what's the problem with PDE below? tnx for help
PDE:=diff(u(x,t),t)=k*diff(u(x,t),x$2)-h*u(x,t);
diff(u(x, t), t) = k*(diff(diff(u(x, t), x), x))-h*u(x, t)
IBC := {u(-Pi,t)=u(Pi,t), (D[1](u))(-Pi, t) = (D[1](u))(Pi, t),u(x,0)=sin(x)};
{u(x, 0) = sin(x), u(-Pi, t) = u(Pi, t), (D[1](u))(-Pi, t) = (D[1](u))(Pi, t)}
pdsolve(PDE,IBC);
Error, (in pdsolve/sys) too many arguments; some or all of the following are wrong: [{u(x, t)}, {u(x, 0) = sin(x), u(-Pi, t) = u(Pi, t), (D[1](u))(-Pi, t) = (D[1](u))(Pi, t)}]
Download PDE_problem.mw
I have two equations as follows:
The goal is finding the parameter 'phi'. This parameter is a positive real numeric constant.
I uploaded two files that they are included two methods to solve the problem.
1.mw
2.mw
Is method in the first file mathematically logical? If it is a correct method, why the command fsolve dosent work?
In file 2, we have 2 equations with further indeterminantes. The constant 'phi' must be minimum possible amount. How we can use the commands like the Minimize in Optimization? Please hint me.
Moreover, if there is a method to solve this problem please help me to know.
Thank you very much
I want to set the position of the legend inside the figure window for example say top right in the figure window. Maple chose the legend to be at right, left, top, bottom outside the figure window. How can I place the legend of my own wish?
thanks,
I am coding a big module to solving my project : analyze function in math, but when I compile my module maple return "Error," but it doesn't tell me what error happened.
I check the maple help and it said:" If no msgString is given, error raises the most recently occurring exception" but I have no exception before.
This is the pic of that error.
Thank for your help.
I would like to look at a 3d plot including an condition about the tree variables of the plot
For this simple case, I only want to see the plot with the condition that
{40 < y, x < y-40, z < y-40} or {x = 0, y = 40, z <= 0}, {y = x+40, 0 < x, z < x}, {y = x+40, z = x, 0 < x}
. Is that possible?
In 2d there is no problem. And in 3d I do not know how.
restart; with(plots, implicitplot);
                         [implicitplot]
p; .2; omega[0] := 1; epsilon[1] := 1.04493; epsilon[2] := .93259; delta := 0.2e-1;
eq := [[omega[0]*a-a*Omega^2+(3/4)*epsilon[2]*a^3]^2+(delta*Omega*a)^2 = p^2];
implicitplot(eq, omega = .5 .. 2, a = 0 .. 5, p = 0 .. 1, color = blue, thickness = 2, gridrefin = 6);
Error, (in plots/implicitplot) invalid input: the following extra unknowns were found in the input expression: {Omega, p}
I am exploring the Statistics package to see how Maple implements the transformation of random variables.  Unfortunately, I got stuck when trying the following example.
W->X+Y and then X-> W/2
For the first part, I did
w:=RandomVariable(BetaDistribution(1,m-1))+RandomVariable(BetaDistribution(1,m-1))
but for the second part I could not figure out what to do.
Any suggestions?
Many thanks
Ed
Hi everybody,
I'm working under Windows 7
My need :
A MAPLE code has to be run from an ECLIPSE session (through a cmaple MyCode).
In this ECLIPSE session the user chooses a data file among many, and ECLIPSE then has to tell MyCode what file it has to read.
The solution I figured out :
Step 1 : ECLIPSE  set an environment variable "DataFile" which contains the user's choice, for instance set MyData=NameOfTheFile
Step 2 : Within MyCode I get the value of MyData from these two commands
MyFile := getenv(DataFile):
readdata(MyFile, …)
This doesn't work ( getenv(DataFile) returns [1," "] instead of the desired file name).
In fact it seems that getenv enables access to the “native” environment variables of Windows only (for instance HOMEDIR), not to the user defined environment variables (?)
Is  it possible to fix this and how ?
