salute ! all Maplesoft managers and employee programers ...
Is there any fortune in near future to have some kind of machin based "Proof Assistant" as built in part of Maple IDE ?
it can be better than COQ ?
also there is a great lack of user interactivity by Geometry and Geometry3d packages of maple !!!
for example most of the time it is nessesary (and more facilated) to define geometrical primitive shapes manually or making simple transformations and dissectings attaching ... rather than doing them programaticaly or by commands ?
even having traditional tools like compass ruler ... in pallettes of Geometry window ?
BEST WISHES FOR MAPLESOFT
I'm trying to solve Laplace's equation in Maple in 2-D domain. But while writing the last line "pdsolve(pdef)" (to get the final solution) and after that hitting enter, it doesn't shows anything. Please help me regaring this.
I have the following code:
f:=proc(x)
   local u;
   Digits:=15;
   if x>10^9
    then
        u:=1/x; evalf(2/Pi*arccos((u*u-1)/(1+u*u)));
        evalf(2/Pi*arccos((1-x*x)/(1+x*x)))
    end if
The advantage is that f(+infinity) is defined in this case whereas evalf(2/Pi*arccos((1-x*x)/(1+x*x))) is not for x:=+infinity. But, I would like to extend this procedure in such a way that f(1/0) or f(something) where something is infinity or a division by zero is defined and gives the same result as f(+infinity).
I added before the preocedure f above the following code:
NumericEventHandler( division_by_zero = proc() +infinity; end proc ):
But, it defines a global environment. I would like a local modification of the environment only inside the procedure for f.
How to solve this issue?
Best regards,
Jaqr
f := -ln(-1-ln(exp(x)))+ln(-ln(exp(x)))-Ei(1, -1-ln(exp(x)))+Ei(1, -ln(exp(x)))
solve(limit(diff((subs(x=q, f)-f),h), h=0) = f, q);
limit(diff((subs(x=x*h, f)-f),h), h=0);
Error, (in limit/dosubs) invalid input: `limit/dosubs` uses a 3rd argument, newx, which is missing
guess an operator called Lee, Lee(f, x) = f
suspect q = x*h or q=x*f
limit(diff((subs(x=f*h, f)-f),h), h=0);
Error, (in depends/internal) invalid input: `depends/internal` uses a 2nd argument, x, which is missing
See WA30 attached.  Why the error?  The variable that represents the vector is in vector form.  If I need to change this to THAXexa := ([1988.0, 1989.0, 1990.0 , ... etc], datatype=float, is there an easy way to convert the THAXexa matrix?
Thanks, Les  WA30.mw
suppose I have
g := (x-4)^2+(y-6)^2-144:
e:=expand(g)
                     e := x^2+y^2-8*x-12*y-92
How do I get from the equation of e back to g?
I have troubles with the command in the title.
When I type
InhomogeneousDiophantine([[5^.3,1.3^.5,3^.5],[1.4^.2,4^.2,3^.33]],[5^.2,2^.5],[10^(-3),10^(-3)]);
I get the following
Error, (in IntegerRelations:-LLL) must have a non-negative size in each dimension
What have I done wrong?
dear all,
i have a Maple file where I have made some calculations solving equations, and have plotted a figure. I would like to know how to process this figure in a way so that i can get the data points of the plot, in order to plot them separately in a different software such as Excel or MATLAB for example.
 Right-click on the figure and exporting doesnt help as the options are only to export the figure to pdf, bitmap, png, etc. This is not what I want. I want to get the data of the fiogure, so that i can plot in external software (excel, MATLAB etc)
can you give some suggestions as to how to do this ?
thanks in advance
best regards,
Abhishek
sys1:=-.736349402144656384 = -1.332282598*10^12*(-.99999999999999966)^po1-1.332282598*10^12*(-.99999999999999966)^po2-.735533633151605248*Resid;
sys2:=.326676717828940144 = 1.331567176*10^12*(-.99999999999999966)^po1+1.331567176*10^12*(-.99999999999999966)^po2+.325144093024965720*Resid;
sys3:=.590327283775080036 = -1.072184073*10^9*(-.99999999999999966)^po1-1.072184073*10^9*(-.99999999999999966)^po2+.589610307487437146*Resid;
Minimize(sys1, {sys2,sys3},assume = nonnegative);
complex value encountered;
how to calculate basis <1,4,0>, <1,0,4> for eigenvalue 2;
how to calculate basis <1,0,1> for eigenvalue -1;
A := Matrix([[-2,1,1],[0,2,0],[-4,1,3]]);
sys1 := Eigenvalues(A)[1]*IdentityMatrix(3)-A;
sys1 := Eigenvalues(A)[2]*IdentityMatrix(3)-A;
sys1 := Eigenvalues(A)[3]*IdentityMatrix(3)-A;
B:=[<sys1[1,1],sys1[2,1],sys1[3,1]>,<sys1[1,2],sys1[2,2],sys1[3,2]>,<sys1[1,3],sys1[2,3],sys1[3,3]>,<0,0,0>];
LinearAlgebra:-Basis(B);
but not <1,4,0>, <1,0,4> for eigenvalue 2
A few days ago I was browsing through some books in my collection, that by Gradshteyn and Ryzhik in particular. What fraction of the intregrals, series and products therein can Maple handle correctly?  Besides special functions these properties are valuable components of symbolic mathematical software.  If the answer to this question is not nearly everything in that printed compilation, this inclusion in Maple is a worthy objective.
In Maple 2015 is there a way to fit data to an exponential model and determine the goodness of fit?
Thanks in advance!
Les
I am trying to solve the particular system of partial differential equation. But I get the following error.pdsolve.mw
"restart;  f(x,y):=x*y:  yy:={diff(f(x,y),x)=0,diff(f(x,y),y)=0}:  ee:=pdsolve(yy,numeric);"
Error, (in pdsolve/numeric) invalid subscript selector
Download pdsolve.mw
Of course, with Maple.
What would be the IBC conditions for the 1D heat equation describing the temperature distribution along a circular rod with a heat source at its base?
First 981 982 983 984 985 986 987 Last Page 983 of 2459
