anyone see a way of re-framing this equation so that Maple can return an answer?
Is it possible to solve numerically a PDE, where the IBC is a function resulting from the numerical resolution of an ODE?
hi,
I want to setup quantum mechanical angular momentum operators and kets such that i can do something like:
Lz[2] . Ket(??, j, m) -> m hbar        (instead of getting m as eigenvalue)
L^2[1] . Ket(??, j, m) -> j (j+1) hbar^2           (instead of getting j)
where L and Lz are quantum operators.
maybe if i knew how to do
QuantumOp . Ket{QuantumOp, j) -> j (j+1)
i could do it with explicit tensor products of Kets - one for j, one for m?
can somebody give me an idea of how to do this, or point me at an example?
many thanks,
larry
The following product gives 0
product(1-1/k, k = 2 .. infinity);
However when I expand the product
1 - 1/2 - 1/3 - 1/4 - ... + 1/2*1/3 + 1/2*1/4 + ... + 1/3*1/4 + ... + triple products + quadruple products + and so forth...
Now the double, triple, quadruple, and so forth sums of products converge.
The 1/2 + 1/3 + 1/4 + ... nevertheless diverges, so why does maple give me 0?
I am really desperate right now and I need help or advice.
I don't understand why dsolve doesn't work for my example. He doesn't get anything out....
de := sin(1)*(diff(y(x), x$2))+(1+cos(1)*x^2)*y(x) = -1:
cond := y(-1) = 0, y(1) = 0:
dsolve({cond, de}, y(x))
Really hope for your help.
First 823 824 825 826 827 828 829 Last Page 825 of 2459