PS  : I face the same difficulties if I type set MyData=NameOfTheFile directly from a cmd command and try to access the value of MyData from a Maple session
Thanks for your help
solve(diff(-1/x,x) = (-1/x)^(b), b);
originally is 2, but it use ln(....) to express
if start from substitute, it seems need to replace manually.
solve(subs(a(x)=-1/x,diff(a(x),x) = (a(x))^(b)), b);
goal is to find b in equation below
solve(diff((x^2+x+1)/(-1+x)^2,x) = ((x^2+x+1)/(-1+x)^2)^(b), b);
(2*x+1)/(-1+x)^2-(2*(x^2+x+1))/(-1+x)^3 = ((x^2+x+1)/(-1+x)^2)^(b)
solve(diff((x^2+x+1)/(-1+x)^2,x) = ((x^2+x+1)/(-1+x)^2)*(b), b);
Hi, my dear friend,
i am solving 9 ODE with boundary conditionsNigam.mw
Eq1 := 2.*F1(eta)+diff(H1(eta), eta) = 0
Eq2 := F1(eta)^2-G1(eta)^2+(diff(F1(eta), eta))*H1(eta)-(diff(F1(eta), eta, eta)) = 0
F1(eta)^2-G1(eta)^2+(diff(F1(eta), eta))*H1(eta)-(diff(diff(F1(eta), eta), eta)) = 0
Eq3 := 2*F1(eta)*G1(eta)+H1(eta)*(diff(G1(eta), eta))-(diff(G1(eta), eta, eta)) = 0
2*F1(eta)*G1(eta)+H1(eta)*(diff(G1(eta), eta))-(diff(diff(G1(eta), eta), eta)) = 0
Eq4 := 4*F1(eta)*F3(eta)+H3(eta)*(diff(F1(eta), eta))+H1(eta)*(diff(F3(eta), eta))-2*G1(eta)*G3(eta)-2.*F1(eta)^2-1.5*H1(eta)-(diff(F3(eta), eta, eta)) = 0
4*F1(eta)*F3(eta)+H3(eta)*(diff(F1(eta), eta))+H1(eta)*(diff(F3(eta), eta))-2*G1(eta)*G3(eta)-2.*F1(eta)^2-1.5*H1(eta)-(diff(diff(F3(eta), eta), eta)) = 0
Eq5 := 2*F3(eta)*G1(eta)+4*F1(eta)*G3(eta)+H3(eta)*(diff(G1(eta), eta))-H1(eta)*(diff(G3(eta), eta))-2*F1(eta)*G1(eta)-1.5*H1(eta)*(diff(G1(eta), eta))-(diff(G3(eta), eta, eta)) = 0
2*F3(eta)*G1(eta)+4*F1(eta)*G3(eta)+H3(eta)*(diff(G1(eta), eta))-H1(eta)*(diff(G3(eta), eta))-2*F1(eta)*G1(eta)-1.5*H1(eta)*(diff(G1(eta), eta))-(diff(diff(G3(eta), eta), eta)) = 0
Eq6 := 4.*F3(eta)+diff(H3(eta), eta) = 0
Eq7 := 6*F1(eta)*F5(eta)-6*F1(eta)*F3(eta)+3.*F3(eta)^2+H1(eta)*(diff(F5(eta), eta))+H3(eta)*(diff(F3(eta), eta))+H5(eta)*(diff(F1(eta), eta))-1.5*(H1(eta)*(diff(F3(eta), eta))+H3(eta)*(diff(F1(eta), eta)))-G3(eta)^2-2*G1(eta)*G5(eta)-(diff(F5(eta), eta, eta)) = 0
6*F1(eta)*F5(eta)-6*F1(eta)*F3(eta)+3.*F3(eta)^2+H1(eta)*(diff(F5(eta), eta))+H3(eta)*(diff(F3(eta), eta))+H5(eta)*(diff(F1(eta), eta))-1.5*H1(eta)*(diff(F3(eta), eta))-1.5*H3(eta)*(diff(F1(eta), eta))-G3(eta)^2-2*G1(eta)*G5(eta)-(diff(diff(F5(eta), eta), eta)) = 0
Eq8 := 6*G5(eta)*F1(eta)+2*G1(eta)*F5(eta)+4*G3(eta)*F3(eta)-4*F1(eta)*G3(eta)-2*F3(eta)*G1(eta)+H1(eta)*(diff(G5(eta), eta))-1.5*(H1(eta)*(diff(G3(eta), eta))+H3(eta)*(diff(G1(eta), eta)))+H3(eta)*(diff(G3(eta), eta))+H5(eta)*(diff(G1(eta), eta))-(diff(G5(eta), eta, eta)) = 0
6*G5(eta)*F1(eta)+2*G1(eta)*F5(eta)+4*G3(eta)*F3(eta)-4*F1(eta)*G3(eta)-2*F3(eta)*G1(eta)+H1(eta)*(diff(G5(eta), eta))-1.5*H1(eta)*(diff(G3(eta), eta))-1.5*H3(eta)*(diff(G1(eta), eta))+H3(eta)*(diff(G3(eta), eta))+H5(eta)*(diff(G1(eta), eta))-(diff(diff(G5(eta), eta), eta)) = 0
Eq9 := 6.*F5(eta)+F3(eta)+diff(H5(eta), eta) = 0
bcs1 := F1(0) = 0, F3(0) = 0, F5(0) = 0
bcs2 := G1(0) = 1, G3(0) = 0, G5(0) = 0
bcs3 := H1(0) = 0, H3(0) = 0, H5(0) = 0
bcs4 := F1(10) = 0, F3(10) = 0, F5(10) = 0
bcs5 := G1(10) = 0, G3(10) = 0, G5(10) = 0
(14)
R := dsolve(eval({Eq1, Eq2, Eq3, Eq4, Eq5, Eq6, Eq7, Eq8, Eq9, bcs1, bcs2, bcs3, bcs4, bcs5}), [F1(eta), F3(eta), F5(eta), G1(eta), G3(eta), G5(eta), H1(eta), H3(eta), H5(eta)], numeric, output = listprocedure)
Maple Worksheet - Error
Failed to load the worksheet
Download Nigam.mwNigam.mw
then i got this error
i dont know where i need to change.. could you help me..
hi:
i'm using expand cmd, but surprisingly, not only execute the expand but execute simplify cmd. Is there any cmd only execute expand withoud simplify?
Best wishes,
from China
I've derived some system matrices from a equation which represents the dynamics of a mechanical system, I've searched for a way to convert this or represented in state space form but I can't figure out how to do it.
I have three simultaneous equations  with three unknown variables (E, W, T). When I solve these  simultaneous equations with fsolve command without specifying any range for variables, I don't get desirable root ( equation sol4 in maple worksheet- {E = 0.1007672475e-2, T = .7969434549, W = 0.1937272759e-2}). For this problem, I know the correct root {E = 2843.916504, T = .2782913990, W = 5344.844134} beforehand which maximize the objective function TP (equation sol8 in maple worksheet) and when I specify the narrow range of variables around the already known correct root in the fsolve command, then I get correct root ( equation sol5 in maple worksheet). If I don't know the actual answer (correct roots of the simultaneous equation) beforehand, How  could I get the correct root with fsolve command because it is very tedious work to specify different range in fsolve command repetitively to solve it by trial and error.
I also tried Direct Search method as suggested in this forum  but DirectSearch is also not able to provide the correct root (equation sol6 in maple worksheet). If I specify the narrow range around known root in direct search method ( equation sol6a in maple worksheet), then it would provide close to optimal root but if I don't know the correct root beforehand, then I couldn't specify the narrow range of variables, then how can I get correct root through direct search command.
Equation sol10 in maple worksheet  (objective function value at correct root) confirms that {E = 2843.916504, T = .2782913990, W = 5344.844134} is the correct root because it provide the value of objective function (TP) equal to 78285.85621 as opposed to negative value (TP value -12.53348074 in equation sol9)  produced by incorrect root  {E = 0.1007672475e-2, T = .7969434549, W = 0.1937272759e-2}).
Is there any method which would provide all the roots of these simultaneous equations which also include correct root. Maple worksheet is attached.
I am trying fsolve and direct search method with known root so that I could get the proper procedure to get the correct root which I can apply to another problem (set of similar simultaneous equations) for which I don't know correct root beforehand.
Thanks for your anticipated help.fsolve_question.mw
I'm still quite new to maple and I'm working calculating some dynamic equations.
I want to be able to selectively group certain variables or numbers depending on how I need the equations to be showed, I don't know if that's possible, I´ll explain further.
In typewritting extended format one equation is shown like this:
And maple standard:
The fisrt thing I want is to show the time derivatives in the dot representation, but I also want the 1/2 multiplyting each term of the whole equation like in the maoke standard format.
I also need to group certain variables in some other equations I have and I was wondering if there is a way to do this.
I have made a small package in a workbook and want to upload it as a package to MapleCloud. According to the help pages, I should select Save To Cloud from the File menu and select the package option for Application Type in the dialog that appears. However, no matter what I do the only option availlable is Maple. What is going on?
First 994 995 996 997 998 999 1000 Last Page 996 of 2459
